rolanaj Posted March 13, 2004 Share Posted March 13, 2004 Ok I have found a modem driver for my modem at the same place as before, however there are non current for my kernel version. There is however this one: hcfpcimodem-1.01lnxt04031300full-1.i386.rpm.zip(use on RPM-based systems like Mandrake/RedHat/SuSE with custom or unsupported kernels)Would this be the one to try for PCLos? Or should I be doing something different? Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 13, 2004 Share Posted March 13, 2004 Hi RolanaPCLos is based on Mandrake 9.2 . . . but are you sure the drivers for your modem are not already in ":/lib/modules/2.4.23-2.tmb.2mdk/misc" . . . . ( that is where the win-modem drivers are located )I can not see on the version number of the package "hcfpcimodem-1.01lnxt04031300full-1.i386.rpm.zip" for what version of Mandrake it would fit . . BrunoPS: Did you try to copy over the driver module from Drake to PCLos ? ( and put it in ":/lib/modules/2.4.23-2.tmb.2mdk/misc" ?? ) Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 13, 2004 Author Share Posted March 13, 2004 PS: Did you try to copy over the driver module from Drake to PCLos ? ( and put it in ":/lib/modules/2.4.23-2.tmb.2mdk/misc" ?? )Where do I find this driver module? Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 13, 2004 Share Posted March 13, 2004 In Mandrake you mean ?? . . . should be something like "/lib/modules/2.4.22-10mdk/kernel/drivers/net" . . . or in another directory in "/lib/modules/2.4.22-10mdk/kernel/drivers" . . . hope you know what it should be calledTo compaire this is what I have in "/lib/modules/2.4.22-10mdk/kernel/drivers/net": 3c501.o.gz de600.o.gz imq.o.gz shaper.o.gz3c503.o.gz de620.o.gz irda/ sis900.o.gz3c505.o.gz defxx.o.gz lance.o.gz sk98lin/3c507.o.gz depca.o.gz lne390.o.gz skfp/3c509.o.gz dgrs.o.gz lp486e.o.gz slhc.o.gz3c515.o.gz dl2k.o.gz mii.o.gz slip.o.gz3c59x.o.gz dmfe.o.gz natsemi.o.gz smc9194.o.gz8139cp.o.gz dummy.o.gz natsemi_old.o.gz smc-ultra32.o.gz8139too.o.gz e100/ ne2k-pci.o.gz smc-ultra.o.gz82596.o.gz e1000/ ne3210.o.gz starfire.o.gz8390.o.gz e2100.o.gz ne.o.gz strip.o.gzac3200.o.gz eepro100.o.gz ni5010.o.gz sundance.o.gzacenic.o.gz eepro.o.gz ni52.o.gz sungem.o.gzaironet4500_card.o.gz eexpress.o.gz ni65.o.gz sunhme.o.gzaironet4500_core.o.gz epic100.o.gz ns83820.o.gz tg3.o.gzaironet4500_proc.o.gz eql.o.gz pcmcia/ tlan.o.gzappletalk/ es3210.o.gz pcnet32.o.gz tokenring/arcnet/ eth16i.o.gz plip.o.gz tulip/arlan.o.gz ethertap.o.gz ppp_async.o.gz tun.o.gzarlan-proc.o.gz ewrk3.o.gz ppp_deflate.o.gz typhoon.o.gzat1700.o.gz fc/ ppp_generic.o.gz via-rhine.o.gzatp.o.gz fealnx.o.gz pppoe.o.gz wan/b44.o.gz hamachi.o.gz pppox.o.gz wavelan.o.gzbonding/ hamradio/ ppp_synctty.o.gz wd.o.gzbsd_comp.o.gz hp100.o.gz r8169.o.gz winbond-840.o.gzcs89x0.o.gz hp.o.gz rcpci.o.gz wireless/de4x5.o.gz hp-plus.o.gz sb1000.o.gz yellowfin.o.gz If you have one not listed in my list . . it probably is that one . . . Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 13, 2004 Author Share Posted March 13, 2004 I seem to have several that are not listed in your list so should I copy /lib/modules/2.4.21-0.13mdk/kernel/drivers/net from mandrake9.1 which I am in now or go to the one in Mandrake 9.2 and use that one? Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 13, 2004 Share Posted March 13, 2004 RolanaYou need 9.2 compatible drivers . . . copying the full directory seems a bit much, and you might over-write some you do not want to replace . . . . ( just wish you knew exactly what module you need . . ) . . . but copy the missing ones.However there is no guarantee it will work thoughB) Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 13, 2004 Author Share Posted March 13, 2004 Ok I am going to look in Mandrake 9.2 and see what is there, then I will look in PCLos. Also maybe I just havent set it up right. I went with what was installed and it seems to see my modem but when it initializes it, it seems to stall there. In Mandrake I have to run that hcfpcimodemconfig file and it sets the modem as device SHCFO. Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 13, 2004 Share Posted March 13, 2004 and it seems to see my modem Rolana, that tells me the driver is there already . . . . Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 wow in Mandrake 9.2 I only have a few of them:8021q/ bluetooth/ decnet/ ipv6/ lapb/ rose/appletalk/ bridge/ econet/ ipx/ netlink/ sched/atm/ core/ ipsec/ irda/ netrom/ wanrouter/ax25/ cryptoapi/ ipv4/ khttpd/ packet/ x25/I think that will make it easier. Well that was wrong, I just looked in PCLos and /lib/modules/2.4.23-2tmb.2mdk/kernel/net has all those files as well as one more I tried running wvdial and it cannot find a modem and asks if I have it configured properly with setserial. So it looks like I will have to configure the modem Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 Hi RolanaI think i found something . . can you post us the results of cat /etc/modules.conf from all 3 distro's ( 9.1, 9.2 and PCLos ) ?? Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 Ok for PCLos there is no such file.Mandrake 9.1 probeall scsi_hostadapter ide-scsiprobeall usb-interface usb-uhciabove snd-via82xx snd-pcm-ossalias sound-slot-0 snd-via82xxalias /dev/ttySHCF[0-9]* hcfpciserialalias char-major-240 hcfpciserialalias /dev/cuaHCF[0-9]* hcfpciserialalias char-major-241 hcfpciserialalias /dev/modem hcfpciserialoptions hcfpciserial serialmajor=240 calloutmajor=241 pcivendorid=0x14F1 pcideviceid=0x1036alias /dev/nvidia* nvidiaMandrake 9.2$ cat /etc/modules.confalias sound-slot-0 snd-via82xxprobeall scsi_hostadapter ide-scsiprobeall usb-interface usb-uhciabove snd-via82xx snd-pcm-ossalias /dev/ttySHCF[0-9]* hcfpciserialalias char-major-240 hcfpciserialalias /dev/cuaHCF[0-9]* hcfpciserialalias char-major-241 hcfpciserialalias /dev/modem hcfpciserialoptions hcfpciserial serialmajor=240 calloutmajor=241 pcivendorid=0x14F1 pcideviceid=0x1036So maybe I need to create this file in PCLos Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 Bingo . . Jackpot ! . . . . You know Rolana , I woke up in the middle of the night . . must have been around 4 or 5 . . and I had this brainwave . . . LOL . . . . . . I was afraid that I would not remember the next morning so I posted . . . . . Now you will find a /etc/modules.conf in PCLos too . . . only in PCLos you have to be root to see it: # cat /etc/modules.conf You will see in PCLos it has the "alias /dev/nvidia* nvidia" line already there too . . ;)Now, I want you to add: alias /dev/ttySHCF[0-9]* hcfpciserialalias char-major-240 hcfpciserialalias /dev/cuaHCF[0-9]* hcfpciserialalias char-major-241 hcfpciserialalias /dev/modem hcfpciserialoptions hcfpciserial serialmajor=240 calloutmajor=241 pcivendorid=0x14F1 pcideviceid=0x1036 NOTE: The last line ( options ) is 1 line . . . . . . all other lines have ( only ) 2 spaces in them, so they are in 3 parts !!This should bring us a lot closer to connecting your modem . . . . . . ( Your modem is a connexant modem and if any winmodem drivers are included in PCLos it surely are the connexant ones ) Bruno Quote Link to comment Share on other sites More sharing options...
teacher Posted March 14, 2004 Share Posted March 14, 2004 Is this not the sign of a hard-core linux geek? Dreaming answers to problems in the middle of the night and getting up to post them???? :DYou have to love such dedication! Julia Quote Link to comment Share on other sites More sharing options...
quint Posted March 14, 2004 Share Posted March 14, 2004 You have to love such dedication! Julia (...zzz...Rolana's modem...zzz...Adam's hdd...zzz...Linus needs help with 2.7...zzz...) Quote Link to comment Share on other sites More sharing options...
