mike180 Posted May 25, 2003 Posted May 25, 2003 While I have gone to great trouble to install the updated Nvidia drivers (ver #4363). I sure wish I hadn't. I am having to view the Forum and Post this message while in Root. All of my fonts in /home/mike are little rounded squares. ???? WHY ???? While my icons and everything else are correct and I can run glxgears now (top speed over 7,500fps.). Slowed down to 3,200fps. There is no way to work with that kind of display. Made it to the WWW and the little rounded Squares were all over the place. By the way. Thank you GolfProRM for the tip. I had done everything as you wrote but, had not know to :wq, so all I was doing was make files and saving them. . Had four copies all over my hd. I am running a GeForce 4 4200Ti with 128Mbs DDR Ram 8x card in a 4x AGP slot. Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Hi Mike,This is very strange, never heard about this one before !If I understand you right, as long as you are root all is O.K., just logged in as user the fonds are messed up ?Can you confirm that please. Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 Hey Bruno, Yes, sure is strange. Must be some frequence change in Refresh rate. That can't be right. Thinking is all messed up. Been working on this all night. 4:42am, now Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 as long as you are root all is O.K. Is THIS correct ? Bruno Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Mike the solution is simple:Open a terminal/console and make a new user: ( have to be root to do this )< adduser > ( without the < > )After setting up that user and giving that user a password. Log out as root and log in as that new user. See if the fonds are O.K. Then log out as the new user and log in as root. Copy the relevant files from the old user to the new user and delete the old user when finished !Don´t copy the .kde and .gnome directories ! Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 OK going to try. By the way, I just killed X and while I was there it said I had new mail. What is that? Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 it said I had new mail. What is that? That is an internally send error message to root, ignore it ! Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 OK, I must admit that I got lost trying to add a user. I Don't know how . Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Just login as root, you probably are already, open a console where you get a prompt, and type < adduser > ( without the < > ) and follow the text you get on the screen. Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 I tried that.at prompt adduser -u /newname -p /newpassword invialid arguement newnametrying to get my Knoppix working so I can post and do as you tell me but cannot get the WWW working without a password to setup the cable modem. Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 [root@localhost root]# adduser -uadduser: option requires an argument -- uusage: adduser [-u uid [-o]] [-g group] [-G group,...] [-d home] [-s shell] [-c comment] [-m [-k template]] [-f inactive] [-e expire ] [-p passwd] [-M] [-n] [-r] name adduser -D [-g group] [-b base] [-s shell] [-f inactive] [-e expire ][root@localhost root]# A little help here. do i use the brackets. adduser [ -u mike8 [-o]]like that Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 tried <adduser mike2> and did not work without < > Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Have a look, clicking, in your /home directory, NOT /home/mike1, but one level higher ! Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 Might as well do a new install and get the 277MBs download again. I am starting to get mad because I am out of coffee and I could really use a cold beer. Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 NO Mike !Do you have Mandrake ?In Mandrake use the GUI --> Menu --> configuration --> Other --> Userdrake And add the new user there. Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 Jezz got four different mikes in there now. wonder what their password is? Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 No password needed for a tempMike.Now log out and log in as one of those mike´sB) Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 I'm going to see now. Be right back. I hope. Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Okie dokie ! See you soon. Just stay calm, we will sort this out ! Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 login incorrect Bruno "Do you have Mandrake ?"Yes MDK9.1 Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Add a user this way:In Mandrake use the GUI --> Menu --> configuration --> Other --> Userdrake Call it ¨tempmike¨ and give him a password.Then try again loging-in as tempmikeB) Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 Why o Why didn't I think of that.Knew it was there! Be right back. Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 Using Knoppix on old machine.So now fonts still don't work.and I've got my coffee. Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Mike I´m afraid you messed up your /etc/X11/XFConfig-4 file. You told us that you had the ¨:wq¨ problem and several of the same files laying around.Go to /etc/X11 ( clicking ) and have a look, I have 2 files there: XFConfig and XFConfing-4 ! Tell me what you have got in /X11. ( only the XFConfig files )Do not take any drastic measures yet, just report back to me. Bruno Quote
mike180 Posted May 25, 2003 Author Posted May 25, 2003 Ran system log and found a security warning at 01:26:57.Security Warning: Change in World Writable Files found:-No longer present writable file: /tmp/.ICE-unix /tmp/.font-unix /tmp/.font-unix/fs-1also security warning: There are modifications for port listening on your machine: Quote
Bruno Posted May 25, 2003 Posted May 25, 2003 Yes but root still has fonts it can use, so we must be able to set things right. Bruno Quote
