As Bruno, and now the rest of you are aware, I have joined the mklivecd and PcLinuxOs projects.There are still a lot of hardware and configuration issues that need to be shaken out to get the PcLInuxOs distro past preview status and get the mklivecd project to 1.0 status.Some background.
PCLinuxOS is a community based non-profit distribution initially based on Mandrake Linux. Just think of it as Mandrake Linux enhanced by Texstar on a single bootable live CD with 1.5GB of desktop applications and the ability to install right to your hard drive with everything ready to work out of the box. NVIDIA drivers, Flash, Java, urpmi setup, and of course all the cool application updates by Texstar. And if we get all the bugs out of the mklivecd program then YOU can make your own Mandrake-style bootable CD as well.
Texstar is the developer and packager for PcLinuxOs. But, he depends on the mklivecd project for the authoring scripts and hardware detection. He also depends on the community, both within and without the project, to test as many configurations as possible.eg: A problem with Toshiba laptops was finally identified as not being able to support resolutions of 1024x768x24, the max depth they can handle is 1024x768x16. The result of tracking this down is that the default depth has been changed from 24bit to 16bit. This will let older systems boot and still allow other users to change there resolutions to whatever there systems can handle. In this case, the change has been implemented in the mklivecd project and passed on to the PcLinuxOs project.What I would like to do is to enlist the support of the forum for ongoing tests of the distro. I want to get the pieces in place before Preview 4 is ready for testing.What I need from the forum is a list volunteers and specific details for available test systems. A sample hardware spec follows. It was created from manuals and by checking Mandrake MCC->Hardware->"HardDrake" and "Configure Your Monitor".
Identification: Owyn - Linux DesktopManufacturer: White BoxModel: DesktopMotherboard: Asus A7V-ECPU: Duron 850RAM: 256MBVideo: nVidia TNT Riva2 Model 64Monitor: Plug 'n Play (Royal Information Company TRL/RIC DH-1764M/DH-1764)Sound: Creative Sound Blaster 16 PCI (snd-ens1371)NIC: DLink DFE-538TX 10/100 Wired Ethernet (8039too)Modem: External Serial V.90 Cdrom(Primary): LG CD-ROM CRD-8522BCdrom(Secondary): NoneMouse: Logitech PS2 Wheel Mouse (psaux)Printer: HP DeskJet 720C (Local, Parallel Port)Other: Onstream DI-30 IDE Tape drive (needs ide-scsi osst)Comments: Connects via router to Internet. Uses KVM switch for Video/Keyboard/Mouse
What I will do is co-ordinate the testing of a new release by announcing it as a new topic, then, consolidate the test results for reporting back to the project mailing lists. I am working on a specific test plan that should cover most of the major issues without requiring a lot of time to test. This test plan may change from release to release depending on what has changed.I may also enlist specific volunteers to test hardware specific issues (eg. A new Sis driver may solve a specific problem. Need to pretest it before it gets included in the next release.). I will also try to expedite solving any problems that are determined. (eg: We are working on a real list of cheatcodes for the distro.)Hope you can help to build what may be one of the best out-of-the box distros available.
  • Replies 71
  • Owyn
    28
  • teacher
    10
  • Bruno
    6
  • mike180
    4
I got about 8 hours before it is downloaded - I'll see what happens here
Sounds great. Do I assume correctly that you want us to PM you with our hardware details or do you want it posted here?
Probably best to post them on the forum. That way you won't need to re-enter details in test reports. Just your system identifications.I will be entering them into a database for reporting purposes. Might be a spreadsheet. Might be XML. Got to decide (soon).
OwynWhat if we post you:
[bruno:~]$ lspci00:00.0 Host bridge: Silicon Integrated Systems [siS] 735 Host (rev 01)00:01.0 PCI bridge: Silicon Integrated Systems [siS] SiS 530 Virtual PCI-to-PCI bridge (AGP)00:02.0 ISA bridge: Silicon Integrated Systems [siS] 85C503/551300:02.2 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 07)00:02.3 USB Controller: Silicon Integrated Systems [siS] USB 1.0 Controller (rev 07)00:02.5 IDE interface: Silicon Integrated Systems [siS] 5513 [iDE] (rev d0)00:02.7 Multimedia audio controller: Silicon Integrated Systems [siS] Sound Controller (rev a0)00:03.0 Ethernet controller: Silicon Integrated Systems [siS] SiS900 10/100 Ethernet (rev 90)00:0b.0 Communication controller: Ambient Technologies Inc HaM controllerless modem (rev 02)01:00.0 VGA compatible controller: nVidia Corporation NV11DDR [GeForce2 MX 100 DDR/200 DDR] (rev b2)[bruno:~]$
Would that do ?:) Bruno
Great. Please use this thread to report success or problems with Preview 3.
