An Interactive Terminal-Agnostic Theme Selection Script
I don’t know about you, but I think that the default look of the terminal is not always the best. And that’s valid if you’re running Linux or macOS.
The script comes with more than 400 themes, an interactive theme picker, and it’s terminal agnostic.
https://github.com/lemnos/theme.sh
the script itself
https://raw.githubusercontent.com/lemnos/theme.sh/master/bin/theme.sh
There are AUR packages but why on earth would you want to use it rather than installing directly I do not understand.
https://aur.archlinux.org/packages?O=0&SeB=nd&K=+theme.sh&outdated=&SB=p&SO=d&PP=50&submit=Go
This is the easiest way I have found for trying out different looks in the terminal. I gave the script a once over to see if it contained any naughties.Installed " fzf " so that I could use the interactive feature.Then I used the install code modified to suit my needs, I keep all  my scripts in /home/me/bin/, an in a couple of clicks I was trying out hundreds of different setups.
I ended up with " dracula " but quite like the look of " birds-of-paradise " . I may use some of the ideas I glean to tweak my set up slightly after I have played around for a while.  😎
I just change my root prompt to red in /root/.bashrc so it's obvious when it is root.
First trick I learned for running a penguin was to have your root terminal in red. I used " su " instead of sudo when I first started out as it kept me on track if doing something as root. It helped me to stop making big mistakes, well most of the time.🤔I used to have it all in red but now I just have little red arrows to show I am in "root".
This is my root prompt. 2023
I had to create a /root/.bashrc file first. Also the PS1= has to be all on one line in the .bashrc if filling in the details when opening up .bashrc with nano from a terminal
export PS1="\[\033[38;5;75m\]\t\[$(tput sgr0)\]\[$(tput bold)\]\[\033[38;5;160m\]-->\[$(tput sgr0)\]\[\033[38;5;75m\]\d\[$(tput sgr0)\]\[$(tput bold)\]\[\033[38;5;160m\]-->\[$(tput sgr0)\]\[\033[38;5;2m\]\W\[$(tput sgr0)\]\n\[$(tput sgr0)\]\[$(tput bold)\]\[\033[38;5;160m\]-->\[$(tput sgr0)\]"
an this is my user prompt
This is my user prompt 2023
export PS1="\[$(tput sgr0)\]\[\033[38;5;75m\]\t\[$(tput sgr0)\]\[$(tput bold)\]\[\033[38;5;21m\]-->\[$(tput sgr0)\]\[\033[38;5;75m\]\d\[$(tput sgr0)\]\[$(tput bold)\]\[\033[38;5;21m\]-->\[$(tput sgr0)\]\[\033[38;5;2m\]\W\[$(tput sgr0)\]\n\[$(tput sgr0)\]\[$(tput bold)\]\[\033[38;5;21m\]-->\[$(tput sgr0)\]"
PROMPT_COMMAND="echo -n $(tput bold) $(tput setaf 6)Put brain in gear before pressing enter"
I gleaned information for " tput " from here,
https://linuxcommand.org/lc3_adv_tput.php
Edited by abarbarian
  • Thanks 1
Very nice AB.  My root also changes colors.  My root is also patriotic.  Hope everyone has a safe Easter weekend.screenshot.jpg
Neat. I like that you change "wa4chq" to "root" in red. I might give that a try if I develop dementia or Alzheimer's. 😋
One last tweak to my terminal "root" prompt.
Mine is visually simple but I am using zsh instead of bash with syntax highlighting/autocomplete and other tweaks. The odd resolutions are due to scaling.
1 hour ago, wa4chq said:
SB, I also use zsh.....
Nice. I have been using it for years now but once I found it, I was surprised that it took me so long to switch.
The first thing that I do on a new install is install and setup zsh.
Yep, same here.  Then I install ranger.
I prefer nnn as ranger will lag on large directories https://github.com/jarun/nnn
Its basically ranger but indexes fast and has a lot of other features like tabs and such. I also like fff which is a fork of nnn but that is mainly because of the name. ;)
I prefer nnn as ranger will lag on large directories https://ithub.com/jarun/nnn
I just had a look at nnn, thanks....looks nice.  I was a big fan of midnight commander for years.  I still use it but not as much anymore.  My head gets wonky if I use something like pcmanfm.... btw, I'm not having much luck with the link you provided...so I just googled nnn instead.
Edited by wa4chq
Can you help ?
I have downloaded the Jetbrains stuff and they show up in my WindowMaker so I can change font that way.
However I am stuck in font mud when it comes to changing the terminal font.
