Fuddster Posted July 25, 2018 Share Posted July 25, 2018 I used the backup software Back In Time to back up my /home folder during my recent openSUSE reinstall. Somehow I missed a setting, I still don't know which one, that allowed BIT to copy/restore more copies of my files with ".backup.fulldate" appended to each file. OVER 250,000 OF THEM! I use the find command often, so I opened a terminal and fired it up. To make sure my search pattern worked, I sent the results to a text file and gave it a quick look. And Today I Learned that the find command has a -delete switch that made getting rid of those files a snap! The full command went something like find /home/fuddster/ -name "*.backup.20180721" -delete Even with commands you use all the time, there's always something else you can learn about them. What's your favorite AHA! moment like that? 3 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted July 25, 2018 Share Posted July 25, 2018 Ah, yes... the command line. It's a wonderful thing. Quote Link to comment Share on other sites More sharing options...
ebrke Posted July 25, 2018 Share Posted July 25, 2018 Well yesterday I learned the hard way never to assume. I was going to allow openSUSE to recreate my /home, so I copied files to a flash drive before my Leap 15 install. When I went to get my Thunderbird files, I found that .thunderbird and .mozilla had NOT been copied to the flash drive. First I thought I had stupidly not asked to copy hidden files, but I must have because I got .config, .cache, etc., just not what I really needed. Absolutely my own fault for not checking before starting the install, but still really aggravating. I dug around and found a .thunderbird backup that was about a year old, so at least got back most of my address book, but what a pain. 1 Quote Link to comment Share on other sites More sharing options...
saturnian Posted July 26, 2018 Share Posted July 26, 2018 Today I learned that Linux Lite doesn't support UEFI: https://www.linuxlit...and-linux-lite/ I had been testing the latest release, running live sessions from a flash drive, but couldn't boot my two newer notebooks. Found the above link later. Actually not a bad Xfce distro, overall, from what I'm seeing. Quote Link to comment Share on other sites More sharing options...
saturnian Posted July 26, 2018 Share Posted July 26, 2018 One of my favorite AHA! moments was finding out about using Ctrl+R to do a "reverse-i-search" through the command history. 3 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted July 27, 2018 Share Posted July 27, 2018 One of my favorite AHA! moments was when I learnt that you could open a new tab in FF by middle clicking on an open space in the top bar, no more fiddling to hit the little cross. An a similar AHA! moment was when I learnt to copy by holding down the left mouse button and to paste in linux with a middle click. This trick has its down side as when I am in Windows it does not work and confuses the heck out of me poor old grey cell. 4 Quote Link to comment Share on other sites More sharing options...
sunrat Posted July 28, 2018 Share Posted July 28, 2018 Some good tips. I usually use exec with find eg.: find . -name "*.wmv" -type f -exec rm {} \; And yes I hate it when middle button paste doesn't work in Windows. Quote Link to comment Share on other sites More sharing options...
saturnian Posted July 28, 2018 Share Posted July 28, 2018 One of my favorite AHA! moments was when I learnt that you could open a new tab in FF by middle clicking on an open space in the top bar, no more fiddling to hit the little cross. AHA! I use Pale Moon, and this trick works with that browser as well! Thanks, abarbarian! 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted July 28, 2018 Share Posted July 28, 2018 TIL that educating prisoners may not be a good thing, 364 Idaho Inmates Hacked Their Prison Tablets for Free Credits 1 Quote Link to comment Share on other sites More sharing options...
Hedon James Posted July 29, 2018 Share Posted July 29, 2018 TIL that educating prisoners may not be a good thing, 364 Idaho Inmates Hacked Their Prison Tablets for Free Credits Haha! I saw that too! Goes to show that they CAN be "rehabilitated" through teaching of productive and useful skills, but we still can't rehabilitate their brain in order to use those skills for good. Reminds me of that Stallone/Snipes movie "Demolition Man" where the convicted are frozen in pods, while their brains are re-programmed for societal integration. Stallone's overzealous cop character is taught knitting (presumably to help with relaxation?) while Snipes' psychopath character learns extensive electronics and computer programming. What could possibly go wrong with that? 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted July 29, 2018 Share Posted July 29, 2018 TIL. Create an alias for sudo with a space at the end: alias sudo='sudo ' Then all other aliases will work with sudo. As in alias w7=" sudo mount /dev/nvme0n1p3 /mnt" alias w7u=" sudo umount /dev/nvme0n1p3" This allows me to mount and unmount my Windows 7 partition on the rare occasion I need to transfer some files. Quote Link to comment Share on other sites More sharing options...
raymac46 Posted August 14, 2018 Share Posted August 14, 2018 If you are editing /etc/fstab, say to configure an SSD you can make a typo or add a space and then completely bork your system boot. To check you have done this edit right issue the following terminal command BEFORE reboot. $ sudo mount -a If this works without error you are good to go. If not, fix /etc/fstab and try again until error-free. 1 Quote Link to comment Share on other sites More sharing options...
