gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 you are right,i did sleep too long or maybe i just wen to bed too late everything is updated and now ill be moving on pclos lilo point.there is still so many things i have to install i dont even wanna think about it Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 LOL . . . installing with "urpmi" is so easy and simple . . . . .really try it: # urpmi kedit Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 ok ill try it,i mean i already installed all the updates so now ill have to install some new things.do you have any list of things that should be installed?i am sure you do boot cd for mandrake works now i am ready to get this lilo to work ok Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 do you have any list of things that should be installed?# urpmi kedit# urpmi galeon# urpmi mozilla-firefox# urpmi mozilla# urpmi anacron# urpmi gkrellm# urpmi koffice# urpmi aumix# urpmi mplayer# urpmi mplayer-plugin:D :DAnd we will have to copy Java and the browser-plugins over from PCLos . . . . one "simple" command :DB) Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 oh i forgot to tell you,i have two mandrake partitions now.this is my updated partition table:swap hda1 pclos hda5windows hda6 and hda3mandrake hda7 - rootmandrake hda8 - homebut it doesn affect the command you posted right? Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 some of those things i cant install cuz it says there is no package to do so Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 after all hda7 i bootable so not hda 8 so no need to make directry for hda 8 right? Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 [gaucho@chello084010044003 guest]$ suPassword:[root@chello084010044003 guest]# mkdir /mnt/hda7[root@chello084010044003 guest]# mount /dev/hda7 /mnt/hda7[root@chello084010044003 guest]# cp -r /mnt/hda7/boot /boot/drake[root@chello084010044003 guest]# ls -al /boot/draketotal 2279drwxr-xr-x 3 root root 640 Jan 28 19:41 ./drwxr-xr-x 3 root root 632 Jan 28 19:41 ../-rw-r--r-- 1 root root 512 Jan 28 19:41 boot.0300lrwxrwxrwx 1 root root 20 Jan 28 19:41 config -> config-2.6.8.1-12mdk-rw-r--r-- 1 root root 60428 Jan 28 19:41 config-2.6.8.1-12mdk-rw-r--r-- 1 root root 5032 Jan 28 19:41 diag1.img-rw-r--r-- 1 root root 16796 Jan 28 19:41 diag2.imgdrwxr-xr-x 2 root root 456 Jan 28 19:41 grub/-rw-r--r-- 1 root root 170698 Jan 28 19:41 initrd-2.6.8.1-12mdk.imglrwxrwxrwx 1 root root 24 Jan 28 19:41 initrd.img -> initrd-2.6.8.1-12mdk.imglrwxrwxrwx 1 root root 28 Jan 28 19:41 kernel.h -> /boot/kernel.h-2.6.8.1-12mdk-rw-r--r-- 1 root root 537 Jan 28 19:41 kernel.h-2.6.8.1-12mdk-rw------- 1 root root 129536 Jan 28 19:41 maplrwxrwxrwx 1 root root 15 Jan 28 19:41 message -> message-graphic-rw-r--r-- 1 root root 62997 Jan 28 19:41 message-graphic-rw-r--r-- 1 root root 116 Jan 28 19:41 message-textlrwxrwxrwx 1 root root 24 Jan 28 19:41 System.map -> System.map-2.6.8.1-12mdk-rw-r--r-- 1 root root 547168 Jan 28 19:41 System.map-2.6.8.1-12mdk-rw-r--r-- 1 root root 256 Jan 28 19:41 us.kltlrwxrwxrwx 1 root root 21 Jan 28 19:41 vmlinuz -> vmlinuz-2.6.8.1-12mdk-rw-r--r-- 1 root root 1306306 Jan 28 19:41 vmlinuz-2.6.8.1-12mdk[root@chello084010044003 guest]# Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 Correct on both questions:1) If it says it does not have the package we will get it later from other sources . . 