rpiz Posted February 11, 2004 Share Posted February 11, 2004 I attempted to install 'Open Office Quickstarter' following the directions in the 'tips' dated Nov.11,2003; but it was the most recent version .....oooqs-2.0.3.tar.qz. I then did the ./configure only to receive thefollowing error: [root@localhost oooqs-2.0.3]# ./configurechecking build system type... i686-pc-linux-gnuchecking host system type... i686-pc-linux-gnuchecking target system type... i686-pc-linux-gnuchecking for a BSD-compatible install... /usr/bin/install -cchecking for -p flag to install... yeschecking whether build environment is sane... yeschecking for gawk... gawkchecking whether make sets $(MAKE)... yeschecking for style of include used by make... GNUchecking for gcc... gccchecking for C compiler default output... a.outchecking whether the C compiler works... yeschecking whether we are cross compiling... nochecking for suffix of executables...checking for suffix of object files... ochecking whether we are using the GNU C compiler... yeschecking whether gcc accepts -g... yeschecking for gcc option to accept ANSI C... none neededchecking dependency style of gcc... gcc3checking how to run the C preprocessor... gcc -Echecking for g++... g++checking whether we are using the GNU C++ compiler... yeschecking whether g++ accepts -g... yeschecking dependency style of g++... gcc3checking whether g++ supports -Wmissing-format-attribute... yeschecking whether g++ supports -Wundef... yeschecking whether g++ supports -Wno-long-long... yeschecking whether g++ supports -Wnon-virtual-dtor... yeschecking whether g++ supports -fno-exceptions... yeschecking whether g++ supports -fno-check-new... yeschecking whether g++ supports -fno-common... yeschecking whether g++ supports -fexceptions... yeschecking how to run the C++ preprocessor... g++ -Echecking whether g++ supports -O0... yesnot using lib directory suffixchecking for ld used by GCC... /usr/bin/ldchecking if the linker (/usr/bin/ld) is GNU ld... yeschecking for /usr/bin/ld option to reload object files... -rchecking for BSD-compatible nm... /usr/bin/nm -Bchecking for a sed that does not truncate output...checking whether ln -s works... yeschecking how to recognise dependant libraries... pass_allchecking for egrep... grep -Echecking for ANSI C header files... yeschecking for sys/types.h... yeschecking for sys/stat.h... yeschecking for stdlib.h... yeschecking for string.h... yeschecking for memory.h... yeschecking for strings.h... yeschecking for inttypes.h... yeschecking for stdint.h... yeschecking for unistd.h... yeschecking dlfcn.h usability... yeschecking dlfcn.h presence... yeschecking for dlfcn.h... yeschecking the maximum length of command line arguments... 32768checking command to parse /usr/bin/nm -B output from gcc object... okchecking for objdir... .libschecking for ranlib... ranlibchecking for strip... stripchecking if gcc static flag works... nochecking if gcc supports -fno-rtti -fno-exceptions... nochecking for gcc option to produce PIC... -fPICchecking if gcc PIC flag -fPIC works... yeschecking if gcc supports -c -o file.o... yeschecking whether the gcc linker (/usr/bin/ld) supports shared libraries... yeschecking whether -lc should be explicitly linked in... nochecking how to hardcode library paths into programs... immediatechecking whether stripping libraries is possible... yeschecking dynamic linker characteristics... GNU/Linux ld.sochecking if libtool supports shared libraries... yeschecking whether to build shared libraries... yeschecking whether to build static libraries... noconfigure: creating libtoolappending configuration tag "CXX" to libtoolchecking whether the g++ linker (/usr/bin/ld) supports shared libraries... yeschecking for g++ option to produce PIC... -fPICchecking if g++ PIC flag -fPIC works... yeschecking if g++ supports -c -o file.o... yeschecking whether the g++ linker (/usr/bin/ld) supports shared libraries... yeschecking whether -lc should be explicitly linked in... yeschecking how to hardcode library paths into programs... immediatechecking whether stripping libraries is possible... yeschecking dynamic