OKBut will have to do that in PCLOsC olin
  • Replies 200
  • kamicota
    99
  • Bruno
    76
  • quint
    12
  • teacher
    10
I knew that . . . you were to quick leaving PCLos . . . . :P :P B) Bruno
Slow and steady Colin! ;)Julia :P
Heck Julia/BrunoI went slow & steady even unchecked the Grub Box Did NOT get the make rescueAnd B) :P :( ;) :'( :P I STILL have the MDK 10 loader BUT :o neither MDK, MEPIS or PCLOs will load.I rebooted with PCLos rescue cd and that's where I'm at CONFUSED as ever :blink: Colin :D
Great Colin . . . well, let us see what the damage is :lol:You are in PCLos ? Do:
$ su< password ># /sbin/lilo# reboot
And tell me if you get the PCLos Lilo at boot :DB) Bruno
Yep BrunoNow just the PCLos liloColin :P
Great Colin . . good progress !!Question . . is Windows already in PCLos Lilo ??Here is the first stage of commands:
$  su < password > #  mkdir  /mnt/mepis #  mkdir  /boot/mepis #  ls  /boot
:P Bruno
No BrunoWindows NOT in PCLOs Lilo only PCLosColin
[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# mkdir /mnt/mepis[root@localhost kamicota]# mkdir /boot/mepis[root@localhost kamicota]# ls /bootboot.0300 lost+found/boot.0800 mapconfig@ mepis/config-2.4.23-2.tmb.2mdk message@diag1.img message-graphicdiag2.img message-textinitrd-2.4.23-2.tmb.2mdk.img System.map@initrd.img@ System.map-2.4.23-2.tmb.2mdkkernel.h@ us.kltkernel.h-2.4.23-2.tmb.2mdk vmlinuz@livecd.klt vmlinuz-2.4.23-2.tmb.2mdk[root@localhost kamicota]#Colin
Brilliant . . step 2:
# mount  /dev/hda7  /mnt/mepis # cp  /mnt/mepis/boot/vmlinuz-2.4.26  /boot/mepis # cp  /mnt/mepis/boot/vmlinuz-2.6.4  /boot/mepis # ls  /boot/mepis
:P Bruno
:P [kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# mount /dev/hda7 /mnt/mepis[root@localhost kamicota]# cp /mnt/mepis/boot/vmlinuz-2.4.26 /boot/mepis[root@localhost kamicota]# cp /mnt/mepis/boot/vmlinuz-2.6.4 /boot/mepis[root@localhost kamicota]# ls /boot/mepisvmlinuz-2.4.26 vmlinuz-2.6.4[root@localhost kamicota]#Colin :P
Great Job Colin !!!Next step:
# kedit  /etc/lilo.conf
( Or use kwrite if you prefer ) This will open a window with the lilo.conf file in it . . . now PASTE at the bottom of it:
image=/boot/mepis/vmlinuz-2.4.26          label="Mepis-24"          root=/dev/hda7          vga=788           read-only  image=/boot/mepis/vmlinuz-2.6.4          label="Mepis-26"          root=/dev/hda7          vga=788           read-only  other=/dev/hda1      	 label="Windows"      	 table=/dev/hda
Then save the file and close the kedit window.Then show me:
# cat /etc/lilo.conf
:P Bruno
[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# cat /etc/lilo.confboot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.4.23-2.tmb.2mdk label="pclinuxos" root=/dev/hda9 initrd=/boot/initrd-2.4.23-2.tmb.2mdk.img append="devfs=mount splash=silent" vga=788 read-onlyimage=/boot/mepis/vmlinuz-2.4.26 label="Mepis-24" root=/dev/hda7 vga=788 read-onlyimage=/boot/mepis/vmlinuz-2.6.4 label="Mepis-26" root=/dev/hda7 vga=788 read-onlyother=/dev/hda1label="Windows"[root@localhost kamicota]#Colin
Brilliant !!!Now do:
# /sbin/lilo
:P Bruno
:P [root@localhost kamicota]# /sbin/liloAdded pclinuxos *Added Mepis-24Added Mepis-26Added Windows[root@localhost kamicota]#Colin :P
Sorry Colin . . I am missing the last line I gave you :other=/dev/hda1 label="Windows" table=/dev/hda <-------------------------------- !!!!!:P Bruno
ColinWindows will NOT boot like that !!! See previous messageB) Bruno
I sort of gathered that BrunoSO what do I DO nowColin
And add:
table=/dev/hda
Directly at the end and then save the file again and:
:P Bruno
this is what I get in Kedit nowboot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.4.23-2.tmb.2mdk label="pclinuxos" root=/dev/hda9 initrd=/boot/initrd-2.4.23-2.tmb.2mdk.img append="devfs=mount splash=silent" vga=788 read-onlyimage=/boot/mepis/vmlinuz-2.4.26 label="Mepis-24" root=/dev/hda7 vga=788 read-onlyimage=/boot/mepis/vmlinuz-2.6.4 label="Mepis-26" root=/dev/hda7 vga=788 read-onlyother=/dev/hda1label="Windows"table=/dev/hdaColin
Good . . that is better !Now again:
# /sbin/lilo
:P Bruno
Bruno because We cross Posted this is what I have now after I checked[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# /sbin/liloAdded pclinuxos *Added Mepis-24Added Mepis-26Added Windows[root@localhost kamicota]#I did NOT do # kedit /etc/lilo.confAnd add:CODEtable=/dev/hdaDirectly at the end and then save the file again and:CODE# cat /etc/lilo.confColin
Colin, let me see:
AGAIN !!:P Bruno
[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# /sbin/liloAdded pclinuxos *Added Mepis-24Added Mepis-26Added Windows[root@localhost kamicota]# cat /etc/lilo.confboot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.4.23-2.tmb.2mdk label="pclinuxos" root=/dev/hda9 initrd=/boot/initrd-2.4.23-2.tmb.2mdk.img append="devfs=mount splash=silent" vga=788 read-onlyimage=/boot/mepis/vmlinuz-2.4.26 label="Mepis-24" root=/dev/hda7 vga=788 read-onlyimage=/boot/mepis/vmlinuz-2.6.4 label="Mepis-26" root=/dev/hda7 vga=788 read-onlyother=/dev/hda1label="Windows"table=/dev/hda[root@localhost kamicota]#Guess I'd better do the CODE# kedit /etc/lilo.confAnd add:CODEtable=/dev/hdaDirectly at the end and then save the file again and:CODE# cat /etc/lilo.confOver again eh :P
NO NO Colin . . it is Okay this way . . don't change anything !!just do
# /sbin/lilo
Again and we are ready !:P Bruno
[root@localhost kamicota]# /sbin/liloAdded pclinuxos *Added Mepis-24Added Mepis-26Added Windows[root@localhost kamicota]#That's itColin
Now first try to reboot into Windows . . . . if that is okay then try Mepis-24 . . . . . and post from there ;):P Bruno
Crossing fingers :w00t::P Bruno
Righty HO brunoYou can uncross them NOW :P We ARE in Mepis-24 and I REALLY like itColin :P :blink: B)
