Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 Here's a guide that someone actually put up on the web about setting up the Audigy 2 with Mandrake 9.1: Audigy 2 linux setup guideBy: Jesper Noehr This is a guide for setting up a Creative Audigy 2 sound card.I had some trouble setting it up, so I decided to write a small guide on it, to help others in the same situation as me.I set it up on a mandrake 9.1, but it shouldn't matter what version of linux you are using. The driver should be equivalent on all variants of linux and perhaps BSD (haven't tested it).First of all, you need to download the latest source of the emu10k1 driver.This driver is supported by Creative, for open-source operating sytems.It seems the latest driver in kernel 2.4.21 at this time, the audigy 2 soundcard is NOT supported. Therefor, you need to download it manually.Here's a short description of how to download it via CVS:$ cd /tmp$ cvs -d:pserver:anonymous@cvs.sourceforge.net:/cvsroot/emu10k1 login $ cvs -z3 -d:pserver:anonymous@cvs.sourceforge.net:/cvsroot/emu10k1 co emu10k1$ su# cd emu10k1/# make# make installWhen you're done with this, presuming it didn't cause any problems, you should do the following:# rm /lib/modules//kernel/drivers/sound/emu10k1/emu10k1.o# mv emu10k1.o /lib/modules//kernel/drivers/sound/emu10k1/emu10k1.oAfter this, you removed the old version of the emu10k1 driver, and replaced it with the new, compiled one.If, you are using mandrake, you need to edit /etc/modules.conf with your favorite editor, this being of course, emacs. :-)You need to remove all the lines containing anything about sound, or with the emu10k1 line in it. Then, you need to add the following line:alias sound emu10k1Run /sbin/lsmod and see if ``snd-emu10k1'' is probed. If it is, you need to do# rmmod snd-emu10k1If it won't allow you to do this because it is in use, close all programs using it.To see a list of programs using it, do:# lsof | grep dspAfter this is done, you need to probe the newly compiled module;# modprobe emu10k1This will load the compiled driver into the memory, so you can use it.Now, see if your user is added to the 'audio' group in /etc/group.If it is not, do so.Now, you may need to reboot, for everything to function, but try it out.Start up xmms and put on your favorite tune. You should hear sound!It worked for me anyways, and as I said, I tried a lot of stuff before this.I hope this helped you out, you are welcome to send me comments.Jesper Nøhr, Sunday, September 28 2003, 00:38 am. Page here:http://guides.printf.dk/audigy2.htm Quote
ross549 Posted October 12, 2003 Author Posted October 12, 2003 [adam@ip68-10-250-190 adam]$ rpm -qa | grep -i alsalibalsa2-0.9.0-0.14rc7mdklibalsa-data-0.9.0-0.14rc7mdkalsa-utils-0.9.0-0.8rc7mdkxmms-alsa-0.9.7-3mdk Were they that way before you started the XMMS test. ie. had you allready installed the alsa upgrades.Also which, mirror did you use. You seem to have different versions than I do. Those came of disc 3 Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 Fran:Just finished reading your comments. Got to think about them for a bit. Also need to do some testing in the console.PS: Thanks for jumping in. I am a novice with the Drake and was feeling uncomfortable about proceeding. Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 My pleasure Owyn, just hope some of it helps LOL! :)I don't have an Audigy 2 card ... or any of the Audigy series for that matter so I was trying to see what others have come up with that might help. Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 Ross:I am starting to poop out. Thanks for sticking with me this far. I did say at the beginning it would be slow and easy. I was checking out a lot of other things for myself at the same time.If you don't mind I will call it a night and get back to this tomorrow. Can think better after some sleep and a good workout.Fran:You are more than welcome to carry on the second shift. You seem to have been there and done that with this type of problem. Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 Owyn,Have a great night! Rest and a workout is always a good restorative.And you are right, I have had my share of audio problems over the years with Linux, but not with the Audigy 2.My problems were usually related to IRQ conflicts with LAN and modem .. and nearly always one of these cards decided not to be cooperative with changing IRQs.ross549,At least you are not having that problem ... IRQ conflicts. There often are little things to cause a wrinkle in an otherwise perfect install. If we can't get it going, perhaps Bruno will be back in time to help overnight Quote
