NEW UPDATES Debian
Started by
Bruno
, Feb 28 2009 02:13 PM
debian updates sunrat bruno v.t. eric layton
1536 replies to this topic
#1526 OFFLINE
Posted 01 February 2019 - 08:39 PM
Debian Security Advisory DSA-4379-1 security@debian.org
https://www.debian.org/security/ Moritz Muehlenhoff
February 01, 2019 https://www.debian.org/security/faq
Package : golang-1.7
CVE ID : CVE-2018-7187 CVE-2019-6486
A vulnerability was discovered in the implementation of the P-521 and
P-384 elliptic curves, which could result in denial of service and in
some cases key recovery.
In addition this update fixes a vulnerability in "go get", which could
result in the execution of arbitrary shell commands.
For the stable distribution (stretch), these problems have been fixed in
version 1.7.4-2+deb9u1.
Debian Security Advisory DSA-4380-1 security@debian.org
Package : golang-1.8
CVE ID : CVE-2018-6574 CVE-2018-7187 CVE-2019-6486
In addition this update fixes two vulnerabilities in "go get", which
could result in the execution of arbitrary shell commands.
version 1.8.1-1+deb9u1.
registered Linux user number 324659 || The importance of Reading The *Fine* Manual! :D
#1527 OFFLINE
Posted 03 February 2019 - 06:06 PM
Debian Security Advisory DSA-4381-1 security@debian.org
February 02, 2019 https://www.debian.org/security/faq
Package : libreoffice
CVE ID : CVE-2018-16858
Alex Infuehr discovered a directory traversal vulnerability which could
result in the execution of Python script code when opening a malformed
document.
For the stable distribution (stretch), this problem has been fixed in
version 1:5.2.7-1+deb9u5. In addition this update fixes a bug in the
validation of signed PDFs; it would display an incomplete status message
when dealing with a partial signature.
Debian Security Advisory DSA-4382-1 security@debian.org
Package : rssh
CVE ID : CVE-2019-3463 CVE-2019-3464
Nick Cleaton discovered two vulnerabilities in rssh, a restricted shell
that allows users to perform only scp, sftp, cvs, svnserve (Subversion),
rdist and/or rsync operations. Missing validation in the rsync support
could result in the bypass of this restriction, allowing the execution
version 2.3.4-5+deb9u2.
Debian Security Advisory DSA-4383-1 security@debian.org
https://www.debian.org/security/ Salvatore Bonaccorso
February 03, 2019 https://www.debian.org/security/faq
Package : libvncserver
CVE ID : CVE-2018-6307 CVE-2018-15126 CVE-2018-15127 CVE-2018-20019
CVE-2018-20020 CVE-2018-20021 CVE-2018-20022 CVE-2018-20023
CVE-2018-20024
Debian Bug : 916941
Pavel Cheremushkin discovered several vulnerabilities in libvncserver, a
library to implement VNC server/client functionalities, which might result in
the execution of arbitrary code, denial of service or information disclosure.
version 0.9.11+dfsg-1.3~deb9u1.
document.
Package : rssh
CVE-2018-20024
Debian Bug : 916941
#1528 OFFLINE
Posted 05 February 2019 - 09:01 PM
Debian Security Advisory DSA-4384-1 security@debian.org
February 04, 2019 https://www.debian.org/security/faq
Package : libgd2
CVE ID : CVE-2019-6977 CVE-2019-6978
Debian Bug : 920645 920728
Multiple vulnerabilities have been discovered in libgd2, a library for
programmatic graphics creation and manipulation, which may result in
denial of service or potentially the execution of arbitrary code if a
malformed file is processed.
version 2.2.4-2+deb9u4.
Debian Security Advisory DSA-4385-1 security@debian.org
February 05, 2019 https://www.debian.org/security/faq
Package : dovecot
CVE ID : CVE-2019-3814
halfdog discovered an authentication bypass vulnerability in the Dovecot
email server. Under some configurations Dovecot mistakenly trusts the
username provided via authentication instead of failing. If there is no
additional password verification, this allows the attacker to login as
anyone else in the system. Only installations using:
auth_ssl_require_client_cert = yes
auth_ssl_username_from_cert = yes
are affected by this flaw.
version 1:2.2.27-3+deb9u3.
Package : libgd2
Package : dovecot
#1529 OFFLINE
Posted 06 February 2019 - 07:20 PM
Debian Security Advisory DSA-4386-1 security@debian.org
https://www.debian.org/security/ Alessandro Ghedini
February 06, 2019 https://www.debian.org/security/faq
Package : curl
CVE ID : CVE-2018-16890 CVE-2019-3822 CVE-2019-3823
Multiple vulnerabilities were discovered in cURL, an URL transfer library.
