sunrat Posted February 17, 2013 Posted February 17, 2013 Android 4.1.1 doesn't include USB Mass Storage mode Is anyone affected by this yet, or do you have workarounds? I find it extremely useful and would hate to lose it. MTP is too restricted in functionality; for my Galaxy S2 it only sees pictures on mine. I like to put a few FLAC and ogg files there, which play fine but only can be transferred with USB mass storage. I currently have Android 4.0.4 and don't want to update if I lose this. Quote
securitybreach Posted February 17, 2013 Posted February 17, 2013 I personally just use mtpfs which works sort of like the USB mass storage did: Mtpfs is FUSE filesystem that supports reading and writing from any MTP device. Basically it allows you to mount your device as an external drive.It's available in the community repository; you can install it by running pacman -S mtpfs. First edit your /etc/fuse.conf and uncomment the following line: user_allow_other To mount your device # mtpfs -o allow_other /media/YOURMOUNTPOINT To unmount your device with fuse as regular user # fusermount -u /media/YOURMOUNTPOINT To unmount your device as root $ umount /media/YOURMOUNTPOINT Also, you can put them into your ~/.bashrc: alias android-connect="mtpfs -o allow_other /media/YOURMOUNTPOINT" alias android-disconnect="fusermount -u /media/YOURMOUNTPOINT" Or, with sudo alias android-disconnect="sudo umount -u /media/YOURMOUNTPOINT" https://wiki.archlin...x.php/MTP#mtpfs As far as having the option to use USB storage, this has been disabled on version 4.1 Quote
