It's a cute way to get CPU speed information. Super-pi is a free program (about 80 K Zip file)to calculate Pi to Millions of digits1) download Super_Pi from ftp://pi.super-computing.org/Linux/super_pi.tar.gz orhttp://superpi.ilbello.com/ (windows and Linux)2)Type in Terminal as user ./super_pi 20which runs the program to measure the time it takes to calculate pi to 1 million digits 3) Pi.dat file is created in superpi directory. which contains the million digits of Pisuperpium5.th.pngHere are my resultsfor Mandriva 2008:pi to 1 million digitsDesktop Intel P4, 1 GB RAM, 2Ghz ---------------66 SecAcer Laptop Pentium duel Core 32bit 1GB ram ---30 SecI am curious to know whether different distros give different results ? Many ATL members are having multiple distros installed.(some have 2 dozen distros per hard disk !)
  • Replies 79
  • Anil
    18
  • Bruno
    14
  • tommyj12
    7
here's mine, mandriva 2008, p4-3Ghz, 1gb ram.
[steve@localhost Download]$ ./super_pi 20 Version 2.0 of the super_pi for Linux OS Fortran source program was translated into C program with version 19981204 of f2c, then generated C source program was optimized manually. pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minline=size:1000 -Mnoframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used for the compilation. ------ Started super_pi run : Fri Dec 14 10:59:19 EST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.494 Sec. I= 1 L= 0 Time= 1.570 Sec. I= 2 L= 0 Time= 1.809 Sec. I= 3 L= 1 Time= 1.813 Sec. I= 4 L= 2 Time= 1.810 Sec. I= 5 L= 5 Time= 1.805 Sec. I= 6 L= 10 Time= 1.805 Sec. I= 7 L= 21 Time= 1.798 Sec. I= 8 L= 43 Time= 1.801 Sec. I= 9 L= 87 Time= 1.802 Sec. I=10 L= 174 Time= 1.800 Sec. I=11 L= 349 Time= 1.806 Sec. I=12 L= 698 Time= 1.796 Sec. I=13 L= 1396 Time= 1.798 Sec. I=14 L= 2794 Time= 1.798 Sec. I=15 L= 5588 Time= 1.787 Sec. I=16 L= 11176 Time= 1.785 Sec. I=17 L= 22353 Time= 1.799 Sec. I=18 L= 44707 Time= 1.711 Sec. I=19 L= 89415 Time= 1.617 Sec. End of main loop End of calculation. Time= 35.628 Sec. End of data output. Time= 0.192 Sec. Total calculation(I/O) time= 35.820( 1.152) Sec. ------ Ended super_pi run : Fri Dec 14 10:59:55 EST 2007[steve@localhost Download]$
Here is mine on Arch Linux with CoreDuo T2250@1.73ghz with 2.066gb of ram:
[comhack@DarkStar ~]$ ./super_pi 20 Version 2.0 of the super_pi for Linux OS Fortran source program was translated into C program with versi f2c, then generated C source program was optimized manually. pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minlframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used compilation. ------ Started super_pi run : Fri Dec 14 11:22:30 EST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time=	   0.370 Sec. I= 1 L=	   0		Time=	   1.203 Sec. I= 2 L=	   0		Time=	   1.397 Sec. I= 3 L=	   1		Time=	   1.390 Sec. I= 4 L=	   2		Time=	   1.387 Sec. I= 5 L=	   5		Time=	   1.417 Sec. I= 6 L=	  10		Time=	   1.400 Sec. I= 7 L=	  21		Time=	   1.393 Sec. I= 8 L=	  43		Time=	   1.397 Sec. I= 9 L=	  87		Time=	   1.393 Sec. I=10 L=	 174		Time=	   1.400 Sec. I=11 L=	 349		Time=	   1.430 Sec. I=12 L=	 698		Time=	   1.393 Sec. I=13 L=	1396		Time=	   1.413 Sec. I=14 L=	2794		Time=	   1.397 Sec. I=15 L=	5588		Time=	   1.387 Sec. I=16 L=   11176		Time=	   1.377 Sec. I=17 L=   22353		Time=	   1.400 Sec. I=18 L=   44707		Time=	   1.317 Sec. I=19 L=   89415		Time=	   1.237 Sec. End of main loop End of calculation.	