ross549 Posted October 12, 2003 Author Posted October 12, 2003 I have been going on this for about 8 hrs. Gonna crash out on this project for the time being. I'll pick it back up in the morning.... um, afternoon. Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 You are a real trooper ross549!Great idea ... fresh minds and eyes are needed for this ... and maybe a few other Linux minds as well. Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 Good morning . . . . . you three have been busy ! I have just a few questions: What does your "/etc/modules.conf" look like ? $ cat /etc/modules.conf ( For the sound there sould only be the line: "alias sound-slot-0 emu10k1", leave eth0 and USB as they are ) Has the mobo on board sound and is it disabled if you are using a PCI card ( Mandrake can´t handle two cards at the same time ) You can start the alsa-mixer by typing "alsamixer" in a console. The quote that Fran posted from http://guides.printf.dk/audigy2.htm looks like the most logic to me. Also interesting: Ok, here is what I have done after compiling again and again and trying diffent combinations, downloading cvs. It was much simpler than I thought.I have open the modules.conf and remove all the entrys of sound (audigy, emu10k1, and the post-install command of the script).Then I have run the the mcc and then I have gone to hardware devices--> Run Configuration. The default driver was the snd-audigy. Choose Let me pick a driver and choose the emu10k1.Quit the mcc and go at the modules.conf and check that the only sound entry is:alias sound-slot-0 emu10k1rebootsolved with 5.1 surround.You might don't need to go through the mcc, but just removing all the sound lines and just adding the alias sound-slot-0 emu10k1 line, works.Ahh! Something else do not try to use the drivers from www.opensound.com/. It DOESN'T work if you DON'T PAY. More accuretly, the trial version works only for 3 hours the first week and then you have to do soundoff and then soundon back again, after the firtst week your soundcard will be blocked for 20min before you can do soundon again. I can NOT understand why this oss is posted as a soloution in some forums (at least at this forum it was posted just once i think). Bruno Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 Good morning Bruno! So glad you are back to help with this LOL!I wish I had experience with Audigy 2 so I could have helped more last night. Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 Bruno,Is this alsa-project October 10, 2003 .tar.bz2 file a later version than included with the stock Mandrake? Could it be of help if it is?alsa-driver-0.9.7b.tar.bz2 Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 Hi allI spent a bit of time this morning trying to recap what had happened and what to do next. Unfortunately I am running out of time and will be gone shortly until late afternoon.One thing I did do was to take all the Mandrake Sound Trouble Shooting Tips and implement them as a shell script. This gives a better and quicker way to get all the sound info in one step.To implement the script:1)Select all the text in the code block at the end of this message. Copy the text.2)In a console type the command "vi mdksoundchk.sh"3)In vi- Press "I" (without the quotes) to go to insert mode- Select Edit->Paste from the console menu- Press "ZZ" to save the new file4)In the console type the command "chmod 755 mdksoundchk.sh"5)Just su and then type "./mdksoundchk.sh" to run the script. The results from the check can be selected and copied into a message quote or code block.I am still confused by why some things, aumix in particular, work on my system but don't on Adams. I also tested the "alsamixer". Seems to work the same as aumix when Alsa modules are loaded. Just Use <- and -> to select control and Up and Down Arrows to adjust level. Press Esc to exit.The script: #!/bin/shecho mdksoundchk.sh - Run all Mandrake Sound Trouble Shooting tipsechoecho Checking Driverlspcidrake -v | fgrep AUDIOechoecho Checking Actual Driver in Usegrep sound-slot /etc/modules.confechoecho Checking Modulescat /etc/modules.confechoecho Checking if Module Loaded/sbin/lsmodechoecho Checking if services configured to be run on initlevel 3echo Checking if Sound services configured/sbin/chkconfig --list soundechoecho Checking if Alsa service configured/sbin/chkconfig --list alsaechoecho Checking if Sound Volume mutedaumix -qechoecho Checking which program uses the sound card/sbin/fuser -v /dev/dspechoecho End of Checks Quote