2). You ohnly need to mane /mnt/hda7 in PCLos :DB) Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 [gaucho@chello084010044003 guest]$ suPassword:[root@chello084010044003 guest]# mkdir /mnt/hda7[root@chello084010044003 guest]# mount /dev/hda7 /mnt/hda7[root@chello084010044003 guest]# cp -r /mnt/hda7/boot /boot/drake[root@chello084010044003 guest]# ls -al /boot/draketotal 2279drwxr-xr-x 3 root root  640 Jan 28 19:41 ./drwxr-xr-x 3 root root  632 Jan 28 19:41 ../-rw-r--r-- 1 root root  512 Jan 28 19:41 boot.0300lrwxrwxrwx 1 root root   20 Jan 28 19:41 config -> config-2.6.8.1-12mdk-rw-r--r-- 1 root root 60428 Jan 28 19:41 config-2.6.8.1-12mdk-rw-r--r-- 1 root root  5032 Jan 28 19:41 diag1.img-rw-r--r-- 1 root root 16796 Jan 28 19:41 diag2.imgdrwxr-xr-x 2 root root  456 Jan 28 19:41 grub/-rw-r--r-- 1 root root 170698 Jan 28 19:41 initrd-2.6.8.1-12mdk.imglrwxrwxrwx 1 root root   24 Jan 28 19:41 initrd.img -> initrd-2.6.8.1-12mdk.imglrwxrwxrwx 1 root root   28 Jan 28 19:41 kernel.h -> /boot/kernel.h-2.6.8.1-12mdk-rw-r--r-- 1 root root  537 Jan 28 19:41 kernel.h-2.6.8.1-12mdk-rw------- 1 root root 129536 Jan 28 19:41 maplrwxrwxrwx 1 root root   15 Jan 28 19:41 message -> message-graphic-rw-r--r-- 1 root root 62997 Jan 28 19:41 message-graphic-rw-r--r-- 1 root root  116 Jan 28 19:41 message-textlrwxrwxrwx 1 root root   24 Jan 28 19:41 System.map -> System.map-2.6.8.1-12mdk-rw-r--r-- 1 root root 547168 Jan 28 19:41 System.map-2.6.8.1-12mdk-rw-r--r-- 1 root root  256 Jan 28 19:41 us.kltlrwxrwxrwx 1 root root   21 Jan 28 19:41 vmlinuz -> vmlinuz-2.6.8.1-12mdk-rw-r--r-- 1 root root 1306306 Jan 28 19:41 vmlinuz-2.6.8.1-12mdk[root@chello084010044003 guest]#Perfect !Next step: open up the /etc/lilo.conf in kwrite ( "kwrite /etc/lilo.conf") and add this part:image=/boot/drake/vmlinuz-2.6.8.1-12mdk  label="Mandrake"  root=/dev/hda7  initrd=/boot/drake/initrd-2.6.8.1-12mdk.img  append="acpi=on resume=/dev/hda1 splash=silent"  vga=788  read-only Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 [root@chello084010044003 guest]# cat /etc/lilo.confboot=/dev/hdamap=/boot/mapdefault="pclinuxos"keytable=/boot/livecd.kltpromptnowarntimeout=100message=/boot/messagemenu-scheme=wb:bw:wb:bwimage=/boot/vmlinuz-2.6.7-2.tmb.6mdk label="pclinuxos" root=/dev/hda5 initrd=/boot/initrd-2.6.7-2.tmb.6mdk.imgappend="devfs=nomount acpi=ht nomce splash=silent"vga=788read-onlyother=/dev/hda3label="win_c"image=/boot/drake/vmlinuz-2.6.8.1-12mdk label="Mandrake" root=/dev/hda7 initrd=/boot/drake/initrd-2.6.8.1-12mdk.img append="acpi=on resume=/dev/hda1 splash=silent" vga=788 read-only[root@chello084010044003 guest]# Mutex destroy failure: Device or resource busy[root@chello084010044003 guest]# ICE default IO error handler doing an exit(), pid = 4994, errno = 0ICE default IO error handler doing an exit(), pid = 5005, errno = 0[root@chello084010044003 guest]# Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 ExcellentNow Ctrl+D . . and again Ctrl+D will close the console . . . open it again and do "su" again . . . ( get rid of the Mutex destroy failure )Then do this: # /sbin/lilo And let me see what it says ! Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 [gaucho@chello084010044003 guest]$ /sbin/liloFatal: open /dev/hda: Permission denied[gaucho@chello084010044003 guest]$ suPassword:[root@chello084010044003 guest]# /sbin/liloAdded pclinuxos *Added win_cAdded Mandrake[root@chello084010044003 guest]# ill be right back. i am soooo hungry.haven eaten yet today Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 WAIT !One more command in PCLos. . . . # cp -rd /usr/lib/mozilla/plugins/*  /mnt/hda7/usr/lib/mozilla/plugins/ To copy over the browser-plugins ! . . . . . If you get questions about overwriting say: YES !! Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 ok,done.i didnt get a question about overwriting.shouldnt we do i for other browsers too before i reboot to mandrake?for now i only have galeon and konuquer out there i think. Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 Nope . . . the directory all the browsers look for plugins is the /usr/lib/mozilla/plugins/ . . . just reboot into Drake and check if they are there Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 ok am back this time in mandrake.no problems with the reboot.the only thing about it is that it takes really long to start it.it always stops at entering non-interactive startup or at starting netprofile or two lines up at init level 5.then i have to wait like 3min or so.also,java doesnt work yet,not in the konqueror at least Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 For java to work in Konqueror:Settings --> Configure Konqueror . . . . . then on the section "Plugins" push the button "Scan for new plugins" . . . and in the section "Java" in the "Path to Java execautable, or java" fill in the path ( but check the path first !! because I am not in PCLos right now and have another java in my Drake !)It should be something like:/usr/lib/mozilla/plugins/java/j2re1.4.2_05/bin/javaDo this first and we will tackle the boot after ! Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 but it does work in galeon no sound though,i got a soundserver-the KDE crash handler popup saying:the application soundserver (artsd) crashed and caused the signal 11 (sigsegv)an application mostly receives the sigsegv signal due to a bug in the application.the application was asked to save its documents. Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 but it does work in galeon no sound though,i got a soundserver-the KDE crash handler popup saying:the application soundserver (artsd) crashed and caused the signal 11 (sigsegv)an application mostly receives the sigsegv signal due to a bug in the application.the application was asked to save its documents.We will need a bug-fix for that one then :DB) Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 no problem Bruno.ill do it but anyway i hardly ever use konqueror.prefer firefox. one thing,can i copy everything form pclos to mandrake using command line?i was thinking about the music and media files i have already gathered in pclos. Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 does it mean we will have to wait till someone comes up with the fix?and should i send a bug report? Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 Yep . . # mkdir /mnt/hda5# mount /dev/hda5 /mnt/hda5 Then the PCLos partition is mounted and you can copy over files :DBetter umount it when you are done: # umount /mnt/hda5 Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 does it mean we will have to wait till someone comes up with the fix?and should i send a bug report?Did you do the things I told you to do in Konqueror ?? Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 well,not yet but i got this error in galeon Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 In Galeon ?? I use galeon all the time and have no problem . . . ( Galeon 1.3.17 ) Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 ill try it one more time then.now maybe ill get the installs i need Quote Link to comment Share on other sites More sharing options...
Bruno Posted January 28, 2005 Share Posted January 28, 2005 For the extra software you need to add a source:This command is ONE line: urpmi.addmedia contrib_ftp.nluug.nl_i586_10.1Official ftp://ftp.nluug.nl/pub/os/Linux/distr/Mandrakelinux/official/10.1/i586/media/contrib/ with ./media_info/hdlist.cz After that you can sure get more of the stuff in my list :DB) Bruno Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 thnx Bruno.i am going over there to get what i need Quote Link to comment Share on other sites More sharing options...
gauchoperezoso Posted January 28, 2005 Author Share Posted January 28, 2005 hey!! the sound works in epiphany-bin.i think it will also work on any other browser .i am nothing but impressed by mandrake Quote Link to comment Share on other sites More sharing options...
