striker Posted December 30, 2006 Posted December 30, 2006 The idea is this:I started this thread to be able to list the printers you are all using on any linux distro.Simply copy 'n paste the below in your replies and add the necessary information: Brand and Model:inktjet, laser, MFP/all-in-one:Driver used:Distro used:I'll try to keep an eye on the thread at regular intervals and fetch the info from the posts, then put them in the placeholder below to keep the info in just that post.That way anybody will be able to just look at that post to see which printer one could use with that particular distro, or simply which printer is usable with which distro.Thanks for participating.How to read this: Below you see the different distros; underneath each distro the working printers are listed and behind that you'll see the driver used.If it's a laser printer or 'all in one'/MFP it will be marked red as such.For ex. MyLinux Vol.1Canon i560/s630Here we go:<placeholder> Archlinux (i686 - 2009.8)HP Laserjet 1320 Laser Jet/Foomatic driver by distro****printing route through server, used CUPS, identifying the LaserJet 1320 instead of JetDirect device see: http://forums.scotsnewsletter.com/index.ph...st&p=275930Archlinux (x86_64)HP PSC 1315V >inkjet all-in-one/hplip (after running hp-setup and adding via cups everything works perfectly. See: http://forums.scotsnewsletter.com/index.ph...st&p=275626 )CentOS 4.4Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileDebian <4Brother 5140 Laser Jet/Cups brother 1220 & 5140HP Deskjet 842C/generic HP driver provided by distributionHP Deskjet 940C/foomatic/hpijsHP PSC 1315 >inkjet all-in-one/hplip-1.6.12 > "etch"HP PSC 1315 >inkjet all-in-one/hpijs (default) (hplip-1.6.12 doesn't support Debian 4.0) > "sid"Debian 4.0 EtchBrother HL-5250DN >BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.1-1.i386.deb +cupswrapperHL5250DN-2.0.1-2.i386.deb > see Note 1 + **.Canon IP4200 > see : http://mambo.kuhp.kyoto-u.ac.jp/~takushi/#canon > works. See also Note 2 reg. other models.HP DeskJet F340 > All in one/HPLIPDebian 4.0r1 64bitBrother HL-5250DN >BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.1-1.i386.deb +cupswrapperHL5250DN-2.0.1-2.i386.deb > see Note 1 + **. > ***Debian 5.0 aka LennyHP 710C/inkjet/see: http://forums.scotsnewsletter.com/index.php?showtopic=22974DreamLinux 3.0Brother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060EliveBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Fedora Core 3HP DeskJet 770C > Parallel interface/CUPS using default HP driver from wizardFedora Core 4Canon i560/bjfiltercups-2.4-0.i386.rpm + bjfilterpixus560i-2.4-0.i386.rpm (ftp canon)Fedora Core 5Canon i560/bjfiltercups-2.4-0.i386.rpm + bjfilterpixus560i-2.4-0.i386.rpm (ftp canon)Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileHP DeskJet 770C > Parallel interface/CUPS using default HP driver from wizardHP PSC 1315 >inkjet all-in-one/hpijs (default)Fedora Core 6Brother 1030 > Laser printer/driver provided by distroBrother HL-5250DN **>BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpmCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileEpson Stylus Color 777/driver provided by distroHP Deskjet 842C/generic HP driver provided by distributionHP PSC 1315 >inkjet all-in-one/hplip-1.6.12Fedora 7Brother HL-5250DN **>BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpmCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd file Fedora 9Brother HL-5250DN **>BW Laser Printer/networked through router w/ static IP