I have this in mkinitcpio.conf
HOOKS=(base udev autodetect modconf kms keyboard keymap consolefont block filesystems fsck)
I found "/etc/vconsole.conf" and it has one entry
KEYMAP=uk
everywhere I look on the net it tells me to add something to that file like
KEYMAP=dvorak
FONT=ter-v18n
or  ( I realise that I do not need the Noto stuff could exclude that)
simply put a fontconfig under ~/.config/fontconfig/fonts.conf and force-refresh the font cache with fc-cache --really-force.
This fontconfig sets up a font alias terminal-font for both fonts in the desired order:
<?xml version='1.0'?>
<!DOCTYPE fontconfig SYSTEM 'fonts.dtd'>
<fontconfig>
  <alias>
    <family>terminal-font</family>
    <prefer>
      <family>JetBrains Mono</family>
      <family>Noto Color Emoji</family>
     </prefer>
  </alias>
</fontconfig>
That’s how we can use this font family name in our terminal config.
I also have this in my ~/. Xrescources but have no idea why and do not know what to put in there to get Jetbrains.
! Use a nice truetype font and size by default...
!xterm*faceName:       xft:DejavuSansMono:pixelsize=14
! Joshs terminal font - pretty neat
!xterm*faceName:        xft:source code pro:pixelsize=14:antialias=true
! Erics terminal font very neat - the non bold one is cool too.
xterm*faceName:        xft:Liberation Mono:bold:pixelsize=13:antialias=true:hinting=true
!xterm*faceName:        xft:Liberation Mono:pixelsize=13:antialias=true:hinting=true
So what do I do to get Jetbrains in the terminal.
Thanks. 😎
P.S I realise that at my age Jetbrains would probably burn out my last few reaming greycells , but hey I am a gambler and speed freak.
Fixed link, sorry forgot the g in github
6 hours ago, abarbarian said:
Can you help ?
So I use urxvt and the config is via ~/.Xresources but this is the line for the font:
xft:jetbrains mono:pixelsize=14:antialias=true
  • Thanks 1
How many times have I done that?  lol
Fonts don't you love em. I got confused with console, terminal and system fonts what with all the confusing reading out there. These two links helped a lot with prettying up and making xterm more useful.
https://www.futurile.net/2016/06/15/xterm-256color-themes-molokai-terminal-theme/
This link helped out with colours. I now have  a red cursor and pointer. His previous post has some useful tweaks too.
https://lukas.zapletalovi.com/posts/2013/hidden-gems-of-xterm/
This article has excellent tips. This set up lets you highlight web addresses or file paths with a double click. Add these to ~/.Xresources
By default clicking in xterm works in the following way:
  • one click - nothing (you can drag or use the other button to select)
  • double click - select word (alphanums plus few characters in the default configuration)
  • triple click - whole line
When working with files (/some/filename) or links (https://www.xyz.com) selecting is difficult. It is easy to change the behavior. The following setting changes what xterm considers as characters:
XTerm*charClass: 33:48,36-47:48,58-59:48,61:48,63-64:48,95:48,126:48
XTerm*on3Clicks: regex ([[:alpha:]]+://)?([[:alnum:]!#+,./=?@_~-]|(%[[:xdigit:]][[:xdigit:]]))+
I wish I had come across this tip years ago
Left and right selection
Some users prefer to select portions of text using left button for beginning and right button for end as an alternative to dragging. I sometimes use this when I want to be absolutely sure with the selection (selecting e.g. ssh key) or I want to select something really big (left click, scroll,right click). Learn this, it is nice feature.
Now if only I could have a red cursor and pointer when I am root and a blue cursor and pointer when as a user. Hmmmmmmmmmmmmm 😋
This will give the red and blue plus orange and green if you really want to get fancy
Edited by wa4chq
2 hours ago, wa4chq said:
This will give the red and blue plus orange and green if you really want to get fancy!
e0ca8c45bc9d095b52bc4dacb253d38b.jpg&sp=
Image seems broken
19 minutes ago, securitybreach said:
Image seems broken
Thanks for the heads up.
Fixed for you :)
  • Thanks 1
37 minutes ago, securitybreach said:
Fixed for you :)
Looks like I fixed it the same time you did!  lol  I had an aunt that used these things.  The tree was white angel hair.  I think she listened to Elvis too.
Typical lazy American cousins automating everything. We over here still have the ability to use our hands and respect the old fashioned way of doing stuff.😛
414_414_901c6df0-c525-4475-bfbb-b395a16e
1 hour ago, V.T. Eric Layton said:
I remember getting pinwheels when I was a kid.  We'd hold 'em out the car window.  I can't remember if the wand had a removable cap at the end and the wand itself contain candy???
Pot-of-Gold-Rainbow.jpg&f=1&nofb=1&ipt=0
I've never found the pot of gold but I did find someones grill...61JHbRd+-vL._AC_UY500_.jpg
