Lover of quiet computers Posted May 12, 2006 Share Posted May 12, 2006 I installed Camino 1.0 on my Mac (with Tiger) when it was released earlier this year. Now that Camino 1.0.1 was released, I'm wondering how I should install it. Is it just as easy as simply installing it over 1.0? Would I get enhanced performace by wiping out the old Camino and importing my bookmarks? Is there something else I should do before I upgrade? Quote Link to comment Share on other sites More sharing options...
bjf123 Posted May 12, 2006 Share Posted May 12, 2006 (edited) When I've installed new versions of programs, I will usually just install it right over the old version. I think your bookmarks will still be there as long as you don't delete the Camino prefs file. You should be able to delete the program file, though I'm not 100% sure on that. It's been quite awhile since I've used Camino, but I've done what I've outlined with Firefox with no problems. Edited May 12, 2006 by bjf123 Quote Link to comment Share on other sites More sharing options...
Lover of quiet computers Posted May 12, 2006 Author Share Posted May 12, 2006 I should clarify: It's not losing data that I'm worried about. Rather, it's inoptimal peformance. Would I get better performance from Camino 1.0.1 by first clearing out my personal data from Camino 1.0, or by deleting Camino 1.0? Quote Link to comment Share on other sites More sharing options...
RobertM Posted May 13, 2006 Share Posted May 13, 2006 Just drag the new Camino into Applications. It will replace your old one with this new version. (If you feel so inclined, you can also remove the old one before copying over the new one, but I believe either will basically do the same thing: old one's gone, replaced with the new one. I don't know how OS X works behind the scenes, but it probably does basically the same thing either way. In any case, I'd say no way is significantly different from the other.)As for your personal information, I'd recommend just leaving that all intact, especially since this is such a small upgrade. (BTW, this info isn't stored with Camino in your Applications folder, it's in /users/<you>/Library/Application Support/Camino. You can add, remove, or update Camino itself, and this other information will remain safe and sound. If, for some reason, you ever would like to remove this information, however, that is where it is stored. I don't really see a reason to do so, however.) Quote Link to comment Share on other sites More sharing options...
epp_b Posted May 13, 2006 Share Posted May 13, 2006 Best way to upgrade Camino? http://www.eudora.com/ Quote Link to comment Share on other sites More sharing options...