Time=	  27.585 Sec. End of data output.	Time=	   0.153 Sec. Total calculation(I/O) time=	  27.738(1.050) Sec. ------ Ended super_pi run : Fri Dec 14 11:22:59 EST 2007
27.738 seconds not too badThanks
@ Steve -- 3 Gzh makes the difference ! 35 sec for P4 is one of the Topmost result on Net@ Securitybreach -- Is it a Laptop or Desktop ? Also if you multiboot, have you tried it with Windows ?Thanks :thumbsup:
Edited by Anil
Main system: 2188MHz, 2GB RAM:
$ uname -aLinux saturn 2.6.22.12-desktop-1mdv #1 SMP Tue Nov 20 08:38:27 EST 2007 i686 AMD Athlon(tm) XP 2700+ GNU/Linux$ free			 total	   used	   free	 shared	buffers	 cachedMem:	   2076160	 407148	1669012		  0	  19132	 204736-/+ buffers/cache:	 183280	1892880Swap:	  4618648		  0	4618648 ------ Started super_pi run : Fri Dec 14 19:09:11 CET 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time=	   0.615 Sec. I= 1 L=	   0		Time=	   1.939 Sec. I= 2 L=	   0		Time=	   2.219 Sec. I= 3 L=	   1		Time=	   2.206 Sec. I= 4 L=	   2		Time=	   2.225 Sec. I= 5 L=	   5		Time=	   2.209 Sec. I= 6 L=	  10		Time=	   2.205 Sec. I= 7 L=	  21		Time=	   2.226 Sec. I= 8 L=	  43		Time=	   2.201 Sec. I= 9 L=	  87		Time=	   2.221 Sec. I=10 L=	 174		Time=	   2.198 Sec. I=11 L=	 349		Time=	   2.223 Sec. I=12 L=	 698		Time=	   2.200 Sec. I=13 L=	1396		Time=	   2.223 Sec. I=14 L=	2794		Time=	   2.212 Sec. I=15 L=	5588		Time=	   2.210 Sec. I=16 L=   11176		Time=	   2.194 Sec. I=17 L=   22353		Time=	   2.165 Sec. I=18 L=   44707		Time=	   2.128 Sec. I=19 L=   89415		Time=	   1.942 Sec. End of main loop End of calculation.	Time=	  43.734 Sec. End of data output.	Time=	   0.183 Sec. Total calculation(I/O) time=	  43.917(	   1.453) Sec. ------ Ended super_pi run : Fri Dec 14 19:09:56 CET 2007
B) BrunoPS: Same result in runlevel 3 :thumbsup:
33.135 secondsSlackware 12 with Boinc client runningAMD 64x2 4400+2gb ram
@ Steve -- 3 Gzh makes the difference ! 35 sec for P4 is one of the Topmost result on Net@ Securitybreach -- Is it a Laptop or Desktop ? Also if you multiboot, have you tied it with Windows ?Thanks :thumbsup:
Its a Toshiba Satellite S105-4114 Laptop. I do not use Windows at all.THanks
Test System: AMD Athlon XP 1700+ = 1100MHz, 1GB RAM:Mandriva: 94.1 secSlackware: 93.9 secDebian: 93,8PCLos: 91.9 secVectorLinux: 94.2 secKubuntu: 90,7Fedora 94,8 secSuSE 90,4B) Bruno
On my AMD Athlon 64 3800+ running Slackware 12:
------ Started super_pi run : Fri Dec 14 14:55:23 EST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.424 Sec. I= 1 L= 0 Time= 1.324 Sec. I= 2 L= 0 Time= 1.516 Sec. I= 3 L= 1 Time= 1.508 Sec. I= 4 L= 2 Time= 1.516 Sec. I= 5 L= 5 Time= 1.520 Sec. I= 6 L= 10 Time= 1.516 Sec. I= 7 L= 21 Time= 1.512 Sec. I= 8 L= 43 Time= 1.520 Sec. I= 9 L= 87 Time= 1.508 Sec. I=10 L= 174 Time= 1.516 Sec. I=11 L= 349 Time= 1.520 Sec. I=12 L= 698 Time= 1.432 Sec. I=13 L= 1396 Time= 1.416 Sec. I=14 L= 2794 Time= 1.504 Sec. I=15 L= 5588 Time= 1.504 Sec. I=16 L= 11176 Time= 1.508 Sec. I=17 L= 22353 Time= 1.488 Sec. I=18 L= 44707 Time= 1.444 Sec. I=19 L= 89415 Time= 1.340 Sec. End of main loop End of calculation. Time= 29.730 Sec. End of data output. Time= 0.160 Sec. Total calculation(I/O) time= 29.890( 0.896) Sec. ------ Ended super_pi run : Fri Dec 14 14:55:54 EST 2007
Here's mine. Core2Duo E6400 (OC to 2.44GHz) 2Gb RAM Debian Testing/Sid Sunrat Special brand :thumbsup: roger@brain:~/bin/super_pi$ ./super_pi 20 Version 2.0 of the super_pi for Linux OS Fortran source program was translated into C program with version 19981204 of f2c, then generated C source program was optimized manually. pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minline=size:1000 -Mnoframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used for the compilation. ------ Started super_pi run : Sat Dec 15 07:05:31 EST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.260 Sec. I= 1 L= 0 Time= 0.852 Sec. I= 2 L= 0 Time= 1.012 Sec. I= 3 L= 1 Time= 1.032 Sec. I= 4 L= 2 Time= 1.004 Sec. I= 5 L= 5 Time= 1.016 Sec. I= 6 L= 10 Time= 0.992 Sec. I= 7 L= 21 Time= 0.984 Sec. I= 8 L= 43 Time= 0.988 Sec. I= 9 L= 87 Time= 1.012 Sec. I=10 L= 174 Time= 1.028 Sec. I=11 L= 349 Time= 0.992 Sec. I=12 L= 698 Time= 1.012 Sec. I=13 L= 1396 Time= 0.984 Sec. I=14 L= 2794 Time= 0.960 Sec. I=15 L= 5588 Time= 0.976 Sec. I=16 L= 11176 Time= 0.976 Sec. I=17 L= 22353 Time= 0.956 Sec. I=18 L= 44707 Time= 0.936 Sec. I=19 L= 89415 Time= 0.884 Sec. End of main loop End of calculation. Time= 19.613 Sec. End of data output. Time= 0.104 Sec. Total calculation(I/O) time= 19.717( 0.612) Sec. ------ Ended super_pi run : Sat Dec 15 07:05:51 EST 2007roger@brain:~/bin/super_pi$
Well, SecurityBreach (27.738) and I (29.890) were both looking pretty good till Sunrat (19.717) posted. :thumbsup:
sunrat is definitely flying.Mine on a Intel Core2 duo 3 Ghz with 2 Gb of DDR2;
End of main loop End of calculation.	Time=	  30.838 Sec. End of data output.	Time=	   0.178 Sec. Total calculation(I/O) time=	  31.016(	   1.070) Sec. ------ Ended super_pi run : Fri Dec 14 17:42:51 AST 2007[rejean@localhost super_pi]$
Not bad, even if a bit slower than Eric and securitybreach.Oops! I forgot to say that I was in Mandriva. Now from Linux Mint; a tad faster:
 End of main loop End of calculation.	Time=	  30.254 Sec. End of data output.	Time=	   0.180 Sec. Total calculation(I/O) time=	  30.434(	   0.984) Sec.
much slower in Fedora Core 6
 End of main loop End of calculation.	Time=	  39.478 Sec. End of data output.	Time=	   0.273 Sec. Total calculation(I/O) time=	  39.751(	   1.610) Sec.
so far PCLinuxOS 2007 is the winner;
End of main loop End of calculation.	Time=	  29.618 Sec. End of data output.	Time=	   0.180 Sec. Total calculation(I/O) time=	  29.798(	   0.828) Sec.
on my machine that is.and in Slackware 12;
End of main loop End of calculation.	Time=	  29.570 Sec. End of data output.	Time=	   0.180 Sec. Total calculation(I/O) time=	  29.750(	   0.908) Sec.
