ForeverLost
Hi All,I have been using ZDNet's Password Pro v2 for years and have a large collection of passwords stored within it's data file. When I tried installing it on a new PC with 64-bit Vista Ultimate, it refused to install. Tried every compatibility option; no luck. Searched the internet and managed to find v3.14 of the software; however, that install also failed (though with a different error message). It appears both versions or their installers may have 16-bit code and Vista 64 therefore refuses to install them.So I am in a big soup. Qs:1. Has anybody had success install either v2 or v3.14 on a 64-bit Vista PC? If so, could you share how you did it?2. Is there a more recent version of this software available anywhere? (I believe its no longer offered by PC Mag, even if you pay to become a downloading member)3. Does anyone know of any other program that can import the contents of the data file (.pwd extension)?I have spent all day trying to find a solution but have had no luck. All help appreciated. :teehee:
Can you set Vista to run the installer in Compatibility mode??
ForeverLost
Tried every compatibility mode for the installer in Vista. None worked. Edited by ForeverLost
Create a shortcut to the apps .exe on the Desktop...Right clik the shortcut and adjust the compatibility mode settings there...Re-boot and try launching from the Desktop.
ForeverLost
There is no "app"; it won't even install!! I have tried setting the compatibility modes for all .exe files that I see in the unzipped installer package, to no avail.
patio is referring to the installer itself. Save it someplace, create a shortcut to it, adjust the shortcut's compatibilty settings, reboot, try the shortcut to see if the app will now install.There may be further shortcuts needed once the install is run.
  • 2 weeks later...
ForeverLost
Here's an update:I downloaded and installed KeePass (http://keepass.info). Funny name, I know. Its an open source, light weight password manager; donations are accepted. It appears to be quite robust and can even run from a USB stick, making it truly portable. Besides, and very importantly, it has a host of plugins that expand its compatibility with other password programs, allowing import/export in various formats (not Password Pro, though). Oh, and it works on 64-bit Vista just fine. Over a couple of days, I manually copied over my passwords. Folks still using Password Pro should realize that they are locked into a proprietary (read incompatible) format, doesn't export, and which is now hopelessly out of date; sooner or later, they will need to migrate to another password manager. KeePass appears to be a sound choice. Happy computing!
Thanks for the update ForeverLost. I use a lot of old ZDNet utilities also and Password Pro especially.
