XP: force Internet accesses to wireless conn in presence of wired conn
In our office we have only wireless networking. However, it hasn't been working so well lately, and since we're moving soon, we're not going to fix it. I just got a linux box, which I want to use by VNCing from my WIN XP laptop. The wireless is too flakey, so I have connected the laptop (using its wired internet connection) and the linux box to an old wired-only router (Microsoft MN100). Problem: When the router is connected to the laptop, the laptop won't access the internet. It appears to insist on using the MN100 as the gateway. I used the route command to change the default gateway to the wireless router [route change 0.0.0.0 MASK 255.255.255.255 <wireless router> METRIC 10], and the route table looks right, but still doesn't work.What's the trick to MAKE it use the wireless router for internet browsing?Thanks!/j
how is the MN100 connected to the wireless router?
it's not, at all. the idea is that the wired network from the laptop to the linux box is a separate, isolated, 2-client network.thanks/j
Hi Temmu - thanks - but since it was a short-term need, we only wanted to put limited effort into it. Eventually, we solved it short-term by putting the linux box in another physical site where it can be connected via wired internet, and long-distance VNC to it (Which is surprisingly lag-free). As part of the debugging, we did work with the route table and even it looked like we had what we wanted we weren't getting what we needed.Thanks anyway - I appreciate it./j
Glad you found a solution, Jeff. An alternative would have been to uncheck the "connect automatically" in the Wireless profile.