Edited by réjean
LOL...well it's a Gateway!Started super_pi run : Fri Dec 14 17:50:21 EST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.331 Sec. I= 1 L= 0 Time= 1.020 Sec. I= 2 L= 0 Time= 1.169 Sec. I= 3 L= 1 Time= 1.167 Sec. I= 4 L= 2 Time= 1.168 Sec. I= 5 L= 5 Time= 1.166 Sec. I= 6 L= 10 Time= 1.165 Sec. I= 7 L= 21 Time= 1.174 Sec. I= 8 L= 43 Time= 1.170 Sec. I= 9 L= 87 Time= 1.174 Sec. I=10 L= 174 Time= 1.174 Sec. I=11 L= 349 Time= 1.167 Sec. I=12 L= 698 Time= 1.163 Sec. I=13 L= 1396 Time= 1.165 Sec. I=14 L= 2794 Time= 1.163 Sec. I=15 L= 5588 Time= 1.161 Sec. I=16 L= 11176 Time= 1.156 Sec. I=17 L= 22353 Time= 1.139 Sec. I=18 L= 44707 Time= 1.102 Sec. I=19 L= 89415 Time= 1.042 Sec. End of main loop End of calculation. Time= 23.035 Sec. End of data output. Time= 0.133 Sec. Total calculation(I/O) time= 23.168( 0.681) Sec. ------ Ended super_pi run : Fri Dec 14 17:50:45 EST 2007[barryb@Core2BoxHave to try a few more systems
Well, SecurityBreach (27.738) and I (29.890) were both looking pretty good till Sunrat (19.717) posted. :hysterical:
Yes It's quite impressive!But I think your results are without Overclocking Eric ?
Thanks Bruno ! I knew PCLos gives better timing than Mandriva but Suse is a surprise for me.
Funny that my OpenSUSE is slower than Mandy, Linux Mint and PCLos but faster than Fedora;
 End of main loop End of calculation.	Time=	  33.666 Sec. End of data output.	Time=	   0.200 Sec. Total calculation(I/O) time=	  33.866(	   1.344) Sec.
still on the same machine.Even slower in Debian /etch
 End of calculation.	Time=	  37.682 Sec. End of data output.	Time=	   0.184 Sec. Total calculation(I/O) time=	  37.866(	   1.068) Sec.
Edited by réjean
Thanks Rejean. Puppy Live CD, which runs in RAM, gives better timing on my machine than Mandriva2008.
Edited by Anil
OK, finally got round to testing my other installed distros. 64Studio is 64bit, others are 32bit. I expected the 2 studio distros to be fast, but the Sidux kernel, also the latest, was a pleasant surprise at just over a full second faster than lenny!Debian lenny/sidroger@brain:~$ uname -aLinux brain 2.6.22-3-686 #1 SMP Mon Nov 12 08:32:57 UTC 2007 i686 GNU/LinuxTotal calculation(I/O) time= 19.717( 0.612) Sec.Studio64 2.0Linux brain 2.6.21-1-multimedia-amd64 #1 SMP PREEMPT RT Fri Jun 22 00:00:33 UTC 2007 x86_64 GNU/Linux Total calculation(I/O) time= 19.004( 0.761) Sec.UbuntuStudio 7.10Linux brain 2.6.22-14-rt #1 SMP PREEMPT RT Mon Oct 15 01:05:51 GMT 2007 i686 GNU/LinuxTotal calculation(I/O) time= 18.782( 0.771) Sec.Sidux "eros"Linux brain-sidux 2.6.23.9-rc1-slh-smp-1 #1 SMP PREEMPT Tue Nov 20 19:33:34 UTC 2007 i686 GNU/LinuxTotal calculation(I/O) time= 18.693( 0.568) Sec.
That's correct, Anil. Clock speed on my system is 2411Mhz (stock speed, no tweaks). :)
OK, finally got round to testing my other installed distros. 64Studio is 64bit, others are 32bit. I expected the 2 studio distros to be fast, but the Sidux kernel, also the latest, was a pleasant surprise at just over a full second faster than lenny!Sidux "eros"Linux brain-sidux 2.6.23.9-rc1-slh-smp-1 #1 SMP PREEMPT Tue Nov 20 19:33:34 UTC 2007 i686 GNU/LinuxTotal calculation(I/O) time= 18.693( 0.568) Sec.
