sunrat Posted September 16, 2022 Posted September 16, 2022 In another thread I posted a link to recommended MPV conf settings - I just had occasion to look at mpv config again as I did a dumb thing and changed a config option in the Qjackctl command I use to launch the PA-JACK bridge. I found several videos which had 5.1 audio were not playing the dialogue channel in my stereo output. Took me several hours to discover the problem. First I thought is was the new videos so I downmixed their audio to stereo and recoded the videos with ffmpeg. That fixed it but later I noticed some videos which I had watched, with dialogue playing, were now not playing it. Eventually the penny dropped and I remembered removing "channels=2" from the module load option because I thought "don't need that, it's the default". Turns out it is needed to downmix 5.1 to stereo automatically! Time wasted ~3 hours. Lesson learnt = invaluable. Anyway, the MPV bit was a side quest. I had previously advised after reading to above link to enable hwdec in mpv.conf but turns out that's not advisable according to https://man.archlinux.org/man/mpv.1#hwdec=_api_ Head slap! I had vaapi specified even though my Nvidia GPU doesn't support vaapi. MPV is smart enough to ignore it. It did help a lot for my other system though, a ThinkPad with Intel graphics. The advised method to enable hardware decoding in MPV is to simply press Ctrl-H which will toggle it on or off. 2 1 Quote
securitybreach Posted September 16, 2022 Posted September 16, 2022 Glad that you fixed it but honestly, I do not think that I have ever even opened the mpv config file. It just works for me. Well it looks like I never even copied the config file from /usr/share/doc/mpv/ Quote
abarbarian Posted September 16, 2022 Posted September 16, 2022 Quote Always enabling HW decoding by putting it into the config file is discouraged. If you use the Ubuntu package, delete /etc/mpv/mpv.conf, as the package tries to enable HW decoding by default by setting hwdec=vaapi (which is less than ideal, and may even cause sub-optimal wrappers to be used). Or at least change it to hwdec=auto-safe. Ha always knew that the buntus were dodgy. My mpv seemed to work well in the main though VLC seemed to play some files better than mpv. I had " hwdec=auto " but changed it to "hwdec=nvdec-copy ", I'll see how that goes. Meanwhile this is my mpv.config Quote vo=gpu profile=gpu-hq hwdec=nvdec-copy hwdec-codecs=all scale=ewa_lanczossharp cscale=ewa_lanczossharp video-sync=display-resample interpolation tscale=oversample keepaspect=no stop-screensaver = "yes" save-position-on-quit ao=pulse sub-bold=yes audio-device=alsa/iec958:CARD=PCH,DEV=0' screenshot-directory=/home/bloodaxe/Screenshots/mpvScreens/ It probably is not correct as I tend to fiddle a lot. That mpv manual page requires you to have several university degrees to just start investigating and setting up mpv. It makes my head hurt after a few sentences. Quote
V.T. Eric Layton Posted September 16, 2022 Posted September 16, 2022 MPV? No such thing in Slackware because no SystemD in Slackware. YAY! Quote
sunrat Posted September 16, 2022 Author Posted September 16, 2022 4 hours ago, abarbarian said: My mpv seemed to work well in the main though VLC seemed to play some files better than mpv. I had " hwdec=auto " but changed it to "hwdec=nvdec-copy ", I'll see how that goes. Meanwhile this is my mpv.config It probably is not correct as I tend to fiddle a lot. That mpv manual page requires you to have several university degrees to just start investigating and setting up mpv. It makes my head hurt after a few sentences. I'm pretty sure an mpv.conf is not necessary. I only created one to display cover files for music which doesn't have embedded covers. You should read that Arch man page link I posted above re hwdec. 2 hours ago, V.T. Eric Layton said: MPV? No such thing in Slackware because no SystemD in Slackware. YAY! MPV doesn't need or depend on Systemd. I can't imagine why it wouldn't be available in Slackware. It's possibly the most capable media player in Linux but without any graphical bells n' whistles, they are all under the hood. It has extensive keyboard controls and a vast array of options; the man page is over 10,000 lines! I'm very surprised you don't use it already. 1 Quote
