Guest LilBambi Posted April 15, 2012 Posted April 15, 2012 We now have a new top navigation link right under the header at the top of each page; it is called Portal. On the Portal link, you will find several items. On the Left: Recently Added Posts On the left side page, you will see that we have, through a third party app/hook, brought back the show recent posts/replies, they call it Recently Added Posts. I really missed this one. It is not identical to the one in the old version of the forusm, but it's the closest I have found. On the Right: Latest Discussions - Site Navigation - Online Users All three down the right side of the portal page. Hope you enjoy the portal page as much as I do! Nice to have the Recently Added Posts back most of all though! Enjoy! Quote
securitybreach Posted April 15, 2012 Posted April 15, 2012 I had noticed the View new Content button on the right but did not notice the Portal link, very neat stuff!!!! BTW I keep losing my replies as I am used to being able to hit tab and enter to post the reply and now it opens up the top search function instead. Odd as you would think that the tab key would go to the next radio button instead of going to the top input field (search function). Quote
amenditman Posted April 15, 2012 Posted April 15, 2012 (edited) I had noticed the View new Content button on the right but did not notice the Portal link, very neat stuff!!!! BTW I keep losing my replies as I am used to being able to hit tab and enter to post the reply and now it opens up the top search function instead. Odd as you would think that the tab key would go to the next radio button instead of going to the top input field (search function). Maybe it's behavior is to default to the first button on the page, not the next from where you are. Weird, but with a kind of logic behind it. Edited April 15, 2012 by amenditman Quote
securitybreach Posted April 15, 2012 Posted April 15, 2012 Maybe it's behavior is to default to the first button on the page, not the next from where you are. Weird, but with a kind of logic behind it. Maybe so, I just keep messing up my replies out of habit. I am a bit of a "keyboard cowboy" so I am used to using my keyboard more so than the mouse but whatever.... Quote
amenditman Posted April 15, 2012 Posted April 15, 2012 Yah, it's tough to break old habits and build new ones. Quote
Guest LilBambi Posted April 15, 2012 Posted April 15, 2012 So true, amenditman! Sometimes the changes are downright annoying ... but then enhanced security and a lot of new features (lots of those, including being able to choose an alternate theme where we can choose our own colors), plus get back some controls we had lost for a time because of security issues in the old version (such as not being able upload avatars for instance). Hopefully these will make up for the annoyances in the long run. Quote
V.T. Eric Layton Posted April 15, 2012 Posted April 15, 2012 Give your little mouse some love, J. Quote
ross549 Posted April 15, 2012 Posted April 15, 2012 Hopefully these will make up for the annoyances in the long run. They will. It is just new. We just have to get used to some slightly different behaviors. Adam Quote
securitybreach Posted April 16, 2012 Posted April 16, 2012 Give your little mouse some love, J. Heresy Quote
V.T. Eric Layton Posted April 17, 2012 Posted April 17, 2012 You are a TCLPH! Total Command Line PHreak! Quote
securitybreach Posted April 20, 2012 Posted April 20, 2012 You are a TCLPH! Total Command Line PHreak! Thanks a lot for the excellent compliment Quote
V.T. Eric Layton Posted April 20, 2012 Posted April 20, 2012 Heh! That would make a great avatar for you. You should even use "CLI Phreak" as your custom title, too. Quote
securitybreach Posted April 20, 2012 Posted April 20, 2012 Heh! That would make a great avatar for you. You should even use "CLI Phreak" as your custom title, too. I like the idea of using that as my custom title hmmm wonder if I can do that or Fran needs to do it for me? Quote
securitybreach Posted April 20, 2012 Posted April 20, 2012 I like the idea of using that as my custom title hmmm wonder if I can do that or Fran needs to do it for me? I found the settings Quote
