OKY DokyOn my wayBUT it choses hdb5 for swapColin
  • Replies 188
  • kamicota
    97
  • Bruno
    74
  • ross549
    10
  • teacher
    4
LOL . . . . . . yep forgot about that one: hdb5 for /swap . . . it will need that one :thumbsup:Have a good install :"> Bruno
Colin . . . . If the same thing happens as last time and it refuses to install Grub in hdb9 . . . just forget about the grub install and we will try to find a way around the problem.>>> In any case do not install grub elsewhere as hdb9 <<<I am going for some fresh air ( it is a nice warm summer evening ) . . . . . so just wait for me to come back so we can try to fix that grub issue.:"> Bruno
BrunoMepis Installed with grub in hdb9 no problemsBut only the PCLos boot up screen with access to PCLos & WindowsXPCheers for YearsColin :"> :"> :">
other=/dev/hdb9label="Mepis"
Add this to the bottom of your LILO while in PCLos. Run lilo -v when ready. If you like, you can give us the lilo.conf before running lilo to proofread it.
Yep :">
# kedit /etc/lilo.conf
While in PCLos.
Edited by ross549
boot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.6.10-oci7 label="pclinuxos" root=/dev/hdb1 initrd=/boot/initrd-2.6.10-oci7.imgappend="devfs=nomount nomce splash=silenboot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.6.10-oci7 label="pclinuxos" root=/dev/hdb1 initrd=/boot/initrd-2.6.10-oci7.imgappend="devfs=nomount nomce splash=silent"vga=788read-onlyother=/dev/hda1label="win_c"other=/dev/hdb6label="win_d"other=/dev/hdb6label="win_e"other=/dev/hdb6label="win_f"other=/dev/hdb6label="win_g"other=/dev/hdb9label="Mepis"t"vga=788read-onlyother=/dev/hda1label="win_c"other=/dev/hdb6label="win_d"other=/dev/hdb6label="win_e"other=/dev/hdb6label="win_f"boot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.6.10-oci7 label="pclinuxos" root=/dev/hdb1 initrd=/boot/initrd-2.6.10-oci7.imgappend="devfs=nomount nomce splash=silenboot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.6.10-oci7 label="pclinuxos" root=/dev/hdb1 initrd=/boot/initrd-2.6.10-oci7.imgappend="devfs=nomount nomce splash=silent"vga=788read-onlyother=/dev/hda1label="win_c"other=/dev/hdb6label="win_d"other=/dev/hdb6label="win_e"other=/dev/hdb6label="win_f"other=/dev/hdb6label="win_g"other=/dev/hdb9label="Mepis"t"vga=788read-onlyother=/dev/hda1label="win_c"other=/dev/hdb6label="win_d"other=/dev/hdb6label="win_e"other=/dev/hdb6label="win_f"other=/dev/hdb6label="win_g"other=/dev/hdb9label="Mepis"other=/dev/hdb6label="win_g"other=/dev/hdb9label="Mepis"Added to lilo AdamBut it did not show when I rebootedWill have to try tat -vColin
Adam here's lilo -vPassword:[root@localhost kamicota]# lilo -vLILO version 22.6.1, Copyright © 1992-1998 Werner AlmesbergerDevelopment beyond version 21 Copyright © 1999-2004 John CoffmanReleased 17-Nov-2004, and compiled at 02:57:04 on Jul 8 2005Reading boot sector from /dev/hdaUsing GRAPHIC secondary loaderCalling map_insert_dataMapping message file /boot/message -> message-graphicCalling map_insert_fileBoot image: /boot/vmlinuz-2.6.10-oci7Mapping RAM disk /boot/initrd-2.6.10-oci7.imgAdded pclinuxos *Boot other: /dev/hda1, on /dev/hda, loader CHAINAdded win_cBoot other: /dev/hdb6, loader CHAINWarning: First sector of /dev/hdb6 doesn't have a valid boot signaturePseudo partition