Or:
[bruno:~]$ lspcidrakeunknown      : Silicon Integrated Systems [siS]|735 Host [bRIDGE_HOST]unknown      : Silicon Integrated Systems [siS]|5591/5592 AGP [bRIDGE_PCI]unknown      : Silicon Integrated Systems [siS]|85C503/5513 [bRIDGE_ISA]usb-ohci        : Silicon Integrated Systems [siS]|7001 USB [sERIAL_USB]usb-ohci        : Silicon Integrated Systems [siS]|7001 USB [sERIAL_USB]unknown      : Silicon Integrated Systems [siS]|5513 [iDE] [sTORAGE_IDE]snd-intel8x0    : Silicon Integrated Systems [siS]|SiS7012 PCI Audio Accelerator [MULTIMEDIA_AUDIO]sis900          : Silicon Integrated Systems [siS]|SiS900 10/100 Ethernet [NETWORK_ETHERNET]Bad:www.linmodems.org: Modem Silicon Operation|MD563X Host Accelerated Modem [COMMUNICATION_OTHER]Card:NVIDIA GeForce2 DDR (generic): nVidia Corporation|NV11 geForce2 100/200 [DISPLAY_VGA]unknown      : Unknown|USB OHCI Root Hub [Hub|Root Hub]unknown      : Unknown|USB OHCI Root Hub [Hub|Root Hub]unknown      : Atmel Corp.|4-port Hub [Hub|Root Hub][bruno:~]$
:) Bruno
That will work fine for the PCI devices. Still need to collect the other info.eg. Problems may be reported for specific peripheral hardware or motherboards.Hmmm. Might be able to automate the inventory process. Have to take a look.
Owyn . . NOTE: that is my main box . . I will be running the tests on my test-box . . has NO nVidia . . :):) BrunoMake a little script and you will have all info streamlined . . :) . . the same info from each tester . .
Exactly. I am going to work on scripts for inventory, and if needed, something to run on PCLos to help trouble shoot problems. Should not be a big problem, just takes time to get the details right.
Great, Owyn...if you want, I'll gladly participate.
Identification: quint - Linux DesktopManufacturer: Home-builtModel: DesktopMotherboard: Asus A7V133CPU: Athlon 1800+ XPRAM: 768MBVideo: nVidia GeForce2 MX400 64MBMonitor: Samtron 96BDF (19in.)Sound: on-board: VIA AC97NIC: Netgear FA311 (natsemi.o driver) DP83815 (MacPhyter)Modem: noneCdrom(Primary): Lite-On LTR-48246SCdrom(Secondary): Lite-On DVD-ROM LTD-163DMouse: Optical PS2 Wheel Mouse (psaux)Printer: EPSON C62 (Parallel Port)Comments: Connects via router to Internet.
[quint@localhost quint]$ lspcidrakeunknown      : VIA Technologies|VT8363/8365 [KT133/KM133] [bRIDGE_HOST]unknown      : VIA Technologies|VT8363/8365 [KT133/KM133 AGP] [bRIDGE_PCI]unknown      : VIA Technologies|VT82C686 [Apollo Super] [bRIDGE_ISA]unknown      : VIA Technologies|VT82C586 IDE [Apollo] [sTORAGE_IDE]usb-uhci        : VIA Technologies|VT82C586B USB [sERIAL_USB]usb-uhci        : VIA Technologies|VT82C586B USB [sERIAL_USB]unknown      : VIA Technologies|VT82C686 [Apollo Super ACPI] [bRIDGE_OTHER]snd-via82xx  : VIA Technologies|VT82C686 [Apollo Super AC97/Audio] [MULTIMEDIA_AUDIO]natsemi      : National Semi|DP83810 10/100 Ethernet [NETWORK_ETHERNET]unknown      : Promise Technology, Inc.|20265 [sTORAGE_OTHER]Card:NVIDIA GeForce2 DDR (generic): nVidia Corporation|NV11 Geforce2 MX/MX 400 [DISPLAY_VGA]unknown      : Linux 2.6.0-0.test9.6mdk uhci_hcd|UHCI Host Controller [Hub|Root Hub]unknown      : Linux 2.6.0-0.test9.6mdk uhci_hcd|UHCI Host Controller [Hub|Root Hub][quint@localhost quint]$
Tx Quint.LOL. I see you have test9.6 as your default kernel.