set/driver out of the boxCanon IP4200/driver out of the boxHP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended driver out of the box) > unit is networked through router (ethernet cable)Fedora 11Foresight 2.0HP Laserjet 1320 > Laser Jet/Included in distroFreespire 1.0HP 712c parallel > inkjet/driver provided by distro Kubuntu 6.0.6Brother HL1030 > Laser Jet/Provided by DistroHP Deskjet 3845/foomatic/hpijs - HPLIPKubuntu 6.10HP PSC 1315 > inkjet all-in-one/hplip-1.6.12Kubuntu 7.10Kubuntu 8.0.4 LTSBrother HL-5250DN **>BW Laser Printer/networked through router w/ static IP set/install via KDE Print Manager, drivers are already availableCanon IP4200/CUPS+Gutenprint v. 5.0.2 Simplified : auto detected and installed during install: just make sure the printer is connected through USB, doesn't even have to be powered on.HP Photosmart C5180 > inkjet all-in-one/HP Photosmart C5100 Foomatic/hpijs,hpijs 2.8.2 > comment:connected via ethernet port and works perfectly in all respects, incl. scanning and HPLIP printer management software. Install with AIO powered on via KDE>System>HPLIP Toolbox: it asks and guides you though installing.Linux Mint 2.1 beaHP Deskjet F340 > inkjet all-in-one/driver provided by distroHP PSC 1315 > inkjet all-in-one/hplip-1.6.12HP PSC 1350 > inkjet all-in-one/hpijs (default from wizard)Linux Mint 3.0 cassandrapossibly Lexmark P6250 > inkjet all-in-one/driver provided by distroHP 712c parallel > inkjet/driver provided by distroLinux Mint 3.1 celenaHP Laser Jet 2015D > laser printer/HPlip Mandriva 2006Brother HL1030 > Laser Jet/Provided by DistroBrother HL-1240 > Laser printer/provided by distroCanon i560/bjfiltercups-2.4-0.i386.rpm + bjfilterpixus560i-2.4-0.i386.rpm (ftp canon)Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileEpson Stylus Color 777/Provided by DistroHP OfficeJet G85 > all-in-one/Distro provided driver w/ CUPS **HP PSC 1315 > inkjet all-in-one/hplip-0.9.5-1.1.2006.0mdk**also on Mandrake 9.2 + 10.1Mandriva 2007Brother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Brother HL1030 > Laser Jet/Provided by DistroCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileEpson stylus photo 825/provided by distroHP Deskjet 720C/DefaultHP PSC 750/inkjet all-in-one/HPLIP 1.6.9-1mdv2007.0 > Print, Scan, Copy: All functions work very well, including front panel display in HP toolbox HP 840C/foomaticHP Deskjet 940C/foomatic/hpijsHP PSC 1310/inkjet all-in-one /HPLIP 1.6.9-1mdv2007.0 > Print, Scan, Copy: All functions work very well, including tools in toolbox HP PSC 1315 > inkjet all-in-one/hplip-1.6.9-1.2007.0mdvTVS Dot Matrix > Dot Matrix 128 column/Epson 1000Mandriva 2007 64 bit PowerpackBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060HP PhotoSmart C4180 > All in One/HPLIP from distro DVD+added lib64sane-hpaio(works fine - all functions including scanning & tools)Mandriva 2007.1 SpringCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileBrother HL-5250DN **>BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpmHP PSC 750 > inkjet all-in-one/hplip-1.6.12-2.2007.1mdvHP PSC 1315 > inkjet all-in-one/hplip-1.6.12-2.2007.1mdvHP 5550 > inkjet /Foomatic/hpijsMandriva 2008.0 - 32bits versionsBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Brother HL-5250DN **>BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpmCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileHP PSC 750 > inkjet all-in-one/hplip-2.7.7-8.1mdv2008.0HP 840C/inkjet/foomaticHP PSC 1315 > inkjet all-in-one/hplip-2.7.7-8.1mdv2008.0HP