merja Posted June 25, 2003 Share Posted June 25, 2003 I am using a Transcend JetFlash USB 2.0 PenDrive (64 MB). Everything run smoothly for a month or so, but now whenever I try to stop it, I get the following message: The device 'Generic Volume' cannot be stopped right now. Try stopping the device again later.All I can do is that I don't care about this message and unplug the device. Maybe it's best not to use this safe stopping at all? Does someone have a hint what's causing this problem and how to avoid it? Quote Link to comment Share on other sites More sharing options...
snoepie Posted June 28, 2003 Share Posted June 28, 2003 Just a thought: did you ever consider disabling indexing service? Quote Link to comment Share on other sites More sharing options...
FuzzButt Posted June 30, 2003 Share Posted June 30, 2003 Odd.While you were browsing the volume did you have the "thumb nails" generated by windows? that too will mess things up. I regularly have issues deleting folders that had the thumbs.db file generated until I reboot.Chris Quote Link to comment Share on other sites More sharing options...
merja Posted June 30, 2003 Author Share Posted June 30, 2003 Yes, I did disable indexing service long ago and I don't find any 'thumbs' at the moment from my folders.So, I just unplug the device discarding the message 'can't be stopped' or, if I have some very important files in it that I definetely don't want to lose, I restart my pc, which enables stopping the USB device correctly.Annoying, anyway! Some genius might develope a tiny tool to do that without restarting??? Quote Link to comment Share on other sites More sharing options...
carlcroom Posted June 30, 2003 Share Posted June 30, 2003 Had this problem with my 256 MB.I noticed that I needed to close all windows associated with the drive and wait a few seconds and all was well.Carl Croom Quote Link to comment Share on other sites More sharing options...
merja Posted July 1, 2003 Author Share Posted July 1, 2003 Had this problem with my 256 MB.I noticed that I needed to close all windows associated with the driveĀ and wait a few seconds and all was well.Carl CroomSorry, but doesn't work for me! (OS Windows2000) Quote Link to comment Share on other sites More sharing options...
