Owyn Posted October 13, 2003 Share Posted October 13, 2003 (edited) The following script was abstracted from another (and at the time of writing, still active) thread.I expect to make changes to this over time, in particular, porting it to work on other distros.Any feedback on using this on other distros would be appreciated.Any changes to this script will be implemented in this post and announced by a new message.Latest update: Rev 1.04 2003-11-25.The initial revision of this script was based on the Mandrake 9.1 Sound Trouble Shooting Tips. This is a way to get all the sound info in one step. The latest revision has been tested on Mandrake 9.2, RedHat 9, Knoppix 3.3, and PCLos. It should also work on most other distributions. Known problems with missing tests on Suse.To implement the script:1)Select all the text in the code block at the end of this message. Copy the text.2)In a console type the command "vi soundchk.sh"3)In vi- Press "I" (without the quotes) to go to insert mode- Select Edit->Paste from the console menu- Press the escape key to leave insert mode- Press "ZZ" to save the new file4)In the console type the command "chmod +x soundchk.sh"5)Just su and then type "./soundchk.sh" to run the script. The results from the check can be selected and copied into a message quote or code block.The script: #!/bin/sh# soundchk.sh# Rev 1.00 2003-10-13 Initial Release - Mandrake 9.1 specific# Rev 1.01 2003-10-13 Added Checking Devices# Added grep steps to restrict output. Really needed for Knoppix.# Add file exists tests to find correct tools# Completed port to Knoppix 3.3. Should also be much better for UNKNOWN.# Rev 1.02 2003-10-14 Added test -x for aumix# Fix bug in lspci greps# Rev 1.03 2003-11-24 Add additional tests from alsa aadebug script# Rev 1.04 2003-11-25 Fix typo in 1.03 lspci grep# Add check for artsd# Add check for using cdromecho "soundchk.sh v1.04 - Running Sound Configuration Checks"echoecho Identifying Systemuname -acat /proc/cpuinfo | grep -i "model name"cat /proc/cpuinfo | grep -i "cpu mhz"cat /proc/meminfo | grep -i memtotalcat /proc/meminfo | grep -i swaptotalechoecho Checking Devicesls -l /dev | egrep -i dsp\|soundechoecho Checking Driverif test -x /usr/bin/lspcidrake ; then lspcidrake -v | egrep -i "(audio|multimedia|host bridge)"else lspci -v | egrep -i "(audio|multimedia|host bridge)"fiechoecho Checking Actual Driver in Use "(/etc/modules.conf)"if test -f /etc/modules.conf; then cat /etc/modules.conf | egrep -i snd\|soundelse echo Test not available on this systemfiif test -d /proc/asound; then echo echo Checking alsa /proc/asound cat /proc/asound/{version,cards,devices,hwdep,pcm}fiif test -d /dev/snd; then echo echo Checking alsa /dev/snd ls --color=none /dev/sndfiechoecho Checking if Module Loaded/sbin/lsmod | egrep -i snd\|sound\|audio\|gameechoecho Checking if services configured to be run on initlevel 3if test -x /sbin/chkconfig; then echo Checking if Sound services configured /sbin/chkconfig --list sound echo echo Checking if Alsa service configured /sbin/chkconfig --list alsaelse echo Test not available on this systemfiechoecho Checking if Sound Volume mutedif test -x /usr/bin/aumix; then aumix -qelse echo Test not available on this systemfiechoecho Checking artsd setupps -A -f | grep -i artsd | grep -v grepechoecho Checking which program uses the sound card or cdromif test -x /sbin/fuser; then /sbin/fuser -v /dev/dsp /sbin/fuser -v /dev/cdromelse /bin/fuser -v /dev/dsp /bin/fuser -v /dev/cdromfiechoecho End of Checks Edited November 25, 2003 by Owyn Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 13, 2003 Share Posted October 13, 2003 Owyn,Is this the last version ? Do you want me to run it on my second computer and in a few diferent disto´s ? Or is it work in progress and is it better to wait ? Bruno Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 