Hi - I have some XPHome (SP3) machines that still have FAT-32 partitions, some as big as 100GB. I'd like to move them to NTFS, but am afraid of breaking what's not broken. Still, tools and SW expect NTFS today. Is there a 0-risk tool that will do the conversion? Does it take hours?any/all thoughts welcomethanks!/j
Frank Golden
I think there is a command line tool to perform this duty from within XP.http://aumha.org/win5/a/ntfscvt.phpWhen it comes to computers I don't think zero risk applies. LOL.I think this method above is low risk but certainly not zero risk. Edited by Frank Golden
Hello,I would suggest backing up any critical data just to be safe and then running the Convert program.Regards,Aryeh Goretsky
I would suggest to search Scot's blog/newsletter: I remember Scot did a thorough review of the possibilities a few years ago, among them what to do and what not to do: if you select the wrong approach, you'll end up with wrong cluster sizes.
Actually, the link from Frank Golden mentions the cluster size issue, and suggests using BootitNG to fix it. Perhaps I can just use BootitNG for the entire process.....thanks/j
At one time or another I've used Partition Magic, Partition Commander, BootIt NG or Windows XP's built-in utility to convert from FAT/FAT32 to NTFS. Never with a data loss and no need to restore from a backup utility, but I always held my breath.Depending on the size of the partition, the conversion process takes some number of minutes. If it's a multi-gigabyte partition it could take and hour and some minutes. If the machine requires external power; is not on an adequate UPS (can run the machine long enough for the entire process to finish); and there is a power failure ...Be careful. Good luck. :)
So tell me this - how likely is it that it will -appear- to work, but things are corrupt (i.e., 3 months later I try to open a rarely-used file and it's broken). Do you see much of that? Or does success typically mean success?/j
