Screen Resolution issue with xrandr
ichase
 Share
Been knee deep in the Xrandr Arch Wiki and have tried a number of things to change my resolution from the current 1366x768 to 1600x1200. Reason I am doing this is because I want to have more info in my conky and it ain't happening with the current resolution.
I am running a Dell Latitude E5510 which is MORE than capable of handling a higher resolution.
xrandr output shows:
[ichase02@arch64 ~]$ xrandr
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192
eDP1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1366x768	 60.0*+
1024x768	 60.0
800x600	 60.3	 56.2
640x480	 59.9
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
DP1 disconnected (normal left inverted right x axis y axis)
1600x1200_60.00 59.9
HDMI2 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
I have tried manually adding the resolution IAW the wiki but I get an error:
[ichase02@arch64 ~]$ cvt 1600 1200 60
# 1600x1200 59.87 Hz (CVT 1.92M3) hsync: 74.54 kHz; pclk: 161.00 MHz
Modeline "1600x1200_60.00"  161.00  1600 1712 1880 2160  1200 1203 1207 1245 -hsync +vsync
[ichase02@arch64 ~]$ xrandr --newmode "1600x1200_60.00"  161.00  1600 1712 1880 2160  1200 1203 1207 1245 -hsync +vsync
[ichase02@arch64 ~]$ xrandr --addmode eDP1 1600x1200_60.00
X Error of failed request:  BadMatch (invalid parameter attributes)
 Major opcode of failed request:  140 (RANDR)
 Minor opcode of failed request:  18 (RRAddOutputMode)
 Serial number of failed request:  33
 Current serial number in output stream:  34
I originally tried
[ichase02@arch64 ~]$ xrandr --output LVDS --mode 1024x768
warning: output LVDS not found; ignoring
To dynamically test some different resolutions but as you can see I am getting an LVDS not found.
So what do you think I am doing wrong here?
Thanks and hope everyone has a great weekend,
Ian
Edited by ichase
Have you tried installing and running arandr? I had some issues with setting the resolution on one of my monitors but I was able to use arandr (which is just a frontend to xrandr) to set the correct values (graphically). Arandr basically lets you set up xrandr visually then you can save it as a script. Here is mine (for reference):
#!/bin/sh
xrandr --output DisplayPort-0 --mode 1920x1080 --pos 1600x0 --rotate normal --output DVI-1 --mode 1600x900 --pos 3520x180 --rotate normal --output DVI-0 --mode 1600x900 --pos 0x180 --rotate normal --output HDMI-0 --mode 1920x1080 --pos 1600x1080 --rotate normal
If it works, then just add the path to ~/.xinitrc:
sh randr.sh &
(replace randr.sh with the filename you chose)
Wait, I just noticed that DP1 shows 1600x1200. Are you sure you are choosing the right output?
][/b][ichase02@arch64 ~]$ xrandr
1366x768 60.0*+
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
I installed the arandr package yesterday and only have 1366x768 to choose from.
No I am using eDP1. The reason you see a setting under DP1 is because I created it forgetting to add the "e" in front of it.
When I click "New" in arandr, nothing happens. I am guessing that is where you are talking about when setting up more elaborate settings.
Try this:
gtf 1600 1200 60.00
xrandr --output eDP1 --mode 1600x1200_60.00
When I get to addmode it fails:
No clue why I am showing the 1600x1200 twice under DP2? Note there is no longer anything showing under DP1??????? :huh:
[ichase02@arch64 ~]$ xrandr -q
  1366x768	   60.0*+
  1024x768	   60.0
  800x600	    60.3	 56.2
  640x480	    59.9
 1600x1200_60:00 (0x12a)  161.0MHz
    h: width  1600 start 1712 end 1880 total 2160 skew    0 clock   74.5KHz
    v: height 1200 start 1203 end 1207 total 1245		   clock   59.9Hz
 1600x1200_60.00 (0x14d)  161.0MHz
    h: width  1600 start 1704 end 1880 total 2160 skew    0 clock   74.5KHz
    v: height 1200 start 1201 end 1204 total 1242		   clock   60.0Hz
 Share