CVE-2018-16890
Wenxiang Qian of Tencent Blade Team discovered that the function
handling incoming NTLM type-2 messages does not validate incoming
data correctly and is subject to an integer overflow vulnerability,
which could lead to an out-of-bounds buffer read.
CVE-2019-3822
creating an outgoing NTLM type-3 header is subject to an integer
overflow vulnerability, which could lead to an out-of-bounds write.
CVE-2019-3823
Brian Carpenter of Geeknik Labs discovered that the code handling
the end-of-response for SMTP is subject to an out-of-bounds heap
read.
version 7.52.1-5+deb9u9.
Package : curl
CVE-2018-16890
CVE-2019-3822
CVE-2019-3823
read.
#1530 OFFLINE
Posted 09 February 2019 - 06:56 PM
Debian Security Advisory DSA-4387-1 security@debian.org
https://www.debian.org/security/ Yves-Alexis Perez
February 09, 2019 https://www.debian.org/security/faq
Package : openssh
CVE ID : CVE-2018-20685 CVE-2019-6109 CVE-2019-6111
Debian Bug : 793412 919101
Harry Sintonen from F-Secure Corporation discovered multiple vulnerabilities in
OpenSSH, an implementation of the SSH protocol suite. All the vulnerabilities
are in found in the scp client implementing the SCP protocol.
CVE-2018-20685
Due to improper directory name validation, the scp client allows servers to
modify permissions of the target directory by using empty or dot directory
name.
CVE-2019-6109
Due to missing character encoding in the progress display, the object name
can be used to manipulate the client output, for example to employ ANSI
codes to hide additional files being transferred.
CVE-2019-6111
Due to scp client insufficient input validation in path names sent by
server, a malicious server can do arbitrary file overwrites in target
directory. If the recursive (-r) option is provided, the server can also
manipulate subdirectories as well.
The check added in this version can lead to regression if the client and
the server have differences in wildcard expansion rules. If the server is
trusted for that purpose, the check can be disabled with a new -T option to
the scp client.
version 1:7.4p1-10+deb9u5.
Package : openssh
CVE-2018-20685
name.
CVE-2019-6109
CVE-2019-6111
the scp client.
#1531 OFFLINE
Posted 11 February 2019 - 08:16 AM
Debian Security Advisory DSA-4388-1 security@debian.org
February 10, 2019 https://www.debian.org/security/faq
Package : mosquitto
CVE ID : CVE-2018-12546 CVE-2018-12550 CVE-2018-12551
Three vulnerabilities were discovered in the Mosquitto MQTT broker, which
could result in authentication bypass. Please refer to
https://mosquitto.or...1-5-6-released/ for additional
information.
version 1.4.10-3+deb9u3.
Package : mosquitto
information.
#1532 OFFLINE
Posted 11 February 2019 - 08:48 PM
Debian Security Advisory DSA-4389-1 security@debian.org
https://www.debian.org/security/ Sebastien Delafond
February 11, 2019 https://www.debian.org/security/faq
Package : libu2f-host
CVE ID : CVE-2018-20340
Debian Bug : 921725
Christian Reitter discovered that libu2f-host, a library implementing
the host-side of the U2F protocol, failed to properly check for a
buffer overflow. This would allow an attacker with a custom made
malicious USB device masquerading as a security key, and physical
access to a computer where PAM U2F or an application with libu2f-host
integrated, to potentially execute arbitrary code on that computer.
version 1.1.2-2+deb9u1.
Debian Security Advisory DSA-4377-2 security@debian.org
Package : rssh
Debian Bug : 921655
The update for rssh issued as DSA 4377-1 introduced a regression that
blocked scp of multiple files from a server using rssh. Updated packages
are now available to correct this issue.
version 2.3.4-5+deb9u3.
Debian Bug : 921725
Package : rssh
Debian Bug : 921655
#1533 OFFLINE
Posted 12 February 2019 - 08:27 PM
Debian Security Advisory DSA-4390-1 security@debian.org
February 12, 2019 https://www.debian.org/security/faq
Package : flatpak
CVE ID : not yet available
Debian Bug : 922059
It was discovered that Flatpak, an application deployment framework for
desktop apps, insufficiently restricted the execution of "apply_extra"
scripts which could potentially result in privilege escalation.
version 0.8.9-0+deb9u2.
Package : flatpak
Debian Bug : 922059
#1534 OFFLINE
Posted 14 February 2019 - 07:12 PM
Debian Security Advisory DSA-4391-1 security@debian.org
February 14, 2019 https://www.debian.org/security/faq
Package : firefox-esr
CVE ID : CVE-2018-18356 CVE-2019-5785
Multiple security issues have been found in the Mozilla Firefox web
browser, which could potentially result in the execution of arbitrary
code.
version 60.5.1esr-1~deb9u1.
code.
