V.T. Eric Layton Posted January 22, 2021 Posted January 22, 2021 I use Liberation Mono Bold 14pt (black on white background). I find it easier for old eyes to read. 1 Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 1 minute ago, V.T. Eric Layton said: I use Liberation Mono Bold 14pt (black on white background). I find it easier for old eyes to read. You know, they make these things called glasses with lens that allow you to see again.... 1 Quote
abarbarian Posted January 22, 2021 Author Posted January 22, 2021 (edited) Well I installed https://archlinux.org/packages/community/any/ttf-liberation/ which has as one of its fonts Quote usr/share/fonts/liberation/LiberationMono-Bold.ttf so I altered my .Xresources file Quote !xterm.faceName: DejaVu Sans Mono Book !xterm.faceSize: 11 xterm.faceName: LiberationMono-Bold.ttf xterm.faceSize: 13 or Quote !xterm.faceName: DejaVu Sans Mono Book !xterm.faceSize: 11 xterm.faceName: LiberationMono-Bold xterm.faceSize: 13 or Quote !xterm.faceName: DejaVu Sans Mono Book !xterm.faceSize: 11 xterm.faceName: Liberation Mono Bold xterm.faceSize: 13 did this after every change and even tried a reboot Quote xrdb ~/.Xresources an my terminal still looks the same. So what am I doing wrong folks ? Edited January 22, 2021 by abarbarian Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 Copy ~/.Xresources to ~/.Xdefaults. Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 If I remember correctly, some applications use the older ~/.Xdefaults so I just always mirror the file whenever I make a change. Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 And depending on your environment, you may have to log out and back in. Quote
V.T. Eric Layton Posted January 22, 2021 Posted January 22, 2021 3 hours ago, securitybreach said: You know, they make these things called glasses with lens that allow you to see again.... WOW! Whoda' thunk it?! 1 Quote
V.T. Eric Layton Posted January 22, 2021 Posted January 22, 2021 2 hours ago, abarbarian said: So what am I doing wrong folks ? Couldn't tell you. I've probably only opened Xterm once or twice in my life and both times were probably by accident. Josh'll know... Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 1 hour ago, V.T. Eric Layton said: Couldn't tell you. I've probably only opened Xterm once or twice in my life and both times were probably by accident. Josh'll know... Mentioned fix above 1 1 Quote
abarbarian Posted January 22, 2021 Author Posted January 22, 2021 (edited) 7 hours ago, securitybreach said: Copy ~/.Xresources to ~/.Xdefaults. Well according to the Arch Wiki .Xresources is the file you need to customise xterm, https://wiki.archlinux.org/index.php/X_resources https://wiki.archlinux.org/index.php/Xterm I have made changes to the .Xresources file like changing the background colour and they have taken and survived reboots. However I can not get the font to change. I have tired one at a time with several examples one taken from a link in the Arch Wiki.Plus I have tried to use the font that I posted earlier in different ways. xterm.faceName: DejaVu Sans Mono Book xterm.faceSize: 11 XTerm*font: -*-terminus-medium-*-*-*-18-*-*-*-*-*-iso10646-1 After every change I have followed the Wiki recommendation to do, xrdb ~/.Xresources and have also tried rebooting the pc after making a change. Also if I comment out all of the font variables like so for example the terminal font does not change, !xterm.faceName: DejaVu Sans Mono Book !xterm.faceSize: 11 !xterm.faceName: Liberation Mono Bold !xterm.faceSize: 14 !XTerm*font: -*-terminus-medium-*-*-*-18-*-*-*-*-*-iso10646-1 So I am a tad puzzled as to how to change the xterm terminal font. Oh and I did make a .Xdefaults file and duplicated all the changes as I made them in .Xresources and it made diddly squat difference. Apart from creating extra work. Edited January 22, 2021 by abarbarian Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 Can you launch xterm from another terminal to check the output? You may be getting an error. Quote