start: 32439519Added win_dBoot other: /dev/hdb6, loader CHAINWarning: First sector of /dev/hdb6 doesn't have a valid boot signaturePseudo partition start: 32439519Added win_eBoot other: /dev/hdb6, loader CHAINWarning: First sector of /dev/hdb6 doesn't have a valid boot signaturePseudo partition start: 32439519Added win_fBoot other: /dev/hdb6, loader CHAINWarning: First sector of /dev/hdb6 doesn't have a valid boot signaturePseudo partition start: 32439519Added win_gBoot other: /dev/hdb9, loader CHAINPseudo partition start: 126979839Added MepisWriting boot sector./boot/boot.0300 exists - no boot sector backup copy made.[root@localhost kamicota]#Colin :">
Well it looks like you should be able to boot Mepis now Colin . . . But you have a whole lot of entries for Windows there and you only have 1 Win install ( I suppose ) . . so we will have to prune that lilo from unneeded Win entries ( only the first ( win_c ) has to stay . . the rest can go :"> )So remove:
And run /sbin/lilo again :">:"> Bruno
Yep, it is showing as having been added. It should work, Colin. You may have to arrow down in the list when you reboot, thought.... with all those entries for Windows. :">
BrunoAll the win entiries are now linux partitions on hdbAnd I have not yet found mepis in the PCLos boot up screenColin :">
Try arrowing down when you reboot Colin.... it might be "off the screen." :">
Heck I'm getting behind here :"> Heres sbin/lilo[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# /sbin/liloAdded pclinuxos *Added win_cWarning: First sector of /dev/hdb6 doesn't have a valid boot signatureAdded win_dWarning: First sector of /dev/hdb6 doesn't have a valid boot signatureAdded win_eWarning: First sector of /dev/hdb6 doesn't have a valid boot signatureAdded win_fWarning: First sector of /dev/hdb6 doesn't have a valid boot signatureAdded win_gAdded Mepis[root@localhost kamicota]#Colin
Colin . . remove this section from /etc/lilo.conf
And only after that run /sbin/liloB) Bruno
OOPS[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# /etc/lilo.confbash: /etc/lilo.conf: Permission denied[root@localhost kamicota]#Colin :">
Try:
:"> Bruno
[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# /sbin/liloAdded pclinuxos *Added win_cAdded Mepis[root@localhost kamicota]#Colin :">
Rebooted (COLLYWOBBLES AND ALL :hysterical: )But the 800x600 screen does not give me the chance to change the display resolutionbecause I cannot access the bottom buttonsColin :">
You can get to those buttons like this:Hold the LEFT Alt-key down and drag the window with your mouse ( you can grab the window at any place now the Alt-key is down ) until you can see the OK button.:hysterical: Bruno
Neat trick Bruno :"> :rolleyes: B) BUT I am only given 640x480No wonder this is So AWKWARD :hysterical: Colin
Okay . . show me:
# ls -al /etc/X11
:hysterical: Bruno