#1535 OFFLINE
Posted 18 February 2019 - 05:25 PM
The Debian Project https://www.debian.org/
Updated Debian 9: 9.8 released press@debian.org
February 16th, 2019 https://www.debian.o...s/2019/20190216
The Debian project is pleased to announce the eighth update of its
stable distribution Debian 9 (codename "stretch"). This point release
mainly adds corrections for security issues, along with a few
adjustments for serious problems. Security advisories have already been
published separately and are referenced where available.
Please note that the point release does not constitute a new version of
Debian 9 but only updates some of the packages included. There is no
need to throw away old "stretch" media. After installation, packages can
be upgraded to the current versions using an up-to-date Debian mirror.
Those who frequently install updates from security.debian.org won't have
to update many packages, and most such updates are included in the point
release.
New installation images will be available soon at the regular locations.
The complete lists of packages that have changed with this revision:
http://ftp.debian.or...retch/ChangeLog
Debian Security Advisory DSA-4392-1 security@debian.org
February 16, 2019 https://www.debian.org/security/faq
Package : thunderbird
CVE ID : CVE-2018-18356 CVE-2018-18500 CVE-2018-18501
CVE-2018-18505 CVE-2018-18509 CVE-2019-5785
Multiple security issues have been found in the Thunderbird mail client,
which could lead to the execution of arbitrary code, denial of service
or spoofing of S/MIME signatures.
version 1:60.5.1-1~deb9u1.
Debian Security Advisory DSA-4388-2 security@debian.org
February 17, 2019 https://www.debian.org/security/faq
Package : mosquitto
Debian Bug : 922071
Kushal Kumaran reported that the update for mosquitto issued as DSA
4388-1 causes mosquitto to crash when reloading the persistent database.
Updated packages are now available to correct this issue.
version 1.4.10-3+deb9u4.
Debian Security Advisory DSA-4393-1 security@debian.org
February 18, 2019 https://www.debian.org/security/faq
Package : systemd
CVE ID : CVE-2019-6454
Chris Coulson discovered a flaw in systemd leading to denial of service.
An unprivileged user could take advantage of this issue to crash PID1 by
sending a specially crafted D-Bus message on the system bus.
version 232-25+deb9u9.
release.
Package : mosquitto
Debian Bug : 922071
Package : systemd
#1536 OFFLINE
Posted Yesterday, 12:35 AM
Debian Security Advisory DSA-4394-1 security@debian.org
Package : rdesktop
CVE ID : CVE-2018-8791 CVE-2018-8792 CVE-2018-8793 CVE-2018-8794
CVE-2018-8795 CVE-2018-8796 CVE-2018-8797 CVE-2018-8798
CVE-2018-8799 CVE-2018-8800 CVE-2018-20174
CVE-2018-20175 CVE-2018-20176 CVE-2018-20177
CVE-2018-20178 CVE-2018-20179 CVE-2018-20180
CVE-2018-20181 CVE-2018-20182
Multiple security issues were found in the rdesktop RDP client, which
could result in denial of service, information disclosure and the
execution of arbitrary code.
version 1.8.4-1~deb9u1.
Debian Security Advisory DSA-4395-1 security@debian.org
https://www.debian.org/security/ Michael Gilbert
Package : chromium
CVE ID : CVE-2018-17481 CVE-2019-5754 CVE-2019-5755 CVE-2019-5756
CVE-2019-5757 CVE-2019-5758 CVE-2019-5759 CVE-2019-5760
CVE-2019-5762 CVE-2019-5763 CVE-2019-5764 CVE-2019-5765
CVE-2019-5766 CVE-2019-5767 CVE-2019-5768 CVE-2019-5769
CVE-2019-5770 CVE-2019-5772 CVE-2019-5773 CVE-2019-5774
CVE-2019-5775 CVE-2019-5776 CVE-2019-5777 CVE-2019-5778
CVE-2019-5779 CVE-2019-5780 CVE-2019-5781 CVE-2019-5782
CVE-2019-5783 CVE-2019-5784
Several vulnerabilities have been discovered in the chromium web browser.
CVE-2018-17481
A use-after-free issue was discovered in the pdfium library.
CVE-2019-5754
Klzgrad discovered an error in the QUIC networking implementation.
CVE-2019-5755
Jay Bosamiya discovered an implementation error in the v8 javascript
library.
CVE-2019-5756
CVE-2019-5757
Alexandru Pitis discovered a type confusion error in the SVG image
format implementation.
CVE-2019-5758
Zhe Jin discovered a use-after-free issue in blink/webkit.
