wa4chq Posted December 31, 2023 Posted December 31, 2023 (edited) Good morning. I'm trying to give Alpine linux a try in virtual box but I am not connecting to internet. I also had it installed on a thumb drive and was able to run through "setup-alpine" but like with VB, I still can't get past the apk setup....no internet connection. With other images that aren't so bare-boned, I have an internet connection after booting. I'm not having any luck with YouTube or Google. Everything I've found doesn't address my problem. Anyway, any suggestions? Thanks Edited December 31, 2023 by wa4chq Quote
securitybreach Posted December 31, 2023 Posted December 31, 2023 I was check the network settings for the vm first as that sounds like the issue. Quote
securitybreach Posted December 31, 2023 Posted December 31, 2023 Then if it is enabled, see what lscpi shows for a network adapter. Quote
wa4chq Posted December 31, 2023 Author Posted December 31, 2023 1 hour ago, securitybreach said: I was check the network settings for the vm first as that sounds like the issue. Hey SB...I'm sure the settings for network are OK since I am able to run other images and access the internet. I will look into "lscpi". Thanks. Quote
securitybreach Posted December 31, 2023 Posted December 31, 2023 Well I only mention it as each vm has its own hardware emulated. I usually use a bridge connection on most of mine. Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 6 hours ago, securitybreach said: Well I only mention it as each vm has its own hardware emulated. I usually use a bridge connection on most of mine. Dude, that was the ticket. I enabled the bridge connection and it's smokin'. The only thing that sucks is no ranger.....using mc until I find something better. Thanks man. Quote
securitybreach Posted January 1, 2024 Posted January 1, 2024 2 minutes ago, wa4chq said: Dude, that was the ticket. I enabled the bridge connection and it's smokin'. The only thing that sucks is no ranger.....using mc until I find something better. Thanks man. No problem, glad I was able help. Happy New Year 1 Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 15 minutes ago, securitybreach said: No problem, glad I was able help. Happy New Year Happy New Year! 1 Quote
raymac46 Posted January 1, 2024 Posted January 1, 2024 Here is a pretty good reference on VBox Internet. I usually use NAT (the default is Intel I think) and don't have problems. I have never tried Alpine in a VM though. Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 OK....Alpine is up and running in VB. In a previous post, I said I couldn't install ranger and installed mc instead. It turns out ranger is available...I forgot to un-hash links in the apk repositories. So 'apk add ranger' now installs ranger. When running "setup-desktop", I chose MATE just to see what would happen. I may see if i3 is available. Anyway, now to power off and see if everything up to this point is saved. Happy 2024 everybody. Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 3 minutes ago, raymac46 said: Here is a pretty good reference on VBox Internet. I usually use NAT (the default is Intel I think) and don't have problems. I have never tried Alpine in a VM though. Happy New Year raymac..... SB uses bridge...so I gave that a try and it works great here. After several tries messing with VB and with the Alpine setup, I think it's all working nicely. Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 OK...just powered off...now to start it back up....fingers crossed.... Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 It works! Everything was saved.....cool. I may have to try Alpine using a RaspberryPi.....but not now. Quote
wa4chq Posted January 1, 2024 Author Posted January 1, 2024 58 minutes ago, raymac46 said: Here is a pretty good reference on VBox Internet. I usually use NAT (the default is Intel I think) and don't have problems. I have never tried Alpine in a VM though. And thanks for the link. Quote
raymac46 Posted January 1, 2024 Posted January 1, 2024 (edited) I am not totally sure on the difference between Bridge and NAT. I *think* that NAT is a virtual emulation of a network interface (machine thinks it's connected via a wired interface,) and Bridge just passes everything through to the hardware interface on the Host. Most of the time everything works with the defaults for me so I never worry about it. I had a look at Alpine Linux and it's radically different from anything I have ever used. Edited January 1, 2024 by raymac46 1 Quote
securitybreach Posted January 1, 2024 Posted January 1, 2024 8 minutes ago, raymac46 said: I am not totally sure on the difference between Bridge and NAT. I *think* that NAT is a virtual emulation of a network interface (machine thinks it's connected via a wired interface,) and Bridge just passes everything through to the hardware interface on the Host. That is sort of correct Quote Host-only only permits network operations with the Host OS. NAT mode will mask all network activity as if it came from your Host OS, although the VM can access external resources. Bridged mode replicates another node on the physical network and your VM will receive it's own IP address if DHCP is enabled in the network. https://superuser.com/questions/227505/what-is-the-difference-between-nat-bridged-host-only-networking 1 Quote