kamicota@1[~]$ suPassword:root@1[kamicota]# ls -al /etc/X11total 148drwxr-xr-x 16 root root 4096 2005-09-03 13:34 .drwxr-xr-x 121 root root 8192 2005-09-03 21:20 ..drwxr-xr-x 2 root root 4096 2005-07-10 21:17 app-defaultsdrwxr-xr-x 2 root root 4096 2005-07-10 21:15 cursors-rw-r--r-- 1 root root 13 2003-02-01 12:18 default-display-managerdrwxr-xr-x 7 root root 4096 2003-02-20 00:56 fontsdrwxr-xr-x 2 root root 4096 2004-10-17 12:51 icewm-rw-r--r-- 1 root root 17371 2001-07-29 15:49 rgb.txtdrwxr-xr-x 4 root root 4096 2005-07-10 21:17 rstart-rw-r--r-- 1 root root 10733 2004-05-23 15:14 rxvt.menudrwxr-xr-x 2 root root 4096 2004-11-05 14:48 serverconfigdrwxr-xr-x 2 root root 4096 2004-11-05 14:48 startheredrwxr-xr-x 2 root root 4096 2005-07-10 21:15 sysconfiglrwxrwxrwx 1 root root 20 2005-09-03 13:24 X -> /usr/bin/X11/XFree86-rw-r--r-- 1 root root 74 2003-05-26 14:43 xawtvrc-rw-r--r-- 1 root root 8339 2005-09-03 13:34 XF86Config-4-rwxr-xr-x 1 root root 8298 2005-08-24 03:02 XF86Config-4.in-rw-r--r-- 1 root root 1335 2005-06-01 14:36 XftConfigdrwxr-xr-x 3 root root 4096 2005-07-10 21:16 xinitdrwxr-xr-x 10 root root 4096 2005-07-10 21:15 xkbdrwxr-xr-x 2 root root 4096 2005-07-10 21:16 Xresourcesdrwxr-xr-x 2 root root 4096 2005-07-10 21:17 xserver-rwxr-xr-x 1 root root 3456 2005-02-18 21:32 Xsessiondrwxr-xr-x 2 root root 4096 2005-07-10 21:15 Xsession.d-rw-r--r-- 1 root root 217 2001-10-19 16:01 Xsession.optionsdrwxr-xr-x 2 root root 4096 2005-07-10 21:16 xsm-rw-r--r-- 1 root root 37 2001-05-29 18:55 Xwrapper.configroot@1[kamicota]#Colin
Good . . now show me
# cat /etc/X11/XF86Config-4
:hysterical: Bruno
root@1[kamicota]# cat /etc/X11/XF86Config-4Section "ServerLayout" Identifier "XFree86 Configured" Screen 0 "Screen0" 0 0 InputDevice "Keyboard0" "CoreKeyboard" InputDevice "PS/2 Mouse" "CorePointer" #InputDevice "USB Mouse" "CorePointer" #InputDevice "Touchpad" "CorePointer" #InputDevice "Stylus" "CorePointer" #InputDevice "Eraser" "CorePointer" #InputDevice "Cursor" "CorePointer" #InputDevice "Serial Mouse" "CorePointer"EndSectionSection "ServerFlags" Option "AllowMouseOpenFail" "true"EndSectionSection "Files" RgbPath "/usr/X11R6/lib/X11/rgb" ModulePath "/usr/X11R6/lib/modules"# True type and type1 fonts FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/Speedo" FontPath "/usr/X11R6/lib/X11/fonts/PEX" FontPath "/usr/X11R6/lib/X11/fonts/cyrillic" FontPath "/usr/share/fonts/truetype/ttf-xfree86-nonfree" FontPath "/usr/share/fonts/truetype/java" FontPath "/usr/share/fonts/truetype/arphic" FontPath "/usr/share/fonts/truetype/freefont" FontPath "/usr/share/fonts/truetype/openoffice" FontPath "/usr/share/fonts/truetype/ttf-bitstream-vera" FontPath "/usr/share/fonts/ttf/western" FontPath "/usr/share/fonts/ttf/decoratives" FontPath "/usr/share/fonts/type1/gsfonts" FontPath "/usr/X11R6/lib/X11/fonts/Type1" FontPath "/usr/X11R6/lib/X11/fonts/defoma/CID" FontPath "/usr/X11R6/lib/X11/fonts/defoma/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" FontPath "/usr/local/share/fonts" FontPath "/usr/share/fonts" FontPath "/usr/X11R6/lib/X11/fonts" FontPath "/usr/share/fonts/afms" FontPath "/usr/share/fonts/bitmap" FontPath "/usr/share/fonts/truetype" FontPath "/usr/share/fonts/ttf" FontPath "/usr/share/fonts/type1" FontPath "/usr/X11R6/lib/X11/fonts/defoma"EndSectionSection "Module" Load "GLcore" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "speedo" Load "type1" Load "vbe" Load "synaptics"EndSectionSection "InputDevice" Identifier "Keyboard0" Driver "keyboard" Option "CoreKeyboard" Option "XkbModel" "pc105" Option "XkbLayout" "us" Option "XKbOptions" ""EndSectionSection "InputDevice" Identifier "Serial Mouse" Driver "mouse" Option "Protocol" "Microsoft" Option "Device" "/dev/ttyS0" Option "Emulate3Buttons" "false" Option "Emulate3Timeout" "70"EndSectionSection "InputDevice" Identifier "Touchpad" Driver "synaptics" Option "Device" "/dev/psaux" Option "Protocol" "auto-dev" Option "LeftEdge" "1700" Option "RightEdge" "5300" Option "TopEdge" "1700" Option "BottomEdge" "4200" Option "FingerLow" "25" Option "FingerHigh" "30" Option "MaxTapTime" "180" Option "MaxTapMove" "220" Option "VertScrollDelta" "100" Option "MinSpeed" "0.06" Option "MaxSpeed" "0.12" Option "AccelFactor" "0.0010" Option "SHMConfig" "on" Option "Repeater" "/dev/input/mice"EndSectionSection "InputDevice" Identifier "PS/2 Mouse" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/psaux" Option "Emulate3Buttons" "false" Option "Emulate3Timeout" "70" Option "ZAxisMapping" "4 5" Option "Buttons" "5"EndSectionSection "InputDevice" Identifier "USB Mouse" Driver "mouse" Option "Device" "/dev/input/mice" Option "Protocol" "ExplorerPS/2" Option "ZAxisMapping" "4 5" Option "Buttons" "5"EndSectionSection "InputDevice" Identifier "Stylus" Driver "wacom" Option "Mode" "Absolute" Option "Type" "stylus" Option "Device" "/dev/input/wacom"Endsection# Settings for wacom eraserSection "InputDevice" Identifier "Eraser" Driver "wacom" Option "Mode" "Absolute" Option "Type" "eraser" Option "Device" "/dev/input/wacom"Endsection# Settings for wacom cursor (mouse)Section "InputDevice" Identifier "Cursor" Driver "wacom" Option "Mode" "Absolute" Option "Type" "cursor" Option "Device" "/dev/input/wacom"EndsectionSection "Monitor" Identifier "Monitor0" VendorName "unknown" ModelName "unknown" #Option "DPMS" "true" HorizSync 30.0 - 82.0 # Warning: This may fry old Monitors VertRefresh 50.0 - 70.0 # Very conservative. May flicker. Modeline "640x480" 25.175 640 664 760 800 480 491 493 525 #60Hz Modeline "800x600" 40.12 800 848 968 1056 600 601 605 628 #60Hz Modeline "1024x768" 75 1024 1048 1184 1328 768 771 777 806 -hsync -vsync Modeline "1024x768" 85 1024 1056 1152 1360 768 784 787 823 ModeLine "1152x864" 65 1152 1168 1384 1480 864 865 875 985 Interlace Modeline "1152x864" 92 1152 1208 1368 1474 864 865 875 895 Modeline "1152x864" 110 1152 1240 1324 1552 864 864 876 908 Modeline "1152x864" 135 1152 1464 1592 1776 864 864 876 908 Modeline "1152x864" 137.65 1152 1184 1312 1536 864 866 885 902 -HSync -VSync Modeline "1280x768" 80.14 1280 1344 1480 1680 768 769 772 795 ModeLine "1280x800" 80.58 1280 1344 1480 1680 800 801 804 827 -HSync -VSync Modeline "1280x1024" 80 1280 1296 1512 1568 1024 1025 1037 1165 Interlace Modeline "1280x1024" 110 1280 1328 1512 1712 1024 1025 1028 1054 Modeline "1280x1024" 126.5 1280 1312 1472 1696 1024 1032 1040 1068 -HSync -VSync Modeline "1280x1024" 135 1280 1312 1456 1712 1024 1027 1030 1064 Modeline "1280x1024" 135 1280 1312 1416 1664 1024 1027 1030 1064 Modeline "1280x1024" 157.5 1280 1344 1504 1728 1024 1025 1028 1072 +HSync +VSync Modeline "1280x1024" 181.75 1280 1312 1440 1696 1024 1031 1046 1072 -HSync -VSync Modeline "1440x900" 106.47 1440 1520 1672 1904 900 901 904 932 +HSync +VSync Modeline "1400x1050" 129 1400 1464 1656 1960 1050 1051 1054 1100 +HSync +VSync Modeline "1600x1200" 162 1600 1664 1856 2160 1200 1201 1204 1250 +HSync +VSync Modeline "1600x1200" 189 1600 1664 1856 2160 1200 1201 1204 1250 -HSync -VSync Modeline "1600x1200" 202.5 1600 1664 1856 2160 1200 1201 1204 1250 +HSync +VSync Modeline "1600x1200" 220 1600 1616 1808 2080 1200 1204 1207 1244 +HSync +VSync Modeline "1680x1050" 147.14 1680 1784 1968 2256 1050 1051 1054 1087 ModeLine "1800x1440" 230 1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync ModeLine "1800x1440" 250 1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync Modeline "1920x1200" 230 1920 1936 2096 2528 1200 1201 1204 1250 +HSync +VSyncEndSectionSection "Device" #Option "sw_cursor" # needed for some ati cards #Option "hw_cursor" #Option "NoAccel" #Option "ShowCache" #Option "ShadowFB" #Option "UseFBDev" #Option "Rotate" #Option "NoUseBios" # needed for some Savage cards Option "UseInternalAGPGART" "no"# nvidia special options, use with care Option "CursorShadow" "1" Option "CursorShadowAlpha" "63" Option "CursorShadowYOffset" "2" Option "CursorShadowXOffset" "4" Option "FlatPanelProperties" "Scaling = native" Option "NoLogo" "false" Option "IgnoreEdid" "true" # needs to be true for some nvidia cards Identifier "Card0" Driver "via" BoardName "unknown" #BusID "PCI:1:0:0"EndSectionSection "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" DefaultColorDepth 16 SubSection "Display" Depth 1 Modes "1024x768" EndSubSection SubSection "Display" Depth 4 Modes "1024x768" EndSubSection SubSection "Display" Depth 8 Modes "1024x768" EndSubSection SubSection "Display" Depth 15 Modes "1024x768" EndSubSection SubSection "Display" Depth 16 Modes "1024x768" EndSubSection SubSection "Display" Depth 24 Modes "1024x768" EndSubSection SubSection "Display" Depth 32 Modes "1024x768" EndSubSection # Only the official NVIDIA driver supports twinview # these setting are an example Option "TwinView" "false" Option "SecondMonitorVendorName" "unknown" Option "SecondMonitorModelName" "unknown" Option "SecondMonitorHorizSync" "30-82" Option "SecondMonitorVertRefresh" "50-75" Option "MetaModes" "1024x768, 1024x768; 800x600, 800x600; 640x480, 640x480" Option "TwinViewOrientation" "RightOf" Option "ConnectedMonitor" "dfp,dfp"EndSectionSection "DRI" Mode 0666EndSectionroot@1[kamicota]#Colin
Geeee . . that is a long file . . . . . . okay, let us try this, now do:
# kedit /etc/X11/XF86Config-4
And edit that file ( look ad he RED changes )
Section "ServerLayout" Identifier "XFree86 Configured" Screen 0 "Screen0" 0 0 InputDevice "Keyboard0" "CoreKeyboard" InputDevice "PS/2 Mouse" "CorePointer" #InputDevice "USB Mouse" "CorePointer" #InputDevice "Touchpad" "CorePointer" #InputDevice "Stylus" "CorePointer" #InputDevice "Eraser" "CorePointer" #InputDevice "Cursor" "CorePointer" #InputDevice "Serial Mouse" "CorePointer"EndSectionSection "ServerFlags" Option "AllowMouseOpenFail" "true"EndSectionSection "Files" RgbPath "/usr/X11R6/lib/X11/rgb" ModulePath "/usr/X11R6/lib/modules"# True type and type1 fonts FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/Speedo" FontPath "/usr/X11R6/lib/X11/fonts/PEX" FontPath "/usr/X11R6/lib/X11/fonts/cyrillic" FontPath "/usr/share/fonts/truetype/ttf-xfree86-nonfree" FontPath "/usr/share/fonts/truetype/java" FontPath "/usr/share/fonts/truetype/arphic" FontPath "/usr/share/fonts/truetype/freefont" FontPath "/usr/share/fonts/truetype/openoffice" FontPath "/usr/share/fonts/truetype/ttf-bitstream-vera" FontPath "/usr/share/fonts/ttf/western" FontPath "/usr/share/fonts/ttf/decoratives" FontPath "/usr/share/fonts/type1/gsfonts" FontPath "/usr/X11R6/lib/X11/fonts/Type1" FontPath "/usr/X11R6/lib/X11/fonts/defoma/CID" FontPath "/usr/X11R6/lib/X11/fonts/defoma/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" FontPath "/usr/local/share/fonts" FontPath "/usr/share/fonts" FontPath "/usr/X11R6/lib/X11/fonts" FontPath "/usr/share/fonts/afms" FontPath "/usr/share/fonts/bitmap" FontPath "/usr/share/fonts/truetype" FontPath "/usr/share/fonts/ttf" FontPath "/usr/share/fonts/type1" FontPath "/usr/X11R6/lib/X11/fonts/defoma"EndSectionSection "Module" Load "GLcore" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "speedo" Load "type1" Load "vbe" Load "synaptics"EndSectionSection "InputDevice" Identifier "Keyboard0" Driver "keyboard" Option "CoreKeyboard" Option "XkbModel" "pc105" Option "XkbLayout" "us" Option "XKbOptions" ""EndSectionSection "InputDevice" Identifier "Serial Mouse" Driver "mouse" Option "Protocol" "Microsoft" Option "Device" "/dev/ttyS0" Option "Emulate3Buttons" "false" Option "Emulate3Timeout" "70"EndSectionSection "InputDevice" Identifier "Touchpad" Driver "synaptics" Option "Device" "/dev/psaux" Option "Protocol" "auto-dev" Option "LeftEdge" "1700" Option "RightEdge" "5300" Option "TopEdge" "1700" Option "BottomEdge" "4200" Option "FingerLow" "25" Option "FingerHigh" "30" Option "MaxTapTime" "180" Option "MaxTapMove" "220" Option "VertScrollDelta" "100" Option "MinSpeed" "0.06" Option "MaxSpeed" "0.12" Option "AccelFactor" "0.0010" Option "SHMConfig" "on" Option "Repeater" "/dev/input/mice"EndSectionSection "InputDevice" Identifier "PS/2 Mouse" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/psaux" Option "Emulate3Buttons" "false" Option "Emulate3Timeout" "70" Option "ZAxisMapping" "4 5" Option "Buttons" "5"EndSectionSection "InputDevice" Identifier "USB Mouse" Driver "mouse" Option "Device" "/dev/input/mice" Option "Protocol" "ExplorerPS/2" Option "ZAxisMapping" "4 5" Option "Buttons" "5"EndSectionSection "InputDevice" Identifier "Stylus" Driver "wacom" Option "Mode" "Absolute" Option "Type" "stylus" Option "Device" "/dev/input/wacom"Endsection# Settings for wacom eraserSection "InputDevice" Identifier "Eraser" Driver "wacom" Option "Mode" "Absolute" Option "Type" "eraser" Option "Device" "/dev/input/wacom"Endsection# Settings for wacom cursor (mouse)Section "InputDevice" Identifier "Cursor" Driver "wacom" Option "Mode" "Absolute" Option "Type" "cursor" Option "Device" "/dev/input/wacom"EndsectionSection "Monitor" Identifier "Monitor0" VendorName "unknown" ModelName "unknown" #Option "DPMS" "true" HorizSync 30.0 - 82.0 # Warning: This may fry old Monitors VertRefresh 50.0 - 70.0 # Very conservative. May flicker.