havnblast Posted June 28, 2004 Share Posted June 28, 2004 root@wolfbase:/home/wolfbase# apt-get -f installReading Package Lists... DoneBuilding Dependency Tree... DoneCorrecting dependencies... DoneThe following extra packages will be installed: libntfs5The following NEW packages will be installed: libntfs50 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.274 not fully installed or removed.Need to get 0B/57.3kB of archives.After unpacking 156kB of additional disk space will be used.Do you want to continue? [Y/n] Y(Reading database ... 107915 files and directories currently installed.)Unpacking libntfs5 (from .../libntfs5_1.9.0-1_i386.deb) ...dpkg: error processing /var/cache/apt/archives/libntfs5_1.9.0-1_i386.deb (--unpack): trying to overwrite `/usr/lib/libntfs.so.5.0.0', which is also in package ntfsprogsdpkg-deb: subprocess paste killed by signal (Broken pipe)Errors were encountered while processing: /var/cache/apt/archives/libntfs5_1.9.0-1_i386.debE: Sub-process /usr/bin/dpkg returned an error code (1)root@wolfbase:/home/wolfbase# grrrr is there away to clear out apt-get cause now I can't install anything with apt-get without getting that above. I need apt-get to install stuff but over and over it gets hung up there - did that to me during the apt-get dist-upgrade, I really don't want to reinstall either. Quote Link to comment Share on other sites More sharing options...
nlinecomputers Posted June 28, 2004 Share Posted June 28, 2004 Have you tried apt-get check or apt-get clean? Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 root@wolfbase:/home/wolfbase# apt-get cleanroot@wolfbase:/home/wolfbase# apt-get install etermReading Package Lists... DoneBuilding Dependency Tree... Doneeterm is already the newest version.You might want to run `apt-get -f install' to correct these:The following packages have unmet dependencies: testdisk: Depends: libntfs5 (>= 1.9.0) but it is not going to be installedE: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).root@wolfbase:/home/wolfbase# I can't get anything installed cause of that dang libntfs5 dependency Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 Hi KellyIs there no way to install the correct libntfs5 first ? Bruno Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 how Bruno?? I just did apt-get dist-upgrade - shouldn't of that done it - it downloaded and installed a lot of stuff till it hit that point in the upgrade and now I am stuck Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 Just find the libntfs package somewhere and install it . . and see if the Eterm you wanted to install stops complaining about a missing dependencyB) BrunoPS: Not sure why you would need "libntfs" for installing Eterm thoughUPDATE: After reading the thread again: Try apt-get -f install libntfs5 Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 libntfs error thing comes up no matter what I try to install tho - no matter what it just does thatI'll see if I can find the libntfs culprit Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 < export DEBIAN_FRONTEND; apt-get install --yes 'libntfs5';echo RESULT=$?Reading Package Lists... DoneBuilding Dependency Tree... DoneThe following NEW packages will be installed: libntfs50 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.274 not fully installed or removed.Need to get 57.3kB of archives.After unpacking 156kB of additional disk space will be used.Get:1 [URL=http://ftp.de.debian.org]http://ftp.de.debian.org[/URL] testing/main libntfs5 1.9.0-1 [57.3kB]Fetched 57.3kB in 17s (3207B/s)(Reading database ... 107915 files and directories currently installed.)Unpacking libntfs5 (from .../libntfs5_1.9.0-1_i386.deb) ...dpkg: error processing /var/cache/apt/archives/libntfs5_1.9.0-1_i386.deb (--unpack): trying to overwrite `/usr/lib/libntfs.so.5.0.0', which is also in package ntfsprogsdpkg-deb: subprocess paste killed by signal (Broken pipe)Errors were encountered while processing: /var/cache/apt/archives/libntfs5_1.9.0-1_i386.debE: Sub-process /usr/bin/dpkg returned an error code (1)RESULT=100 broken pipe? is that like a 404 error or something - augh I'm screwed aren't I? Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 KellyWhat if you remove: apt-get remove libntfs5 Then remove manualy:/var/cache/apt/archives/libntfs5_1.9.0-1_i386.debThen apt-get -f install libntfs5 ?? Bruno Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 same thing - same errorTried using kpackage and everything to install the package - man I was really hoping I wouldn't have to reinstall since I just got it pretty much setup here to where I want it. Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 Did you remove it first ?? Bruno Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 yup sure did root@wolfbase:/home/wolfbase# apt-get remove libntfs5Reading Package Lists... DoneBuilding Dependency Tree... DonePackage libntfs5 is not installed, so not removedYou might want to run `apt-get -f install' to correct these:The following packages have unmet dependencies: testdisk: Depends: libntfs5 (>= 1.9.0) but it is not going to be installedE: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).root@wolfbase:/home/wolfbase# Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 Package libntfs5 is not installed, so not removedIt is getting weirder every minute ! . . . . What is this package: "testdisk" ?? . . that one failes because libntfs5 is missing . . . What if you do apt-get -f install testdisk ?? Bruno Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 root@wolfbase:/home/wolfbase# apt-get -f install testdiskReading Package Lists... DoneBuilding Dependency Tree... Donetestdisk is already the newest version.You might want to run `apt-get -f install' to correct these:The following packages have unmet dependencies: testdisk: Depends: libntfs5 (>= 1.9.0) but it is not going to be installedE: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).root@wolfbase:/home/wolfbase#I have no idea - says it is already the newest - something with the dist-upgrage - I was in XP and booted to Linux and ran the dist-upgrade first thing and it looked like it was going fine till thisremove testdisk? Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 remove testdisk?Yep why not . . . and run distupgrade again before reinstalling it ( or trying to reinstall it ) Bruno Quote Link to comment Share on other sites More sharing options...
havnblast Posted June 28, 2004 Author Share Posted June 28, 2004 Thanks Brunoremoved the testdisk and the dist-upgrade took right off continuing, yay no reinstall!!made my day! Quote Link to comment Share on other sites More sharing options...
Bruno Posted June 28, 2004 Share Posted June 28, 2004 HURRAY !!!!Wow . . that was a nasty bugger ;) Bruno Quote Link to comment Share on other sites More sharing options...
nlinecomputers Posted June 28, 2004 Share Posted June 28, 2004 Cool that was wierd... Glad you got it fixed. Quote Link to comment Share on other sites More sharing options...
