Bruno Posted December 7, 2006 Share Posted December 7, 2006 Here is the idea: You have Mandriva running on a Laptop, and you want to share the experience so that people with the same laptop know what distro to install.Please copy the next report to your post and fill in the details:**********Model:Videocard:Network:Wifi:Bluetooth:Webcam:Touchpad:Hotkey (Home, Eject, Suspend ...):Display:OS:Kernel:Suspend on Disk:Suspend on RAM:Comments:**********We will collect all the data in the 2nd post ( that is why it is empty now ) Your All Things Linux Mod Team Quote Link to comment Share on other sites More sharing options...
Bruno Posted December 7, 2006 Author Share Posted December 7, 2006 ( This is to collect data ) -- Kamicota Model: HP DV5020CA (Canadian version of DV5000US)Videocard: ATI MOBILITY RADEON Xpress 200 seriesNetwork: as below Wifi: Broadcom 802.11b/g WLANBluetooth:Webcam: NoneTouchpad: yes and external USB keytronicHotkey (Home, Eject, Suspend ...):Display: 1280x800 OS: Mandriva 2007 64bits Kernel: 26.17-5mdv Suspend on Disk: Suspend on RAM:Comments: -- striker Model:ACER Travelmate 6465WLMi - Intel® Core2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard:ATI Technologies Inc.M52 [Mobility Radeon X1300]/ driver ATI 8.34.8Network:Broadcom NetLink BCM5787M Gigabit Ethernet PCI ExpressWifi:Intel PRO/Wireless 3945ABG, works out of the boxBluetooth: not testedWebcam:Acer Orbicam (SuYin) > works with Ekiga, Kopete (use v4l2)Touchpad:works OK > Trackpoint also works OKHotkey (Home, Eject, Suspend ...):I don't use theseDisplay:15.4" matte display business class 1680x1050OS:Mandriva Spring (2007.1)Kernel:stock 2.6.17-13mdvSuspend on Disk: I don't use thisSuspend on RAM: I don't use thisComments:Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller, works out of the box with alsa 1.0.12;Display and ATI driver were installed and set up correctly out of the box. Mandriva Spring 'One' KDE used : of the distros out there it's oneof the very few which detects,recognizes and handles this notebook well.Webcam took some reseach but works.Wireless works with the set up tools provided wth the distro out of the box, after setting it up reboot and switch on the wireless network.The Powerdown feature seems to have a bug (?) : if you start in init3 mode Mandy hangs on it, when you start in init5 it might take a minutebut then it starts through; Also at first possibility you can't enter your username and password : click the session button and select restart x server,now you can enter the credentials and hit the enter button. -- Anil Model:Acer Aspire 4710Z Intel® Pentium® dual-core T2080Videocard:Mobile Intel® 943GML Express Chipset with integrated 3D graphicsNetwork:Gigabit Ethernet, Wake-on-LAN readyWifi:Acer InviLink 802.11b/g Wi-Fi CERTIFIEDBluetooth:Bluetooth® 2.0+EDR (Enhanced Data Rate)Webcam:Integrated Acer Crystal Eye webcamTouchpad:Seamless touchpad with 4-way scroll buttonHotkey (Home, Eject, Suspend ...):Most of them functionDisplay:14.1" WXGA high-brightness (200-nit) TFT LCD, multi-window viewingOS:Mandriva 2008.0Kernel:2.6.22.9Suspend on Disk: worksSuspend on RAM: worksComments:Mandriva 2008 installed flawlessly. wifi, sound, screen resolution, 3d etc worked out of Box. 5-in-1 card reader is detected but only SD card works. Most of the Hot Keys function without any problems. I went to keyboard setup and chose laptop mode for Acer. -- striker Model: ACER Travelmate 6465WLMi -- Intel® Core™2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard: ATI Technologies Inc.M52 Mobility Radeon X1300 (128MB) / ATI driver version 8.40.4Network: NetLink BCM5787M Gigabit Ethernet PCI Express > worksWifi: PRO/Wireless 3945ABG Network Connection > works with manual edit in network set upBluetooth: Bluetooth® 2.0+EDR (Enhanced Data Rate) > can't test due to lack of BT equipmentWebcam: Acer Orbicam works with Ekiga and v4l2 driver, works with Kopete.Touchpad: works, Trackpoint also worksHotkey (Home, Eject, Suspend ...):special Acer buttons (4) not configured; Home, End, PgUp and PgDn work.Display: 15.4" matte display 1680 x 1050 (24bit used in video driver)OS: Mandriva 2008 "One" / KDE i586Kernel: 2.6.22.9-desktop586-1mdvSuspend on Disk: I don't use thisSuspend on RAM: I don't use thisComments: (7240 frames in 5.0 seconds = 1447.807 FPS)- direct rendering:YES Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller works out of the box(Alsa 1.0.14), just cranck up the volume a bit in kMix.If you need more 'power' use active speakers with volume control. Cooling fan of laptop works, goes up in rpms when it should and down when the laptop has cooled down. Card reader may work but not with xD Picture Card, I don't have other types (like SD) so I can't test that any further, albeit the driver is loaded. Display brightness up and down buttons work. -- striker Model: ACER Travelmate 6465WLMi -- Intel® Core™2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard: ATI Technologies Inc.M52 Mobility Radeon X1300 (128MB) / ATI driver version 8.40.4Network: NetLink BCM5787M Gigabit Ethernet PCI Express > worksWifi: PRO/Wireless 3945ABG Network Connection > had to fiddle a bit but it works nowBluetooth: Bluetooth® 2.0+EDR (Enhanced Data Rate) > can't test due to lack of BT equipmentWebcam: Acer Orbicam works with Ekiga and v4l2 driver, not tested with Kopete but probably works.Touchpad: works, Trackpoint also worksHotkey (Home, Eject, Suspend ...):special Acer buttons (4) not configured; Home, End, PgUp and PgDn work.Display: 15.4" matte display 1680 x 1050 (24bit used in video driver)OS: Mandriva 2008 "Free" x86_64Kernel: 2.6.22.9-laptop-1mdvSuspend on Disk: I don't use thisSuspend on RAM: I don't use thisComments: (7285 frames in 5.0 seconds = 1456.804 FPS)- direct rendering:YES Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller works out of the box(Alsa 1.0.14), just cranck up the volume a bit in kMix.If you need more 'power' use active speakers with volume control. Cooling fan of laptop works, goes up in rpms when it should and down when the laptop has cooled down. Card reader may work but not with xD Picture Card, I don't have other types (like SD) so I can't test that any further, albeit the driver is loaded. Display brightness up and down buttons work. -- striker Model: ACER Travelmate 6465WLMi -- Intel® Core™2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard: ATI Technologies Inc.M52 Mobility Radeon X1300 (128MB) / ATI driver version 8.40.4Network: NetLink BCM5787M Gigabit Ethernet PCI Express > worksWifi: PRO/Wireless 3945ABG Network Connection > had to fiddle a bit but it works nowBluetooth: Bluetooth® 2.0+EDR (Enhanced Data Rate) > works OK with k320i mobile phone (KDE); also Blue LED at front of laptop lights up when accessing the front mounted switch.Webcam: Acer Orbicam works with Ekiga and v4l2 driver, not tested with Kopete but probably works.Touchpad: works, Trackpoint also worksHotkey (Home, Eject, Suspend ...):special Acer buttons (4) work **; Home, End, PgUp and PgDn work. (** see : http://forums.scotsnewsletter.com/index.php?showtopic=20010 )Display: 15.4" matte display 1680 x 1050 (24bit used in video driver)OS: Mandriva 2008 "Free" x86_64Kernel: 2.6.22.12-laptop-1mdvSuspend on Disk: I don't use thisSuspend on RAM: worksComments: (7285 frames in 5.0 seconds = 1456.804 FPS)- direct rendering:YES Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller works out of the box(Alsa 1.0.14), just cranck up the volume a bit in kMix.If you need more 'power' use active