Frank Golden Posted January 3, 2007 Posted January 3, 2007 (edited) Brand and Model:Hp Photosmart 7760inktjet, laser, MFP/all-in-one:inkjetDriver used:HPLIP from distroDistro used:Ubuntu 6.06.1 LTS and Ubuntu 6.10 (edgy)Brand and Model:Hp Photosmart 7760inktjet, laser, MFP/all-in-one:inkjetDriver used:HPLIP distro providedDistro used:PCLinuxOS 93 (Big Daddy)Brand and Model:Hp Photosmart 7760inktjet, laser, MFP/all-in-one:inkjetDriver used:HPLIP distro providedDistro used:Zenwalk 3.0 (a slackware based distro)All distros installed printer easily although method differed.Printer works flawlessly in all cases. Edited January 3, 2007 by Frank Golden Quote
Urmas Posted January 3, 2007 Posted January 3, 2007 (edited) Brand and Model: HP psc 750inkjet or laser: inkjet all-in-oneDriver used: hpijs (default from wizard)Distro used: Ubuntu 6.10.[yes... old HDD went south... so I went "Edgy"... "all-in-one" was connected and power was on during the install... everything works auto detected.] Edited January 3, 2007 by Urmas Quote
striker Posted January 3, 2007 Author Posted January 3, 2007 splendid Urmas! thanks for reporting. I added it. Quote
réjean Posted January 3, 2007 Posted January 3, 2007 (edited) Hi striker I'll give you the info for Linux Mint for now and will experiment with the other distros next week when I'll have a chance to get the 2 machines and the printer next to each others.Brand and Model: HP psc 1350inkjet or laser: inkjet all-in-oneDriver used: hpijs (default from wizard)Distro used: Linux Mint (not sure which version but if I go into System and "About Ubuntu" I get some info about Ubuntu 6.10 Edgy Eft ). I downloaded the latest version they had about 3 or 4 weeks ago.I did some research and I am pretty sure it is Linux Mint 2.1 codename Bea Edited January 3, 2007 by réjean Quote
longgone Posted January 3, 2007 Posted January 3, 2007 Striker.............could you add to "Debian" to the post I made earlier ..... Quote
striker Posted February 7, 2007 Author Posted February 7, 2007 Brand and Model: Brother HL-5250DNinktjet, laser, MFP/all-in-one: BW LaserDriver used: brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpm > networked via routerDistro used: Fedora Core 6 Quote
ross549 Posted February 7, 2007 Posted February 7, 2007 HP DeskJet F380 printer/scanner comboDrivers: any hplip >.9.9 will enable scanning with xsaneDistro: Ubuntu 6.06 LTS;)Adam Quote
tommyj12 Posted February 8, 2007 Posted February 8, 2007 HP Deskjet F340 All-in-one printer, scanner, copier. Works out of the box with pclos .93@ 2007tr1; suse10.2; minty bea Don't know if this one was already posted---a lot of posts to read thru Quote
cybrmat Posted February 8, 2007 Posted February 8, 2007 Brand and Model: HP OfficeJet G85 (Connected via HP JetDirect 170x print server) All-in-OneCurrent Driver: Distro provided Foomatic/hpijs, Cups / HPLIPCurrent Distro: PCLinuxOS .93Other Distros / Driver: VL 5.1 SOHO, Mandriva 9.2, 10.1 & 2006, Distro provided driver w/ CUPS Quote
striker Posted February 8, 2007 Author Posted February 8, 2007 Thanks tommy and Matt, all were added. Quote
Manitoban Posted February 8, 2007 Posted February 8, 2007 Brother 1030 LaserEpson Stylus Color 777Drivers for both by DistroGimp Driver for Epson from ?Os Fedora Core 6Bill Quote
charlie Posted February 8, 2007 Posted February 8, 2007 Brother 1050 Laser printer Distro: Ubuntu 6.10Driver supplied by distro Charlie Quote
striker Posted February 8, 2007 Author Posted February 8, 2007 Thanks Bill and Charlie, they were added. Quote