teacher Posted October 12, 2003 Posted October 12, 2003 Nice script Owyn. I just ran it on my machine (I have yet to configure my sound That put together a lot of the things I was messing with on mine last night. Now I just have to figure out why also is off for 1, 2, and 6. That could be why mine does not work. Between that and the article I am looking at I should have some good ideas......Now if we can get Ross549 up and running so he can have "joy"! We want him to be a happy penguin. Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 Now I just have to figure out why also is off for 1, 2, and 6. That could be why mine does not work.Those are initlevels Julia. 3 and 5 are the key ones. Quote
teacher Posted October 12, 2003 Posted October 12, 2003 Thanks! I had not gotten that far in my reading yet to decode it all. I figure this is all practice anyway since the new release is around the corner. <<with a look of longing in the eyes >> Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 >>I hear ya Julia! With the alsa project working on these issues, the next version sounds better all the time LOL! Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 Bruno,Is this alsa-project October 10, 2003 .tar.bz2 file a later version than included with the stock Mandrake? Could it be of help if it is?alsa-driver-0.9.7b.tar.bz2 Fran, this looks indeed like a driver that is the most fresh you can get . . . and not yet in Mandrake.Owyn, Nice script, will run it on my second computer, that has weird reactions on the RC2 and sound, that are filed as a bug and fixed in the cooker for the final. Bruno Quote
Guest LilBambi Posted October 12, 2003 Posted October 12, 2003 Cool! Could be of help then! Yeah! Quote
ross549 Posted October 12, 2003 Author Posted October 12, 2003 Now if we can get Ross549 up and running so he can have "joy"! We want him to be a happy penguin. I am NOT a penguin!!!!!!!! I just decided to stop cleaning my windows all the time. Quote
ross549 Posted October 12, 2003 Author Posted October 12, 2003 5)Just su and then type "./mdksoundchk.sh" to run the script. mdksoundchk.sh - Run all Mandrake Sound Trouble Shooting tipsChecking Driveraudigy : Creative Labs|EMU10K2 Audigy Audio Processor [MULTIMEDIA_AUDIO] (vendor:1102 device:0004 subv:1102 subd:1002)Checking Actual Driver in Usealias sound-slot-1 audigyalias sound-slot-0 audigyChecking if Module LoadedModule Size Used by Not taintedisofs 27988 1 (autoclean)zlib_inflate 21156 0 (autoclean) [isofs]udf 90464 0 (autoclean)snd-pcm-oss 43556 1snd-mixer-oss 14488 0 [snd-pcm-oss]snd-emu10k1 69268 5snd-rawmidi 17600 0 [snd-emu10k1]snd-pcm 77536 0 [snd-pcm-oss snd-emu10k1]snd-timer 18376 0 [snd-pcm]snd-page-alloc 7732 0 [snd-emu10k1 snd-pcm]snd-util-mem 3008 0 [snd-emu10k1]snd-ac97-codec 40160 0 [snd-emu10k1]snd-seq-device 5832 0 [snd-emu10k1 snd-rawmidi]snd-hwdep 6368 0 [snd-emu10k1]snd 40868 4 [snd-pcm-oss snd-mixer-oss snd-emu10k1 snd-rawmidi snd-pcm snd-timer snd-util-mem snd-ac97-codec snd-seq-device snd-hwdep]sg 34636 0 (autoclean)lp 8096 0 (autoclean) (unused)parport 34176 0 (autoclean) [lp]radeon 107428 0ipt_TOS 1592 12 (autoclean)ipt_LOG 4280 5 (autoclean)ipt_REJECT 3640 4 (autoclean)ipt_state 1080 10 (autoclean)iptable_mangle 2712 1 (autoclean)ip_nat_irc 3280 0 (unused)ip_nat_ftp 4016 0 (unused)iptable_nat 21048 2 [ip_nat_irc ip_nat_ftp]ip_conntrack_irc 4304 1ip_conntrack_ftp 5200 1ip_conntrack 27264 4 [ipt_state ip_nat_irc ip_nat_ftp iptable_nat ip_conntrack_irc ip_conntrack_ftp]iptable_filter 2348 1 (autoclean)ip_tables 14648 9 [ipt_TOS ipt_LOG ipt_REJECT ipt_state iptable_mangle iptable_nat iptable_filter]ac97_codec 12488 0sound 70644 0soundcore 6276 0 [snd sound]nfsd 74256 0 (autoclean)af_packet 14952 1 (autoclean)sr_mod 16920 2 (autoclean)floppy 55132 08139too 17160 1 (autoclean)mii 3832 0 (autoclean) [8139too]ohci1394 19048 0 (unused)ieee1394 45900 0 [ohci1394]nls_iso8859-1 3516 3 (autoclean)ntfs 76812 2 (autoclean)supermount 15296 2 (autoclean)ide-cd 33856 0cdrom 31648 0 [sr_mod ide-cd]ide-scsi 11280 1scsi_mod 103284 3 [sg sr_mod ide-scsi]printer 8448 0 (unused)usb-ohci 20584 0 (unused)usbcore 72992 1 [printer usb-ohci]rtc 8060 0 (autoclean)ext3 59916 2jbd 38972 2 [ext3]Checking if services configured to be run on initlevel 3Checking if Sound services configuredsound 0:off 1:off 2:on 3:on 4:on 5:on 6:offChecking if Alsa service configuredalsa 0:off 1:off 2:on 3:on 4:on 5:on 6:offChecking if Sound Volume mutedvol 100, 100, Pbass 100, 100treble 100, 100pcm 100, 100speaker 100, 100line 100, 100, Pmic 100, 100, Rcd 100, 100, Pigain 100, 100line1 100, 100, Pphin 100, 100, Pvideo 100, 100, PChecking which program uses the sound card USER PID ACCESS COMMAND/dev/dsp 2713 f.... artsd 2714 f.... artsdEnd of Checks Nifty script!! Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 Hi RossJust to have the complete info, would you post the outcome of:cat /etc/modules.confB) Bruno Quote
