Mandriva 2007 HP PSC-210 Scanner problem
jimtheplanner
Okay . . . . . looking gooood.So now try to add a new printer in the MCC ( and just leave the old one but set the new one to "default" )Crossing fingers.:teehee: Bruno
jimtheplanner
Oh Bruno,I get the same message as before when I fire sane up "No devices available".Are we running out of options? :hmm: Jim....
Edited by jimtheplanner
jimtheplanner
Sorry Bruno,I should have added this warning: prior to firiing up sane, this warning happens during the printer install:-"Could not install sane packages! Scanning on the HP 1200 series will not be possible"Sorry....Jim
:hmm: . . okay let us compare packages:what have you got installed with "sane" in the name ?what have you got installed with "hplip" in the name ?B) Bruno
jimtheplanner
OK Bruno,First SANElibsane641-1.018-7mdv2007.0libsane1-1.0.18-7mdv2007.0libsane1-devel-1-1.0.18-7mdv2007.0libsane-hpaio1-1.6.9-1mdv2007.0sanebackends-1.0.18-7mdv2007.0xsane-0.991-2mdv2007.0Second hpliphplip-1.6.9-1mdv2007.0hplip-hpijs-1.6.9-1mdv2007.0hplip-model-data-1.6.9mdv2007.0Jim......
The strange thing is that the "libsane641-1.018-7mdv2007.0" we removed earlier is there again . . . . I wonder why that is.can you show me for the rest of the packages:
# rpm -qi hplip# rpm -qi hplip-hpijs# rpm -qi hplip-model-data# rpm -qi libsane1# rpm -qi libsane1-devel# rpm -qi libsane-hpaio1# rpm -qi sane-backends# rpm -qi xsane
Also please show:
# urpmq --list-media
and
# urpmq --list-media --active
With that info I will see what I can come up with . . let me study it overnight and we will pick up from there tomorrow.:hmm: Bruno
jimtheplanner
Ok Bruno,As requested:-Password:[root@localhost james]# rpm -qi hplipName : hplip Relocations: (not relocatable)Version : 1.6.9 Vendor: MandrivaRelease : 1mdv2007.0 Build Date: Mon 18 Sep 2006 14:11:41 BSTInstall Date: Fri 15 Dec 2006 08:03:46 GMT Build Host: seggie.mandriva.comGroup : System/Servers Source RPM: hplip-1.6.9-1mdv2007.0.src.rpmSize : 10325593 License: GPL/MIT/BSDSignature : DSA/SHA1, Wed 20 Sep 2006 17:51:53 BST, Key ID e7898ae070771ff3Packager : Iurt the rebuild bot <warly@mandriva.com>URL : http://hpinkjet.sourceforge.net/Summary : HP printer/all-in-one driver infrastructureDescription :This is the HP driver package to supply Linux support for mostHewlett-Packard DeskJet, LaserJet, PSC, OfficeJet, and PhotoSmartprinters and all-in-one peripherals (also known as Multi-FunctionPeripherals or MFPs), which can print, scan, copy, fax, and/or accessflash memory cards.It is work in progress, but printing, scanning, memory card access,ink/toner/battery/consumable level checking, and inkjet printermaintenance are supported on most models, when either connected to theUSB or LAN (built-in interfaces or selected HP JetDirect models) on aLinux workstation with CUPS printing system.For status and consumable checking and also for inkjet maintenancethere is the graphical tool "hp-toolbox" available (Menu:"System"/"Monitoring"/"HP Printer Toolbox").[root@localhost james]# rpm -qi hplip-hpijsName : hplip-hpijs Relocations: (not relocatable)Version : 1.6.9 Vendor: MandrivaRelease : 1mdv2007.0 Build Date: Mon 18 Sep 2006 14:11:41 BSTInstall Date: Fri 15 Dec 2006 07:54:12 GMT Build Host: seggie.mandriva.comGroup : System/Servers Source RPM: hplip-1.6.9-1mdv2007.0.src.rpmSize : 479993 License: GPL/MIT/BSDSignature : DSA/SHA1, Wed 20 Sep 2006 17:51:54 BST, Key ID e7898ae070771ff3Packager : Iurt the rebuild bot <warly@mandriva.com>URL : http://hpinkjet.sourceforge.net/Summary : HPs printer driver IJS plug-in for GhostScriptDescription :HPs printer driver IJS plug-in for GhostScript. This driver gives fullprinting support for nearly all non-PostScript inkjet and laserprinters made by HP.