abarbarian Posted January 22, 2021 Author Posted January 22, 2021 I finally managed to make a change to the xterm font and make it stick. I put this in my ~/.Xresources, xterm*faceName: Terminus:pixelsize=14 and did a , xrdb ~/.Xresources then opened up a new terminal. As you can see in the screenshot the terminal is bigger and so is the font. I tried this method with a pixelsize of 16/18/ and each time the terminal and font became bigger. No log outs or reboots or using a ~/.Xdefaults file needed. I have no idea if the font displayed is a " Terminus " font, I had a look on line and it looks the same as examples but my eyes are getting tired and I can not be certain. I am still left with the puzzle of how to enter a differently named font in th e~/>Xresources file. Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 Ah ok, it was an xterm specific option in Xresources as I do not have a "faceName" option in mine. urxvt*geometry: 52x20 urxvt*font:xft:source code pro:pixelsize=14:antialias=true urxvt*boldFont:xft:source code pro:pixelsize=14:antialias=true urxvt*depth: 32 urxvt*borderless: 1 urxvt*scrollBar: false urxvt*scrollBar_right: false urxvt*saveLines: 5000 urxvt*tintColor: grey urxvt*shading: 40 urxvt*termName: rxvt-256color URxvt.letterSpace: -1 URxvt.lineSpace: 3 urxvt*cursorBlink: true urxvt*cursorUnderline: true urxvt*cursorColor: #FFFFFF URxvt.internalBorder: 0 URxvt.perl-ext-common: default,matcher,vtwheel,font-size URxvt.url-launcher: /usr/bin/chromium URxvt.matcher.button: 1 URxvt.keysym.C-Up: font-size:increase URxvt.keysym.C-Down: font-size:decrease *.foreground: nord4 *.background: nord0 *.cursorColor: nord4 *fading: 35 *fadeColor: nord3 *.color0: nord1 *.color1: nord11 *.color2: nord14 *.color3: nord13 *.color4: nord9 *.color5: nord15 *.color6: nord8 *.color7: nord5 *.color8: nord3 *.color9: nord11 *.color10: nord14 *.color11: nord13 *.color12: nord9 *.color13: nord15 *.color14: nord7 *.color15: nord6 !-- Xft settings -- ! Xft.dpi: 100 Xft.antialias: true Xft.rgba: rgb Xft.hinting: true Xft.hinstyle: full rofi.font: source code pro 14 rofi.forebackground: #FFFFFF rofi.background: #000000 rofi.opacity: 80 rofi.width: 40 rofi.lines: 15 rofi.columns: 1 rofi.color-enabled: true rofi.color-window: #273238, #273238, #1e2529 rofi.color-normal: #273238, #c1c1c1, #273238, #394249, #ffffff rofi.color-active: #273238, #80cbc4, #273238, #394249, #80cbc4 rofi.color-urgent: #273238, #ff1844, #273238, #394249, #ff1844 rofi.bw: 1 rofi.location: 0 rofi.padding: 5 rofi.yoffset: 0 rofi.xoffset: 0 rofi.fixed-num-lines: false rofi.terminal: urxvtc rofi.ssh-client: ssh rofi.ssh-command: {terminal} -e {ssh-client} {port} {host} rofi.run-command: {cmd} rofi.run-list-command: rofi.run-shell-command: {terminal} -e {cmd} rofi.disable-history: false rofi.levenshtein-sort: true rofi.case-sensitive: false rofi.sidebar-mode: false rofi.lazy-filter-limit: 5000 rofi.eh: 1 rofi.auto-select: false rofi.parse-hosts: false rofi.kb-primary-paste: Control+Shift+v,Shift+Insert rofi.kb-secondary-paste: Control+v,Insert rofi.kb-move-front: Control+a rofi.kb-move-end: Control+e rofi.kb-move-word-back: Alt+b rofi.kb-move-word-forward: Alt+f rofi.kb-move-char-back: Left,Control+b rofi.kb-move-char-forward: Right,Control+f rofi.kb-remove-word-back: Control+Alt+h rofi.kb-remove-word-forward: Control+Alt+d rofi.kb-remove-char-forward: Delete,Control+d rofi.kb-remove-char-back: BackSpace,Control+h rofi.kb-accept-entry: Control+j,Control+m,Return,KP_Enter rofi.kb-accept-custom: Control+Return rofi.kb-accept-entry-continue: Shift+Return rofi.kb-mode-next: Shift+Right,Control+Tab rofi.kb-mode-previous: Shift+Left,Control+Shift+Tab rofi.kb-toggle-case-sensitivity: grave,dead_grave rofi.kb-delete-entry: Shift+Delete Quote
abarbarian Posted January 22, 2021 Author Posted January 22, 2021 51 minutes ago, securitybreach said: Ah ok, it was an xterm specific option in Xresources as I do not have a "faceName" option in mine. Sort of. The problem is more in how the fonts are named. Anyway I tried your font, xterm*faceName: xft:source code pro:pixelsize=14:antialias=true An decided it looks crisp and clean and easily readable so have decided to use it. From left to right, your font at size 14, middle your font size 12, right my font size 14. Thanks for your help. Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 Awesome, I really like the font as well Quote
securitybreach Posted January 22, 2021 Posted January 22, 2021 Did you notice this in my config? It allows you to increase or decrease font size on the fly using ctrl+up arrow or ctrl-down arrow. I do not know if it works for xterm though URxvt.keysym.C-Up: font-size:increase URxvt.keysym.C-Down: font-size:decrease Quote
