Frank Woods Posted June 20, 2013 Posted June 20, 2013 I did a clean install and before this. I was able to to this drive on or off and Windows would see it. Now in order for Windows to see the drive I have to turn the drive on and then do a full restart. It then will see the drive even if I shut it off. Then if I want to restart I have to hit the restart button or the PC will not re boot. It is seen in the Bios. So if someone can tell me how to Fix this I will appreciate it. If not I can make it into a USB drive but it will be slower. Bios is up to date. Thanks Quote
crp Posted June 21, 2013 Posted June 21, 2013 and, just to make clear as i am very short on sleep, you are not trying to hotswap or disconnect the eSata while pc is running in any way? Quote
Frank Woods Posted June 21, 2013 Author Posted June 21, 2013 (edited) No, If I turn it on and then reboot it wil so up in windows. This then gives me problems shutting down. It worked fine before I did the clean install. I have it on a USB port so it does not cause me any problems. The Image I did last night took 55 minutes in the USB with E-Sata it took about 20. I have a blank 1TB internal diask that I will use for imaging until this is sorted out. Edited June 21, 2013 by Frank Woods Quote
goretsky Posted June 21, 2013 Posted June 21, 2013 Hello, It sounds to me like some sort of driver involved in managing hot-plugging an eSATA connection is missing. Since you just reinstalled Microsoft Windows, go ahead and run Windows Update to download and install all of the missing hotfixes, patches and updates for your operating system, followed by the device drivers for the various components from their respective manufacturers and see if that makes any difference. Regards, Aryeh Goretsky Quote
goretsky Posted June 23, 2013 Posted June 23, 2013 Hello, I had the same issue with my Asus P6T Deluxe V1 motherboard and solved it by using newer SATA drivers from Marvell Semiconductor. What is the brand and model of the computer? Regards, Aryeh Goretsky 1 Quote
Frank Woods Posted June 24, 2013 Author Posted June 24, 2013 Hello, I had the same issue with my Asus P6T Deluxe V1 motherboardand solved it by using newer SATA drivers from Marvell Semiconductor. What is the brand and model of the computer? Regards, Aryeh Goretsky It is a Cyberpower PC with a Haf 912 case an MSI X58 Pro E ,MS-7522 MOBO with Dr Mos Bios running Win 7 64 Bit with 24GB of DDR3 ram.. CPU is an Intel Core i7 960 Quote
Guest LilBambi Posted June 24, 2013 Posted June 24, 2013 (edited) Sounds like a very nice gaming machine (as far as CPU and RAM go and video capabilities)! Edited June 24, 2013 by LilBambi Quote
Guest LilBambi Posted June 24, 2013 Posted June 24, 2013 Have you gone to the download pages for the Intel® X58 Express Chipset Based - MSI site? Quote
Frank Woods Posted June 24, 2013 Author Posted June 24, 2013 Have you gone to the download pages for the Intel® X58 Express Chipset Based - MSI site? You are a live saver. It was this one that did it: jmicron_jmb363_ide_all_mb.zip I did run that MSI live update and it showed nothing. Thanks you very muck! 1 Quote
Guest LilBambi Posted June 26, 2013 Posted June 26, 2013 You are very welcome! Glad to help Frank! Changed the topic to show it [[sOLVED]] Quote
