zlim Posted January 14, 2012 Share Posted January 14, 2012 Elizabeth, I've managed to install a sound card in one computer and a video card in another. The hardest part might be working around everything if the case is small. Don't let it intimidate you, it is not hard. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted January 14, 2012 Share Posted January 14, 2012 By the way, Elizabeth... You might want to take your computer outside and open the case on it. If you've never done this before, it'll probably be loaded with dust, pet hair, human hair, etc. That's not a reflection on your housecleaning skills; it's just that electronic equipment tends to attract the stuff. Anyway, it wouldn't hurt to blow out the case (with a leaf blower, compressed air, whatever). You can even use a paint brush to clean vents and fan blades on the cooling fans, should you not have any means to blow the case out. After doing this, gently apply pressure to your sound card (and other plug ins) to make sure everything is still snug and tight in their slots. Sometimes, just a loose card connection can cause issues. Keep us posted... Quote Link to comment Share on other sites More sharing options...