Has been "stable-to-a-fault". :)
Owyn,This is the "Test-box"
Identification: Bruno - Linux Testbox ( Uranus )Manufacturer: Home buildModel: Desktop Motherboard: EagleTec M825ML KM266 chipset CPU: Duron 1100 RAM: 512DDR Video: Onboard ProSavage8 KM266/KL266 Monitor: Plug 'n Play Compaq 171FS Sound: Onboard  VIA Technologies, Inc. VT8233/A/8235 AC97  NIC: Onboard VIA Technologies, Inc. VT6102 [Rhine-II] (rev 74) Modem: none Cdrom(Primary): LiteOn CDRW  Cdrom(Secondary): None Mouse: Logitech PS2 Optical Wheel Mouse (psaux) Printer: Canon 300 on network Comments: Connects via Alcatel 4 ports modem/router/switch
[bruno:~]$ lspcidrakeunknown      : VIA Technologies Inc|CPU-to-PCI Bridge [bRIDGE_HOST]unknown      : VIA Technologies|VT8633 [Apollo Pro266 AGP] [bRIDGE_PCI]usb-uhci        : VIA Technologies|VT82C586B USB [sERIAL_USB]usb-uhci        : VIA Technologies|VT82C586B USB [sERIAL_USB]usb-uhci        : VIA Technologies|VT82C586B USB [sERIAL_USB]ehci-hcd        : VIA Technologies Inc|VT8235 USB Enhanced Controller [sERIAL_USB]unknown      : VIA Technologies Inc|VT8233A PCI to ISA Bridge [bRIDGE_ISA]unknown      : VIA Technologies|VT82C586 IDE [Apollo] [sTORAGE_IDE]snd-via82xx  : VIA Technologies|VT8233 [AC97 Audio Controller] [MULTIMEDIA_AUDIO]via-rhine    : VIA Technologies|VT6102 [Rhine II 10/100] [NETWORK_ETHERNET]Card:S3 Savage4 : S3 Inc.|VT8751 [ProSavageDDR P4M266] VGA Controller [DISPLAY_VGA]unknown      : Linux 2.6.0-0.test9.4mdk ehci_hcd|EHCI Host Controller [Hub|Root Hub]unknown      : Linux 2.6.0-0.test9.4mdk uhci_hcd|UHCI Host Controller [Hub|Root Hub]unknown      : Linux 2.6.0-0.test9.4mdk uhci_hcd|UHCI Host Controller [Hub|Root Hub]unknown      : Linux 2.6.0-0.test9.4mdk uhci_hcd|UHCI Host Controller [Hub|Root Hub][bruno:~]$
( I still use the 'old' 2.6 test kernel :) ):) BrunoPS: has two maxtor HD´s . . . one 60G and one 5G
Tx.No real reason to upgrade from test9.4 to test9.6 if you don't have hardware problems. Main thing was to make sure people knew about test9.6 before the next set of changes come down the pipe. I have this feeling that test9.7 is going to be a release to avoid.