# Modeline "640x480" 25.175 640 664 760 800 480 491 493 525 #60Hz# Modeline "800x600" 40.12 800 848 968 1056 600 601 605 628 #60Hz Modeline "1024x768" 75 1024 1048 1184 1328 768 771 777 806 -hsync -vsync Modeline "1024x768" 85 1024 1056 1152 1360 768 784 787 823 ModeLine "1152x864" 65 1152 1168 1384 1480 864 865 875 985 Interlace Modeline "1152x864" 92 1152 1208 1368 1474 864 865 875 895 Modeline "1152x864" 110 1152 1240 1324 1552 864 864 876 908 Modeline "1152x864" 135 1152 1464 1592 1776 864 864 876 908 Modeline "1152x864" 137.65 1152 1184 1312 1536 864 866 885 902 -HSync -VSync Modeline "1280x768" 80.14 1280 1344 1480 1680 768 769 772 795 ModeLine "1280x800" 80.58 1280 1344 1480 1680 800 801 804 827 -HSync -VSync Modeline "1280x1024" 80 1280 1296 1512 1568 1024 1025 1037 1165 Interlace Modeline "1280x1024" 110 1280 1328 1512 1712 1024 1025 1028 1054 Modeline "1280x1024" 126.5 1280 1312 1472 1696 1024 1032 1040 1068 -HSync -VSync Modeline "1280x1024" 135 1280 1312 1456 1712 1024 1027 1030 1064 Modeline "1280x1024" 135 1280 1312 1416 1664 1024 1027 1030 1064 Modeline "1280x1024" 157.5 1280 1344 1504 1728 1024 1025 1028 1072 +HSync +VSync Modeline "1280x1024" 181.75 1280 1312 1440 1696 1024 1031 1046 1072 -HSync -VSync Modeline "1440x900" 106.47 1440 1520 1672 1904 900 901 904 932 +HSync +VSync Modeline "1400x1050" 129 1400 1464 1656 1960 1050 1051 1054 1100 +HSync +VSync Modeline "1600x1200" 162 1600 1664 1856 2160 1200 1201 1204 1250 +HSync +VSync Modeline "1600x1200" 189 1600 1664 1856 2160 1200 1201 1204 1250 -HSync -VSync Modeline "1600x1200" 202.5 1600 1664 1856 2160 1200 1201 1204 1250 +HSync +VSync Modeline "1600x1200" 220 1600 1616 1808 2080 1200 1204 1207 1244 +HSync +VSync Modeline "1680x1050" 147.14 1680 1784 1968 2256 1050 1051 1054 1087 ModeLine "1800x1440" 230 1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync ModeLine "1800x1440" 250 1800 1896 2088 2392 1440 1441 1444 1490 +HSync +VSync Modeline "1920x1200" 230 1920 1936 2096 2528 1200 1201 1204 1250 +HSync +VSyncEndSectionSection "Device" #Option "sw_cursor" # needed for some ati cards #Option "hw_cursor" #Option "NoAccel" #Option "ShowCache" #Option "ShadowFB" #Option "UseFBDev" #Option "Rotate" #Option "NoUseBios" # needed for some Savage cards Option "UseInternalAGPGART" "no"# nvidia special options, use with care Option "CursorShadow" "1" Option "CursorShadowAlpha" "63" Option "CursorShadowYOffset" "2" Option "CursorShadowXOffset" "4" Option "FlatPanelProperties" "Scaling = native" Option "NoLogo" "false" Option "IgnoreEdid" "true" # needs to be true for some nvidia cards Identifier "Card0" Driver "via" BoardName "unknown" #BusID "PCI:1:0:0"EndSectionSection "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" DefaultColorDepth 16 SubSection "Display" Depth 1 Modes "1024x768" EndSubSection SubSection "Display" Depth 4 Modes "1024x768" EndSubSection SubSection "Display" Depth 8 Modes "1024x768" EndSubSection SubSection "Display" Depth 15 Modes "1024x768" EndSubSection SubSection "Display" Depth 16 Modes "1024x768" EndSubSection SubSection "Display" Depth 24 Modes "1024x768" EndSubSection SubSection "Display" Depth 32 Modes "1024x768" EndSubSection # Only the official NVIDIA driver supports twinview # these setting are an example Option "TwinView" "false" Option "SecondMonitorVendorName" "unknown" Option "SecondMonitorModelName" "unknown" Option "SecondMonitorHorizSync" "30-82" Option "SecondMonitorVertRefresh" "50-75" Option "MetaModes" "1024x768, 1024x768; 800x600, 800x600; 640x480, 640x480" Option "TwinViewOrientation" "RightOf" Option "ConnectedMonitor" "dfp,dfp"EndSectionSection "DRI" Mode 0666EndSection
Save the file and reboot . . . . :hysterical: Bruno
no . . . . . you add the # sign at the start of those linesB) Bruno
