Hi Everyone,When I am using the computer for a long period time, the IE toolbar icons change around. I have it set up for 2 rows of icons but then it will change to 4. I do have the option to Lock Toolbars checked. Also-after this happens, if I go to open one of my OE emails, it says- not enough memory to open this- and I have to reboot.I also went into the C drive properties-Total Size 74.4 GB Free Space 63.8 GB-does this seem right? Any help would be so much appreciated! XP SP2 HomeIE6
Next time this happens, open taskmanager and see what applications are using the most RAM, and how much is being used.
Poss,Some additional information would be nice. For example, when it says not enough information, what other applications are you running at that time? Post some system specs to help us - help you. e.g. Processor, RAM, etc. Have you set windows to manage the swap file? Or have you set to manual?As far as the browser toolbar, which version of IE are you using? Do you have the latest service pack for IE installed? Have you run a spyware scan? If so, what did you use? Have you kept your antivirus definitions upto date?Do you have any other toolbars installed?
