Sign in to follow this
Shamgar
Using Nero 6: copy disk or create Iso?
Shamgar
When using Nero 6, how do you decide between the function "Create Iso" or the function "Disk Copy" to make a copy of another disk?
Share this post
Link to post
GolfProRM
If you're just creating a single copy of a disk, then it's easiest to use Disk Copy... Creating the ISO is handy if you want to keep a backup of your CD on your harddrive, OR if you're burning the same CD multiple times. :thumbsup:
Share this post
Link to post
Shamgar
Thanks for the reply. Do they do make the extact same kind of copy onto the new disk?
Share this post
Link to post
GolfProRM
Yes :thumbsup:
Share this post
Link to post
James M. Fisher
Where is "Create ISO" option in Nero 6? I thought Nero only made it's own images....
Share this post
Link to post
Temmu
me thinks so too... .nro files.
Share this post
Link to post
Ozidave
Hi James, Temmu,I've burned a few CD's back to .iso files on the HD with Nero... v5.5 though.It's under Nero / More / Save tracks to HD / Settings / .nrg or .iso..... While the Menu looks like it's mainly for saving music... It'll handle any file(s). :) PcLos cuts back from the bootable-CD, to exactly the same as the original ISO. B) Edited by Ozidave
Share this post
Link to post
James M. Fisher
It's under Nero / More / Save tracks to HD / Settings / .nrg or .iso..... While the Menu looks like it's mainly for saving music... It'll handle any file(s). B)
I can't find anything remotely similar in Nero 6...maybe I'm blind.... :wacko:
Share this post
Link to post
GolfProRM
James... Start up the disk copy, and then go to more | Save Tracks | select your drive (if you've got more than one) and then in the output file format, you can choose ISO
Share this post
Link to post
James M. Fisher
I'm still not sure where you find the "More" button Ryan:nero.jpgI just have to option to save as an .nrg Nero image...
Share this post
Link to post
GolfProRM
Ahh... that would be because I'm using Nero Express...
Share this post
Link to post
James M. Fisher
OK, I see it now Ryan! :wacko:
Share this post
Link to post
Ozidave
OK, I see it now Ryan!  :)
You ain't seen nuthin' yet, my friend!  ^_^
Hi James, :">I didn't mention Nero Express because we were talking two different versions... but I did think that they would not have left that option out in an upgrade.Anyway! question?Is there any difference with .nro and .iso that matters when you are only using .nro to burn CD's from your own PC?. I mean it's different if you are posting the files, as not everyone uses Nero?. :(
Share this post
Link to post
Ozidave
:) :( ^_^
Share this post
Link to post
James M. Fisher
Is there any difference with .nro and .iso that matters when you are only using .nro to burn CD's from your own PC?. I mean it's different if you are posting the files, as not everyone uses Nero?. ^_^
I wouldn't think so Dave. None that I know of anyway.
Share this post
Link to post
umeshdhingra
Hi Guys,thanks for all the info , I am now in a position to use Nero software more efficiently ,cheers,Umesh
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