mlangdn Posted February 12, 2007 Posted February 12, 2007 Brand and Model: Epson Stylus Photo 825inktjet, laser, MFP/all-in-one: InkjetDriver used: Cups+ gimp-print v4.2.7Distro used: Slackware 11.0This is my first post on the forum. My Epson works flawlessly. I had a Lexmark Z22, but it was a pita to get to working. Quote
Bruno Posted February 12, 2007 Posted February 12, 2007 This is my first post on the forum. Welcome to the forum mlangdn !! Bruno Quote
striker Posted February 12, 2007 Author Posted February 12, 2007 Thanks mlangdn, it's added. And welcome to the forums ! Quote
Anil Posted February 19, 2007 Posted February 19, 2007 Brand and Model: HP 840Cinkjet or laser: inkjet Driver used: foomaticDistro used: Mandriva 2007 Quote
Anil Posted February 19, 2007 Posted February 19, 2007 (edited) Brand and Model: TVS Dot Matrixinktjet, laser: Dot Matrix 128 columnDriver used: Epson 1000Distro used : Mandriva 2007 Edited February 19, 2007 by Anil Quote
Grogerf Posted February 20, 2007 Posted February 20, 2007 Brand and Model: TVS Dot Matrixinktjet, laser: Dot Matrix 128 columnDriver used: Epson 1000Distro used : Mandriva 2007Hallo Stricker,Brand and Model: HP PhotoSmart C4180inktjet, /all-in-one:Driver used: HPLIP in DistroDistro used: Mandriva 2007 64 bit Power pack,NotesPrinter recognised automatically with option to automatically install. This worked with a few hiccoughs helped through these by Bruno & Stricker - Thank you both :- Had to install HPLIP from distro DVD via MCCthen needed to add lib64sane-hpaio did this on dial up - not sure if it's on the DVDPrinter worked fine after this - all functions including scanning & tools.Bit of work needed to get the new printer to show up in XSANE as a printer see 'Help Please adding new printer" in this ForumIf you can do a full update before you start it would probably save some effort - I was on dial up only, so didn't want to do a full update.Grogerf Quote
striker Posted February 20, 2007 Author Posted February 20, 2007 Thank you Anil and Grogerf, all were added ! Quote
Guest LilBambi Posted February 20, 2007 Posted February 20, 2007 Brand and Model: HP DeskJet 770Cinkjet or laser: inkjetDriver used: CUPS using default HP driver from the wizardDistro used: Fedora Core 3 and Fedora Core 5Interface: ParallelBrand and Model: HP DeskJet 882Cinkjet or laser: inkjetDriver used: CUPS using default HP driver from wizardDistro used: Ubuntu EdgyInterface: Parallel (also possible to use USB with this printer which works great on the Mac) Quote
sloppyslacker Posted February 22, 2007 Posted February 22, 2007 (edited) Brand and Model: HP PSC 1610 All in oneinkjet or laser: InkjetDriver used: Cups with HPLIP version 1.7.1Distro used: Slackware 11.0Interface: USBShould say, took some work but scanner and printer both work. Used info found here. http://www.linuxquestions.org/linux/answer..._Slackware_10_2 Edited February 23, 2007 by sloppyslacker Quote
kamicota Posted February 22, 2007 Posted February 22, 2007 (edited) Hi StikerMOI still Playin around with Brand and Model: HP Deskjet 9800 (wide format)inkjet or laser: inkjetDriver used: foomaticDistro used: PCLinuxOS 2007 Test 1also--->>>Brand and Model: Epson Stylus c88+inkjet or laser: inkjetDriver used: foomatic ( I think)Distro used: PCLinuxOS 2007 Test 1BUT WAITING FOR PCLinuxOS 2007 Final Cheers for yearsColin Edited February 22, 2007 by kamicota Quote
tiarnach Posted February 27, 2007 Posted February 27, 2007 Brand and Model: HP LaserJet 1020inktjet, laser, MFP/all-in-one: laser, bw onlyDriver used: Generic provided by distroDistro used: Ubuntu 6.10Fired up the other pc which has Ubuntu only, and my HP LaserJet 1020 worked automatically. Ubuntu detected and configured it, with no hassle. Quote