Great Timings Sunrat :)
Results so far :sperpi1ff6.pngP.S: Sorry, forgot to add Mlangdn's Result: AMD 64x2 4400+/2gb ram/33.135 seconds/Slackware 12
Edited by Anil
Very nice chart. Helps to compare the results better. Quick question--Do you have all the other distros you listed the Time(sec) on? If so you have quite a list of distros you tried it on. Wow I cannot believe the 90+ second ones.THanks
Edited by securitybreach
LOL..No I just have Mandriva ! Poor me B) As the chart tries to show-- Bruno tested for 8 distros, Sunrat 4 and Rejean 5. The difference in speed will be noticeable if we run ./super_pi 25 . It will do the calculation for 32 million digits of Pi :)
Intel Core2Duo 2000MHz, 2GB DDR ram, PCLinuxOS 2007
[frank@localhost ~]$ ./super_pi 20 Version 2.0 of the super_pi for Linux OS Fortran source program was translated into C program with version 19981204 of f2c, then generated C source program was optimized manually. pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minline=size:1000 -Mnoframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used for the compilation. ------ Started super_pi run : Sun Dec 16 08:43:21 PST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.292 Sec. I= 1 L= 0 Time= 0.848 Sec. I= 2 L= 0 Time= 0.968 Sec. I= 3 L= 1 Time= 0.968 Sec. I= 4 L= 2 Time= 0.972 Sec. I= 5 L= 5 Time= 0.964 Sec. I= 6 L= 10 Time= 0.964 Sec. I= 7 L= 21 Time= 0.968 Sec. I= 8 L= 43 Time= 0.968 Sec. I= 9 L= 87 Time= 0.968 Sec. I=10 L= 174 Time= 0.968 Sec. I=11 L= 349 Time= 0.964 Sec. I=12 L= 698 Time= 0.964 Sec. I=13 L= 1396 Time= 0.968 Sec. I=14 L= 2794 Time= 0.964 Sec. I=15 L= 5588 Time= 0.960 Sec. I=16 L= 11176 Time= 0.952 Sec. I=17 L= 22353 Time= 0.936 Sec. I=18 L= 44707 Time= 0.908 Sec. I=19 L= 89415 Time= 0.844 Sec. End of main loop End of calculation. Time= 19.053 Sec. End of data output. Time= 0.124 Sec. Total calculation(I/O) time= 19.177( 0.744) Sec. ------ Ended super_pi run : Sun Dec 16 08:43:40 PST 2007[frank@localhost ~]$
Same processor etc., Gutsy Gibbon Ubuntu (7.10)
Version 2.0 of the super_pi for Linux OS Fortran source program was translated into C program with version 19981204 of f2c, then generated C source program was optimized manually. pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minline=size:1000 -Mnoframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used for the compilation. ------ Started super_pi run : Sun Dec 16 08:33:29 PST 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.308 Sec. I= 1 L= 0 Time= 0.896 Sec. I= 2 L= 0 Time= 1.064 Sec. I= 3 L= 1 Time= 1.096 Sec. I= 4 L= 2 Time= 1.024 Sec. I= 5 L= 5 Time= 1.016 Sec. I= 6 L= 10 Time= 0.984 Sec. I= 7 L= 21 Time= 1.064 Sec. I= 8 L= 43 Time= 1.092 Sec. I= 9 L= 87 Time= 1.072 Sec. I=10 L= 174 Time= 1.060 Sec. I=11 L= 349 Time= 1.016 Sec. I=12 L= 698 Time= 1.020 Sec. I=13 L= 1396 Time= 1.020 Sec. I=14 L= 2794 Time= 1.012 Sec. I=15 L= 5588 Time= 1.020 Sec. I=16 L= 11176 Time= 1.004 Sec. I=17 L= 22353 Time= 0.948 Sec. I=18 L= 44707 Time= 0.960 Sec. I=19 L= 89415 Time= 0.852 Sec. End of main loop End of calculation. Time= 20.325 Sec. End of data output. Time= 0.132 Sec. Total calculation(I/O) time= 20.457( 0.792) Sec. ------ Ended super_pi run : Sun Dec 16 08:33:50 PST 2007frank@frank-laptop:~$
This may or may not be of interest but I ran Super Pi (win version) on XP pro,same proc etc. Got 26 sec!! I always knew Linux was faster. :) B) Edited by Frank Golden
This may or may not be of interest but I ran Super Pi (win version) on XP pro,same proc etc. Got 26 sec!! I always knew Linux was faster. hysterical.gif hysterical.gif
Thanks Frank for posting XP result. On some other forum, running the same thread , certain results were banned because of having Unfair Advantage(Read Linux OS) :) Edited by Anil
Those Core2Duo processors really do make a difference don't they ? Really impressive !I am a bit worried about Réjeans results . . . . it looks like only one core of the C2D is giving the horsepower shown . . . . . ( ?? )
The 90+ second ones are on my test-system that has only 1 GHz CPU and 1 GB RAM . . . it is the system with the most distros installed so I could compare the difference between distros in a fair way.My faster 2.2 GHz CPU and 2 GB RAM system only has Mandriva installed ( and the 23 other distros running in VirtualBox ) so I was not able to compare the difference between distros on that one.
