V.T. Eric Layton Posted November 6, 2012 Posted November 6, 2012 Is anyone having issues with Arch updating the past couple days. Neither my Pacman nor Yaourt finds any updates since Friday, I think. However, according to Josh's regular updates thread, there are some updates available. I checked the servers manually (by visiting them via browser) and they don't show the new updates; bash, for example, should be 4.2.039-1, yet on the server it's still 4.2.037-1. Arch usually isn't this slow to sync those mirrors. What's up? Quote
securitybreach Posted November 6, 2012 Posted November 6, 2012 Do you have a mirrorlist.pacnew file? And if so, have you ran rankmirrors against the new file? Here is my mirrorlist if it helps: Server = http://cosmos.cites.illinois.edu/pub/archlinux/$repo/os/$arch Server = http://mirror.us.leaseweb.net/archlinux/$repo/os/$arch Server = http://mirror.rit.edu/archlinux/$repo/os/$arch Server = http://mirrors.rutgers.edu/archlinux/$repo/os/$arch Server = http://mirror.nexcess.net/archlinux/$repo/os/$arch Server = http://mirrors.cicku.me/archlinux/$repo/os/$arch Server = http://mirrors.liquidweb.com/archlinux/$repo/os/$arch Quote
securitybreach Posted November 6, 2012 Posted November 6, 2012 Also, remember your first mirror in the list is the first one that gets tried. So try commenting it out. Quote
securitybreach Posted November 6, 2012 Posted November 6, 2012 You could also try refreshing them with: # pacman -Syy Then try to update again. I have had this happen before and that fixed it. Quote
V.T. Eric Layton Posted November 6, 2012 Author Posted November 6, 2012 Yup. I followed all the usual steps you mention. It's OK now. It updated just a few minutes ago. Server = http://cake.lib.fit.edu/archlinux/$repo/os/$arch Server = http://mirror.jmu.edu/pub/archlinux/$repo/os/$arch Server = http://mirror.us.leaseweb.net/archlinux/$repo/os/$arch Server = http://mirror.umd.edu/archlinux/$repo/os/$arch Server = http://archlinux.tserver.net/$repo/os/$arch Server = http://cosmos.cites.illinois.edu/pub/archlinux/$repo/os/$arch The updates were just NOT on the server this morning. They're obviously there now, though. Thanks, ~Eric Quote
