abarbarian Posted October 18, 2024 Posted October 18, 2024 (edited) You can find out a lot of information on your ssd/nvme drives with smartmontools. In the past smartmontools did not support nvme drives and you had to use the nvme-cli nvme. Smartmontools Documentation Here is a quick look at the smartmontool smartctl. I have one ssd and two nvme drives in my rig and here are the results of running, smartctl -i basic information smartctl -a more information smartctl -x even more information for nvme drives "smartctl -a" and "smartctl -x" give the same informarion only The ssd drive. Brain engaged-->16:40:10-->Fri Oct 18-->bloodaxe -->smartctl -i /dev/sda smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.11.3-arch1-1] (local build) Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Samsung based SSDs Device Model: Samsung SSD 860 EVO 500GB Serial Number: S3Z2NB0K369918E LU WWN Device Id: 5 002538 e40246241 Firmware Version: RVT01B6Q User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database 7.3/5528 ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Oct 18 16:40:14 2024 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled Brain engaged-->16:40:14-->Fri Oct 18-->bloodaxe -->smartctl -a /dev/sda smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.11.3-arch1-1] (local build) Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Samsung based SSDs Device Model: Samsung SSD 860 EVO 500GB Serial Number: S3Z2NB0K369918E LU WWN Device Id: 5 002538 e40246241 Firmware Version: RVT01B6Q User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database 7.3/5528 ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Oct 18 16:44:34 2024 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x53) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 85) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 26271 12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 1317 177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 12 179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0 181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0 183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0032 075 053 000 Old_age Always - 25 195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0 199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0 235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 317 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 9525864481 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. The above only provides legacy SMART information - try 'smartctl -x' for more This is the extra information that along with all the information from "smartctl -a" comes with "smartctl -x" SCT Status Version: 3 SCT Version (vendor specific): 256 (0x0100) Device State: Active (0) Current Temperature: 25 Celsius Power Cycle Min/Max Temperature: 25/40 Celsius Lifetime Min/Max Temperature: 19/47 Celsius Specified Max Operating Temperature: 55 Celsius Under/Over Temperature Limit Count: 0/0 SMART Status: 0xc24f (PASSED) SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 10 minutes Min/Max recommended Temperature: 0/70 Celsius Min/Max Temperature Limit: 0/70 Celsius Temperature History Size (Index): 128 (103) Index Estimated Time Temperature Celsius 104 2024-10-17 19:30 22 *** ... ..( 7 skipped). .. *** 112 2024-10-17 20:50 22 *** 113 2024-10-17 21:00 ? - 114 2024-10-17 21:10 22 *** 115 2024-10-17 21:20 24 ***** 116 2024-10-17 21:30 25 ****** 117 2024-10-17 21:40 25 ****** 118 2024-10-17 21:50 25 ****** 119 2024-10-17 22:00 26 ******* 120 2024-10-17 22:10 25 ****** 121 2024-10-17 22:20 25 ****** 122 2024-10-17 22:30 25 ****** 123 2024-10-17 22:40 26 ******* 124 2024-10-17 22:50 26 ******* 125 2024-10-17 23:00 26 ******* 126 2024-10-17 23:10 25 ****** ... ..( 4 skipped). .. ****** 3 2024-10-18 00:00 25 ****** 4 2024-10-18 00:10 26 ******* 5 2024-10-18 00:20 25 ****** ... ..( 3 skipped). .. ****** 9 2024-10-18 01:00 25 ****** 10 2024-10-18 01:10 26 ******* 11 2024-10-18 01:20 26 ******* 12 2024-10-18 01:30 25 ****** 13 2024-10-18 01:40 26 ******* ... ..