speakers with volume control. Cooling fan of laptop works, goes up in rpms when it should and down when the laptop has cooled down. Card reader works perfectly with Sandisk SD card but not with xD Picture Cards, I don't use other types (like MMC) so I can't test that any further, albeit the driver is loaded. Display brightness up and down buttons work. For the suspend to RAM you may read this post to get it in working state: http://forums.scotsnewsletter.com/index.php?showtopic=20003 --rakemup Model: Dell Vostro 1500 - 2.2GHz --Intel® Core™2 Duo CPUVideocard: Model: NVidia GeForce 8600M GTNetwork: Intel Pro/Wireless 4965 AGN linking to Linksys300N routerWifi: Bluetooth: untriedWebcam: noneTouchpad: yes - works fineHotkey (Home, Eject, Suspend ...): untriedDisplay: 1680x1050OS: Mandriva2008 / XPKernel: 2.6.22.18-laptop-1mdvSuspend on Disk: unknownSuspend on RAM: unknownComments: I first tried a Linksy 330N router but it would only connect for 5 minutes at a time. The sound card will not record. No other problems. -- Bruno Model: ASUS EeePC 701 4GB ( Celeron M processor 900MHz )Videocard: Intel Mobile 915GM/GMS/910GML Express Graphics ControllerNetwork: Attansic Technology Corp. L2 100 Mbit Ethernet AdapterWifi: Atheros Communications AR5000GEG 802.11 b/g ( Madwifi driver )Bluetooth: noneWebcam: WorksTouchpad: YesHotkey's (Home, Eject, Suspend ...): All work great like with the default Xandros-simpleDisplay: OS: Mandriva 2008.1 Spring PowerPackKernel: 2.6.24.4-laptop-3mnbSuspend on Disk: Works fineSuspend on RAM: Works fineComments: Everything is supported, works out of the box. -- Anil Model: ASUS EeePC 701 4GB ( Celeron M processor 900MHz )Videocard: Intel Mobile 915GM/GMS/910GML Express Graphics ControllerNetwork: Attansic Technology Corp. L2 100 Mbit Ethernet AdapterWifi: Atheros Communications AR5000GEG 802.11 b/g ( Madwifi driver )Bluetooth: WorksWebcam: WorksTouchpad: YesHotkey's (Home, Eject, Suspend ...): WorksDisplay: 1024x768OS: Mandriva 2009 ONE-KDE4Kernel: 2.6.27.5-desktop586-2mnbSuspend on Disk: WorksSuspend on RAM: Works Comments: Everything is supported, works out of the box(almost) ( This is to collect data ) Quote Link to comment Share on other sites More sharing options...
kamicota Posted December 8, 2006 Share Posted December 8, 2006 (edited) Well here we goWe may need to update it later--->>>Model: HP DV5020CA (Canadian version of DV5000US)Videocard: ATI MOBILITY RADEON Xpress 200 seriesNetwork: as below Wifi: Broadcom 802.11b/g WLANBluetooth:Webcam: NoneTouchpad: yes and external USB keytronicHotkey (Home, Eject, Suspend ...):Display: 1280x800 (In AA Rehab) Using 1280x1024 Dell LCD Flat Panel via KVM OS: Mandriva 2007 64 (for now)Kernel: Linux localhost 2.6.17-5mdv #1 SMP Wed Sep 13 14:28:02 EDT 2006 x86_64 AMD Turio n 64 Mobile Technology ML-32 GNU/LinuxSuspend on Disk: Do NOT KNOW ABOUT THESE TWO Suspend on RAM:Comments: a little patience please MOI in middle of CHANGES Cheers for YearsColin Edited December 9, 2006 by Bruno Quote Link to comment Share on other sites More sharing options...
striker Posted December 30, 2006 Share Posted December 30, 2006 ( This is to collect data ) -- Piet (not registered)* Model:TOSHIBA S1900-203Videocard:ATI Mobility Radeon (M6)Network:Intel® PRO/100 VE Network Connection > worksWifi:not usedBluetooth:not usedWebcam:not usedTouchpad:not used, USB mini mouse connectedHotkey (Home, Eject, Suspend ...):Home key works, others not usedDisplay:1024x768OS:Mandriva 2006Kernel:2.6.12-12mdkSuspend on Disk:not usedSuspend on RAM:not usedComments:Intel Brookdale i845D mainboard chipset;512 MB(DDR SDRAM);PCMCIA+USB works;*: profile provided by striker ( This is to collect data ) Quote Link to comment Share on other sites More sharing options...