ross549 Posted October 12, 2003 Author Posted October 12, 2003 [root@ip68-10-250-190 ]# cat /etc/modules.confprobeall scsi_hostadapter ide-scsialias sound-slot-1 audigyalias eth0 8139tooabove snd-intel8x0 snd-pcm-ossalias sound-slot-0 audigyprobeall usb-interface usb-ohcialias ieee1394-controller ohci1394above snd-emu10k1 snd-pcm-oss Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 Ross,We will wait for Owyn to check in and look at the outcome of his script . . . . but I see here that there are a few lines too many: probeall scsi_hostadapter ide-scsialias sound-slot-1 audigyalias eth0 8139tooabove snd-intel8x0 snd-pcm-ossalias sound-slot-0 audigyprobeall usb-interface usb-ohcialias ieee1394-controller ohci1394above snd-emu10k1 snd-pcm-oss The RED lines will have to go, the BLUE lines are the correct ones.OR: according to the post on LQ the only line should be: alias sound-slot-0 emu10k1 ( and NOT audigy )This came out of Owyns script too:Checking Actual Driver in Usealias sound-slot-1 audigyalias sound-slot-0 audigy.....snd-emu10k1 69268 5:'( Bruno Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 Just to have the complete info, would you post the outcome of:cat /etc/modules.confI edited the post in case anyone grabs the script in the future. Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 We will wait for Owyn to check in and look at the outcome of his script .Just got back. Made some visits, 30k on the bike, 2 hours at the gym. I really need some carbs and protein before I look at this in detail.Bruno. Looks like you are right on. Could you post instructions on which files should be edited while I handle body chores.Ross: Also noticed that you have artsd running twice. That seems strange. Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 RossIn a console:$ su< password ># vi /etc/modules.conf ( will open modules.conf in the vi-editor )i ( to put vi in "insert' mode )These are the lines in modules.conf as they should be: ( no more, no less )-----------------------------------------probeall scsi_hostadapter ide-scsialias eth0 8139tooalias sound-slot-0 emu10k1probeall usb-interface usb-ohcialias ieee1394-controller ohci1394above snd-emu10k1 snd-pcm-oss-----------------------------------------Esc ( to put vi back in command-mode )ZZ ( to safe the file, two capital Z :'( )Then to load the new modules either reboot ( I like that better to be sure that the old modules are gone ) or# depmod -aB) Bruno Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 Ross: Also noticed that you have artsd running twice. That seems strange. Owyn, could this be because it loaded "sound-slot-1 audigy" AND "sound-slot-0 audigy" ??:'( Bruno Quote
ross549 Posted October 12, 2003 Author Posted October 12, 2003 These are the lines in modules.conf as they should be: ( no more, no less )-----------------------------------------probeall scsi_hostadapter ide-scsialias eth0 8139tooalias sound-slot-0 emu10k1probeall usb-interface usb-ohcialias ieee1394-controller ohci1394above snd-emu10k1 snd-pcm-oss----------------------------------------- Bruno [root@ip68-10-250-190 adam]# cat /etc/modules.confprobeall scsi_hostadapter ide-scsialias eth0 8139tooalias sound-slot-0 emu10k1probeall usb-interface usb-ohcialias ieee1394-controller ohci1394above snd-emu10k1 snd-pcm-oss Hehe- my first self-generated command in the console.... this feels so good!! :'( Quote
Owyn Posted October 12, 2003 Posted October 12, 2003 Ross: Also noticed that you have artsd running twice. That seems strange. Owyn, could this be because it loaded "sound-slot-1 audigy" AND "sound-slot-0 audigy" ??Yep. Just what I was thinking while I made supper. Quote
Bruno Posted October 12, 2003 Posted October 12, 2003 Good stuff Ross !!. . . . and do you have sound now ?? ( well, that is what we were after in the first place . . :'( ) Bruno Quote