Deskjet F2100 > inktjet, laser, MFP/all-in-one/HP Deskjet F2100 Foomatic/ hpijsHP Photosmart C5180 > inkjet all-in-one/HPLIP 2.7.7-8.1 installed from distro RPM > comment:connected via a USB2 port and works perfectly in all respects, incl. HPLIP printer management softwareTVS > Dot Matrix 128 column/Epson 1000Mandriva 2008.0 - 64bits versionsBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Brother HL-5250DN **> BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpm***Canon IP4200/note 3/default or tweaked .ppd fileEpson Color 600/provided by distro/CUPS + Gutenprint v5.0.1HP Photosmart C4180 > inkjet all-in-one/Foomatic/hpijs (recommended)HP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended),hplip 2.7.7-8.1mdv2008.0 + lib64sane-hpaio1> unit is networked through router (ethernet cable)Mandriva 2008.1 'Spring' - 32bits versionsBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060HP PSC 750 > inkjet all-in-one/hplip-2.8.2-2mdv2008.1HP PSC 1315 > inkjet all-in-one/hplip-2.8.2-2mdv2008.1 ( For the scanner to work, install 2 files with the command "urpmi libsane-hpaio1 xsane" )HP Deskjet F2100 > inktjet, laser, MFP/all-in-one/HP Deskjet F2100 Foomatic/ hpijsMandriva 2008.1 'Spring' - 64bits versionsBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Brother HL-5250DN **> BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpmCanon IP4200/gutenprint 5.0.2HP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended),hplip 2.8.2 + lib64sane-hpaio1> unit is networked through router (ethernet cable)Mandriva 2009.0 - 32bits versionsEpson Color 600/provided by distro automatically through its printer set up detection/mtink installed manuallyHP Deskjet F2100 > inktjet, laser, MFP/all-in-one/HP Deskjet F2100 Foomatic/ hpijsHP PSC 750 > inkjet all-in-one/hplip-2.8.7-5mdv2009.0HP PSC 1315 > inkjet all-in-one/hplip-2.8.7-5mdv2009.0HP Photosmart C4180 > inkjet all-in-one/provided by distro automatically through its printer set up detection Mandriva 2009.1HP PSC 750 > inkjet all-in-one/hplip-3.9.2-2mdv2009.1.i586HP PSC 1315 > inkjet all-in-one/hplip-3.9.2-2mdv2009.1.i586HP Deskjet F2100 > inktjet, laser, MFP/all-in-one/HP Deskjet F2100 Foomatic/ hpijsPCLinuxOS P92Canon i560/bjfiltercups-2.4-0.i386.rpm + bjfilterpixus560i-2.4-0.i386.rpm (ftp canon)Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileHP Deskjet 842/HPLIPHP Deskjet 940C/foomatic/hpijsHP PSC 1315 > inkjet all-in-one/hplip-1.6.12PCLinuxOS P93Brother 5140 > Laser Jet/Cups brother 1220 & 5140Canon i560/bjfiltercups-2.4-0.i386.rpm + bjfilterpixus560i-2.4-0.i386.rpm (ftp canon)Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileEpson Stylus c88+ > on 2007tr1 >/foomaticEpson stylus photo 825/provided by distroHP Deskjet F340 > on 2007tr1 >inkjet all-in-one/driver provided by distroHP Deskjet 720C/DefaultHP Deskjet 970/HPLIPHP LaserJet 1020 > Laser Jet/Generic provided by distroHP PSC 1315 > inkjet all-in-one/hplip-1.6.12HP2550 > color laserjet/default driversHP deskjet 5550/Foomatic/hpijsHP OfficeJet G85/all-in-one/Distro provided Foomatic/hpijs, Cups / HPLIPHp Photosmart 7760/HPLIP distro providedHP Deskjet 9800 (wide format)> on 2007tr1 >/foomaticPCLinuxOS 2007Brother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Brother HL-5250DN **> BW Laser Printer/networked through router w/ static IP set/brhl5250dnlpr-2.0.0-1.i386.rpm + cupswrapperHL5250DN-2.0.0-1.i386.rpmCanon i560s/Canon BJC-8200 Foomatic/bj8pa06n.uppCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileHP LJ 1012 > Laser