striker Posted February 2, 2007 Share Posted February 2, 2007 ( This is to collect data ) -- Piet (not registered)* Model:TOSHIBA S1900-203Videocard:ATI Mobility Radeon (M6)Network:Intel® PRO/100 VE Network Connection > worksWifi:not usedBluetooth:not usedWebcam:not usedTouchpad:not used, USB mini mouse connectedHotkey (Home, Eject, Suspend ...):Home key works, others not usedDisplay:1024x768OS:Mandriva 2007.0Kernel:2.6.17-5mdkSuspend on Disk:not usedSuspend on RAM:not usedComments:Intel Brookdale i845D mainboard chipset;512 MB(DDR SDRAM);PCMCIA+USB works; *: profile provided by striker ( This is to collect data ) Quote Link to comment Share on other sites More sharing options...
striker Posted September 13, 2007 Share Posted September 13, 2007 Yes, finally took the plunge and got myself a notebook !Model:ACER Travelmate 6465WMLi - Intel® Core2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard:ATI Technologies Inc.M52 [Mobility Radeon X1300]/ driver ATI 8.34.8Network:Broadcom NetLink BCM5787M Gigabit Ethernet PCI ExpressWifi:Intel PRO/Wireless 3945ABG, works out of the boxBluetooth: not testedWebcam:Acer Orbicam (SuYin) > works with Ekiga (use v4l2), Kopete.Touchpad:works OK > Trackpoint also works OKHotkey (Home, Eject, Suspend ...):I don't use theseDisplay:15.4" matte display 1680x1050OS:Mandriva Spring (2007.1)Kernel:stock 2.6.17-13mdvSuspend on Disk:I don't use theseSuspend on RAM:I don't use theseComments:Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller, works out of the box with alsa 1.0.12; Display and ATI driver were installed and set up correctly out of the box. Mandriva Spring 'One' KDE used : of the distros out there it's one of the very few which detects,recognizes and handles this notebook well.Webcam took some reseach but works.Wireless works with the set up tools provided wth the distro out of the box, after setting it up reboot and switch on the wireless network. The Powerdown feature seems to have a bug (?) : if you start in init3 mode Mandy hangs on it, when you start in init5 it might take a minute but then it starts through; Also at first possibility you can't enter your username and password : click the session button and select restart x server, now you can enter the credentials and hit the enter button. Quote Link to comment Share on other sites More sharing options...
Anil Posted October 15, 2007 Share Posted October 15, 2007 (edited) Model: Acer Aspire 4710Z Intel® Pentium® dual-core T2080Videocard: Mobile Intel® 943GML Express Chipset with integrated 3D graphicsNetwork: Gigabit Ethernet, Wake-on-LAN readyWifi: Acer InviLink™ 802.11b/g Wi-Fi CERTIFIEDBluetooth:Bluetooth® 2.0+EDR (Enhanced Data Rate)Webcam: Integrated Acer Crystal Eye webcamTouchpad: Seamless touchpad with 4-way scroll buttonHotkey (Home, Eject, Suspend ...): Most of them functionDisplay: 14.1\\\" WXGA high-brightness (200-nit) TFT LCD, multi-window viewingOS: Mandriva 2008Kernel: 2.6.22.9Suspend on Disk: worksSuspend on RAM: worksComments: Mandriva 2008 installed flawlessly. wifi, sound, screen resolution, 3d etc worked out of Box. 5-in-1 card reader is detected but only SD card works. Most of the Hot Keys function without any problems. I went to keyboard setup and chose laptop mode for Acer. Edited October 15, 2007 by Anil Quote Link to comment Share on other sites More sharing options...
striker Posted October 15, 2007 Share Posted October 15, 2007 Thanks Anil, added. Quote Link to comment Share on other sites More sharing options...
striker Posted November 8, 2007 Share Posted November 8, 2007 Model: ACER Travelmate 6465WLMi -- Intel® Core™2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard: ATI Technologies Inc.M52 Mobility Radeon X1300 (128MB) / ATI driver version 8.40.4Network: NetLink BCM5787M Gigabit Ethernet PCI Express > worksWifi: PRO/Wireless 3945ABG Network Connection > works with manual edit in network set upBluetooth: Bluetooth® 2.0+EDR (Enhanced Data Rate) > can't test due to lack of BT equipmentWebcam: Acer Orbicam works with Ekiga and v4l2 driver, works with Kopete.Touchpad: works, Trackpoint also worksHotkey (Home, Eject, Suspend ...):special Acer buttons (4) not configured; Home, End, PgUp and PgDn work.Display: 15.4" matte display 1680 x 1050 (24bit used in video driver)OS: Mandriva 2008 "One" / KDE i586Kernel: 2.6.22.9-desktop586-1mdvSuspend on Disk: I don't use thisSuspend on RAM: I don't use thisComments: (7240 frames in 5.0 seconds = 1447.807 FPS)- direct rendering:YESSoundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller works out of the box(Alsa 1.0.14), just cranck up the volume a bit in kMix.Ifyou need more 'power' use active speakers with volume control.Cooling fan of laptop works, goes up in rpms when it should and down when the laptop has cooled down.Card reader may work but not with xD Picture Card, I don't have other types (like SD) so I can't test that any further, albeit the driver is loaded.Display brightness up and down buttons work.Added the above. Quote Link to comment Share on other sites More sharing options...