[root@localhost james]# rpm -qi hplip-model-dataName : hplip-model-data Relocations: (not relocatable)Version : 1.6.9 Vendor: MandrivaRelease : 1mdv2007.0 Build Date: Mon 18 Sep 2006 14:11:41 BSTInstall Date: Fri 15 Dec 2006 08:03:20 GMT Build Host: seggie.mandriva.comGroup : System/Servers Source RPM: hplip-1.6.9-1mdv2007.0.src.rpmSize : 531470 License: GPL/MIT/BSDSignature : DSA/SHA1, Wed 20 Sep 2006 17:51:54 BST, Key ID e7898ae070771ff3Packager : Iurt the rebuild bot <warly@mandriva.com>URL : http://hpinkjet.sourceforge.net/Summary : XML file listing the HP printer models supported by HPLIPDescription :HPLIP supports most current HP printers and multifunction devices, butthere are some older models not supported. This package contains thelist of supported models. Printerdrake installs it automatically todetermine whether HPLIP has to be installed or not.[root@localhost james]# rpm -qi libsane1Name : libsane1 Relocations: (not relocatable)Version : 1.0.18 Vendor: MandrivaRelease : 7mdv2007.0 Build Date: Mon 18 Sep 2006 09:51:08 BSTInstall Date: Sat 16 Dec 2006 05:05:22 GMT Build Host: n1.mandriva.comGroup : System/Kernel and hardware Source RPM: sane-1.0.18-7mdv2007.0.src.rpmSize : 6107872 License: LGPLSignature : DSA/SHA1, Wed 20 Sep 2006 15:58:27 BST, Key ID e7898ae070771ff3Packager : Till Kamppeter <till@mandriva.com>URL : http://www.sane-project.org/Summary : SANE - local and remote scanner access. This package contains the sane libraryDescription :SANE (Scanner Access Now Easy) is a sane and simple interfaceto both local and networked scanners and other image acquisition deviceslike digital still and video cameras. SANE currently includes modules foraccessing a range of scanners, including models from Agfa SnapScan, Apple,Artec, Canon, CoolScan, Epson, HP, Microtek, Mustek, Nikon, Siemens,Tamarack, UMAX, Connectix, QuickCams and other SANE devices via network.For the latest information on SANE, the SANE standard definition, andmailing list access, see http://www.mostang.com/sane/This package does not enable network scanning by default; if you wishto enable it, install the saned package.[root@localhost james]# rpm -qi libsane1-develName : libsane1-devel Relocations: (not relocatable)Version : 1.0.18 Vendor: MandrivaRelease : 7mdv2007.0 Build Date: Mon 18 Sep 2006 09:51:08 BSTInstall Date: Sat 16 Dec 2006 05:05:25 GMT Build Host: n1.mandriva.comGroup : Development/C Source RPM: sane-1.0.18-7mdv2007.0.src.rpmSize : 106756 License: LGPLSignature : DSA/SHA1, Wed 20 Sep 2006 15:58:27 BST, Key ID e7898ae070771ff3Packager : Till Kamppeter <till@mandriva.com>URL : http://www.sane-project.org/Summary : SANE - local and remote scanner accessDescription :SANE (Scanner Access Now Easy) is a sane and simple interfaceto both local and networked scanners and other image acquisition deviceslike digital still and video cameras. SANE currently includes modules foraccessing a range of scanners, including models from Agfa SnapScan, Apple,Artec, Canon, CoolScan, Epson, HP, Microtek, Mustek, Nikon, Siemens,Tamarack, UMAX, Connectix, QuickCams and other SANE devices via network.For the latest information on SANE, the SANE standard definition, andmailing list access, see http://www.mostang.com/sane/This package contains the headers and development libraries necessaryto develop applications using SANE.