SueD Posted October 25, 2007 Author Posted October 25, 2007 That's what I thought but I don't have Gnome as an option...DefaultCustomIceWMKDEdrak3devilwmFailsafeHeaven only knows what kind of trouble I can get into by choosing Custom. Quote
Bruno Posted October 25, 2007 Posted October 25, 2007 Hi SueYou will have to install gnome-desktop ( I think that is the meta package ) using the MCC . . . after that you should have the choice at the login screen. Bruno Quote
SueD Posted October 25, 2007 Author Posted October 25, 2007 *sigh*It's installed, I rebooted and it's still not an option. Quote
Bruno Posted October 25, 2007 Posted October 25, 2007 Sorry . . I was wrong . . In Mandriva 2008 the meta package is called "task-gnome" ( or you can take "task-gnome-minimal" ) Bruno Quote
SueD Posted October 25, 2007 Author Posted October 25, 2007 (edited) Hubby will be happy since he'll be able to hear what he's doing on pogo again.Embedded wave files aren't working and I still have no sounds when trying to play my videos in VLC.Do you think buying a sound card will work?UPDATE: sound is gone again. That's it, I'm getting a new card. Edited October 25, 2007 by SueD Quote
striker Posted October 25, 2007 Posted October 25, 2007 Take care Sue which card you buy... Maybe it's a good idea to just look around only, then post what you have in mind. So we might be able to dig up something about linux compatibility before you buy it. Quote
SueD Posted October 25, 2007 Author Posted October 25, 2007 Striker, do you think I'd screw that up? Ok, so I didn't buy the best printer but how bad could this turn out? What I'm looking at is a Creative Labs Audigy SE. Quote
Bruno Posted October 25, 2007 Posted October 25, 2007 The SE is not the best supported . . . have a look here:http://www.alsa-project.org/main/index.php...r-Creative_Labs ( The ones with the emu10k1 and emu10k2 driver are best supported, donṫ buy the latest/greatest . . . I had good luck on ebay getting 4 exact the same SB value Live cards for my computers ) Bruno Quote
striker Posted October 25, 2007 Posted October 25, 2007 exactly, the SE is ... eh not good Sue. I use an Audigy4 (not pro), got it from something like ebay, works like a charm in fedora 6,mandy Spring, pclos 2007, debian 4r1, openSUSE 10.3 and Mandriva 2008 One (KDE).The latest Creatives, XiFi series : there's only a beta 64bit driver out there and I haven't heard of results yet, positive or negative. No 32bit driver yet AFAIK. Quote
SueD Posted October 25, 2007 Author Posted October 25, 2007 Ok.The only other option the place I usually buy things from is an AOpen PCI 6 Channel. If that's no good, then I'll have to either go to Ottawa or buy online. Quote
Bruno Posted October 26, 2007 Posted October 26, 2007 Only these Aopen cards are supported Sue:http://www.alsa-project.org/main/index.php...ix:Vendor-Aopen Bruno Quote
SueD Posted October 26, 2007 Author Posted October 26, 2007 I bought this one for my daughter 2 years ago. If I'm reading that chart right, it should be ok? Quote
raymac46 Posted October 26, 2007 Posted October 26, 2007 (edited) I bought this one for my daughter 2 years ago. If I'm reading that chart right, it should be ok?That'll definitely work Sue. I have one in my XP box and it works with Puppy Linux. Also I have an AOpen AW-840 4-channel PCI card in my main Linux desktop that works fine with Ubuntu. Edited October 26, 2007 by raymac46 Quote
SueD Posted October 26, 2007 Author Posted October 26, 2007 Thanks Ray. I think I'll see if I can swipe it from Kimi's computer this weekend. Quote
Bruno Posted October 26, 2007 Posted October 26, 2007 I bought this one for my daughter 2 years ago. If I'm reading that chart right, it should be ok?Yes I agree with Ray . . that Creative SB card will most definitely work ! ( but since the "reconfigure" button in the MCC --> Hardware does not work we will need to adapt the /etc/modprobe.conf manually . . . . let us know when you are ready ) Bruno Quote
SueD Posted October 26, 2007 Author Posted October 26, 2007 Thanks Bruno, I'll look for one this weekend if I can't swipe my daughter's. Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 My new card arrived this morning! I'll install it later today after I get home from where ever we go today. Installation won't be any different than it was with my vid card, will it? Quote
Bruno Posted November 3, 2007 Posted November 3, 2007 Just plug it in and see if it pic it up and auto-configures . . . if not we will have to know the exact type of the card ans see what driver it uses . . . next we adapt the /etc/modprobe.conf file so it loads the correct driver at the next boot. Bruno Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 G'day Bruno.It's in but it didn't autoconfig. There's a lot more places I could've plugged my speakers into back there. I wasn't quite sure which one to use soooo since they had been plugged into the green hole previously, that's where I plugged them in this time. My husband said I could plug it there, in the green or in the black. Right place or wrong? Quote
