Microsoft Cummulative Update for Windows 10 Version 1809
No replies to this topic
#1 OFFLINE   Corrine
Corrine
    The Mystical Rose
  • 4,416 posts
Posted 18 June 2019 - 06:07 PM
Microsoft has released a cumulative update with non-security improvements and fixes for Windows 10 Version 1809. The update includes a large number of quality improvements. There are also several "known issues" in the update, with the one most helpful to know before updating as follows:
Symptom:
We are investigating reports that a small number of devices may startup to a black screen during the first logon after installing updates.
Workaround:
To mitigate this issue, press Ctrl+Alt+Delete, then select the Power button in the lower right corner of the screen and select Restart. Your device should now restart normally.
We are working on a resolution and will provide an update in an upcoming release.
To view the improvements and features and review the other known issues, see the following: 4501371 (OS Build 17763.592)
To download and install this update, go to Settings > Update and Security > Windows Update and select Check for updates.
If you are using Windows Update, the latest SSU (KB4504369) will be offered to you automatically. However, to get the standalone package for the SSU update, go to the Microsoft Update Catalog website.