abarbarian Posted January 23, 2021 Author Posted January 23, 2021 (edited) 11 hours ago, securitybreach said: Did you notice this in my config? It allows you to increase or decrease font size on the fly using ctrl+up arrow or ctrl-down arrow. I do not know if it works for xterm though URxvt.keysym.C-Up: font-size:increase URxvt.keysym.C-Down: font-size:decrease Xterm has pop up windows if you ctrl + right/left/middle mouse buttons which allow you to do all sorts. I use Liberation Mono Bold 14pt (black on white background). I find it easier for old eyes to read. @V.T. Eric Layton I would like to try Eric's suggestion. I found a Arch package with it included and installed it but can not work out how to enter the correct name for it in the .Xresources file. Edited January 23, 2021 by abarbarian Quote
abarbarian Posted January 23, 2021 Author Posted January 23, 2021 Finally figured out how to get Eric's font in me ~/.Xresource file, this is the entry, ! Eric's terminal font very neat - the non bold one is cool too. xterm*faceName: xft:Liberation Mono:bold:pixelsize=13:antialias=true:hinting=true !xterm*faceName: xft:Liberation Mono:pixelsize=13:antialias=true:hinting=true I have to say that the Arch Wiki is as clear as mud on how to change fonts in xterm.Yes there is a lot of information but it is like being blindfolded and wandering around in a swamp at night for all the good it does. For instance there is no mention of the " .Xresources " file on the Xterm wiki page which is strange as that is where you put all your customisations for Xterm as a user. 1 Quote
V.T. Eric Layton Posted January 23, 2021 Posted January 23, 2021 Seems that you're doing this the hard way, @abarbarian. When I want to add fonts to my Slackware (or any Linux), I just download the font (TTF) from a reputable website like Font Squirrel, unpack the archive and dump them into /usr/share/fonts/TTF. Once that's done the font choice appears in all my font settings (Xfce manager, Firefox, T-bird, Terminal, etc.) You can find Liberation Mono HERE. Quote
V.T. Eric Layton Posted January 23, 2021 Posted January 23, 2021 Just out of curiosity, why would you even be using Xterm? It's a masochist's terminal emulator... something I would expect Gentoo fans to be using. There are many other terminal emulators (Xfce Terminal, KDE Konsole, etc.) that are much easier to customize and use. But hey... I'm lazy, so I don't care much for high maintenance type software. Quote
securitybreach Posted January 23, 2021 Posted January 23, 2021 Yeah, I was thinking the same..xterm is very old and lacking. You're literally the only person I know who actually uses xterm. Xterm is usually used to install another terminal (sort of like how IE was used). 1 Quote
V.T. Eric Layton Posted January 23, 2021 Posted January 23, 2021 Meh... he's a barbarian, after all. 1 Quote
securitybreach Posted January 23, 2021 Posted January 23, 2021 I use a very simplistic terminal, rxvt-unicode (urxvt). While it is very simplistic and you have to configure it manually via ~/.Xresources, it is very modern and has some cool features: https://curryncode.com/2019/03/06/rxvt-unicode-features/ Plus it has a daemon mode where all terminals are running as a single process. You simply add urxvtd to your startup file (~/.xinintc) amd launch a terminal using urxvtc It's a bit more difficult on the setup than others like lxterminal, konsole, etc but its a lot more lightweight. I mean it is a terminal after all, the process shouldn't use any memory really. I have 12 terminals open and it is only using 54mb of memory: Cerberus :: ~ » ps aux | grep urxvtd comhack 1406 0.0 0.0 54920 17780 tty1 S 07:34 0:00 urxvtd -q -o -f Cerberus :: ~ » pmap 1406 | tail -n 1 total 54924K Quote
abarbarian Posted January 23, 2021 Author Posted January 23, 2021 6 hours ago, V.T. Eric Layton said: You can find Liberation Mono HERE. Yeah I already installed it from an Arch package. 4 hours ago, securitybreach said: While it is very simplistic and you have to configure it manually via ~/.Xresources, it is very modern and has some cool features: Yeah you do extra customisations the same way for xterm. An as to the cool features xterm can do all of them too as well as all sorts of other even cooler stuff. Not so sure about the perl stuff though. I can not see the problem with xterm . You install it , alter the prompt in .bashrc, add a couple of things in .Xresources and use it. Where is the difficulty in that ????? https://lukas.zapletalovi.com/2013/07/hidden-gems-of-xterm.html https://invisible-island.net/xterm/manpage/xterm.html Quote