Bruno Posted November 3, 2007 Posted November 3, 2007 The green should be okay Sue.Boot a PCLos Live CD and look what driver it uses in /etc/modprobe.confIf it is the card I think you have the line would be "alias sound-slot-0 snd_emu10k1" Bruno Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 The green should be okay Sue.Boot a PCLos Live CD and look what driver it uses in /etc/modprobe.confIf it is the card I think you have the line would be "alias sound-slot-0 snd_emu10k1" BrunoOooh, close...[guest@localhost guest]$ cat /etc/modprobe.confinstall usb-interface /sbin/modprobe ohci-hcd; /sbin/modprobe ehci-hcd; /bin/truealias sound-slot-1 snd-emu10k1remove snd-intel8x0 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0 && { /sbin/modprobe snd-pcm-oss; /bin/true; }remove snd-emu10k1 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-emu10k1install snd-emu10k1 /sbin/modprobe --first-time --ignore-install snd-emu10k1 && { /sbin/modprobe snd-pcm-oss; /bin/true; }alias sound-slot-0 snd-intel8x0alias net-pf-10 off Quote
Bruno Posted November 3, 2007 Posted November 3, 2007 Did you disable the on-board sound chip in the BIOS ??? ( that is the first step )Next reboot and remove the old line for the onboard from the /etc/modprobe.conf . . and then add: alias sound-slot-0 snd_emu10k1 ( I think PCLos uses the - and Mandriva the _ between snd and emu10k1 )Next reboot again and see what happens . . . . is Kmix present and do you get a mixer-panel when you press the button in Kmix ? BrunoPS: These 4 lines can go . . .they are not needed: remove snd-intel8x0 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0 && { /sbin/modprobe snd-pcm-oss; /bin/true; }remove snd-emu10k1 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-emu10k1install snd-emu10k1 /sbin/modprobe --first-time --ignore-install snd-emu10k1 && { /sbin/modprobe snd-pcm-oss; /bin/true; } Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 Disable the onboard sound chip? Um, no. I'll do that now. I'll be back.Listen, if you're busy, we can do this later...just letting you know I'm ok with waiting. Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 [root@localhost sue]# cat /etc/modprobe.confalias eth0 sis900alias sound-slot-0 snd_emu10k1install usb-interface /sbin/modprobe ohci_hcd; /sbin/modprobe ehci_hcd; /bin/trueinstall ide-controller /sbin/modprobe sis5513; /bin/trueinstall ipv6 /bin/truealias sound-slot-1 snd_emu10k1remove snd-intel8x0 /sbin/modprobe --first-time -r --ignore-remove snd-intel8x0install snd-intel8x0 /sbin/modprobe --first-time --ignore-install snd-intel8x0remove snd_intel8x0 /sbin/modprobe --first-time -r --ignore-remove snd_intel8x0install snd_intel8x0 /sbin/modprobe --first-time --ignore-install snd_intel8x0Remove the last 4 lines??? I already see alias sound-slot-1 snd_emu10k1 in there...or do you want me to change it to alias sound-slot-0 snd_emu10k1? Or ignore it and add alias sound-slot-0 snd_emu10k1? Quote
Bruno Posted November 3, 2007 Posted November 3, 2007 It's okay . . I have loads of time . . . . and it will be fixed in minutes :DB) Bruno Remove the last 4 lines??? I already see alias sound-slot-1 snd_emu10k1 in there...or do you want me to change it to alias sound-slot-0 snd_emu10k1? Or ignore it and add alias sound-slot-0 snd_emu10k1?Crosspost . . . . . LOL . . . . well you only need sound-slot-0 . . . Yes you can remover the last 4 lines . . . they are useless.Actually you should already have sound this way . . . . did you reboot after the edit ? Bruno Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 I never edited...just wanted to clarify things before I hit that Delete button. And no, no sound yet.I'll reboot right after I edit. Quote
Bruno Posted November 3, 2007 Posted November 3, 2007 Okay . . . let's do the edit and reboot ;) Bruno Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 I HAVE SOUND!!! Real LOUD sound!!! Thank you so much Bruno! You is a Linux god! Quote
Bruno Posted November 3, 2007 Posted November 3, 2007 I HAVE SOUND!!! Real LOUD sound!!! HURRRRRRRRRAY !!! BrunoPS: You can use the "black exit" of the card for a second pair of speakers behind you . . there are special sliders for in in Kmix Quote
SueD Posted November 3, 2007 Author Posted November 3, 2007 Now I know what I want for Christmas....new speakers! Kmix looks so different now...lots of things in there for me to get into trouble with. Thanks again Bruno. Quote
