LLfan Posted October 1, 2003 Posted October 1, 2003 If this is breaking any rules please delete this link but since I have gone through a process of help already that didn't work it makes sense for you to know what I have already tried. Plus I posted a screenshot as well. http://www.mypcclinic.com/forum/index.php?...?showtopic=1287Basically, no matter what I do I can't get java to work on my machine. I have tried the bin/rpm, and that said it went ok. But I still get the 'plugin needed'.Can anyone help? Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 MikeIt´s your lucky day . . . . . . . . . . . . or not . . :DJust yesterday I did post a Tip about installing the Java plugin. Let me tell you first that many have stumbled over this and never did get it right . . . . funny enough I use Galeon and without doing anything special my Java has worked fine from the start ( did not install anything, it was already there, but then I installed from PowerPack, a boxed version ).From my first impression your install of the plugin seemed to have gone fine, only the browser integration part is the stumbling block ( what browser do you use ? ). The Tip I posted does discribe how to do it . . . . Like I said . . . . . . it´s your lucky day . . . or maybe not, because it does look complicated. BrunoPS: I could always send you my plugin directory by mail if needed. Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 A nightly build of Firebir 0.6+. As the posts in the link says, I have tried everything within the browser to make sure it is enabled. Will check out the link. Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Sorry, I did read that thread to quick to notice . . . ;)I thought Firebird had an extension database with ultra easy to install extensions . . . click and run . . is the Java plugin not one of the hundred listed ? Bruno Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Mike,Have a look here: http://plugindoc.mozdev.org/linux.html#JavaThat should help you out for Firebird. Bruno Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 No idea what a symbolic link is but I tried it and got this: [mike:~]$ ln -s /usr/java/j2re1.4.2/plugin/i386/ns610/libjavaplugin_oji.so /hom e/mike/mozillafirebird/plugins/libjavaplugin_oji.soln: creating symbolic link `/home/mike/mozillafirebird/plugins/libjavaplugin_oji.so' to `/usr/java/j2re1.4.2/plugin/i386/ns610/libjavaplugin_oji.so': No such file or directory Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 MikeI think it should be:[mike:~]$ ln -s /usr/java/j2re1.4.2/plugin/i386/ns610/libjavaplugin_oji.so /home/mike/MozillaFirebird/plugins/Did you do it with tab completion to be sure you´ve got the names right ?? Bruno Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 WHat in the world is tab completion! Quote
teacher Posted October 1, 2003 Posted October 1, 2003 Did you do it with tab completion to be sure you´ve got the names right ??Type four or five letters of the name and then press the tab key and it should fill it in. If there are multiple files starting the same way it will go as far as the first place where they are different and wait for you to type some more while showing you a list of the possibilitites! Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 I entered in what you just typed out and got this:ln: `/home/mike/MozillaFirebird/plugins//libjavaplugin_oji.so': File exists Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Mike There where a few mistakes in the line you pasted . . The Directory is MozillaFirebird with M and F . . and the line should end with /plugins/Tab Completion Bruno Quote
teacher Posted October 1, 2003 Posted October 1, 2003 Did you try to copy and paste? Sometimes that helps eliminate little errors. Did you see the answer to tab completion? Evidently we posted at the same time. I thought you might wonder what he was talking about. Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 I entered in what you just typed out and got this:ln: `/home/mike/MozillaFirebird/plugins//libjavaplugin_oji.so': File existsJava plugin is installed then . . . so it should workB) Bruno Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 I knew I had that file there as I took a screen shot of it. For some reason, it still is not working. Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Well acording to the Mozilla site, there has to be a soft link in the plugin directory and not the actual file . . . maybe the "libjavaplugin_oji.so" depends other files that are in the "/usr/java/j2re1.4.2/plugin/" directory . . . and will not work if you pace the file outside that directory . . . . Bruno Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 Well contrary to my message title 'Message Adept' I am rather inept at this stuff and what you just said made little sense to me. How can I fix this? (not my ineptness-in case you were thinking on making a wise crack ) Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Mike If you did a system-wide install of Sun JRE 1.4.2 as root, libjavaplugin_oji.so is located in /usr/java/j2re1.4.2/plugin/i386/ns610/ Will you check this first ??Then just delete the "libjavaplugin_oji.so"currently in the /home/mike/MozillaFirebird/plugins directorythen: Create ~/.mozilla/plugins if it doesn't exist. Then use the following command at a console: ln -s /usr/java/j2re1.4.2/plugin/i386/ns610/libjavaplugin_oji.so home/mike/.mozilla/plugins/libjavaplugin_oji.so In your home directory just make a new directory ( with the GUI ) and call it ".mozilla" don´t forget the dot before the m . . . it will not show because it will be a hidden directory . . . so "view hidden files" . . . and make in the .mozilla a plugins directory . . . Then to the console:ln -s /usr/java/j2re1.4.2/plugin/i386/ns610/libjavaplugin_oji.so home/mike/.mozilla/plugins/libjavaplugin_oji.soJust copy and paste it in the console . . you should get no error message return, actually you will just get the prompt back, that means it did the trickB) Bruno Quote