13, 2003 Share Posted October 13, 2003 The following script was abstracted from another (and at the time of writing, still active) thread.I expect to make changes to this over time, in particular, porting it to work on other distros.Any feedback on using this on other distros would be appreciated.Good idea, Owyn! Should make it easier helping people using Mandrake this way. On using it with other distros, the 'lspcidrake' is probably specific to Mandrake so that would cause a problem right away.On my SuSE 8.2 system, it had problems on that line (no such command) and I pasted the output from the other areas below. Everything else worked fine. My sound is provided onboard (CrystalClear SoundFusion CS 4624 chipset) and works fine.Checking if services configured to be run on initlevel 3Checking if Sound services configuredsound: unknown serviceChecking if Alsa service configuredalsa: unknown serviceChecking if Sound Volume muted./soundchk.sh: line 37: aumix: command not foundChecking which program uses the sound card./soundchk.sh: line 41: /sbin/fuser: No such file or directoryThe last one is because fuser is /bin/fuser on SuSE 8.2.You definitely should write for the LSB if you decide to port it to other distros. I believe that Red Hat, SuSE, and Mandrake are LSB-certified, so writing for it will save you some work. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 13, 2003 Share Posted October 13, 2003 Getting errors in SuSE, Slackware and RedHat too . . . RedHat: ./soundchk.sh: line 12: lspcidrake: command not founderror reading information on service sound: No such file or directoryerror reading information on service alsa: No such file or directorySuSE:./soundchk.sh: line 12: lspcidrake: command not foundsound: unknown servicealsa: unknown service./soundchk.sh: line 37: aumix: command not found./soundchk.sh: line 41: /sbin/fuser: No such file or directorySkackware:root@drake:/home/bruno# ./soundchk.sh >Sound_Slack91_Main.txt./soundchk.sh: line 12: lspcidrake: command not found./soundchk.sh: line 29: /sbin/chkconfig: No such file or directory./soundchk.sh: line 33: /sbin/chkconfig: No such file or directory./soundchk.sh: line 41: /sbin/fuser: No such file or directory Bruno Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 Definitely a work in progress. Porting it to Knoppix 3.3 right now.Want to make it available as a test tool with Knoppix to find out how it configures cards.Watch the rev notes in the first post for changes and as promised I will also post an announcement of any changes. Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 PS: I think most of the problems you noted have shown up during the Knoppix port.At the moment I am fighting some shell script [expr] problems. Getting close. Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 Help. I give up. What am I doing wrong. echoecho Identifying DistributionDISTRO="UNKNOWN"NODENAME=`uname -n`KERNEL=`uname -r`if test "$NODENAME"="Knoppix"; then DISTRO="KNOPPIX"elif test -x /usr/bin/lspcidrake; then DISTRO="MANDRAKE"fiecho Nodename=[$NODENAME] Kernel=[$KERNEL]echo Distribution is $DISTRO gives me Identifying DistributionNodename=[mdk91] Kernel=[2.4.21-0.13mdk]Distribution is KNOPPIX Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 Worked around the problem by changing the "elif" to an "fi if".Not logically the same and I would like to know what I am doing wrong with the elif construct. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 13, 2003 Share Posted October 13, 2003 Identifying DistributionNodename=[mdk91] Kernel=[2.4.21-0.13mdk]Distribution is KNOPPIX LOL This is fun Owyn ! Knoppix with a mandrake kernel !! :'( we won´t need any sound-propblems after that one, the box will explode . . . LOLB) Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 13, 2003 Share Posted October 13, 2003 I think you should skip that part . .it is making the script extra complicated and it is not really that important to see the name of the distro. The kernel version should be enough.Or let the usere type the distro ( or a number out of a list ) Mandrake = 1RedHat = 2Slackware = 3Debian/Knoppix = 4B) Bruno Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 I am STUBBORN.I really want to be able to use everything that is available. I am doing something really stupid and it will bite my again later.As I said, this echoecho Identifying DistributionDISTRO="UNKNOWN"NODENAME=`uname -n`KERNEL=`uname -r`if test "$NODENAME"="Knoppix"; then DISTRO="KNOPPIX"fiif test -x /usr/bin/lspcidrake; then DISTRO="MANDRAKE"fiecho Nodename=[$NODENAME] Kernel=[$KERNEL]echo Distribution is $DISTRO works on Knoppix and Mandrake, but, it is NOT logically the same construct. You are dealing with a programmer now. Logic is important. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 13, 2003 Share Posted October 13, 2003 Help. I give up. What am I doing wrong.echoecho Identifying DistributionDISTRO="UNKNOWN"NODENAME=`uname -n`KERNEL=`uname -r`if test "$NODENAME"="Knoppix"; then     DISTRO="KNOPPIX"elif test -x /usr/bin/lspcidrake; then     DISTRO="MANDRAKE"fiecho Nodename=[$NODENAME] Kernel=[$KERNEL]echo Distribution is $DISTRO If you have only two conditions, then you'd use just if and else; you'd only use elif if you had a third condition. I had to look this up in the manpage because I've forgotten where all the ;'s go since working in csh programming if list; then list; [ elif list; then list; ] ... [ else list; ] fiThe if list is executed. If its exit status is zero, the then list isexecuted. Otherwise, each elif list is executed in turn, and if itsexit status is zero, the corresponding then list is executed and thecommand completes. Otherwise, the else list is executed, if present.The exit status is the exit status of the last command executed, or zero if no condition tested true.If you're going to do multiple distros, you probably want to use switch, but this is a good start Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 No luck echoecho Identifying DistributionNODENAME=`uname -n`KERNEL=`uname -r`if test "$NODENAME"="Knoppix"; then DISTRO="KNOPPIX"elif test -x /usr/bin/lspcidrake; then DISTRO="MANDRAKE"else DISTRO="UNKNOWN"fiecho Nodename=[$NODENAME] Kernel=[$KERNEL]echo Distribution is $DISTRO still gives me KNOPPIX on Mandrake Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 Rev 1.01 posted. See initial post for details.Tested on Knoppix 3.3 and Mandrake 9.1.Added file exist tests and added/changed greps to control size of output. You do NOT want to look at modules.conf on Knoppix. Should work much better on other systems.PS: I pulled the idchk code out entirely from the script. Was able to get job done with "test -x".PPS: I have not given up on the puzzle of why those code fragments don't work. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 13, 2003 Share Posted October 13, 2003 This seems to work on my system. Try it on yours. I think the problem was in the test condition which needs to be surrounded by brackets. At least that's what I think I did that fixed it. echoecho Identifying DistributionDISTRO="UNKNOWN"NODENAME=`uname -n`KERNEL=`uname -r`if [ "$NODENAME" = "Knoppix" ]; then DISTRO="KNOPPIX";elif test -x /usr/bin/lspcidrake; then DISTRO="MANDRAKE"i;else DISTRO="UNKNOWN";fiecho Nodename=[$NODENAME] Kernel=[$KERNEL]echo Distribution is $DISTRO Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 13, 2003 Author Share Posted October 13, 2003 Nope. Tried [ <expr> ] and [ test <expr> ]. The second one throws an error (unary operator expected).I have started reading some of the scripting gotchas from google. Must be something related to string comparisons.The "if test -x ...." contstructs work perfectly.A previous error was using "eq" instead of "=". Numeric vs string operators.Will post results when I figure it out. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 14, 2003 Share Posted October 14, 2003 Rev 1.01 posted. See initial post for details.Tested on SuSE 8.2:# ./soundchk.shsoundchk.sh - Running Sound Configuration ChecksIdentifying SystemLinux sheridan 2.4.20-4GB #1 Tue May 13 08:07:43 PDT 2003 i686 unknown unknown GNU/LinuxChecking Deviceslrwxrwxrwx 1 root root 5 2003-08-31 20:36 adsp -> adsp0crw------- 1 jay audio 14, 12 2003-03-14 08:07 adsp0crw------- 1 jay audio 14, 28 2003-03-14 08:07 adsp1crw------- 1 jay audio 14, 44 2003-03-14 08:07 adsp2crw------- 1 jay audio 14, 60 2003-03-14 08:07 adsp3lrwxrwxrwx 1 root root 4 2003-08-31 20:36 dsp -> dsp0crw------- 1 jay audio 14, 3 2003-03-14 08:07 dsp0crw------- 1 jay audio 14, 19 2003-03-14 08:07 dsp1crw------- 1 jay audio 14, 35 2003-03-14 08:07 dsp2crw------- 1 jay audio 14, 51 2003-03-14 08:07 dsp3crw-rw---- 1 root root 55, 0 2003-03-14 08:07 dsp56klrwxrwxrwx 1 root root 16 2003-08-31 20:36 snd -> /proc/asound/devlrwxrwxrwx 1 root root 24 2003-08-31 20:36 sndstat -> /proc/asound/oss/sndstatChecking DriverChecking Actual Driver in Use (/etc/modules.conf)# These aliases will be changed by YaST2 sound configurator.# take a look at the files on /usr/src/linux/Documentation/sound.alias sound off# Alsa sound support.# Warning: please don't modify comments over aliases 'snd-card-#'alias char-major-116 snd#alias sound-slot-1 nvaudiooptions snd-cs46xx snd_enable=1 snd_external_amp=0 snd_index=0 snd_mmap_valid=0 snd_thinkpad=0# YaST2: sound system dependent partalias sound-slot-0 snd-card-0alias sound-service-0-0 snd-mixer-ossalias sound-slot-1 offalias sound-service-1-0 offalias sound-slot-2 offalias sound-service-2-0 offalias sound-slot-3 offalias sound-service-3-0 offoptions snd snd_cards_limit=1 snd_major=116# gZD2.kEZ_kK3OAS1:CS 4614/22/24 [CrystalClear SoundFusion Audio Accelerator]alias snd-card-0 snd-cs46xxalias sound-service-0-1 snd-seq-ossalias sound-service-0-3 snd-pcm-ossalias sound-service-0-8 snd-seq-ossalias sound-service-0-11 snd-mixer-ossalias sound-service-0-12 snd-pcm-ossChecking if Module Loadedsnd-pcm-oss 45888 0 (autoclean)snd-mixer-oss 13560 1 (autoclean) [snd-pcm-oss]snd-seq-midi 4448 0 (unused)snd-seq-midi-event 2984 0 [snd-seq-midi]snd-seq 39184 0 [snd-seq-midi snd-seq-midi-event]snd-cs46xx 69864 1gameport 1404 0 [snd-cs46xx]snd-pcm 62912 0 [snd-pcm-oss snd-cs46xx]snd-timer 11904 0 [snd-seq snd-pcm]snd-ac97-codec 31152 0 [snd-cs46xx]snd-rawmidi 13824 0 [snd-seq-midi snd-cs46xx]snd-seq-device 4000 0 [snd-seq-midi snd-seq snd-rawmidi]snd 35940 0 [snd-pcm-oss snd-mixer-oss snd-seq-midi snd-seq-midi-event snd-seq snd-cs46xx snd-pcm snd-timer snd-ac97-codec snd-rawmidi snd-seq-device]soundcore 3396 0 [snd]Checking if services configured to be run on initlevel 3Checking if Sound services configuredsound: unknown serviceChecking if Alsa service configuredalsa: unknown serviceChecking if Sound Volume muted./soundchk.sh: line 49: aumix: command not foundChecking which program uses the sound cardEnd of Checks Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 Tx Jason:I would guess you are using a Turtle Beach Santa Cruz.Looks fairly good except for the errors near the end and the switch in the device.If you can tell me what the correct tests are on Suse I will modify the script accordingly. Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 I made one other minor change to the script to include the rev code in the title.Just in case of future problems with using old scripts. I left the rev code at 1.01. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 14, 2003 Share Posted October 14, 2003 I would guess you are using a Turtle Beach Santa Cruz.If you can tell me what the correct tests are on Suse I will modify the script accordingly.No, what I'm using is onboard CrystalClear SoundFusion CS 4624.As for the second part, I don't really know what the correct tests are under SuSE. Everything was auto-detected for me, and it's been quite a while since I've upgraded (as you can probably tell by my computer specs). Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 LOL. No wonder my Santa Cruz only functions as a basic card. Works just great in WXP but none of the advanced functions are available in Linux. It uses the same driver as you do.No big problem. Still waiting for other things to stabilize before I upgrade (Feb maybe). Lots of time to decide on a new sound card before that.Tx for the help. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 14, 2003 Share Posted October 14, 2003 Nope. Tried [ <expr> ] and [ test <expr> ]. The second one throws an error (unary operator expected).That's interesting. I wonder if it's because Mandrake actually uses the real sh whereas on SuSE, it's only a symbolic link to bash. I actually tested the script as I showed it and it works perfectly on my system - shows up as 'unknown distro'. I even changed the first condition so it would be true and it came up as Knoppix as expected. Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 Interesting. I will try it as bin/bash. But not tonight. I had 4 hours sleep last night and have basically been punching away at computer screens all day.Time to take a break before I do. Nite. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted October 14, 2003 Share Posted October 14, 2003 Interesting. I will try it as bin/bash. But not tonight. I had 4 hours sleep last night and have basically been punching away at computer screens all day.Sleep and computers just don't mix, do they? Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 Rev 1.02 released. Minor bug fixes. Known problems with Suse. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 14, 2003 Share Posted October 14, 2003 Owyn,What OS do you want me to test it on ?? Bruno Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 Owyn,What OS do you want me to test it on ?? BrunoI would like to find out what the differences are for Suse. If you could trace down the equivalent devices/services/programs that would be a big help.Also working on Knoppix issues again. I happened to rerun the tests without Alsa and things are quite different.When I have the script stable for both those cases then it should be worthwhile to give it a retest.It would also be usefull to pre-test it on Mandrake 9.2 RC2 (if you have it available). It would be nice if it was stable before Mandrake 9.2 is generally available. Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 14, 2003 Share Posted October 14, 2003 I will pre test it on RC2 and have a look in SuSE . . ( not very accustomed to SuSE yet, but I´l give it a try ) Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted October 14, 2003 Share Posted October 14, 2003 Owyn,Your script on Mandrake 9.1 and 9.2RC2 ( on two different computers, 9.1 on Athlon, 9.2 on Duron ! ) soundchk.sh v1.02 - Running Sound Configuration ChecksIdentifying SystemLinux drake.lan 2.4.21-0.13mdk #1 Fri Mar 14 15:08:06 EST 2003 i686 unknown unknown GNU/LinuxChecking Deviceslr-xr-xr-x 1 root root 11 Oct 14 19:00 audio -> sound/audiolr-xr-xr-x 1 root root 9 Oct 14 19:00 dsp -> sound/dsplr-xr-xr-x 1 root root 11 Oct 14 19:00 mixer -> sound/mixerlr-xr-xr-x 1 root root 15 Oct 14 19:00 sequencer -> sound/sequencerlr-xr-xr-x 1 root root 16 Oct 14 19:00 sequencer2 -> sound/sequencer2drwxr-xr-x 1 root root 0 Jan 1 1970 soundChecking Driversnd-intel8x0 : Silicon Integrated Systems [siS]|SiS7012 PCI Audio Accelerator [MULTIMEDIA_AUDIO] (vendor:1039 device:7012 subv:1019 subd:0a14)Checking Actual Driver in Use (/etc/modules.conf)above