Printer/driver provided by distroHP Deskjet D2345/inkjet/Foomatic/hpijsHP 9800/Wideformat/HPJS Driver : USB or Parallel PCLinuxOS 2008 GNOMEEpson D92/TurboprintPCLinuxOS MiniMe 2008HP DeskJet 5550 > InkJet/foomatic/hpijs PCLinuxOS 2009.1HP V45 deskjet > inkjet all-in-one/driver provided by distributionPCLinuxOS 2009.2HP OfficeJet 4215 > inkjet all-in-one/driver provided by distributionlexmark Z22 > driver provided by distributionPCLinuxOS 2011.6HP 8500 > All-In-One wireless/Go to "configure computer"> Manage System Services>Printer>turn "CUPS" 'on'> then activate a console, and type: hp-setup (make sure that HP-LIP and CUPS is installed in Synaptic)>enter your HP information in the GUI application. Then make sure that the user is listed in the Group's "lp" section. See http://forums.scotsnewsletter.com/index.php?showtopic=46718 Sam Linux Desktop 2006-3Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileSimplyMEPIS 6.5HP Laserjet 1320 > Laser Jet/networked/Foomatic HP/Postscript SimplyMEPIS 8.0 HP 710C/inkjet/see: http://forums.scotsnewsletter.com/index.php?showtopic=22974Slackware 11Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileEpson Stylus Photo 825/Cups+ gimp-print v4.2.7HP Deskjet 842C/generic HP driver provided by distributionHP Deskjet 940C/foomatic/hpijsHP PSC 1315 > inkjet all-in-one/hpijs (default)HP PSC 1610 > inkjet all-in-one/Cups with HPLIP version 1.7.1HP OfficeJet 5610v > inkjet all-in-one/hpoj deprecated with foomatic/hpijs >>> comment: All functions work, but only with using the hpoj driver, and the ptalbackend. HPLIP will not let all functions work in Slackware. hp-setup in HPLIP complains that Slackware is not LSB certified.Slackware 12.0HP Deskjet 842C/inkjet/hpjis > used parallel connectionHP Deskjet F2100 > All in One/HP Deskjet F2100 Foomatic/ hpijsSlackware 12.1Brother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060HP Deskjet F2100 > inktjet, laser, MFP/all-in-one/HP Deskjet F2100 Foomatic/ hpijs Slackware 13.0SuSE 9.3Canon i560/bjfiltercups-2.4-0.i386.rpm + bjfilterpixus560i-2.4-0.i386.rpm (ftp canon)OpenSuSE 10.0HP Laserjet 1220 > Laser Jet/Included in distroOpenSuSE 10.1remasteredCanon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileHP 712c parallel > inkjet/driver provided by distroHP Deskjet 842C/generic HP driver provided by distributionOpenSuSE 10.2Brother 5140 > Laser Jet/Cups brother 1220 & 5140Canon IP4200/cnijfilter-common-2.60-1.i386.rpm + cnijfilter-ip4200-2.60-1.i386.rpm (ftp canon) + tweaked .ppd fileEpson Stylus CX4200 > inkjet all-in-one/included in distroHP Deskjet F340 > inkjet all-in-one/driver provided by distroHP PSC 1315 > inkjet all-in-one/hplip-1.6.12OpenSuSE 10.3Brother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060HP deskjet 5550/Foomatic/hpijsOpenSuSE 11.0HP V45 deskjet > inkjet all-in-one/driver provided by distributionOpenSuSE 11.1Ubuntu 6.01.1 LTSHP Deskjet D2345/inkjet/Foomatic/hpijs : had to trick Ubuntu 6.01.1 LTS by using a hpijs driver for a different printer because CUPS for this version of Ubuntu doesn't have my printerUbuntu 6.0.6 LTSHP DeskJet F380 > printer/scanner combo/any hplip >.9.9 will enable scanning with xsaneHP psc 750 > inkjet all-in-one/hpijs/HPLIP 0.9.7 (default from wizard)HP Deskjet 842C/generic HP driver provided by distributionHP Deskjet 932C/driver provided by distributionHP PSC 1315 > inkjet all-in-one/hpijs (default)HP Deskjet 3747/driver provided by distributionHp Photosmart 7760/HPLIP distro providedUbuntu 6.10Note for Canon users: See this page: http://mambo.kuhp.kyoto-u.ac.jp/~takushi/#canonBrother 1050 > Laser printer/driver provided by distroBrother 5140 > Laser Jet/Cups brother 1220 & 5140HP psc 750/hpijs(default from wizard) > inkjet all-in-one > everything works auto detectedHP DeskJet 882C > Parallel interface/CUPS using default HP driver from wizardHP LaserJet 1020 > all in one bw laser jet/Generic provided by distroHP Deskjet D2345/inkjet/Foomatic/hpijsHp Photosmart 7760/HPLIP distro providedUbuntu 7.04Epson Stylus CX5400 > all in one inkjet/OS-supplied driverHP Deskjet F380 > all in one/works out of the boxHP 712c parallel > inkjet/driver provided by distroHP Laserjet 1320 > Laser Jet/Included in distroHP Deskjet D2345/inkjet/Foomatic/hpijsHP 3747 > all in one inkjet/Native driver in distroUbuntu 7.10HP Deskjet D2345/inkjet/Foomatic/hpijsHP Deskjet F340 > all-in-one/Generic "as supplied"HP psc 750 > all-in-one/works out of the boxHP Photosmart C3100 > all-in-one/works out of the boxUbuntu 8.04LTSBrother HL 2070N > BW Laser Printer/networked/driver through CUPS HL 2060Brother HL 2070N > BW Laser Printer/using USBBrother HL-5250DN **> BW Laser Printer/networked through router w/ static IP set/driver out of the boxCanon IP4200/driver out of the boxHP psc 750 > all-in-one/works out of the boxHP Photosmart C3100 > all-in-one/works out of the boxHP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended driver out of the box) > unit is networked through router (ethernet cable)HP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended driver out of the box) > unit is connected through USBUbuntu 8.04LTS - 64bitBrother HL-5250DN **> BW Laser Printer/networked through router w/ static IP set/driver out of the boxCanon IP4200/driver out of the boxHP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended driver out of the box) > unit is networked through router (ethernet cable)HP Photosmart C5180 > inkjet all-in-one/Foomatic/hpijs(recommended driver out of the box) > unit is connected through USBUbuntu 8.10Lexmark X1185 > inkjet all-in-one/Driver used: CJLZ600LEsee this document: https://help.ubuntu.com/community/HardwareS...ltifuncPrintershttps://help.ubuntu.com/community/HardwareSupportComponentsPrinters/LexmarkPrinters Ubuntu 9.04HP Officejet 6500 Wireless > inkjet all-in-one/just plugged it in and away she went HP Photosmart C5180 > inkjet all-in-one/hpijs+hplipUbuntu Ultimate 1.6HP Photosmart 2610 > all-in-one/distro detected "plug & play" >comment: Print, Scan, Copy: All functions work Vector Linux 5.1.x HP OfficeJet G85 > all-in-one/Distro provided driver w/ CUPSHP deskjet 5550/Foomatic/hpijs Vector Linux 6.0HP 710C/inkjet/see: http://forums.scotsnewsletter.com/index.php?showtopic=22974Xandros 4.0 Lexmark T616 > bw laser printer/works via Windows shareXandros 4.1HP LaserJet 1020 > Laser Jet/Generic provided by distroHP Laser Jet 2015D > laser printer/HPLIPXandros eeepcHP DeskJet 5550/foomatic/hpijsZenwalk 3.0Hp Photosmart 7760/HPLIP distro provided Note 1: for best printing quality use the BR-Script3 driver; Install brhl5250dnlpr-2.0.1-1.i386.deb + cupswrapperHL5250DN-2.0.1-2.i386.deb from manufacturers website;If error messages during install of cupswrapper, open synaptic,search for printer and install all Lp stuff;Finally from manufacturers CD copy BR5250_2.PPDto /usr/share/cups/model, restart CUPS or reboot;Goto KDE>Print system>Print manager : hit Admin button,select your Brother printer, goto tab Properties, select Driver > click Change,click Brother, click ' Other' button and navigate to the BR5250_2.PPD filein /usr/share/cups/model and select this file as driver. Reboot and ready to go.Note 2:the page listed above also has drivers available for other Canon models.Note 3:install the below files in shown order:lib64xml1-1.8.17-11mdv2008.0.x86_64libpopt0-1.10.8-22mdv2008.0.i586cnijfilter-common-2.60-1.i386.rpmlibglib1.2-1.2.10-18mdv2008.0.i586libgtk+1.2-1.2.10-47mdv2008.0.i586libxml1-1.8.17-11mdv2008.0.i586cnijfilter-ip4200-2.60-1.i386Next Add Printer through Print Manager (and if appropriate redirect driver to use tweaked .ppd file) ;**Brother HL-5250DN: settings for optimal results : 600DPI - Toner Save = Off - Half Tone Screen Lock=Off, use driver :Brother HL5250DN-BR-Script3ftp Canon means: ftp://download.canon.jp/pub/driver/bj/linux/See also this artcle by Carla Schroder:More Fun With Printinghttp://www.oreillynet.com/linux/blog/2007/...n+With+Printingfor Canon PIXMA iP1600:Canon PIXMA iP1600 Printer - Working and Shared Note 13 August 2009: You first have to log in (or create an account and after that log in) to be able to see any content. I don't know if the article is still there, because I refuse to create an account just to see if the article is there or not.see this link : http://www.pclinuxos.com/index.php?option=...6.msg246443#newseems to be removedCanon LBP 5100 with Samba (amd64)http://www.debian-administration.org/artic...ith_Samba_amd64Canon LBP 2900 with Sambahttp://www.gentoo-wiki.info/HOWTO_Canon_LBP_2900_with_SambaWindowsPrinterSharingWithoutSamba http://www.pclinuxos.com/wiki/index.php/Share_PrinterHow to print to a shared Windows printerJuly12 2009: the link for this one I still couldn't locate back again, seems to be vanished...How to make Windows use CUPS IPPhttp://www.owlfish.com/thoughts/winipp-cups-2003-07-20.html*** How to use/install the Brother Linux printer drivers on 64bit linux? (from the Brother FAQ)For RPM package users:If you cannot print, install lib32stdc++6 or ia32-libs.For DPKG package users:Install the driver using the command option "--force-architecture".If you cannot print, install lib32stdc++6 or ia32-libs.(commands: used Brother HL5250DN drivers as example below:)dpkg -i --force-architecture brhl5250dnlpr-2.0.1-1.i386.debdpkg -i --force-architecture cupswrapperHL5250DN-2.0.1-2.i386.debAlso, try copying the file which name starts with "brlpdwrapper" in the" /usr/lib/cups/filter" to the "/usr/lib64/cups/filter".Samsung ML-2571N error message after changing IP address settings from DHCP to static and change hostname.Lost access to the web interface.http://blog.eracc.com/2008/05/21/embedded-...twork-printers/Lexmark Z55 printer drivers (and a couple of others) for rpm based distros are available from the Lexmark website. For a setup in Ubuntu 8.0.4 see this link:http://onlyubuntu.blogspot.com/2008/05/how...printer-in.htmllink seems to be removedHOWTO: Install Canon ImageCLASS MF4270 Multifunction driver in Ubuntu 8.04 Hardy Heronhttp://ubuntuforums.org/showthread.php?t=1140724DELL A940 AIOsee comments section in : http://onlyubuntu.blogspot.com/2008/05/how...printer-in.htmllink seems to be removed <placeholder> links checked : May 12 2010 01.08 AMlast modified : May 12 2010 01.08 AM Quote
Urmas Posted December 30, 2006 Posted December 30, 2006 Brand and Model: HP psc 750inkjet or laser: inkjet all-in-oneDriver used: hpijs/HPLIP 0.9.7 (default from wizard)Distro used: Ubuntu 6.06. Quote