striker Posted November 17, 2007 Share Posted November 17, 2007 Model: ACER Travelmate 6465WLMi -- Intel® Core™2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard: ATI Technologies Inc.M52 Mobility Radeon X1300 (128MB) / ATI driver version 8.40.4Network: NetLink BCM5787M Gigabit Ethernet PCI Express > worksWifi: PRO/Wireless 3945ABG Network Connection > had to fiddle a bit but it works now; using a Dlink DWL-G630 rev.E2(Cardbus II): MDV detects it and install RAlink RT61 driver for it, after that it works(only WEP 128). Next I used a Siemens Gigaset PCCard 108: MDV detects it, installs drivers for it (and fails, I installed them myself manually): got detected as ath0, works like a charm with WPA-PSK. Bluetooth: Bluetooth® 2.0+EDR (Enhanced Data Rate) > can't test due to lack of BT equipment. Blue LED lights up when accessing the front mounted switch.Webcam: Acer Orbicam works with Ekiga and v4l2 driver, not tested with Kopete but probably works.Touchpad: works, Trackpoint also worksHotkey (Home, Eject, Suspend ...):special Acer buttons (4) work **; Home, End, PgUp and PgDn work. (** see : http://forums.scotsnewsletter.com/index.php?showtopic=20010 )Display: 15.4" matte display 1680 x 1050 (24bit used in video driver)OS: Mandriva 2008 "Free" x86_64Kernel: 2.6.22.9-laptop-1mdvSuspend on Disk: I don't use thisSuspend on RAM: worksComments: (7285 frames in 5.0 seconds = 1456.804 FPS)- direct rendering:YES Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller works out of the box(Alsa 1.0.14), just cranck up the volume a bit in kMix.If you need more 'power' use active speakers with volume control. Cooling fan of laptop works, goes up in rpms when it should and down when the laptop has cooled down. Card reader may work but not with xD Picture Card, I don't have other types (like SD) so I can't test that any further, albeit the driver is loaded. Display brightness up and down buttons work. For the suspend to RAM you may read this post to get it in working state: http://forums.scotsnewsletter.com/index.php?showtopic=20003added the above Quote Link to comment Share on other sites More sharing options...
striker Posted December 1, 2007 Share Posted December 1, 2007 added new entry with same distro on same laptop but now with working suspend to ram. Also added the link to the post where one can read what it takes to make it tick like clock work.edit: 2 December 2007: made some other things work and added these to the posts above. Quote Link to comment Share on other sites More sharing options...
striker Posted December 15, 2007 Share Posted December 15, 2007 edited the Bluetooth entry in my last post: it works ! :Dedited card reader entry: works. Quote Link to comment Share on other sites More sharing options...
rakemup Posted March 23, 2008 Share Posted March 23, 2008 Model: Dell Vostro 1500 - 2.2GHz --Intel® Core2 Duo CPUVideocard: Model: NVidia GeForce 8600M GTNetwork: Intel Pro/Wireless 4965 AGN linking to Linksys300N routerWifi: Bluetooth: untriedWebcam: noneTouchpad: yes - works fineHotkey (Home, Eject, Suspend ...): untriedDisplay: 1680x1050OS: Mandriva2008 / XPKernel: 2.6.22.18-laptop-1mdvSuspend on Disk: unknownSuspend on RAM: unknownComments: I first tried a Linksy 330N router but it would only connect for 5 minutes at a time. The sound card will not record. No other problems. Quote Link to comment Share on other sites More sharing options...
striker Posted March 24, 2008 Share Posted March 24, 2008 Great ! Urmas will add it later when he has some time available. Quote Link to comment Share on other sites More sharing options...
