D K G Posted September 2, 2005 Share Posted September 2, 2005 I have the XP recycle bin set to configure drives separately. Drive G is my external hard drive, used only for backups. I check the configuration on it every time I start the computer and if it's a restart or shutdown or I turned off the harddrive and didn't turn it on until after startup, it is ALWAYS reset to the default settings. If it's a hibernate startup with the drive on, or I turned the drive off and then on before the startup, the recycle bin may or may not be reset to the default. I can live with all of this, but the real kicker is that after I reset it the way I want, sometimes it resets itself to the default settings! As a minor aside, the Apply button doesn't work as it should: it actually resets things to the default. To get the settings I want, I have to simply click the OK button.Any suggestions? Quote Link to comment Share on other sites More sharing options...
fastway Posted September 3, 2005 Share Posted September 3, 2005 Do you have admin rights??? Quote Link to comment Share on other sites More sharing options...
D K G Posted September 4, 2005 Author Share Posted September 4, 2005 Do you have admin rights???<{POST_SNAPBACK}> Yes. Quote Link to comment Share on other sites More sharing options...
patio Posted September 5, 2005 Share Posted September 5, 2005 Any Norton products installed ? ?patio. Quote Link to comment Share on other sites More sharing options...
D K G Posted September 5, 2005 Author Share Posted September 5, 2005 Any Norton products installed ? ?patio. <{POST_SNAPBACK}> Norton SystemWorks: Norton Utilities--Disk Doctor, WinDoctor, Speed Disk only Norton CleanSweep--NOT set to run automaticallyWinFax Pro 10--all the autostart things permanently disabled via M. Lin's "Startup Control Panel" and Administrative Tools--Services.I had Norton AntiVirus 2005, but uninstalled it when I bought ZoneAlarm Security Suite. Quote Link to comment Share on other sites More sharing options...
patio Posted September 7, 2005 Share Posted September 7, 2005 You will have to set those parameters in System Works for the behaviour of the Recycle Bin...I walked away from all Norton products about 3 years ago so i can't give more details. Someone will be along shortly.patio. Quote Link to comment Share on other sites More sharing options...