zlim Posted December 30, 2006 Posted December 30, 2006 Brand and Model: HP deskjet 5550inkjetDriver used: Foomatic/hpijsDistros: PCLinux .93, Mepis 3.4.3 (I think, I've since replaced this) Vector 5.1.1 SOHO Quote
Bruno Posted December 30, 2006 Posted December 30, 2006 . . . . got 2 HPs:Old printer Brand and Model: HP PSC 750inkjet or laser: inkjet all-in-oneDriver used: HPLIP 1.6.9-1mdv2007.0Distro used: Mandriva 2007Print, Scan, Copy: All functions work very well, including front panel display in HP toolbox New printer Brand and Model: HP PSC 1310inkjet or laser: inkjet all-in-oneDriver used: HPLIP 1.6.9-1mdv2007.0Distro used: Mandriva 2007Print, Scan, Copy: All functions work very well, including tools in toolbox Both printers work in all other distros ( see profile ) as well but I only use them in Mandriva. Bruno Quote
V.T. Eric Layton Posted December 30, 2006 Posted December 30, 2006 Brand and Model: Hewlett Packard Deskjet 842Cinkjet or laser: inkjetDriver used: generic HP driver provided by distributionDistro used: Ubuntu 6.06.1 LTS, Debian Etch, Fedora Core 6, OpenSuSE 10.1, Slackware 11.0 Quote
quint Posted December 30, 2006 Posted December 30, 2006 (edited) Brand and Model: HP PSC 1315Inkjet, Laser, MFP/all-in-one: all-in-oneDriver used: hpijs (default)Distro used: Slackware 11.0 (/w dlg)Works fine.(Also works fine /w the following, though I'm currently in Slack and do not have the additional driver info):FedoraCore 5 / Driver used: hpijs (default)Mint 2.1 / Driver used: hplip-1.6.12openSuSE 10.2 / Driver used: hplip-1.6.12PCLOS 92 / Driver used: hplip-1.6.12Mandriva 2007 / Driver used: hplip-1.6.9-1.2007.0mdvSlackware 11.0 / Driver used: hpijs (default)DSL 3.1 / No luck !!"El Sid" / Driver used: hpijs (default) (hplip-1.6.12 doesn't support Debian 4.0)Mandriva 2006 / Driver used: hplip-0.9.5-1.1.2006.0mdkUbuntu dapper / Driver used: hpijs (default)Kubuntu 6.10 / Driver used: hplip-1.6.12FedoraCore 6 / Driver used: hplip-1.6.12PCLOS "BigDaddy" / Driver used: hplip-1.6.12Slackware current / Driver used: hplip-1.6.12 (works partially)Debian Etch / Driver used: hplip-1.6.12... and 7 other variations (versions) of some of the above. Edited December 31, 2006 by quint Quote
mhbell Posted December 30, 2006 Posted December 30, 2006 QUOTEBrand and Model: Brother 5140 Laser Jet Black & White only USB Portlaser, Driver used: Cups brother 1220 & 5140Distro used:Ubuntu, Suse, PCLos, Debian Have used it in over 40 different distro's with no problems. Quote
striker Posted December 30, 2006 Author Posted December 30, 2006 added all as far as information was provided.Thanks friends, looking great! Quote
SueD Posted December 30, 2006 Posted December 30, 2006 I don't have a printer anymore since my daughter confiscated mine when she headed off to school over a year ago. But I will be taking notes. Quote
rpiz Posted December 30, 2006 Posted December 30, 2006 Brand and Model: HP Deskjet 720Cinktjet, laser, MFP/all-in-one: inkjetDriver used: DefaultDistro used: Mandriva 2007 and PClos .93aNo problems whatsoever, just worked from thebeginning. Good luck. Quote
Fuddster Posted December 30, 2006 Posted December 30, 2006 Brand and Model: Epson Stylus CX4200inktjet, laser, MFP/all-in-one: Print/Scan/Copy all-in-oneDriver used: included in distroDistro used: openSuse 10.2*Note: Printer is connected to Windows machine and accessed through SAMBA share over home LAN. Quote