teacher Posted October 1, 2003 Posted October 1, 2003 Don't worry. Your title says Message adept not Linux adept! We don't expect you to be an expert at this point. Heck, some of us are still in the learning phase! What he is saying is (assuming I understand) that if the file is in the wrong folder from where the browser expects it to be then it will not work even if it installed okay. Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 Thanks for all the help folks!Here is the location of the file:/usr/java/j2re1.4.2_01/plugin/i386/ns610 (notice the _01 on the jre directory is not what sun has)What to do now? Can I simply rename the folder without breaking too much? Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 Don't worry. Your title says Message adept not Linux adept! We don't expect you to be an expert at this point. Heck, some of us are still in the learning phase! What he is saying is (assuming I understand) that if the file is in the wrong folder from where the browser expects it to be then it will not work even if it installed okay.Is there such thing as Linux Adept? That's like saying stable Windows--it's impossible. Quote
teacher Posted October 1, 2003 Posted October 1, 2003 No - Don't remove the 1. That means you have a file that has been updated since Bruno's file. Leave it as it is and see if it works. Be sure to close your browser and reopen it to make sure it picked up the changes. Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 No - Don't remove the 1. That means you have a file that has been updated since Bruno's file. Leave it as it is and see if it works. Be sure to close your browser and reopen it to make sure it picked up the changes.Closed the browser and still i get the plugin needed prompt Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Thanks for all the help folks!Here is the location of the file:/usr/java/j2re1.4.2_01/plugin/i386/ns610 (notice the _01 on the jre directory is not what sun has)What to do now? Can I simply rename the folder without breaking too much?No do not rename it !I will adapt the command:ln -s /usr/java//j2re1.4.2_01/plugin/i386/ns610/libjavaplugin_oji.so /home/mike/.mozilla/plugins/libjavaplugin_oji.soB) BrunoPS: did you get that plugin from the Mozilla site or directly from Sun ?? Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 Thanks for all the help folks!Here is the location of the file:/usr/java/j2re1.4.2_01/plugin/i386/ns610 (notice the _01 on the jre directory is not what sun has)What to do now? Can I simply rename the folder without breaking too much?No do not rename it !I will adapt the command:ln -s /usr/java//j2re1.4.2_01/plugin/i386/ns610/libjavaplugin_oji.so /home/mike/.mozilla/plugins/libjavaplugin_oji.soB) BrunoPS: did you get that plugin from the Mozilla site or directly from Sun ?? Wait, that can't be right since it's located in file:/home/mike/MozillaFirebird/plugins I tried to change it myself but got bad command so probably screwed up the syntax somewhere--could you reconfigure the command again please. Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 MikeI was following the instructions from Mozilla: * Create home/mike/.mozilla/plugins if it doesn't exist. Then use the following command at a console: ln -s /usr/java/j2re1.4.2/plugin/i386/ns610/libjavaplugin_oji.so /home/mike/.mozilla/plugins/libjavaplugin_oji.soThe second method is preferred, as it bypasses the permissions issue completely, although it only installs the plugin for an individual user. You can also create the link using Konqueror or other GUI file managers See that last line ?? Bruno Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 Yes, I see the last line. SO what you were attempting to do is create that directory and put the file in it? It didn't work as I got an error that it did not exist. Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 MikeI think you missed this part: In your home directory just make a new directory ( with the GUI ) and call it ".mozilla" don´t forget the dot before the m . . . it will not show because it will be a hidden directory . . . so "view hidden files" . . . and make in the .mozilla a plugins directory . . . Bruno Quote
LLfan Posted October 1, 2003 Author Posted October 1, 2003 Surprisingly enough .mozilla already existed. So I went in and created a new directory called 'plugins'. Now what? Quote
Bruno Posted October 1, 2003 Posted October 1, 2003 Good !!ln -s /usr/java//j2re1.4.2_01/plugin/i386/ns610/libjavaplugin_oji.so /home/mike/.mozilla/plugins/libjavaplugin_oji.soand to be safe:ln -s /usr/java//j2re1.4.2_01/plugin/i386/ns610/libjavaplugin_oji.so /home/mike/MozillaFirebird/plugins/libjavaplugin_oji.soB) Bruno Quote
