abarbarian Posted November 12, 2019 Posted November 12, 2019 13 hours ago, sunrat said: PS. MX can be run live from CD/USB. It even has an advanced persistence utility which will set up a USB flash drive to retain all you changes and data. You can use that every day instead of installing to HD. And MX-19 is out now! I have it installed and it's quite good. Got a glowing review at DistroWatch - https://distrowatch.com/weekly.php?issue=20191104#mx PPS. MX has Opera in the MX Package Installer. I installed MX-19 to a usb on Sunday with the intention of keeping it as my backup get me out of trouble tool. The persistence set up is very easy and most useful and am impressed with MX's latest offering.Have set it up to run from ram and only tried it on my ToughBook which has 4 GB of memory,an older ssd, and an older cpu " Intel Core2 Duo T7300" ,it runs pretty sweetly if a tad sedately. I bet it flies along on my main rig. Looks to be an even better offering from the MX team than the 18 version which was bomb proof in my experience. P.S. apologies for the hijack. Quote
V.T. Eric Layton Posted November 12, 2019 Posted November 12, 2019 19 hours ago, Cluttermagnet said: Next question- what is the exact syntax needed to point to this? See Roger's (Sunrat) answer above. :) Quote
Cluttermagnet Posted November 12, 2019 Author Posted November 12, 2019 Thanks for all the suggestions- but we seem to have gotten blown off course somewhere. I know how to launch opera from a Terminal window. What I'm trying to figure out here is how to add a launcher icon to my Menu/Internet. I asked a question above regarding what specific address syntax could be added into the Menu. Eric had previously given me enough info on how to do a custom launcher. All I'm lacking is the exact syntax now. I suppose I can eventually figure it out on my own... Thanks, Clutter Quote Eric- I see a file called opera under /usr/bin Next question- what is the exact syntax needed to point to this? I can imagine: clutter/usr/bin/opera also just /usr/bin/opera and perhaps a few others... so which would be 'letter perfect'? Quote
securitybreach Posted November 12, 2019 Posted November 12, 2019 It will most likely be /usr/bin/opera but you can easily find out by opening a terminal and typing: which opera Like for instance: 1 Quote
Cluttermagnet Posted November 12, 2019 Author Posted November 12, 2019 Thanks, Josh! I'll play with this shortly. In the middle of making myself a meal. Some warmed over Indian fare... Clutter P.S. these sorts of little problems tend to resolve easily, I'm confident that is the sort we're dealing with here... 1 Quote
Cluttermagnet Posted November 12, 2019 Author Posted November 12, 2019 ...and the answer is... (drum roll) /usr/bin/opera Thanks, Josh! 2 Quote
securitybreach Posted November 12, 2019 Posted November 12, 2019 Just now, Cluttermagnet said: ...and the answer is... (drum roll) /usr/bin/opera Thanks, Josh! No problem Quote
sunrat Posted November 12, 2019 Posted November 12, 2019 To summarise my last post which seems to have been misunderstood, if you can launch it from terminal with just "opera" you should be able to put just "opera" in your menu entry. /usr/bin/opera will work anyway so job done! 1 Quote
Cluttermagnet Posted November 12, 2019 Author Posted November 12, 2019 1 hour ago, sunrat said: To summarise my last post which seems to have been misunderstood, if you can launch it from terminal with just "opera" you should be able to put just "opera" in your menu entry. /usr/bin/opera will work anyway so job done! No problems, mate! All the help is appreciated. I'm still mulling over one additional oddity I have encountered. When I went to try and make a launcher, I encountered an icon for opera already 'in there' and checked with a + as well. It still does not, however, show up in my actual Menu, only in the Edit Menu environment. That's a little confusing and unexpected... As an experiment, there was one unchecked software in there so I checked it. It immediately started showing up in my menu (Iced Tea Java Web Start). So I know the idea of checking/unchecking is basically working, But NOT for Opera, for some reason. Weird... Clutter Quote
V.T. Eric Layton Posted November 12, 2019 Posted November 12, 2019 Wish I knew more about the current Linux Mint interface, David, but I haven't had LM on any of my systems in years. Making a panel or taskbar shortcut should be pretty easy, though, I would think. What Desktop Manager does LM use these days? Gnome? Quote
securitybreach Posted November 12, 2019 Posted November 12, 2019 5 minutes ago, V.T. Eric Layton said: What Desktop Manager does LM use these days? Gnome? They use various flavors. I think the default is cinnamon (?) 1 Quote
securitybreach Posted November 12, 2019 Posted November 12, 2019 They offer Cinnamon, Mate and XFCE. 1 Quote
V.T. Eric Layton Posted November 12, 2019 Posted November 12, 2019 Well, with Xfce, you just RIGHT click on a blank panel spot and choose Panel > Preferences > Item tab... then create your new launcher. Easy-peasy. I don't know diddly about Cinnamon or Mate these days. Quote
Cluttermagnet Posted November 13, 2019 Author Posted November 13, 2019 5 hours ago, securitybreach said: They offer Cinnamon, Mate and XFCE. I found Cinnamon a little over the top. Immediately took a dislike to 'mouse gestures' or whatever nonsense. I guess they were trying to create a more smart phone screen environment. Anyway, Betty and I both disliked Cinnamon so I settled on Mate. Clunky, kind of minimal, but less so than Xfce from what I remember of that one. I've been using Mate for some years now... Quote
Cluttermagnet Posted November 13, 2019 Author Posted November 13, 2019 5 hours ago, V.T. Eric Layton said: Well, with Xfce, you just RIGHT click on a blank panel spot and choose Panel > Preferences > Item tab... then create your new launcher. Easy-peasy. I don't know diddly about Cinnamon or Mate these days. Maybe I ought to try Xfce again. It's been a while. Likewise MX18, also suggested in this thread. Clutter Quote
