Bruno Posted May 8, 2004 Posted May 8, 2004 Hi Colin,This is what Quint and I have been cooking for you: MEPIS !! ( Kernel 2.6 and KDE 3.2.2, Debian based distro ) Download this ISO and burn it to CD: ftp://ftp.nluug.nl/pub/os/Linux/distr/mep....05.b03.cd1.iso There is no checksum so you will have to test it by running it life Also because after the install we will be using The PCLos lilo we need a boot-CD for PCLos, boot into PCLos and do: mkrescue --iso --initrd /boot/initrd-2.4.23-2.tmb.2mdk.img --kernel /boot/vmlinuz-2.4.23-2.tmb.2mdk And after that rightclick the "rescue.iso" in your /home/kamicota and burn it to CD . . . then test it if it works Let us hear how far you got . . . . . No lazy weekend for you Colin ! Sweat sweat sweat !! Buckets of it D Bruno Quote
teacher Posted May 8, 2004 Posted May 8, 2004 And be very careful when you get to the bootloader. Do not install grub. Clear the box there and continue without doing that (just in case you jump the gun here!). Julia Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 Heck Bruno I DID download the stable LIVE version LATE last night.BUT installing it over MDK 10 is giving me the "Willie " all over again.First have to burn the CD and see if it goes as smooyth as Knoppix 3.4.And FINALLY I got the MESSAGE a STABLE version of Linux alongside PCLOs just makes so much commom sense By the way I also ENJOY and EXCITING weekend too Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Colin,The file I linked you to above is stable ! . . Check if you do have the right one: mepis-2004.05.b03.cd1.iso and NOT:mepis-2004.05.b04.cd1.isoB) Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 Bruno Here is the one I downloaded--->>> file:/home/kamicota/downloads/knoppix/mepis-2004.05.b03.cd1.isoJulia Ill get back for more clarification on the Grub instructions seems like it might be time to bur a Cd Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Okay . . burn the CD Colin !!And if you are in PCLos make the rescue CD as well as long as you are there anyway ( See first post ) Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 BrunoSurely I need to be in Mepis to make the rescu cd Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 NOPE: You need to be in PCLos to make the rescue CD !!! Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 Righty Ho Bruno Will do it as soon as the Mepis Live is ready. Is there an application in Mepis the same as PCLOs to install to hard drive hda 7.Thankz Julia, if I read you right there will be a check box to install grub and it needs to be unchecked if that makes any sense HECK I even confuse myself at times Colin Quote
teacher Posted May 8, 2004 Posted May 8, 2004 Thankz  Julia, if I read you right there will be a check box to install grub and it needs to be unchecked if that makes any sense You got that part exactly right! Later on you will see an option to burn a boot floppy. That is what will happen. Slow and steady - one step at a time. Do your MD5Sum check and burn your CD and then onward and upward!Julia : Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Mepis uses Lilo Colin . . so no worries :DAnd yes there is an app to install it to HD . . very easy ! BrunoPS: There is no checksum Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 Hey Julia Don't throw TOO many cuve balls at me at once, I'm a SLOW LearnerAny ways that's mepis Burned Now to PCLOs rescue and possibly then a try to see if Mepis Live works Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 First test the PCLos rescue Colin . . then boot into MepisB) Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 I just KNEW things were going to smoothlyheres what I got with the rescue command and the CD does not seem to be burning or does it do it that quick[kamicota@localhost kamicota]$ mkrescue --iso --initrd /boot/initrd-2.4.23-2.tmb.2mdk.img --kernel /boot/vmlinuz-2.4.23-2.tmb.2mdkbash: mkrescue: command not found[kamicota@localhost kamicota]$ suPassword:[root@localhost kamicota]# mkrescue --iso --initrd /boot/initrd-2.4.23-2.tmb.2mdk.img --kernel /boot/vmlinuz-2.4.23-2.tmb.2mdk2880+0 records in2880+0 records outMaking filesystemmke2fs 1.34 (25-Jul-2003)/tmp/mkrescue-emu