larrynose Posted September 11, 2017 Posted September 11, 2017 Hello ppl, I have run into a problem here trying to move some files from the pc to phone. Its a windows 10 and it ain't recognizing the device. I have tried enabling the usb debugging option and plugging into the pc again. Still the same issue. redmi 4a is not recognized by the pc.On the other hand, iphone 7 gets recognized by the pc. no issues. Can someone tell me how to make the redmi work pls? Thanks in advance. Quote
securitybreach Posted September 11, 2017 Posted September 11, 2017 Odd as it says that all you need to do is enable USB Debugging: http://c.mi.com/thread-319923-1-0.html Have you tried another cable? Perhaps this driver will help you http://gsmusbdriver.com/xiaomi-redmi-4a Quote
larrynose Posted September 12, 2017 Author Posted September 12, 2017 Thank you heaps Securitybreach. Another cable did the trick. Odd as it says that all you need to do is enable USB Debugging: http://c.mi.com/thread-319923-1-0.html Have you tried another cable? Perhaps this driver will help you http://gsmusbdriver....xiaomi-redmi-4a 1 Quote
securitybreach Posted September 12, 2017 Posted September 12, 2017 Thank you heaps Securitybreach. Another cable did the trick. 1 Quote