[root@localhost james]# rpm -qi libsane-hpaio1Name : libsane-hpaio1 Relocations: (not relocatable)Version : 1.6.9 Vendor: MandrivaRelease : 1mdv2007.0 Build Date: Mon 18 Sep 2006 14:03:00 BSTInstall Date: Sat 16 Dec 2006 19:15:48 GMT Build Host: n5.mandriva.comGroup : System/Servers Source RPM: hplip-1.6.9-1mdv2007.0.src.rpmSize : 94944 License: GPL/MIT/BSDSignature : DSA/SHA1, Wed 20 Sep 2006 15:58:26 BST, Key ID e7898ae070771ff3Packager : Iurt the rebuild bot <warly@mandriva.com>URL : http://hpinkjet.sourceforge.net/Summary : SANE driver for scanners in HP's multi-function devices (from HPLIP)Description :SANE driver for scanners in HP's multi-function devices (from HPLIP)[root@localhost james]# rpm -qi sane-backendsName : sane-backends Relocations: (not relocatable)Version : 1.0.18 Vendor: MandrivaRelease : 7mdv2007.0 Build Date: Mon 18 Sep 2006 12:55:43 BSTInstall Date: Sat 16 Dec 2006 05:05:44 GMT Build Host: deborah.mandriva.comGroup : System/Kernel and hardware Source RPM: sane-1.0.18-7mdv2007.0.src.rpmSize : 4095505 License: LGPLSignature : DSA/SHA1, Wed 20 Sep 2006 18:10:13 BST, Key ID e7898ae070771ff3Packager : Iurt the rebuild bot <warly@mandriva.com>URL : http://www.sane-project.org/Summary : SANE - local and remote scanner accessDescription :SANE (Scanner Access Now Easy) is a sane and simple interfaceto both local and networked scanners and other image acquisition deviceslike digital still and video cameras. SANE currently includes modules foraccessing a range of scanners, including models from Agfa SnapScan, Apple,Artec, Canon, CoolScan, Epson, HP, Microtek, Mustek, Nikon, Siemens,Tamarack, UMAX, Connectix, QuickCams and other SANE devices via network.For the latest information on SANE, the SANE standard definition, andmailing list access, see http://www.mostang.com/sane/This package does not enable network scanning by default; if you wishto enable it, install the saned package and set up the sane-net backend.This package contains the backends for different scanners.[root@localhost james]# rpm -qi xsaneName : xsane Relocations: (not relocatable)Version : 0.991 Vendor: MandrivaRelease : 2mdv2007.0 Build Date: Tue 05 Sep 2006 19:42:30 BSTInstall Date: Sat 16 Dec 2006 05:04:34 GMT Build Host: seggie.mandriva.comGroup : Graphics Source RPM: xsane-0.991-2mdv2007.0.src.rpmSize : 4680224 License: GPLSignature : DSA/SHA1, Wed 20 Sep 2006 18:14:49 BST, Key ID e7898ae070771ff3Packager : Nicolas L�ureuil <neoclust@mandriva.org>URL : http://www.xsane.org/Summary : Xsane is a frontend for the SANE scanner interfaceDescription :XSane is an X based interface for the SANE (Scanner Access Now Easy)library, which provides access to scanners, digital cameras, and othercapture devices. XSane is written in GTK+ and provides control forperforming the scan and then manipulating the captured image.You may install xsane-gimp if you want the GIMP plug-in.[root@localhost james]# urpmq --list-mediaPowerpack DVDPowerpack DVD (main32)Powerpack DVD (non-free64)Powerpack DVD (non-free32)update_source2007_main-322007_contrib-32[root@localhost james]# urpmq --list-media --activeUnknown option: active[root@localhost james]#Thank you once again Bruno :hmm: Catch you tomorrowJIm......
Sorry Jim . . I made a typo in the last command . . it should have been:
# urpmq --list-media active
Thanks for the rest of the info !:hmm: Bruno
jimtheplanner
Ok Bruno,The missing link?[james@localhost ~]$ suPassword:[root@localhost james]# urpmq --list-media activePowerpack DVDPowerpack DVD (main32)Powerpack DVD (non-free64)Powerpack DVD (non-free32)update_source2007_main-322007_contrib-32[root@localhost james]#Jim...
