ross549 Posted October 8, 2005 Posted October 8, 2005 (edited) Do NOT update!Folks,As part of the latest updates here, I have lost the function of my USB mouse on one of my computers. I have since then stopped the update on my main machine. I am currently trying to figure out why the mouse is not working, and will alert you as soon as I find a solution.Adam Edited October 8, 2005 by ross549 Quote
burninbush Posted October 8, 2005 Posted October 8, 2005 Do NOT update! I am currently trying to figure out why the mouse is not working, and will alert you as soon as I find a solution.AdamAhhh... xorgconfig? There are a bunch of mouse types listed there. If you can get a working config with that, you can at least see what type of mouse works, and paste that into your regular xorg.conf. Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 I have been using mousedrake, which lists all of them . I have also been playing around in xorg.conf. Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 I have been reading something about the USB mouse and Mandr 2006 . . . something with xorg . . .can't remember the fix . . . . will try to trace it and post. Bruno Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 Thanks, Bruno! I have halted the updates on my main machine until this gets hammered out. ;)Adam Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 Running 'modprobe evdev' at the console as root might help. That's what was suggested for people who experienced this problem late in 2006's development, anyway, so it might be good for previous versions too...Please try this . . . and let us know if it worksB) Bruno Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 Can you do a "lsmod"on both systems and compare "before" and "after" update ??I am checking the output of the updates . . . Bruno Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 These were the "warnings" after the update: ( I always save them ) While installing package libiw28-28-0.pre9.1tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package wireless-tools-28-0.pre9.1tex:Moving /usr/lib/hotplug to /lib/hotplugWhile installing package initscripts-7.61.1-39tex:warning: /etc/sysctl.conf created as /etc/sysctl.conf.rpmnewWhile installing package libMesaGL1-5.0.2-9tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libxorg-x11-6.9-0.cvs20051007.1tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libMesaglut3-5.0.2-9tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: Cannot lstat /usr/lib/libkpilot.so.0.0.0.#prelink#.eS1Cu5: No such file or directory/sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libcups2-1.1.23-14tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package cups-1.1.23-14tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libgphoto2-2.1.6-2tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package sane-backends-1.0.16-1tex:warning: /etc/sane.d/dll.conf created as /etc/sane.d/dll.conf.rpmnewWhile installing package libgutenprint2-5.0.0-1tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkaddressbook.so.0.0.0.#prelink#.Zlf7kP is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libijs1-0.35-19tex:/sbin/ldconfig: File /usr/lib/librss.so.1.0.0.#prelink#.w8c93H is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libdbus-glib-1_0-0.23.4-5tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdeinit_kcontrol.so.#prelink#.1wCx14 is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libhpojip0-0.91-11tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libwx_gtk2_html-2.6.so.0.0.0.#prelink#.3UZxLi is too small, not checked.While installing package libdbus-qt-1_0-0.23.4-5tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package kdebase-3.4.2-5tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.Due to changes in KDM Please reboot system by selecting LOG OUTfrom the main menu and selecting RESTART COMPUTER./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package kdenetwork-3.4.2-2tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libsane-hpaio1-0.9.4-5tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package libsane-hpoj1-0.91-11tex:/sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked./sbin/ldconfig: File /usr/lib/libkonnector.so.0.0.0.#prelink#.BFNlVw is too small, not checked./sbin/ldconfig: File /usr/lib/libkdegames.so.1.2.0.