securitybreach Posted September 16, 2022 Posted September 16, 2022 Yup as noted, has absolutely zero to do with systemd. MPV is a fork of the old mplayer. It work on windows, linux, bsd and mac. https://mpv.io/installation/ Quote mpv was forked by Vincent Lang, also known as wm4, in 2012 from mplayer2, which was forked in 2010 from MPlayer. https://en.wikipedia.org/wiki/Mpv_(media_player) Quote
securitybreach Posted September 16, 2022 Posted September 16, 2022 MPV is available via slackbuilds https://github.com/duganchen/my_slackbuilds/blob/master/mpv.SlackBuild 1 Quote
V.T. Eric Layton Posted September 17, 2022 Posted September 17, 2022 20 hours ago, sunrat said: MPV doesn't need or depend on Systemd. I can't imagine why it wouldn't be available in Slackware. MPV is a Gnome-based application. There's no Gnome in Slackware. The reason I suspected SystemD in the above post was because the "Qjackctl" command you mention above looked suspiciously like a SystemD command. Quote
abarbarian Posted September 17, 2022 Posted September 17, 2022 21 hours ago, sunrat said: You should read that Arch man page link I posted above re hwdec. I did but became very confused. Yep mpv does not need a .conf, I have one so I can use some of the lua scripts. Quote
sunrat Posted September 17, 2022 Author Posted September 17, 2022 7 hours ago, V.T. Eric Layton said: MPV is a Gnome-based application. There's no Gnome in Slackware. The reason I suspected SystemD in the above post was because the "Qjackctl" command you mention above looked suspiciously like a SystemD command. Nope. Qjackctl is for controlling the JACK audio system. Nothing to do with systemd. MPV is not Gnome-based either. It does depend on a couple of wayland libs in Debian, but I don't use Wayland so that's moot as well. Quote
V.T. Eric Layton Posted September 18, 2022 Posted September 18, 2022 Hmm... no Wayland on my Slackware (14.2). I have not upgraded to Slackware 15 primarily because I don't like the UGLY client-side modifications that have been made to Xfce's latest version. Quote
securitybreach Posted September 20, 2022 Posted September 20, 2022 Yup mpv has absolutely nothing to do with gnome or systemd. Where are you getting your info from Eric?? Quote
securitybreach Posted September 20, 2022 Posted September 20, 2022 You can even play mpv without X (or wayland) running in TTY: mpv --quiet -vo caca 'url' Quote
securitybreach Posted September 20, 2022 Posted September 20, 2022 See, no mention of wayland or gnome: #!/usr/bin/env bash set -e TMP=${TMP:-/tmp} PKG="$TMP/package-mpv" BUILD=${BUILD:-2} TAG=${TAG:-dc} SBO="${SBO:-https://raw.githubusercontent.com/Ponce/slackbuilds/master/multimedia/mpv}" if [[ -z $ARCH ]]; then case $( uname -m ) in i?86) ARCH=i486 ;; arm*) ARCH=arm ;; *) ARCH=$( uname -m ) ;; esac fi if [ "$ARCH" = "i586" ]; then SLKCFLAGS="-O2 -march=i586 -mtune=i686" LIBDIRSUFFIX="" elif [ "$ARCH" = "i686" ]; then SLKCFLAGS="-O2 -march=i686 -mtune=i686" LIBDIRSUFFIX="" elif [ "$ARCH" = "x86_64" ]; then SLKCFLAGS="-O2 -fPIC" LIBDIRSUFFIX="64" else SLKCFLAGS="-O2" LIBDIRSUFFIX="" fi cd "$TMP" rm -rf mpv-build package-mpv git clone https://github.com/mpv-player/mpv-build cd mpv-build ./use-mpv-release cat << EOF > mpv_options --prefix=/usr --confdir=/etc/mpv --mandir=/usr/man --docdir=/usr/doc/mpv --enable-libmpv-shared --libdir=/usr/lib$LIBDIRSUFFIX EOF ./rebuild -j"$(( $(nproc) + 1))" cd mpv VERSION="$(git describe --tags | cut -c 2-)" ./waf --destdir="$PKG" install find "$PKG" -print0 | xargs -0 file | grep -e "executable" -e "shared object" \ | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null || true gzip -9 "$PKG/usr/man/man1/mpv.1" ETC="$PKG/etc/mpv" mv "$ETC/encoding-profiles.conf" "$ETC/encoding-profiles.conf.new" DOC="$PKG/usr/doc" DOCDIR="$DOC/mpv-$VERSION" mv "$DOC/mpv" "$DOCDIR" cp -a DOCS "$DOCDIR" INSTALL="$PKG/install" mkdir "$INSTALL" wget -O "$INSTALL/doinst.sh" "$SBO/doinst.sh" wget -O "$INSTALL/slack-desc" "$SBO/slack-desc" cd "$PKG" /sbin/makepkg -l y -c n "$TMP/mpv-$VERSION-$ARCH-$BUILD$TAG.${PKGTYPE:-tgz}" https://github.com/duganchen/my_slackbuilds/blob/master/mpv.SlackBuild Quote
V.T. Eric Layton Posted September 20, 2022 Posted September 20, 2022 5 hours ago, securitybreach said: Where are you getting your info from Eric?? H3LL, I don't know. 1 Quote