OwynThe specs of my Main box . . ( only used for testing if product is 100% safe :) )
Identification: Bruno - Linux Mainbox ( Jupiter ) Manufacturer: Home BuildModel: Desktop Motherboard: ECS K7S5A CPU: Athlon 1700 RAM: 512DDR Video: nVidia geForce2 200 Monitor: Plug 'n Play Miro A1785F ( CRT )Sound: onboard SiS7012 PCI Audio Accelerator snd-intel8x0 NIC:  SiS900 10/100 Ethernet (rev 90) Modem: ?? ( never used it ) Cdrom(Primary): LiteOn DVD Cdrom(Secondary): LiteOn CDRW HD: 2x Maxtor 80 G 7200rpmMouse: Logitech PS2 Wireless Optical Wheel Mouse (psaux) Printer: Canon 300 on network Comments: Connects via Alcatel 4 ports modem/router/switch
( Runs default kernel :) . . because of nVidia card ):) Bruno
Well, here is my baby:
Motherboard:Intel D845SPPEBT2CPU: Intel 2.8 HT 533 Mhz bux, 512 Cache RAM: 1GB DDR333 SD Ram Video: Radeon 9000Monitor: Flat Microtek C783Sound: onboard snd-intel8x0  ICH4 845G/GL Chipset AC-97 Audio ControllerNIC:  EtherExpress Pro/100 Modem:  (Don't need one.Cdrom(Primary): Creative DVD Cdrom(Secondary): LiteOn CDRW HD: 2x Maxtor 80 G 7200rpmMouse: Logitech PS2 Wireless Optical Wheel Mouse (psaux) MousemanPrinter: HP720Comments: Connects via Dlink604 4 port router[julia@localhost julia]$ lspcidrakeagpgart      : Intel Corporation|82845 845 Chipset Host Bridge (MCH) [bRIDGE_HOST]unknown      : Intel Corp.|82845G/GL [brookdale-G] Chipset AGP Bridge [bRIDGE_PCI]usb-uhci        : Intel Corporation|82801DB USB Controller [sERIAL_USB]usb-uhci        : Intel Corporation|82801DB USB Controller [sERIAL_USB]usb-uhci        : Intel Corporation|82801DB USB Controller [sERIAL_USB]ehci-hcd        : Intel Corporation|82801DB USB Enhanced Controller [sERIAL_USB]i810_rng        : Intel Corporation|82820 815e (Camino 2) Chipset PCI [bRIDGE_PCI]i810-tco        : Intel Corporation|82801DB 845G/GL Chipset ISA Bridge (ICH4) [bRIDGE_ISA]unknown      : Intel Corporation|82801DB 845G/GL Chipset IDE Controller [sTORAGE_IDE]unknown      : Intel Corporation|82801DB SMBus Controller [sERIAL_SMBUS]snd-intel8x0    : Intel Corporation|ICH4 845G/GL Chipset AC'97 Audio Controller [MULTIMEDIA_AUDIO]Card:ATI Radeon (fglrx): ATI|Radeon RV250 If [Radeon 9000] [DISPLAY_VGA]Card:ATI Radeon (fglrx): ATI Technologies Inc|Radeon R250 [Radeon 9000] (Secondary) [DISPLAY_OTHER]unknown      : Silicon Image|Sil3112A Serial ATA [sTORAGE_OTHER]eepro100        : Intel Corporation|EtherExpress PRO/100 [NETWORK_ETHERNET]unknown      : Linux 2.4.22-10mdkenterprise ehci_hcd|Intel Corp. 82801DB USB2 [Hub|Root Hub]unknown      : unknown (0781/8185/ffff/ffff) [Mass Storage|SCSI|Bulk (Zip)]unknown      : Unknown|USB UHCI Root Hub [Hub|Root Hub]unknown      : Unknown|USB UHCI Root Hub [Hub|Root Hub]
If you can design something that does not stop and search for the SATA drives that don't exist on every boot despite being turned off in the BIOS I would be extremely happy! Someday I will figure out a way to get past all those "unknowns". :) Kernel is whichever one I have booted in on a given day, whether or not I waited around to change it to the newer one or let the default take over.....
Tx Julia.This should work out very well. Almost every system is using substantially different components.As far as SATA is concerned, I suspect the problem is upstream to mklivecd, ie. in the Mandrake pieces.Made a note to follow up, but, it will probably be very low priority. Fixing things that don't work is top maintenance priority (yours works, just slowly). and, getting HD installer to work is probably top development priority.