is not a block special device.Proceed anyway? (y,n) Filesystem label=OS type: LinuxBlock size=1024 (log=0)Fragment size=1024 (log=0)24 inodes, 2880 blocks144 blocks (5.00%) reserved for the super userFirst data block=11 block group8192 blocks per group, 8192 fragments per group24 inodes per groupWriting inode tables: doneWriting superblocks and filesystem accounting information: doneThis filesystem will be automatically checked every 24 mounts or180 days, whichever comes first. Use tune2fs -c or -i to override.Mounting filesystem`/boot/diag1.img' -> `/tmp/mkrescue-flp/diag1.img'`/boot/diag2.img' -> `/tmp/mkrescue-flp/diag2.img'Copying files...`/boot/livecd.klt' -> `/tmp/mkrescue-flp/lang.ktl'`/boot/initrd-2.4.23-2.tmb.2mdk.img' -> `/tmp/mkrescue-flp/initrd'`/boot/vmlinuz-2.4.23-2.tmb.2mdk' -> `/tmp/mkrescue-flp/linux'done.Running /sbin/lilo ...Ignoring entry 'boot'Added linux *Added hard_diskAdded diagnostic_1Added diagnostic_2done.MKISOFSSize of boot image is 5760 sectors -> Emulating a 2880 kB floppyTotal translation table size: 2488Total rockridge attributes bytes: 410Total directory bytes: 0Path table size(bytes): 10Max brk space used 01624 extents written (3 Mb)END MKISOFS: output is in 'rescue.iso'The bootable CD can be burned with the 'cdrecord' utilityusing a command of the form: cdrecord [<options>] [dev=<device>] rescue.isoAll done.[root@localhost kamicota]#Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 I don't get it Colin . . do you have a rescue.iso file in /home/kamicota ? Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 BrunoThis is what I have in home/kamicota file:/home/kamicota/rescue.isoColin Quote
ross549 Posted May 8, 2004 Posted May 8, 2004 And after that rightclick the "rescue.iso" in your /home/kamicota and burn it to CD . . . then test it if it works Do this. Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 OOPS AdamI didn't do that fiorgot I had oneSilly moo me Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Right, burn the ISO to CD . . and boot from it ! Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 Righty Ho "HOUSTON we have lift off" PCLOs Rescue CD works I'm posting from it Looks like Mepis time Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Good . . give me a second to write instructions you can print out ! Bruno Quote
teacher Posted May 8, 2004 Posted May 8, 2004 You know exactly which partition you are going to use and do not have anything on that partition? Make sure you follow Bruno's instructions down to the very last period!Julia Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Right Colin,You boot from the Mepis CD and at the welcome screen you select with the arrow up and arrow down keys: Boot MEPIS with 1024x768   2.6.4 kernel Engish ( Experimental ) Then press enter !At the login: the password for "demo"is "demo"Once the KDE desktop is up you see an Icon with "Mepis Install Center" . . . . . . click it and you will have to give the rootpassword: "root" . . . . . then you will see a line that says: "Install Mepis to harddrive" select it and next.Then in the right pane you see the drive: hda . . . next . . . then you have to select to install / on hda7 . . . . from there on it is easy as pie . . . . do not install a bootloader, not needed . . . . just skip that part . . . . then when ready reboot into PCLos and we will see you back here. Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 OOPS I jumped the gun again I'm already in MEPIS after giving it palpitations at the beginning when I tried to log in as kamicota Silly me it froze the mouse Don't know if I like the Google start in each browser thoughColin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Hey Colin . . what kernel did you boot ?? Bruno Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 BrunoIm in the 2.4 kernel the first one on Mepis's list and as rootColin Quote
kamicota Posted May 8, 2004 Posted May 8, 2004 root@0[root]# uname -aLinux mepis1 2.4.26 #1 Mon Apr 19 13:22:52 EDT 2004 i686 GNU/Linuxroot@0[root]#Colin Quote
Bruno Posted May 8, 2004 Author Posted May 8, 2004 Print out my instructions and start again Colin !! . . And don't jump the gun next time :DB) Bruno Quote