linker characteristics... GNU/Linux ld.soappending configuration tag "GCJ" to libtoolchecking if gcj supports -fno-rtti -fno-exceptions... (cached) nochecking for gcj option to produce PIC... -fPICchecking if gcj PIC flag -fPIC works... nochecking if gcj supports -c -o file.o... nochecking whether the gcj linker (/usr/bin/ld) supports shared libraries... yeschecking whether -lc should be explicitly linked in... yeschecking how to hardcode library paths into programs... immediatechecking whether stripping libraries is possible... yeschecking dynamic linker characteristics... GNU/Linux ld.sochecking for msgfmt... msgfmtchecking for gmsgfmt... msgfmtfound msgfmt program is not GNU msgfmt; ignore itchecking for xgettext... :checking for strlcat... nochecking if strlcat needs custom prototype... yes - in libkdefakeschecking for strlcpy... nochecking if strlcpy needs custom prototype... yes - in libkdefakeschecking for main in -lutil... yeschecking for main in -lcompat... nochecking for crypt in -lcrypt... yeschecking for socklen_t... socklen_tchecking for dnet_ntoa in -ldnet... nochecking for dnet_ntoa in -ldnet_stub... nochecking for inet_ntoa... yeschecking for connect... yeschecking for remove... yeschecking for shmat... yeschecking for sys/types.h... (cached) yeschecking for stdint.h... (cached) yeschecking for poll in -lpoll... nochecking CoreAudio/CoreAudio.h usability... nochecking CoreAudio/CoreAudio.h presence... nochecking for CoreAudio/CoreAudio.h... nochecking if res_init needs -lresolv... yeschecking if res_init is available... yeschecking for killpg in -lucb... nochecking for int... yeschecking size of int... 4checking for long... yeschecking size of long... 4checking for char *... yeschecking size of char *... 4checking for dlopen in -ldl... yeschecking for shl_unload in -ldld... nochecking for size_t... yeschecking size of size_t... 4checking for unsigned long... yeschecking size of unsigned long... 4checking sizeof size_t == sizeof unsigned long... yeschecking crt_externs.h usability... nochecking crt_externs.h presence... nochecking for crt_externs.h... nochecking for _NSGetEnviron... nochecking for vsnprintf... yeschecking for snprintf... yeschecking for X... configure: error: Can't find X includes. Please check your installation and add the correct paths!I am not clear on how to resolve this error 'Can' find X includes'. Perhaps someone can show me where I went astray.Tnx Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 11, 2004 Share Posted February 11, 2004 Hi RpizIn what distro are you trying to install this ?? . . And can you give me the result of ( as root ): # echo $PATH Bruno Quote Link to comment Share on other sites More sharing options...
rpiz Posted February 11, 2004 Author Share Posted February 11, 2004 Hi Bruno; I'm sorry for omitting the distro, which is Mandrake 9.2. I guessa was concentrating on the problem and the output from ./configure,forgetting to list the distro. Here is the output you requested: [root@localhost rp]# echo $PATH/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/usr/local/sbinAppreciate your help. Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 11, 2004 Share Posted February 11, 2004 Hi Rpiz My friend, in Mandrake do not use the tarball . . . it is available in urpmi: just configure your sources and the install will be painless . . . :D Bruno Quote Link to comment Share on other sites More sharing options...
rpiz Posted February 11, 2004 Author Share Posted February 11, 2004 My friend; I was just following the Nov. 11, 2003 'Tip' and forgot to even checkMCC for the file. In any event I thank you for the additional help and I hopeto give it a try this evening. Quote Link to comment Share on other sites More sharing options...
Bruno Posted February 11, 2004 Share Posted February 11, 2004 Sorry RpizI really thought I had added a line to that Tip . . . well, apparently I did not . . . . But I did now NOTE: Mandrake users can get it in the MCC if they have all the sources configured Thanks for pointing it out to me . . ;) Bruno Quote Link to comment Share on other sites More sharing options...