ebrke Posted December 30, 2006 Posted December 30, 2006 HP Laserjet 1220Print, copy, scanDriver: Included in distroOpenSuSE 10.0As a caveat, I have to say that I have not installed the hplip that would enable the scanning. I did use the predecessor package several versions ago, and scanning did work, but I don't scan very often and I have not pursued it for my last few installs. Quote
longgone Posted December 30, 2006 Posted December 30, 2006 Brand and Model:---- hp 940cinktjet, laser, MFP/all-in-one:-- deskjetDriver used:-- foomatic/hpijsDistro used:-- Slackware 11.0, MD2007, PCLOS92 Quote
BillD Posted December 31, 2006 Posted December 31, 2006 Brand and Model: HP Deskjet 970inktjet, laser, MFP/all-in-one: InkjetDriver used: HPLIPDistro used: PCLos 0.93a-------------------Brand and Model: HP Deskjet 842inktjet, laser, MFP/all-in-one: InkjetDriver used: HPLIPDistro used: PCLos 0.92-------------------Tool box works fine on both of them, altho ink level cannot be determined on 842 in either Windows or Linux because of shortcoming in 842 cartridges, I assume.Bill Quote
Manitoban Posted December 31, 2006 Posted December 31, 2006 Brand and Model:Brother HL 1030 inktjet, laser, MFP/all-in-one: LaserDriver used: Provided by DistroDistro used: Mandriva 2006 and 2007; also Kubuntu 6.06This printer originallly used Parallel cable, Now uses USB to Parallel connection. Works well either way.Brand and Model:Epson Stylus Color 777InkjetDriver used: provided by DistroMandriva 2006 Quote
Dense Posted December 31, 2006 Posted December 31, 2006 Epson stylus photo 825Windows XPPcLinux B. D.Mandriva 2007driver provided by distro's in LinuxProvided by Mfg. in XP Quote
teacher Posted December 31, 2006 Posted December 31, 2006 Hello allI was running my HP2550 color laserjet from PCLos Big Daddy. Worked with default drivers when set up parallel, USB, and as an IP address. Quote
striker Posted December 31, 2006 Author Posted December 31, 2006 Thanks Julia, it was added. Happy New Year ! Quote
tiarnach Posted December 31, 2006 Posted December 31, 2006 Brand and Model: HP LaserJet 1020inktjet, laser, MFP/all-in-one: laser, bw onlyDriver used: Generic provided by distroDistro used: Xandros 4.1, PCLOS .93 Quote
cybormoron Posted January 1, 2007 Posted January 1, 2007 Brand and Model: Brother HL-1240inktjet, laser, MFP/all-in-one: bw onlyDriver used: provided by distroDistro used: mandriva free 2006 Quote
striker Posted January 1, 2007 Author Posted January 1, 2007 all updated, going great ! Quint : thanks for updating your reply. Quote
quint Posted January 1, 2007 Posted January 1, 2007 Both printers work in all other distros ( see profile ) as well but I only use them in Mandriva. BrunoHi Bruno,Can you let me know what driver you used for your "HP PSC 1310" in DSL? I've tried almost all of the offerings in "apsfilter", w/o any luck! Thanks very much. Quote
Bruno Posted January 1, 2007 Posted January 1, 2007 Hi Bruno,Can you let me know what driver you used for your "HP PSC 1310" in DSL? I've tried almost all of the offerings in "apsfilter", w/o any luck! Thanks very much.Hi Quint . . . . . cups is available in MyDSL . . . . . . :thumbsup: Bruno. . . . . . . . Quote
quint Posted January 1, 2007 Posted January 1, 2007 Hi Quint . . . . . cups is available in MyDSL . . . . . . Bruno. . . . . . . . Thanks, Bruno ... will check. Quote
striker Posted January 2, 2007 Author Posted January 2, 2007 whenever you have a spare moment add your printer please for the benefit of all ! Quote
Malachite Posted January 3, 2007 Posted January 3, 2007 Brand and Model: HP Deskjet 3845inktjet, laser, MFP/all-in-one: InkjetDriver used: foomatic/hpijs - HPLIPDistro used: Kubuntu 6.06 Quote