Just to add my system as I am testing it:Identification: Zox - Linux DesktopManufacturer: White BoxModel: TowerMotherboard: ECS K7S5APROChipset:SIS 735CPU: Athlon XP 1600+ (1.4 Ghz)RAM: 512Mb DDR 3200 (400Mhz)Video: ATI Radeon 8500 (retail) 64MbMonitor: NEC Multisync LCD 1700VSound: C-Media CMI9738/4CH AC'97 CODEC (onboard)NIC: RealTek RTL8201BL 10/100Mbps PHYceiver (onboard)Cdrom(Primary): LG DVD-+R RW 4x 4040B (DVD Burner)Mouse: MicrosoftIntellimouse Optical USB/PS2 Wheel Mouse (psaux)Comments: Connects via router to Internet.Uses KVM switch for Video/Keyboard/MouseOther: Firewire cardOther: Promise Ultra ATA 100TX controller[zox@rogers zox]$ lspcidrakeunknown : Silicon Integrated Systems [siS]|735 Host [bRIDGE_HOST]unknown : Silicon Integrated Systems [siS]|5591/5592 AGP [bRIDGE_PCI]unknown : Silicon Integrated Systems [siS]|85C503/5513 [bRIDGE_ISA]usb-ohci : Silicon Integrated Systems [siS]|7001 USB [sERIAL_USB]usb-ohci : Silicon Integrated Systems [siS]|7001 USB [sERIAL_USB]unknown : Silicon Integrated Systems [siS]|5513 [iDE] [sTORAGE_IDE]snd-intel8x0 : Silicon Integrated Systems [siS]|SiS7012 PCI Audio Accelerator [MULTIMEDIA_AUDIO]sis900 : Silicon Integrated Systems [siS]|SiS900 10/100 Ethernet [NETWORK_ETHERNET]unknown : Promise Technology, Inc.|20268 [sTORAGE_OTHER]ohci1394 : Lucent Microelectronics|FW323 FireWire (IEEE 1394) [sERIAL_FIREWIRE]usb-uhci : VIA Technologies|VT82C586B USB [sERIAL_USB]usb-uhci : VIA Technologies|VT82C586B USB [sERIAL_USB]ehci-hcd : VIA Technologies Inc|VT8235 USB Enhanced Controller [sERIAL_USB]Card:ATI Radeon (fglrx): ATI|Radeon 8500 QL [DISPLAY_VGA]unknown : Linux 2.4.22-10mdk ehci_hcd|VIA Technologies, Inc. USB 2.0 [Hub|Root Hub]unknown : Unknown|USB UHCI Root Hub [Hub|Root Hub]unknown : Unknown|USB UHCI Root Hub [Hub|Root Hub]unknown : Unknown|USB OHCI Root Hub [Hub|Root Hub]unknown : Unknown|USB OHCI Root Hub [Hub|Root Hub]
Tx Zox.PS: Remind me to buy stock in "White Box". They have manufactured all of the reported systems.
Identification: Rons - Linux DesktopManufacturer: Home buildModel: TowerMotherboard: MSI KM2MChipset:VIA KM266CPU: Athlon XP 2000RAM: 256 MB - DDR 2700Video: Onboard Savage 8 2D/3D 32mbMonitor: Viewsonic 17" E773Sound: AC'97 CODEC (onboard)NIC: RealTek RTL8201BL 10/100Mbps (onboard)Cdrom(Primary): Sony CDRWMouse: PS2 generic wheel mouseComments: Connects via router to Internet.
Tx Rons.Could you give me the lspcidrake as well (or lspci if you are not using Mandrake).
I didn't call mine a white box because my case is black! It was fun picking out the case. Sometimes I wish I had broken down and spent the extra $25 for the acrylic side panel to see inside. Oh well, you have to be practical once in a while.
I will join too..... but I just got a mismatch on the md5sum... will have to redownload.System 1:Shuttle SS51 Barebones PCSis 651 ChipsetPIV 2.5 GHz512MB RAMWD 80GB Hard DriveSamsung SM332-B CD writer/DVD combo driveATI All in Wonder 7500Sound Blaster Audigy 2RTL-8139 onboard NIClspcidrake:
[root@localhost Documents]# lspcidrakeunknown         : Silicon Integrated Systems [SiS]|SiS651 Host [BRIDGE_HOST]unknown         : Silicon Integrated Systems [SiS]|5591/5592 AGP [BRIDGE_PCI]unknown         : Silicon Integrated Systems [SiS]|85C503/5513 [BRIDGE_ISA]unknown         : Silicon Integrated Systems [SiS]|5513 [IDE] [STORAGE_IDE]usb-ohci        : Silicon Integrated Systems [SiS]|7001 USB [SERIAL_USB]usb-ohci        : Silicon Integrated Systems [SiS]|7001 USB [SERIAL_USB]usb-ohci        : Silicon Integrated Systems [SiS]|7001 USB [SERIAL_USB]ehci-hcd        : Silicon Integrated Systems [SiS]|7002 USB 2.0 Controller [SERIAL_USB]audigy          : Creative Labs|EMU10K2 Audigy Audio Processor [MULTIMEDIA_AUDIO]emu10k1-gp      : Creative Labs|EMU10K2 Audigy Gameport [INPUT_OTHER]ohci1394        : Creative Labs|EMU10K2 Audigy IEEE1394 Firewire Controller [SERIAL_FIREWIRE]8139too         : Realtek|RTL-8139 [NETWORK_ETHERNET]ohci1394        : VIA Technologies|OHCI Compliant IEEE 1394 Host Controller [SERIAL_FIREWIRE]Card:ATI Radeon : ATI|Radeon 7500 QW [DISPLAY_VGA]unknown         : Linux 2.4.22-10mdk ehci_hcd|Silicon Integrated Systems [SiS] USB 2.0 Controller [Hub|Root Hub]unknown         : Unknown|USB OHCI Root Hub [Hub|Root Hub]unknown         : Unknown|USB OHCI Root Hub [Hub|Root Hub]unknown         : Unknown|USB OHCI Root Hub [Hub|Root Hub]unknown         : Samsung       |YP-55               [Mass Storage|SCSI|Bulk (Zip)]
System 2:Dell Precision Workstation 410440BX Chipset (INtel)Dual CPU capable (coming soon!)Dual SCSI Controllers onboardSCSI CDROMSCSI Hard Drive 9.6GBDual NIC's (one onboard)Matrox G400 Dualhead video cardlspcidrake:
[root@localhost adam]# lspcidrakeagpgart         : Intel Corporation|440BX/ZX - 82443BX/ZX Host bridge [BRIDGE_HOST]unknown         : Intel Corporation|440BX/ZX - 82443BX/ZX AGP bridge [BRIDGE_PCI]unknown         : Intel Corporation|82371AB PIIX4 ISA [BRIDGE_ISA]unknown         : Intel Corporation|82371AB PIIX4 IDE [STORAGE_IDE]usb-uhci        : Intel Corporation|82371AB PIIX4 USB [SERIAL_USB]sonypi          : Intel Corporation|82371AB PIIX4 ACPI - Bus Master IDE Controller [BRIDGE_OTHER]3c59x           : 3Com Corporation|3c905C-TX [Fast Etherlink] [NETWORK_ETHERNET]3c59x           : 3Com Corporation|3c905B 100BaseTX [Cyclone] [NETWORK_ETHERNET]unknown         : DEC|DECchip 21152 [BRIDGE_PCI]Card:Matrox Millennium G400 DualHead: Matrox Graphics, Inc.|Millennium G400 Dual Head Max [DISPLAY_VGA]aic7xxx         : Adaptec|AHA-2940U2/W / 7890 [STORAGE_SCSI]aic7xxx         : Adaptec|AIC-7880U [STORAGE_SCSI]unknown         : Unknown|USB UHCI Root Hub [Hub|Root Hub]
Owyn - here you go.[root@localhost root]# lspcidrakeunknown : VIA Technologies Inc|CPU-to-PCI Bridge [bRIDGE_HOST]unknown : VIA Technologies|VT8633 [Apollo Pro266 AGP] [bRIDGE_PCI]Bad:www.linmodems.org: ESS Technology|ES2838/2839 SuperLink Modem [COMMUNICATION_OTHER]usb-uhci : VIA Technologies|VT82C586B USB [sERIAL_USB]usb-uhci : VIA Technologies|VT82C586B USB [sERIAL_USB]usb-uhci : VIA Technologies|VT82C586B USB [sERIAL_USB]ehci-hcd : VIA Technologies Inc|VT8235 USB Enhanced Controller [sERIAL_USB]unknown : VIA Technologies Inc|VT8233A PCI to ISA Bridge [bRIDGE_ISA]unknown : VIA Technologies|VT82C586 IDE [Apollo] [sTORAGE_IDE]snd-via82xx : VIA Technologies|VT8233 [AC97 Audio Controller] [MULTIMEDIA_AUDIO]via-rhine : VIA Technologies|VT6102 [Rhine II 10/100] [NETWORK_ETHERNET]Card:S3 Savage4 : S3 Inc.|VT8751 [ProSavageDDR P4M266] VGA Controller [DISPLAY_VGA][root@localhost root]#
Owyn, I'm in too.Manufacturer: Home BuildModel: DesktopMotherboard: Asus A7V KT133ACPU: AMD Athlon Thunderbird 1.2 GHz 266FSBRAM: 256 PC 133Video: nVidia geForce2 64Monitor: Plug 'n Play ViewSonic E70 ( CRT )Sound: Creative SoundBlaster Live Value PCINIC: D-Link DFE-530TX PCICdrom: Pioneer DVD-ROM DVD-116HD: 2x Maxtor 40 GB 7200rpmMouse: PS2Printer: HP Lazer 4PComments: Connects via router to net