Pete! Posted August 14, 2018 Share Posted August 14, 2018 Today I learned (the hard way) ..... synchronizing works both ways. Just stuck my toe in the "Linux pool" by using "LICK" to do an easy dual boot with Puppy. Rather than do all the work of setting up the included browser (Palemoon), I installed Firefox, and "synchronized". Now, back on Windows, all the NoScript "trusted" sites are back in "default" mode, and stuff doesn't work until I put it back. If the only things you want to synchronize are bookmarks and log-ins ...... UNCHECK EVERYTHING ELSE ! 1 Quote Link to comment Share on other sites More sharing options...
raymac46 Posted August 14, 2018 Share Posted August 14, 2018 (edited) If you mess up /etc/fstab and are unable to boot to a GUI and fstab is now read-only, you can remount the fs as follows if you can get to a root shell in recovery mode: mount -n -o remount -t ext4 /dev/sda1 / You should then be able to use nano (or VIM) to edit your fstab file and get back to where you were before. Note depending on your setup the partition info and file system parameters may differ. Edited August 14, 2018 by raymac46 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 29, 2020 Share Posted May 29, 2020 TIL about SWAY, Quote Sway is a tiling Wayland compositor and a drop-in replacement for the i3 window manager for X11. It works with your existing i3 configuration and supports most of i3's features, plus a few extras. https://swaywm.org/ Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 29, 2020 Share Posted May 29, 2020 1 hour ago, abarbarian said: TIL about SWAY, https://swaywm.org/ Yeah, I would probably be using it if Wayland supported Nvidia. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 29, 2020 Share Posted May 29, 2020 1 hour ago, securitybreach said: Yeah, I would probably be using it if Wayland supported Nvidia. Right your using nvidia drivers not the nouveau drivers. Posted in case anyone missed the news. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 29, 2020 Share Posted May 29, 2020 7 hours ago, abarbarian said: Right your using nvidia drivers not the nouveau drivers. Posted in case anyone missed the news. Well Noveau is ok if you just have one monitor and do not need graphic performance but other than that, it is not very good. Now its not noveau's fault as they are having to reverse engineer the nvidia driver as Nvidia doesn't share any of their code, hence the Linus gesture to them years back https://www.wired.com/2012/06/torvalds-nvidia-linux/ On the other hand, AMD has a team dedicated to developing their open source driver along with the community. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 15, 2021 Share Posted May 15, 2021 TIL a neat little cli program, The CLI To-Do List / Task Manager for Geeks There is a neat .gif showing it running, Highlights For ninjas - do things faster with keyboard shortcuts Markdown lovers, feel at :house:! You'll see markdown everywhere. Full featured (almost) - Projects, Tasks, due-dates, task notes... A <4MB app that takes <1% CPU and ~7MB memory 1 - how much lighter you can think? Task note editor with markdown syntax highlighting2 Full mouse support Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 15, 2021 Share Posted May 15, 2021 Neat but missing the most important part of a Todo list, Benning able to sync between devices. Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 15, 2021 Share Posted May 15, 2021 59 minutes ago, securitybreach said: Neat but missing the most important part of a Todo list, Benning able to sync between devices. Quote Where is the data stored? Can I change the location? By default, it will try to create a db file in you home directory. But as a geek, you may try to put it different location (e,g, in your dropbox for syncing). In that case, just mention DB_FILE as an environment variable. DB_FILE=~/dropbox/geek-life/default.db geek-life He does give some help with setting up a sync feature. Admittedly not everyone uses DropBox but then again not everyone needs a sync feature as there are many single pc users out there. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 15, 2021 Share Posted May 15, 2021 Gotcha. I wonder if it would work with pcloud Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 26, 2021 Share Posted May 26, 2021 On 5/15/2021 at 3:31 PM, securitybreach said: Gotcha. I wonder if it would work with pcloud Don't see why not. 