I have a wireless mouse that will not work with a pc. I have tried it on Windows 11, MX linux and Arch.
In Arch lsusb shows it as,
Bus 005 Device 003: ID 04d9:2517 Holtek Semiconductor, Inc.
Here is a detailed look at the specs,
Negotiated speed: Low Speed (1Mbps)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 [unknown]
  bDeviceSubClass         0 [unknown]
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x04d9 Holtek Semiconductor, Inc.
  idProduct          0x2517
  bcdDevice            1.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x003b
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              5 2.4G Wireless Keyboard
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 (null)
          wDescriptorLength      79
          Report Descriptors:
            ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      2 Mouse
      iInterface              6 2.4G Wireless Mouse
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength     158
          Report Descriptors:
            ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
The mouse has a new battery and the sensor lights up and as it shows in lsusb I guess it is functioning but unable to fully work on a pc. Searching the net has not produced any useful solutions so far.
Can anyone shine a light on my problem ? 🤔
Does it have a pairing button on it? Just because the dongle is usb, you still have to pair the device on some mice. If you have tried it on multiple OSs, then it is not driver related. It's either not paired or its a faulty mouse.
Power Cycle: Turn off the mouse (if it has a power switch) and then turn it back
Reset Button: Some mice have a small reset button on the bottom, try pressing it.
Pairing Mode: Some wireless mice require you to enter pairing mode to reconnect with the receiver, check the documentation for your specific model
Ha it has a very small button that I did not see. Pressing and holding it down does cause the sensor to flash but the mouse will still not function. I'll give it a try on the laptop but I recon it is furbar. That was probably why it was hiding in a drawer gathering dust. 😅