CVE-2019-5759
Almog Benin discovered a use-after-free issue when handling HTML pages
containing select elements.
CVE-2019-5760
Zhe Jin discovered a use-after-free issue in the WebRTC implementation.
CVE-2019-5762
CVE-2019-5763
Guang Gon discovered an input validation error in the v8 javascript
library.
CVE-2019-5764
Eyal Itkin discovered a use-after-free issue in the WebRTC implementation.
CVE-2019-5765
Sergey Toshin discovered a policy enforcement error.
CVE-2019-5766
David Erceg discovered a policy enforcement error.
CVE-2019-5767
Haoran Lu, Yifan Zhang, Luyi Xing, and Xiaojing Liao reported an error
in the WebAPKs user interface.
CVE-2019-5768
Rob Wu discovered a policy enforcement error in the developer tools.
CVE-2019-5769
Guy Eshel discovered an input validation error in blink/webkit.
CVE-2019-5770
hemidallt discovered a buffer overflow issue in the WebGL implementation.
CVE-2019-5772
Zhen Zhou discovered a use-after-free issue in the pdfium library.
CVE-2019-5773
Yongke Wong discovered an input validation error in the IndexDB
implementation.
CVE-2019-5774
Jnghwan Kang and Juno Im discovered an input validation error in the
SafeBrowsing implementation.
CVE-2019-5775
evil1m0 discovered a policy enforcement error.
CVE-2019-5776
Lnyas Zhang discovered a policy enforcement error.
CVE-2019-5777
Khalil Zhani discovered a policy enforcement error.
CVE-2019-5778
David Erceg discovered a policy enforcement error in the Extensions
implementation.
CVE-2019-5779
David Erceg discovered a policy enforcement error in the ServiceWorker
implementation.
CVE-2019-5780
Andreas Hegenberg discovered a policy enforcement error.
CVE-2019-5781
CVE-2019-5782
Qixun Zhao discovered an implementation error in the v8 javascript library.
CVE-2019-5783
Shintaro Kobori discovered an input validation error in the developer
tools.
CVE-2019-5784
Lucas Pinheiro discovered an implementation error in the v8 javascript
library.
version 72.0.3626.96-1~deb9u1.
Package : rdesktop
Package : chromium
CVE-2018-17481
CVE-2019-5754
CVE-2019-5755
library.
CVE-2019-5756
CVE-2019-5757
CVE-2019-5758
CVE-2019-5759
CVE-2019-5760
CVE-2019-5762
CVE-2019-5763
library.
CVE-2019-5764
CVE-2019-5765
CVE-2019-5766
CVE-2019-5767
CVE-2019-5768
CVE-2019-5769
CVE-2019-5770
CVE-2019-5772
CVE-2019-5773
implementation.
CVE-2019-5774
CVE-2019-5775
CVE-2019-5776
CVE-2019-5777
CVE-2019-5778
implementation.
CVE-2019-5779
implementation.
CVE-2019-5780
CVE-2019-5781
CVE-2019-5782
CVE-2019-5783
tools.
CVE-2019-5784
library.
#1537 OFFLINE
Posted Yesterday, 07:48 PM
Debian Security Advisory DSA-4396-1 security@debian.org
February 19, 2019 https://www.debian.org/security/faq
Package : ansible
CVE ID : CVE-2018-10855 CVE-2018-10875 CVE-2018-16837 CVE-2018-16876
CVE-2019-3828
Several vulnerabilities have been found in Ansible, a configuration
management, deployment, and task execution system:
CVE-2018-10855 / CVE-2018-16876
The no_log task flag wasn't honored, resulting in an information leak.
CVE-2018-10875
ansible.cfg was read from the current working directory.
CVE-2018-16837
The user module leaked parameters passed to ssh-keygen to the process
environment.
CVE-2019-3828
The fetch module was susceptible to path traversal.
version 2.2.1.0-2+deb9u1.
Package : ansible
CVE-2019-3828
CVE-2018-10875
CVE-2018-16837
environment.
CVE-2019-3828
Also tagged with one or more of these keywords: debian, updates, sunrat, bruno, v.t. eric layton
The Highlands →
Bruno's All Things Linux →
Debian point release 9.7 for apt vulnerabilityStarted by sunrat , 23 Jan 2019 ![]() |
The Highlands →
Neptune OS installationStarted by sunrat , 22 Jan 2019 ![]() |
The Highlands →
MX-18 Continuum Now AvailableStarted by abarbarian , 22 Dec 2018 ![]() |
The Highlands →
Debian Linux founder Ian Murdock dies at 42Started by abarbarian , 21 Dec 2018 ![]() |
The Highlands →
Happy Birthday Debian!Started by sunrat , 16 Aug 2018 ![]() |
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