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 27, 2021 Share Posted May 27, 2021 TIL HOW TO: Get a General Purpose Mouse Cursor for Your Linux TTY Virtual Console Quote If you work with the TTY virtual console on your Linux box, you might want a general purpose mouse functionality. Why? I don’t know why YOU might need it but, so far, I’ve use it for copy-pasting. For Arch users, https://archlinux.org/packages/core/x86_64/gpm/ https://archlinux.org/packages/core/x86_64/gpm/ This would have saved me quite a lot of time and effort in my early days learning about linux os's. I doubt I will use it much in the future but it could come in handy. 1 Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 27, 2021 Share Posted May 27, 2021 Wait? You didn't know about GPM?? It's been around since 2009. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 27, 2021 Share Posted May 27, 2021 Actually the last release was in 2012 https://github.com/telmich/gpm Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 29, 2021 Share Posted May 29, 2021 (edited) On 5/27/2021 at 11:56 AM, securitybreach said: Wait? You didn't know about GPM?? It's been around since 2009. Takes me a while to catch up with things. Just love the developers page at GitHub, Quote conf Initial commit 16 years ago contrib also remove contrib/Makefile 13 years ago doc fix your D*** email address, nico 8 years ago scripts fix scripts/report_success.sh 13 years ago src Merge pull request #37 from trofi/master 12 months ago .exclude Exclude .git from going into the tar 14 years ago .gitignore update ignored file list 5 years ago COPYING Initial commit 16 years ago MANIFEST Initial commit 16 years ago Makefile.in dist: include generated autotools in tarballs 5 years ago Makefile.include.in add datarootdir to make autoconf happy 13 years ago README cleanup readme, update urls 9 years ago README.gpm2 Commit readme for gpm2 14 years ago README.versions hint for versions 13 years ago TODO todo updated - old stuff removed 9 years ago acinclude.m4 get version string from git without calling ugly m4 macros 9 years ago autogen.sh do not use -e, as git describe may fail 9 years ago configure.ac.footer Resolve linking against ncursesw 8 years ago install-sh Initial commit 16 years ago Who needs constant updates if your base is sound. Edited May 29, 2021 by abarbarian 1 Quote Link to comment Share on other sites More sharing options...
abarbarian Posted September 2, 2021 Share Posted September 2, 2021 TDI Came across some MPV extras that I did not know about, they are MPV User-Scripts. User Scripts Quote Here is a list of scripts that users of mpv have published, adding functionality that is not part of the core mpv player. Most of these scripts are unofficial 3rd party scripts. Anyone can add their own script by editing this wiki. I have used three of the scripts and find them very useful. history-bookmark.lua I watch Anime and TV series but like to download the entire series before I watch. Also I may just watch a couple of episodes and then not return to watching for a few days or even weeks. Sometimes I have several series on the go as I like to watch stuff to suit my mood. As you can imagine this makes tracking which episode I need to watch next a tad tricky. The above script helps find the correct episode to watch easily. autoload.lua A neat script. Down at the bottom ;left in mpv you have a two little arrows for last/next item. On my mpv they have always been greyed out and done nothing. With this script they are showing active and the call up last/next item. I addition they show a playlist on screen for a very short time of the items in the folder you are playing items from. This works with series which are named the same with episode numbering and also with a folder containing random named files. I have some folders with movies and odd shorts so it is handy to see what I have directly in mpv rather than going to the folder itself all the time. autocrop.lua I watch a lot of older stuff and it is mainly in 4:3 aspect which is ok for nostalgia but the black lines at the side of the screen bug me as I have a widescreen monitor. Now not all 4:3 stuff looks good if filling the screen but quite a lot of the anime I watch looks just fine to me when it is changed from 4:3 to filling the screen which is what this script does. I have not tried it out with those stupid cinema screen films that have empty black spaces at the top and bottom of the screen. I hope it works with them as they really do make me see red. There is another script that is dedicated to changing 4:3 to fill your screen but I have not tried it out yet. As you can see there are many scripts for all sorts of things in the User-Script library and if you are able it seems pretty easy to add your own scripts too. Don't you just love the versatility of penguins. Enjoy. 1 Quote Link to comment Share on other sites More sharing options...