#prelink#.YXKp1K is too small, not checked.While installing package printer-utils-10.2-2tex:useradd: user saned existsWhile installing package shorewall-2.4.1-1tex:warning: /etc/shorewall/interfaces created as /etc/shorewall/interfaces.rpmnewwarning: /etc/shorewall/policy created as /etc/shorewall/policy.rpmnewwarning: /etc/shorewall/rules created as /etc/shorewall/rules.rpmnewwarning: /etc/shorewall/zones created as /etc/shorewall/zones.rpmnewThe only thing in here that I can mark as "suspect" is:While installing package initscripts-7.61.1-39tex:warning: /etc/sysctl.conf created as /etc/sysctl.conf.rpmnewPlease compare the two files . . . Also:Moving /usr/lib/hotplug to /lib/hotplugMaybe make a link to the old location ? "ln -s /lib/hotplug /usr/lib/hotplug" ??Checking my other install to . . . see what I saved there . . Bruno Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 Bruno.....1. List of differences between the two system's lsmod outpus is numerous... completely different hardware.2. The sysctl files are not much different..... only chnages were for net.ipv4 entries.3. Hotplug is working... my thumbdrives are working. Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 3. Hotplug is working... my thumbdrives are working.Yep but maybe the mouseconfig is still pointing to the old location ? ( Just guessing )You can also check http://qa.mandriva.com/buglist.cgi?bug_sta...alue1-0-3=mouse the 2006 bugreports on USB mouse.Also: did you upgrade your kernel ?? And if so are you using the correct initrd.img ? ( I know . . sounds stupid but still doublecheck . . . ) BrunoPS: Sorry deleted the "changes-file" on the other computer since all was okay . . Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 http://qa.mandriva.com/show_bug.cgi?id=17828This is close..... :hmm:I am running the latest kernel.How do I check mouseconfig? Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 . . does not look like they came up with a solution yet . . . . ( no replies in that thread )What if you unplug the mouse and (hot)plug it back in ?? BrunoHow do I check mouseconfig? Running mousedrake Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 Maybe check:/etc/sysconfig/mouse/etc/udev/rules.d/mouse.rules.old/etc/udev/conf.d/mouse.conf/etc/makedev.d/mouse.conf/etc/devfs/conf.d/mouse.confB) Bruno Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 Oct 8 17:50:20 localhost kernel: usb 2-1: USB disconnect, address 2Oct 8 17:50:20 localhost hal.hotplug[5918]: DEVPATH is not setOct 8 17:50:22 localhost hald[5333]: Timed out waiting for hotplug event 1683. Rebasing to 1713Oct 8 17:50:27 localhost kernel: usb 2-1: new low speed USB device using uhci_hcd and address 3Oct 8 17:50:27 localhost kernel: input: Microsoft Microsoft Wireless Optical Desktop® 1.00 on usb-0000:00:1d.0-1Oct 8 17:50:27 localhost hal.hotplug[5942]: DEVPATH is not setOct 8 17:50:28 localhost udev[5953]: run_program: exec of program failedOct 8 17:50:28 localhost udev[5954]: run_program: exec of program failedOct 8 17:50:28 localhost udev[5961]: run_program: exec of program failedOct 8 17:50:28 localhost udev[5963]: run_program: exec of program failed That is when I unplug/replug the mouse. Something is clearly wrong.You are giving me quite a CLI workout today, Bruno... my brain feels stronger! Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 DEVPATH is not setHave a look at the files I posted just above your last post. Bruno Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 Here is what I get in Drake: [bruno:~]$ cat /etc/devfs/conf.d/mouse.confREGISTER ^input/mice$ CFUNCTION GLOBAL mksymlink input/mice mouseUNREGISTER ^input/mice$ CFUNCTION GLOBAL unlink mouse[bruno:~]$ cat /etc/makedev.d/mouse.conf# Alternative names for mouse devices. Should these be symlinks?c $CONSOLE 10 0 1 1 logimousec $CONSOLE 10 1 1 1 psmousec $CONSOLE 10 2 1 1 msmousec $CONSOLE 10 3 1 1 atimousec $CONSOLE 10 4 1 1 jmousec $CONSOLE 10 4 1 1 amigamousec $CONSOLE 10 5 1 1 atarimousec $CONSOLE 10 6 1 1 sunmousec $CONSOLE 10 7 1 1 amigamouse1c $CONSOLE 10 8 1 1 smouse#c $CONSOLE 10 9 1 1 pc110padc $CONSOLE 10 10 1 1 adbmouse#c $CONSOLE 10 13 1 1 vpcmouse[bruno:~]$ cat /etc/udev/conf.d/mouse.conf#!/bin/shMOUSECFG=/etc/sysconfig/mouse[ -f "$MOUSECFG" ] || exit 0;. "$MOUSECFG"if [ -n "$device" -a ! -e /dev/mouse ]; then ln -s $device /dev/mousefi[bruno:~]$ cat /etc/sysconfig/mouseMOUSETYPE=ps/2XMOUSETYPE=ExplorerPS/2FULLNAME='"Universal|Any PS/2 & USB mice"'XEMU3=noWHEEL=yesdevice=input/mice Bruno Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 The only one I do not see is mouse.rules.old:hmm:The rest appear to be shell scripts. I do not know what they are doing. Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 The only one I do not see is mouse.rules.old:hmm:The rest appear to be shell scripts. I do not know what they are doing.Have a look on what those files look like in Drake ( again above your post :PWill have a look at mouse.rules.old . . Bruno[bruno:~]$ cat /etc/udev/rules.d/mouse.rules.oldKERNEL="input/mice", SYMLINK="mouse" Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 What if you make a "/etc/udev/rules.d/mouse.rules" with the text I posted above ? Maybe it is an udev issue . . . You can always remove the file if its no goodB) BrunoFORGET IT: PClos has that file already . . . . . . then maybe rename it so it is un-active ? Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 DEVPATH is not setDo you have a /dev/usbmouse ??This is from my PCLos:lrwxrwxrwx 1 root root 10 Jun 15 06:00 /mnt/hdb5/dev/usbmouse -> /dev/input/mice( !! Not to /dev/psaux !! ) Bruno Quote
ross549 Posted October 8, 2005 Author Posted October 8, 2005 My mouse.rules.old does not exist.....Unfortunately, I have guests, and must attend to them... Will take a poke at this tomorrow. Quote
Bruno Posted October 8, 2005 Posted October 8, 2005 Okay . . have fun ! . . . . . keep the "DEVPATH is not set" error in mind ! Bruno Quote
zlim Posted October 9, 2005 Posted October 9, 2005 Sure wish I had read this an hour earlier BEFORE I decided to update.I typed X at the login and got a listing of problems the last being Fatal server error: no screens foundI don't think I'll get a display.errors: 1. Unable to open /usr/X11R6/lib/modules/extensions/libglx.a2. Failed to load module "/usr/X11R6/lib/modules/extensions/libglx.a" (open failed,2) dlopen:/usr/X11R6/lib/modules/drivers/r128_drv.so: undefined symbol: gR128EntityIndex3. Failed to load /usr/X11R6/lib/modules/drivers/r128_drv.so4. Failed to load module "128" (loader failed,7)5. No devices detectedPlease also check the log file at "var/log/Xorg.0.log" for additional information. I don't know if that is on my computer or on the internet.It makes no sense to me other than the update broke some stuff. I only posted it so you can see what happened. Quote
ross549 Posted October 9, 2005 Author Posted October 9, 2005 Liz,You need to run XFdrake in the command line interface, and you should have a restoral of your X. See the post stickied at the top of ATL. Quote
zlim Posted October 9, 2005 Posted October 9, 2005 Adam, I just ran the live CD and installed it again.I will look at XFDrake so the next time it happens, I won't have to reinstall. Thanks. Quote
roger2002 Posted October 9, 2005 Posted October 9, 2005 I'm glad that I'm not alone in this adventure today! I had updated the kernel to 2.6.12 oci4 before I did the updates and it slammed me good. Couldn't boot cause the /dev/root file system was not ext 2? So I did a re-install after grumbling and wishing that I wasn't trying to convince my son-in-law that Linux was the way to go today as he was watching! Then foolishly did the updates without the latest kernel and there I was back at the beginning with no mouse this time. I'm on istall #3 today and trying to get all my email out of the old thunderbird acct. I hope I can still convince him that Linux is better by recovering everything that I need to! Quote
Bruno Posted October 9, 2005 Posted October 9, 2005 Hi Roger and AdamAny chance you can boot from the old kernel ?? ( it should still be there in /boot so you should be able to ) Bruno Quote
ross549 Posted October 9, 2005 Author Posted October 9, 2005 lrwxrwxrwx 1 root root 10 Jun 15 06:00 /mnt/hdb5/dev/usbmouse -> input/mice Mine looks like the above.... the link is slightly different. I don't think that it makes a difference, though.Tried the older kernel..... no luck there. Quote
ross549 Posted October 9, 2005 Author Posted October 9, 2005 Problem Solved!! mousedev/hid is already built into our kernels and not as a module though itif was then mousedrake would try to load it.Do you have usbmouse in /etc/modprobe.preload or /etc/modprobe.config? If soremove it or add blacklist usbmouse in modprobe.conf and see what happens.You can always back it out with nano.I think we ran into this problem with the livecd at one point because it wasloading the usbmouse and screwing up things.TexAdding "blacklist usbmouse" to /etc/modprobe.conf did the trick! My mouse lives! :DAdam Quote