( 3 skipped). .. ******* 17 2024-10-18 02:20 26 ******* 18 2024-10-18 02:30 25 ****** 19 2024-10-18 02:40 ? - 20 2024-10-18 02:50 22 *** 21 2024-10-18 03:00 22 *** 22 2024-10-18 03:10 23 **** 23 2024-10-18 03:20 23 **** 24 2024-10-18 03:30 23 **** 25 2024-10-18 03:40 24 ***** 26 2024-10-18 03:50 24 ***** 27 2024-10-18 04:00 24 ***** 28 2024-10-18 04:10 26 ******* 29 2024-10-18 04:20 25 ****** 30 2024-10-18 04:30 25 ****** 31 2024-10-18 04:40 26 ******* 32 2024-10-18 04:50 25 ****** ... ..( 2 skipped). .. ****** 35 2024-10-18 05:20 25 ****** 36 2024-10-18 05:30 24 ***** 37 2024-10-18 05:40 25 ****** ... ..( 2 skipped). .. ****** 40 2024-10-18 06:10 25 ****** 41 2024-10-18 06:20 26 ******* 42 2024-10-18 06:30 25 ****** ... ..( 11 skipped). .. ****** 54 2024-10-18 08:30 25 ****** 55 2024-10-18 08:40 24 ***** 56 2024-10-18 08:50 25 ****** ... ..( 4 skipped). .. ****** 61 2024-10-18 09:40 25 ****** 62 2024-10-18 09:50 ? - 63 2024-10-18 10:00 22 *** 64 2024-10-18 10:10 23 **** 65 2024-10-18 10:20 23 **** 66 2024-10-18 10:30 24 ***** ... ..( 12 skipped). .. ***** 79 2024-10-18 12:40 24 ***** 80 2024-10-18 12:50 25 ****** ... ..( 15 skipped). .. ****** 96 2024-10-18 15:30 25 ****** 97 2024-10-18 15:40 24 ***** ... ..( 2 skipped). .. ***** 100 2024-10-18 16:10 24 ***** 101 2024-10-18 16:20 ? - 102 2024-10-18 16:30 25 ****** 103 2024-10-18 16:40 25 ****** SCT Error Recovery Control: Read: Disabled Write: Disabled Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 1317 --- Lifetime Power-On Resets 0x01 0x010 4 26271 --- Power-on Hours 0x01 0x018 6 9525864481 --- Logical Sectors Written 0x01 0x020 6 11266366 --- Number of Write Commands 0x01 0x028 6 10610873701 --- Logical Sectors Read 0x01 0x030 6 29424397 --- Number of Read Commands 0x01 0x038 6 699000 --- Date and Time TimeStamp 0x04 ===== = = === == General Errors Statistics (rev 1) == 0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors 0x04 0x010 4 11 --- Resets Between Cmd Acceptance and Completion 0x05 ===== = = === == Temperature Statistics (rev 1) == 0x05 0x008 1 25 --- Current Temperature 0x05 0x020 1 47 --- Highest Temperature 0x05 0x028 1 19 --- Lowest Temperature 0x05 0x058 1 55 --- Specified Maximum Operating Temperature 0x06 ===== = = === == Transport Statistics (rev 1) == 0x06 0x008 4 5211 --- Number of Hardware Resets 0x06 0x010 4 0 --- Number of ASR Events 0x06 0x018 4 0 --- Number of Interface CRC Errors 0x07 ===== = = === == Solid State Device Statistics (rev 1) == 0x07 0x008 1 0 N-- Percentage Used Endurance Indicator |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 2 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000d 2 0 Non-CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0010 2 0 R_ERR response for host-to-device data FIS, non-CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x0013 2 0 R_ERR response for host-to-device non-data FIS, non-CRC The older 2020 nvme drive. Brain engaged-->17:20:39-->Fri Oct 18-->bloodaxe -->smartctl -x /dev/nvme1 smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.11.3-arch1-1] (local build) Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: ADATA SX8200PNP Serial Number: 2K4529A71GKL Firmware Version: 32B3T8EA PCI Vendor/Subsystem ID: 0x1cc1 IEEE OUI Identifier: 0x000000 Controller ID: 1 NVMe Version: 1.3 Number of Namespaces: 1 Namespace 1 Size/Capacity: 1,024,209,543,168 [1.02 TB] Namespace 1 Utilization: 694,033,825,792 [694 GB] Namespace 1 Formatted LBA Size: 512 Local Time is: Fri Oct 18 17:47:28 2024 BST Firmware Updates (0x14): 2 Slots, no Reset required Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test Optional NVM Commands (0x005f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp Log Page Attributes (0x0f): S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Maximum Data Transfer Size: 64 Pages Warning Comp. Temp. Threshold: 75 Celsius Critical Comp. Temp. Threshold: 80 Celsius Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 9.00W - - 0 0 0 0 0 0 1 + 4.60W - - 1 1 1 1 0 0 2 + 3.80W - - 2 2 2 2 0 0 3 - 0.0450W - - 3 3 3 3 2000 2000 4 - 0.0040W - - 4 4 4 4 15000 15000 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 + 512 0 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 40 Celsius Available Spare: 100% Available Spare Threshold: 10% Percentage Used: 2% Data Units Read: 46,388,015 [23.7 TB] Data Units Written: 25,128,979 [12.8 TB] Host Read Commands: 289,434,670 Host Write Commands: 294,010,441 Controller Busy Time: 5,737 Power Cycles: 2,290 Power On Hours: 9,451 Unsafe Shutdowns: 260 Media and Data Integrity Errors: 25 Error Information Log Entries: 25 Warning Comp. Temperature Time: 14 Critical Comp. Temperature Time: 0 Thermal Temp. 1 Transition Count: 158 Thermal Temp. 2 Transition Count: 1 Thermal Temp. 1 Total Time: 742 Thermal Temp. 2 Total Time: 9 Error Information (NVMe Log 0x01, 16 of 256 entries) No Errors Logged Self-test Log (NVMe Log 0x06) Self-test status: No self-test in progress No Self-tests Logged The newer 2022 nvme drive. Brain engaged-->17:18:42-->Fri Oct 18-->bloodaxe -->smartctl -x /dev/nvme0 smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.11.3-arch1-1] (local build) Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: SHPP41-1000GM Serial Number: SJB8N828712009333 Firmware Version: 51060A20 PCI Vendor/Subsystem ID: 0x1c5c IEEE OUI Identifier: 0xace42e Controller ID: 0 NVMe Version: 1.4 Number of Namespaces: 1 Namespace 1 Size/Capacity: 1,000,204,886,016 [1.00 TB] Namespace 1 Formatted LBA Size: 512 Namespace 1 IEEE EUI-64: ace42e 002649fc00 Local Time is: Fri Oct 18 17:20:39 2024 BST Firmware Updates (0x16): 3 Slots, no Reset required Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test Optional NVM Commands (0x00df): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp Verify Log Page Attributes (0x1e): Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Pers_Ev_Lg Maximum Data Transfer Size: 64 Pages Warning Comp. Temp. Threshold: 86 Celsius Critical Comp. Temp. Threshold: 87 Celsius Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 7.50W - - 0 0 0 0 5 305 1 + 3.9000W - - 1 1 1 1 30 330 2 + 1.5000W - - 2 2 2 2 100 400 3 - 0.0500W - - 3 3 3 3 500 1500 4 - 0.0050W - - 4 4 4 4 1000 9000 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 + 512 0 0 1 - 4096 0 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 39 Celsius Available Spare: 100% Available Spare Threshold: 10% Percentage Used: 0% Data Units Read: 14,335,000 [7.33 TB] Data Units Written: 13,460,530 [6.89 TB] Host Read Commands: 239,613,128 Host Write Commands: 209,145,051 Controller Busy Time: 16,249 Power Cycles: 826 Power On Hours: 3,938 Unsafe Shutdowns: 196 Media and Data Integrity Errors: 0 Error Information Log Entries: 0 Warning Comp. Temperature Time: 0 Critical Comp. Temperature Time: 0 Temperature Sensor 1: 33 Celsius Temperature Sensor 2: 41 Celsius Error Information (NVMe Log 0x01, 16 of 256 entries) No Errors Logged Self-test Log (NVMe Log 0x06) Self-test status: No self-test in progress No Self-tests Logged Just for comparison here is information from the nvme-cli tool "nvme" run on the older 2020 nvme drive. Brain engaged-->16:35:34-->Fri Oct 18-->bloodaxe -->nvme smart-log /dev/nvme1 Smart Log for NVME device:nvme1 namespace-id:ffffffff critical_warning : 0 temperature : 35 °C (308 K) available_spare : 100% available_spare_threshold : 10% percentage_used : 2% endurance group critical warning summary: 0 Data Units Read : 46,388,015 (23.75 TB) Data Units Written : 25,128,979 (12.87 TB) host_read_commands : 289,434,670 host_write_commands : 294,010,441 controller_busy_time : 5,737 power_cycles : 2,290 power_on_hours : 9,450 unsafe_shutdowns : 260 media_errors : 25 num_err_log_entries : 25 Warning Temperature Time : 14 Critical Composite Temperature Time : 0 Thermal Management T1 Trans Count : 158 Thermal Management T2 Trans Count : 1 Thermal Management T1 Total Time : 742 Thermal Management T2 Total Time : 9 Edited October 18, 2024 by abarbarian 1 Quote