snd-intel8x0 snd-pcm-ossalias sound-slot-0 snd-intel8x0Checking if Module Loadedsnd-seq-oss 31104 0 (unused)snd-seq-midi-event 5640 0 [snd-seq-oss]snd-seq 42608 2 [snd-seq-oss snd-seq-midi-event]snd-pcm-oss 43556 1snd-mixer-oss 14488 0 [snd-pcm-oss]snd-intel8x0 21988 5snd-ac97-codec 40160 0 [snd-intel8x0]snd-pcm 77536 0 [snd-pcm-oss snd-intel8x0]snd-timer 18376 0 [snd-seq snd-pcm]snd-mpu401-uart 4396 0 [snd-intel8x0]snd-rawmidi 17600 0 [snd-mpu401-uart]snd-seq-device 5832 0 [snd-seq-oss snd-seq snd-rawmidi]snd-page-alloc 7732 0 [snd-intel8x0 snd-pcm]snd 40868 4 [snd-seq-oss snd-seq-midi-event snd-seq snd-pcm-oss snd-mixer-oss snd-intel8x0 snd-ac97-codec snd-pcm snd-timer snd-mpu401-uart snd-rawmidi snd-seq-device]soundcore 6276 0 [snd]Checking if services configured to be run on initlevel 3Checking if Sound services configuredsound 0:off 1:off 2:on 3:on 4:on 5:on 6:offChecking if Alsa service configuredalsa 0:off 1:off 2:on 3:on 4:on 5:on 6:offChecking if Sound Volume mutedvol 87, 87, Ppcm 39, 39speaker 73, 73line 61, 61, Pmic 0, 0, Rcd 71, 71, Pigain 0, 0line1 0, 0, Pphin 0, 0, Pvideo 74, 74, PChecking which program uses the sound card USER PID ACCESS COMMAND/dev/dsp bruno 2342 f.... artsdEnd of Checks soundchk.sh v1.02 - Running Sound Configuration ChecksIdentifying SystemLinux dolphin.lan 2.4.22-1mdk #1 Mon Aug 25 11:19:10 EDT 2003 i686 unknown unknown GNU/LinuxChecking Deviceslr-xr-xr-x 1 root root 10 Oct 14 20:12 adsp -> sound/adsplr-xr-xr-x 1 root root 11 Oct 14 20:12 audio -> sound/audiolr-xr-xr-x 1 root root 9 Oct 14 20:12 dsp -> sound/dsplr-xr-xr-x 1 root root 11 Oct 14 20:12 mixer -> sound/mixerdrwxr-xr-x 1 root root 0 Jan 1 1970 soundChecking Driversnd-via82xx : VIA Technologies|VT8233 [AC97 Audio Controller] [MULTIMEDIA_AUDIO] (vendor:1106 device:3059 subv:1106 subd:4161)Checking Actual Driver in Use (/etc/modules.conf)alias sound-slot-0 snd-via82xxabove snd-via82xx snd-pcm-ossChecking if Module Loadedsnd-pcm-oss 43428 0snd-mixer-oss 14232 0 [snd-pcm-oss]snd-via82xx 14816 2snd-pcm 78692 0 [snd-pcm-oss snd-via82xx]snd-timer 18276 0 [snd-pcm]snd-ac97-codec 44824 0 [snd-via82xx]snd-mpu401-uart 4608 0 [snd-via82xx]snd-rawmidi 17664 0 [snd-mpu401-uart]snd-seq-device 5672 0 [snd-rawmidi]snd 40836 2 [snd-pcm-oss snd-mixer-oss snd-via82xx snd-pcm snd-timer snd-ac97-codec snd-mpu401-uart snd-rawmidi snd-seq-device]soundcore 6308 0 [snd]snd-page-alloc 8948 0 [snd-via82xx snd-pcm]Checking if services configured to be run on initlevel 3Checking if Sound services configuredsound 0:off 1:off 2:on 3:on 4:on 5:on 6:offChecking if Alsa service configuredalsa 0:off 1:off 2:off 3:off 4:off 5:off 6:offChecking if Sound Volume mutedvol 84, 84, Ppcm 0, 0speaker 0, 0line 0, 0, Pmic 0, 0, Rcd 100, 100, Pigain 0, 0line1 0, 0, Pphin 0, 0, Pvideo 0, 0, PChecking which program uses the sound cardEnd of ChecksFunny the second one was playing a vivaldi CD . . . and still gives zero at "Checking which program uses the sound card" Bruno Quote Link to comment Share on other sites More sharing options...
Owyn Posted October 14, 2003 Author Share Posted October 14, 2003 Tx Bruno.Noticed a couple of things. Mandrake 9.1Checking Actual Driver in Use (/etc/modules.conf)above snd-intel8x0 snd-pcm-ossalias sound-slot-0 snd-intel8x0The "above" is before the "alias". I still don't really understand modules.conf. Back to RTM.Mandrake 9.2Checking if Alsa service configuredalsa 0:off 1:off 2:off 3:off 4:off 5:off 6:offYou are using alsa but it does not seem to be configured to start at boot.Looks like basic compatability is there. Will do my own tests as soon as Mdk9.2 available from FTP.PS: Strange. When I initially quoted your post I got a lot of html in the quote. Trashed that and created a new reply and copied from the message history. Quote Link to comment Share on other sites More sharing options...