Okay Jim . . . after closely looking at the packages you have installed and comparing them to the ones I have installed I see a difference in size in the hplip, hplip-hpijs, sane-backends and xsane.What I think that is happening is that when you go through configuring your printer it takes some files from your DVD's and some from the mirror we added . . and that is why you have a mix if 64 and 32 bits packages.So what we will try today is:1). Remove ( with "rpm -e <package> --nodeps" ) all those sane and hplip packages.2). Go in the MCC and de-activate all sources except the 2007_main-32 and 2007_contrib-32 . . . this way we can only get 32bits packages.3). Re-install the sane and hplip packages.Maybe we will have to look at the /etc/mandriva-release ( also mandrakelinux-release and mandrake-release ) and set it to i586 . . . to make sure your package manager does not complain.Please show "cat /etc/mandriva-release" so I can tell you what to change ( that way you will have a copy on the forum so you can revert back to the original after we are done. )Question: are you game for our little experiment ?So, first step:
# rpm -e  hplip --nodeps# rpm -e hplip-hpijs --nodeps # rpm -e hplip-model-data --nodeps# rpm -e libsane1 --nodeps# rpm -e libsane1-devel --nodeps# rpm -e libsane-hpaio1 --nodeps# rpm -e sane-backends --nodeps# rpm -e xsane --nodeps
:hysterical: Bruno
jimtheplanner
Hi Bruno,Let's go for it I'm learning all the time as we go through this....I followed your instructions & got the following:-[james@localhost ~]$ suPassword:[root@localhost james]# rpm -e hplip --nodeps[root@localhost james]# rpm -e hplip-hpijs --nodeps[root@localhost james]# rpm -e hplip-model-data --nodeps[root@localhost james]# rpm -e libsane1 --nodeps[root@localhost james]# rpm -e libsane1-devel --nodeps[root@localhost james]# rpm -e libsane-hpaio1 --nodeps[root@localhost james]# rpm -e sane-backends --nodepswarning: /etc/sane.d/dll.conf saved as /etc/sane.d/dll.conf.rpmsave[root@localhost james]# rpm -e xsane --nodeps[root@localhost james]#Is this what you expected?Jim...
Yep that is indeed looking good . . . . . now go in the MCC and disable ALL the sources ( also updates ) except the 2007_main-32 and 2007_contrib-32Next please show:
:hysterical: Bruno
jimtheplanner
Ok Bruno,Here we are:-[james@localhost ~]$ suPassword:[root@localhost james]# urpmq --list-media active2007_main-322007_contrib-32[root@localhost james]#Jim....
jimtheplanner
Here we are:-[root@localhost james]# cat /etc/mandriva-releaseMandriva Linux release 2007.0 (Official) for x86_64[root@localhost james]#Jim....
Okay make that read:
Mandriva Linux release 2007.0 (Official) for i586
The other ones are symlinks to this file so you only have to change this one.Next do:
# urpmi hplip# urpmi hplip-hpijs # urpmi hplip-model-data # urpmi libsane1# urpmi libsane1-devel # urpmi libsane-hpaio1 # urpmi sane-backends # urpmi xsane
One by one so we can analyze error-messages as they come.:hysterical: Bruno
jimtheplanner
Alright Bruno,Here's No. 1[james@localhost ~]$ suPassword:[root@localhost james]# urpmi hplipTo satisfy dependencies, the following packages are going to be installed:hplip-1.6.9-1mdv2007.0.i586hplip-hpijs-1.6.9-1mdv2007.0.i586hplip-model-data-1.6.9-1mdv2007.0.i586Proceed with the installation of the 3 packages? (11 MB) (Y/n) y ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpm ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpm ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpminstalling hplip-hpijs-1.6.9-1mdv2007.0.i586.rpm hplip-model-data-1.6.9-1mdv2007.0.i586.rpm hplip-1.6.9-1mdv2007.0.i586.rpm from /var/cache/urpmi/rpmsPreparing... ############################################# 1/3: hplip-model-data ############################################# 2/3: hplip-hpijs ############################################# 3/3: hplip #############################################[root@localhost james]#No. 2[james@localhost ~]$ suPassword:[root@localhost james]# urpmi hplip-hpijsThe package(s) are already installed[root@localhost james]#No. 3[james@localhost ~]$ suPassword:[root@localhost james]# urpmi hplip-model-dataThe package(s) are already installed[root@localhost james]#No. 4[james@localhost ~]$ suPassword:[root@localhost james]# urpmi libsane1 ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpminstalling libsane1-1.0.18-7mdv2007.0.i586.rpm from /var/cache/urpmi/rpmsPreparing... ############################################# 1/1: libsane1 #############################################[root@localhost james]#No. 5[james@localhost ~]$ suPassword:[root@localhost james]# urpmi libsane1-devel ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpminstalling libsane1-devel-1.0.18-7mdv2007.0.i586.rpm from /var/cache/urpmi/rpmsPreparing... ############################################# 1/1: libsane1-devel #############################################[root@localhost james]#No. 6[james@localhost ~]$ suPassword:[root@localhost james]# urpmi libsane-hpaio1To satisfy dependencies, the following packages are going to be installed:libsane-hpaio1-1.6.9-1mdv2007.0.i586sane-backends-1.0.18-7mdv2007.0.i586Proceed with the installation of the 2 packages? (4 MB) (Y/n) y ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpm ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpminstalling sane-backends-1.0.18-7mdv2007.0.i586.rpm libsane-hpaio1-1.6.9-1mdv2007.0.i586.rpm from /var/cache/urpmi/rpmsPreparing... ############################################# 1/2: sane-backends ############################################# 2/2: libsane-hpaio1 #############################################[root@localhost james]#No. 7[james@localhost ~]$ suPassword:[root@localhost james]# urpmi sane-backendsThe package(s) are already installed[root@localhost james]#No. 8[james@localhost ~]$ suPassword:[root@localhost james]# urpmi xsane ftp://ftp.nluug.nl/pub/os/Linux/distr/Man...2007.0.i586.rpminstalling xsane-0.991-2mdv2007.0.i586.rpm from /var/cache/urpmi/rpmsPreparing... ############################################# 1/1: xsane #############################################[root@localhost james]#All added . . .Jim :hysterical:
Well, Jim . . . I might be wrong, but I am getting the impression this was okay :hysterical: So next go in the MCC and remove the old printer and add a new one . . . . . Crossing fingers ;):w00t: Bruno
jimtheplanner
Sorry Bruno,I got that old familiar warning whilst adding the printer:-"Could not install sane packages! Scanning on the HP 1200 series will not be possible"And again XSane would not detect the scanner.....Jim.... :hysterical:
Nooooo . . . . this is very mega frustrating ! :w00t: . . . I am slowly running out of options.Okay let us remove the packages again:
# rpm -e  hplip --nodeps# rpm -e hplip-hpijs --nodeps# rpm -e hplip-model-data --nodeps# rpm -e libsane1 --nodeps# rpm -e libsane1-devel --nodeps# rpm -e libsane-hpaio1 --nodeps# rpm -e sane-backends --nodeps# rpm -e xsane --nodeps
Then change the /etc/mandriva-release back to what it was before.Next
# urmpi.removemedia 2007_main-32 # urmpi.removemedia  2007_contrib-32
And I will look up the 64 bits sources for Main and Contrib . . . . and put them in my next post.:hysterical: Bruno
jimtheplanner
Bruno,If were hitting a brick wall with this don't worry. As I mentioned before; Xmas is coming :hysterical: If the probem lies with the HP PSC-1200 series! What if I got a 1300 series - would I stand a better chance of scanner detection????Jim...
I have a 1300 series . . but am not 100% sure it is the scanner or the 64bits distro that is to blame. Basically the 1200 and the 1300 use the same software.Anyway, here is the second part:Add new sources . . . . . Main:
# urpmi.addmedia --wget "2007_main-64" ftp://ftp.nluug.nl/pub/os/Linux/distr/Mandrakelinux/official/2007.0/x86_64/media/main/release/ with ./media_info/hdlist.cz
And Contrib:
# urpmi.addmedia --wget "2007_contrib-64" ftp://ftp.nluug.nl/pub/os/Linux/distr/Mandrakelinux/official/2007.0/x86_64/media/contrib/release/ with ./media_info/hdlist.cz
Should only list the 2 we just added.Next only install the most important
# urpmi hplip# urpmi xsane
Next try the MCC --> add a new printer again . . . . .:w00t: Bruno
jimtheplanner
Bruno, NO NO thank you for your patience in geting me though this. I guess all I need to do now is switch my updates on again.If I dont have any other problems :hysterical: I would like to wish you & your family very good Xmas & an even better new year :w00t: RegardsJimthe-extremelyhappy-planner..........
Yep indeed . . I was about to post that :clap:
If I dont have any other problems :w00t: I would like to wish you & your family very good Xmas & an even better new year :clap:
Same to you are yours Jim !
Jim-the-extremelyhappy-planner..........
This is exactly why I like this "job" :hysterical: :clap: Bruno
