patio Posted September 10, 2004 Share Posted September 10, 2004 it's a minor annoyance for me but is there a way to turn off the " No Subject " reminder that pops up if you don't include a subject in your outgoing e-mail??Thanx in advance,patio. Quote Link to comment Share on other sites More sharing options...
GolfProRM Posted September 10, 2004 Share Posted September 10, 2004 I'm guessing there's something in the config, but I don't have Tbird at work, so can't look until I get home Quote Link to comment Share on other sites More sharing options...
Ed_P Posted September 10, 2004 Share Posted September 10, 2004 Are you trying to emulate an AOL user patio? Quote Link to comment Share on other sites More sharing options...
epp_b Posted September 10, 2004 Share Posted September 10, 2004 Are you trying to emulate an AOL user patio? Ssssssssssss! BURN! I don't use Tbird, but I think there's probably an option somewhere in the settings for this. Quote Link to comment Share on other sites More sharing options...
patio Posted September 12, 2004 Author Share Posted September 12, 2004 Are you trying to emulate an AOL user patio? not at all.Daily e-mails and responses to a small group (8 people ) i work with.Just trying to speed things up and eliminate a step.I've checked all the options and settings, nothing there.I've also perused the user.js file but i don't see any switch for it. patio. Quote Link to comment Share on other sites More sharing options...
GolfProRM Posted September 12, 2004 Share Posted September 12, 2004 I checked through everything as well, and couldn't find anything related to subjects... It's been requested a few times that it be added to TB, but it hasn't... You might go to http://forums.mozillazine.org/index.php and go to the extensions forum and request that an extension be made to do this (unless you want to code it yourself) Quote Link to comment Share on other sites More sharing options...
patio Posted September 13, 2004 Author Share Posted September 13, 2004 Thanx GolfPro,Will do.Course the last time i visited the forums i spent so much time there i forgot what it was i was after... patio. Quote Link to comment Share on other sites More sharing options...
Ed_P Posted September 14, 2004 Share Posted September 14, 2004 You could just use short subjects. I've frequently used just "?", "!" or "$" as my subjects. Quote Link to comment Share on other sites More sharing options...
nlinecomputers Posted September 14, 2004 Share Posted September 14, 2004 FYI spamassassin tends to add more weight to email that has no subject line. You are much more likely to be marked as a false positive if you don't put something in the subject header. Quote Link to comment Share on other sites More sharing options...
GolfProRM Posted October 10, 2004 Share Posted October 10, 2004 Patio... I'm not sure if you ever resolved this, but someone did release an extension! http://update.mozilla.org/extensions/morei...?id=305&vid=911 Quote Link to comment Share on other sites More sharing options...
patio Posted October 11, 2004 Author Share Posted October 11, 2004 Patio... I'm not sure if you ever resolved this, but someone did release an extension! http://update.mozilla.org/extensions/morei...?id=305&vid=911 Just what the doctor ordered...Thanxxpatio. Quote Link to comment Share on other sites More sharing options...