Urmas Posted March 24, 2008 Share Posted March 24, 2008 I'm workin' in a coal mineGoin' down down downWorkin' in a coal mineWhop! about to slip downWorkin' in a coal mineGoin' down down downWorkin' in a coal mineWhop! about to slip down Added. Thanks! Quote Link to comment Share on other sites More sharing options...
striker Posted March 26, 2008 Share Posted March 26, 2008 added Siemens wifi PCCard in my post nr. 10 above. Quote Link to comment Share on other sites More sharing options...
striker Posted May 11, 2008 Share Posted May 11, 2008 Model: ACER Travelmate 6465WLMi -- Intel® Core™2 CPU T7200 @ 2.00GHz and 2Gigs RAM DDR667Videocard: ATI Technologies Inc.M52 Mobility Radeon X1300 (128MB) / ATI driver version 8.47.1Network: NetLink BCM5787M Gigabit Ethernet PCI Express > worksWifi: PRO/Wireless 3945ABG Network Connection > I don't use this one, I use a Siemens Gigaset PCCard 108: MDV detects it, installs drivers for it, got detected as ath0, works like a charm with WPA-PSK. Bluetooth: Bluetooth® 2.0+EDR (Enhanced Data Rate) > Blue LED lights up when accessing the front mounted switch. Works with Sony Ericsson k320i and Samsung SGH-E250.Webcam: Acer Orbicam works with Ekiga and v4l2 driver. Also Cheese works.Touchpad: works, Trackpoint also worksHotkey (Home, Eject, Suspend ...):Home, End, PgUp and PgDn work.Display: 15.4" matte display 1680 x 1050 (24bit used in video driver)OS: Mandriva 2008.1 (aka Spring) "Free" x86_64Kernel: 2.6.24.4-laptop-1mnbSuspend on Disk: I don't use thisSuspend on RAM: tested and works with *** (see below)Comments: Soundcard:Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller works out of the box(Alsa 1.0.16). Cooling fan of laptop works, goes up in rpms when it should and down when the laptop has cooled down. Card reader works for SD cards. Display brightness up and down buttons work.*** : For the suspend to RAM you may read this post to get it in working state: http://forums.scotsnewsletter.com/index.php?showtopic=20003It does not work without this, you'll get orphaned inodes when you try which the system needs to clean. (that's bad!)note:The QSynaptics part is not applicable to MDV 2008.1 anymore. (only for 2008.0) Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 24, 2008 Author Share Posted May 24, 2008 I could not resist and got myself an ASUS EeePC . . . . Xandros did not get more then 24 hours . . I had to install Mandriva 2008.1: Model: ASUS EeePC 701 4GB ( Celeron M processor 900MHz )Videocard: Intel Mobile 915GM/GMS/910GML Express Graphics ControllerNetwork: Attansic Technology Corp. L2 100 Mbit Ethernet AdapterWifi: Atheros Communications AR5000GEG 802.11 b/g ( Madwifi driver )Bluetooth: noneWebcam: WorksTouchpad: YesHotkey's (Home, Eject, Suspend ...): All work greatDisplay: OS: Mandriva 2008.1 Spring PowerPackKernel: 2.6.24.4-laptop-3mnbSuspend on Disk: Closing the lid puts it to sleep, opening it wakes it up, Not sure if that is to disk or RAMSuspend on RAM: Closing the lid puts it to sleep, opening it wakes it up, Not sure if that is to disk or RAMComments: Everything is supported, works out of the box. Brilliant ! Bruno Quote Link to comment Share on other sites More sharing options...
Anil Posted December 3, 2008 Share Posted December 3, 2008 Model: ASUS EeePC 701 4GB ( Celeron M processor 900MHz ) Videocard: Intel Mobile 915GM/GMS/910GML Express Graphics Controller Network: Attansic Technology Corp. L2 100 Mbit Ethernet Adapter Wifi: Atheros Communications AR5000GEG 802.11 b/g ( Madwifi driver ) Bluetooth: Works Webcam: Works Touchpad: Yes Hotkey's (Home, Eject, Suspend ...): works Display: 1024x768 OS: Mandriva 2009 ONE-KDE4 Kernel: 2.6.27.5-desktop586-2mnb Suspend on Disk: Works Suspend on RAM: Works Comments: Everything is supported, works out of the box(almost) Quote Link to comment Share on other sites More sharing options...
