Oppps..... here is the problem ... just installed Windows 7 RC 64 bit on the first partition of HD1 .. the install went very smoothly ,,, EXCEPT ,,,, now the only entries on the boot menu are either "earlier version of Windows and Windows 7" .... I also have PCLOS, Vector SOHO, Kubuntu, and Mandriva (current) on HD0 ..in this order Windows XP then PCLOS, Vector SOHO, Kubuntu and Mandriva ... I am using GRUB with PCLOS as the default boot OS ... now how do I get back to my original boot menu
Disregard my original post .. got the problem fixed .... Tks
It would be nice if you told us how you fixed the problem. :">
Sorry .......... used the PCLOS 2009.1 disk as live CD ... opened consol as root and made the entry "redo-mbr" followed the prompts/questions got the MBR back ,, did a reboot and it was good
Edited by longgone
Frank Golden
A really great tool for restoring grub is SuperGrubCDhttp://www.supergrubdisk.org/This is a powerful tool that will restore grub as well as restore the Windows mbr if needed.It has a help mode that walks you through the steps.
I have the "Super Grub" disk but I cannot get it to work .. so I am not sure if the disk is bad or .. it is operator error .. have tried to both use it after the OS is booted up and to try and boot with it in the tray .. neither way has worked for me ... ????
Frank Golden
It is meant to be booted like a live cd. You should download the latest version and try burning another cd. Burn at slowest speed posible.What happens when you try to boot SuperGrub? Edited by Frank Golden
Nothing happens at all ... it just boots right on up into the default OS .. it is as if there is nothing in the tray at all
How are you burning it to the CD? What sw are you using? What do you see on the CD after the burning process finishes?
Does K3B write the ISO file to the CD or creates a bootable CD with the files within the ISO?
I think . that it must just do the latter ... since I can click on it and when I open it .. what I am left with is a file folder with the title Super Grub and the version number/
Booting with the CD in the tray and the hd's OS starting implies that the BIOS isn't configured to boot from a CD 1st or that the CD is not recognized as being bootable.If you're sure the BIOS is set correctly then the problem has to be the latter. Can you try burning the ISO on a Windows' machine with an app called IMGBurn?
Edited by Ed_P
I can give it a try .. and see what the end result is ... will get back with it ..
Frank Golden
Aha, Dale that's your problem. You are only copying the .iso to cd.You need to "burn" the image it to make it bootable.The screenshot below shows what opening the CD in explorer should show exactly.Anything else won't boot.th_Untitled-17.jpgI've never used K3B but this should helphttp://www.linuxquestions.org/linux/answer...Os_in_Linux_K3Bsee the first post.I use Nero in Windows for all my .iso burning needs. If you have Nero start the program after inserting a blank cd (CD-R are recomended but I get good results wirh CD-RW disks). This will open the "Nero Start Smart" applet. Click the little Nero flame icon at the bottom left of window and choose "Nero Burning Rom". When Burning Rom windows opens select recorder from the toolbar and choose burn image. This will take you to a dialog box where you can browse to where your .iso is stored. I usually copy it to my desktop temporarily when burning an image. When you've located the .iso highlight it and click open.This will open a new dialog box, don't change anything, just click the burn button and wait for Nero to finish the burn.BTW, how did you create (burn) the PCLinucOS Live CD.Use the exact same method for Super Grub. Edited by Frank Golden
