I am going to give it a whirl.... see what happens. :blink:
  • Replies 162
  • Owyn
    77
  • ross549
    55
  • Bruno
    12
  • teacher
    2
Hmmm.... CVS is not letting me login... do I have to have a specific login or can I use anonymous/email?
One comment Adam. This was done from a clean install of Mdk91 with just the security, bugfix and alsa updates.
Just press enter at the password prompt and continue on with next step.Got to run.
Hey ross549 ... the changing of the guard as it were ;)Let me go back over where we are and see if I can help you get through these steps. :blink:
Were you able to get into CVS after pressing enter as Owyn mentioned?
sorry ross549 (and Owyn) ... guess I got here too late!Guess we'll have to wait till later. :blink:
Well, after getting only a couple hours of sleep last night (bad case of insomnia), I am running into bit of a problem....
[root@ip68-10-250-190 emu10k1]# makemake -Cscriptsmake[1]: Entering directory `/tmp/emu10k1/scripts'/lib/modules/2.4.21-0.13mdk/build directory does not exist. Please edit the file 'config'in this directory and set KERNEL_SOURCE to the correct location of yourkernel source.You are currently running kernel version 2.4.21-0.13mdk, the source code shouldbe for this version.make[1]: *** [get_version] Error 1make[1]: Leaving directory `/tmp/emu10k1/scripts'make: *** [opts] Error 2
I navigated to /lib/modules/2.4.21-0.13mdk, and there (obviously) is no "build" directory. What is an alternative location?
Adam,Hold on for a bit. I am rerunning the build procedure and annotating in my notes to the the procedure. I will repost details with every step I went through.
okie...I am downloading RH9 iso's right now anyway. :lol:
Shudder
Well, gotta do SOMETHING... I have the day off. Gonna DL Suse as well.