Goes to show how Windows makes use of ( wastes ) your CPU cycles :) B) Bruno
Nice chart, Anil! :)By the way, my processor (AMD Athlon 64 3800+) is a single core processor. Also, I'm running 2Gig of RAM on my system. :)
Acer 6465WLMi laptop - Core 2 Duo T7200 2 GHz - 2gig RAM - Mandriva 2008 64 bit./super_pi 20 Version 2.0 of the super_pi for Linux OS Fortran source program was translated into C program with version 19981204 of f2c, then generated C source program was optimized manually. pgcc 3.2-3 with compile option of "-fast -tp px -Mbuiltin -Minline=size:1000 -Mnoframe -Mnobounds -Mcache_align -Mdalign -Mnoreentrant" was used for the compilation. ------ Started super_pi run : Sun Dec 16 21:24:10 CET 2007 Start of PI calculation up to 1048576 decimal digits End of initialization. Time= 0.323 Sec. I= 1 L= 0 Time= 0.857 Sec. I= 2 L= 0 Time= 0.980 Sec. I= 3 L= 1 Time= 0.973 Sec. I= 4 L= 2 Time= 0.977 Sec. I= 5 L= 5 Time= 0.973 Sec. I= 6 L= 10 Time= 0.977 Sec. I= 7 L= 21 Time= 0.970 Sec. I= 8 L= 43 Time= 0.983 Sec. I= 9 L= 87 Time= 0.980 Sec. I=10 L= 174 Time= 0.970 Sec. I=11 L= 349 Time= 0.980 Sec. I=12 L= 698 Time= 0.980 Sec. I=13 L= 1396 Time= 0.977 Sec. I=14 L= 2794 Time= 0.963 Sec. I=15 L= 5588 Time= 0.963 Sec. I=16 L= 11176 Time= 0.960 Sec. I=17 L= 22353 Time= 0.937 Sec. I=18 L= 44707 Time= 0.903 Sec. I=19 L= 89415 Time= 0.843 Sec. End of main loop End of calculation. Time= 19.209 Sec. End of data output. Time= 0.130 Sec. Total calculation(I/O) time= 19.339( 0.697) Sec. ------ Ended super_pi run : Sun Dec 16 21:24:30 CET 2007
I ran gkrellm at the same time as super_pi, and the CPU use was 100% for one core only with the other almost idle. So super_pi runs only a single thread anyway.Maybe Rejean's comp has frequency scaling active. I would have expected to see times similar to Frank's. Instead it seems more like a 1.5GHz CPU. Exactly which model CPU is it, Rejean?I also ran superpi on WinXP and got 24seconds. Thats about 30% slower! :P :thumbsup: Not sure how similar the Win version is to Linux version though, could be a different program.Might try it in VBox. Will post results soon. o:) :D
I'm not going to speculate, but what do you make of these figures from Sidux in VirtualBox?
Total calculation(I/O) time=	  12.020(	   0.605) Sec. ------ Ended super_pi run : Tue Dec 18 01:15:04 EST 2007roger@siduxbrain:~/super_pi$
:thumbsup: :D o:)