teacher Posted March 14, 2004 Share Posted March 14, 2004 Bravo Quint. Once again you do it. I can't imagine the library of images you must have ready at the click of a button. :)Julia Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 you were right Bruno I had to be root. I added the text you wanted I just cut and pasted it in with vi. alias /dev/ttySHCF[0-9]* hcfpciserialalias char-major-240 hcfpciserialalias /dev/cuaHCF[0-9]* hcfpciserialalias char-major-241 hcfpciserialalias /dev/modem hcfpciserialoptions hcfpciserial serialmajor=240 calloutmajor=241 pcivendorid=0x14F1 pcideviceid=0x1036The modem is detected and it gets to initializing modem and just hangs there. Also if I set the device as SHCFO it cant open it, I set it as tty1 or tty2 and it can find it but if I query the modem it brings up an empty screen , I woke up in the middle of the night . . must have been around 4 or 5 . . and I had this brainwave . . . LOL . . . . . . I was afraid that I would not remember the next morning so I posted . . .And I thought I had weird dreams Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 I set it as tty1 or tty2 Those are no good . . . but there is a way to check what "com-port" it uses . . . . Give me a few minutes to search the info . . Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 RolanaDo you know what com port it uses in Windows ? dos devfs old name major minor address COM1 /dev/tts/0 /dev/ttyS0 4, 64; 3F8COM2 /dev/tts/1 /dev/ttyS1 4, 65; 2F8COM3 /dev/tts/2 /dev/ttyS2 4, 66; 3E8COM4 /dev/tts/3 /dev/ttyS3 4, 67; 2E8 Still looking for the other info . . Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 PART 3The command was the "setserial" command . . there was a very easy howto . . can not find it . . But I found this: http://www.tldp.org/HOWTO/Modem-HOWTO-10.html#ss10.1 Bruno Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 PART4Apparently for connexant it has to be ¨/dev/ttySHCF0¨ ( CF Zero ) . . but that is only if the installer made that /dev device . . . . So maybe you will have to use the setserial detection command . . .Or wvdial . . did that not autodectect the com port ? Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 ok I will have to go into windows and check on the com port and I will take a look at the how to thanks Bruno. Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 Or wvdial . . did that not autodectect the com port ? Missed that last time. wvdial says the modem is busy is it in use by something else and asks if it is configured properly with setserial Looks like we might be on to something. Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 Here is the simplified info for setserial: To try to detect the physical hardware use for example :setserial /dev/ttyS2 -v autoconfigIf the resulting message shows a uart type such as 16550A, then you're OK. If instead it shows "unknown" for the uart type, then there is supposedly no serial port at all at that I/O address. Some cheap serial ports don't identify themselves correctly so if you see "unknown" you still might have a serial port there.The full document is here: http://www.tldp.org/HOWTO/Modem-HOWTO.html#toc10 ( very long ) Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 Windows says my modem is on COM3 (took a few minutes to remember how to find that info considering I havent been using windows at all lately )so would this: setserial /dev/ttyS2 -v autoconfigbe thissetserial /dev/ttyS3 -v autoconfig Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 14, 2004 Share Posted March 14, 2004 Nope . . . you could do setserial /dev/ttyS2 -v autoconfig to see if Linux sees the modem . . . ( ttyS2 is com3 )But I think it is should be enoung to do : # rm /dev/modem# ln  -s  /dev/ttyS2  /dev/modem and then set kppp to /dev/modem . . . Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 14, 2004 Author Share Posted March 14, 2004 ok I will give that a shot cross your fingers the next post will be from PCLos Quote Link to comment Share on other sites More sharing options...
teacher Posted March 14, 2004 Share Posted March 14, 2004 Fingers crossed. Waiting for good results!Julia Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 15, 2004 Author Share Posted March 15, 2004 Well no luck yet says kppp cant find the device is it configured properly. setserial /dev/ttyS2 -v autoconfigtold me no such device Quote Link to comment Share on other sites More sharing options...
Bruno Posted March 15, 2004 Share Posted March 15, 2004 Maybe you were right and it should be "setserial /dev/ttyS3 -v autoconfig" ?? . . . Just try all the other options 0 - 3, including "/dev/ttySHCF0" and the "/dev/tts/0 to /dev/tts/3" . . . the modem must be somewhere . . Bruno Quote Link to comment Share on other sites More sharing options...
rolanaj Posted March 15, 2004 Author Share Posted March 15, 2004 [root@localhost rolana]# setserial /dev/ttyS2 -v autoconfig/dev/ttyS2: No such file or directory root@localhost rolana]# setserial /dev/ttyS2 -v autoconfig/dev/ttyS2: No such file or directory[root@localhost rolana]# rm /dev/modemrm: remove symbolic link `/dev/modem'? y[root@localhost rolana]# ln -s /dev/ttyS2 /dev/modem[root@localhost rolana]# cat /dev/modemcat: /dev/modem: No such file or directoryThought I would give you the actual errors I am gettingso you want me to try that setserial /dev/ttyS2 -v autoconfig cahnging the ttyS2 to the other available options and see if that works?Is there a way in Linux to see where the modem is?This commandcat /proc/pcigives me in part this:Bus 0, device 9, function 0: Multimedia video controller: PCI device 14f1:8800 (Conexant) (rev 3). IRQ 10. Master Capable. Latency=32. Min Gnt=20.Max Lat=55. Non-prefetchable 32 bit memory at 0xee000000 [0xeeffffff]. Bus 0, device 11, function 0: Communication controller: Conexant HCF 56k Data/Fax/Voice/Spkp Modem (rev 8). IRQ 9. Master Capable. Latency=32. Non-prefetchable 32 bit memory at 0xef000000 [0xef00ffff]. I/O at 0xec00 [0xec07]. Bus 1, device 0, function 0: VGA compatible controller: nVidia Corporation NV11 [GeForce2 MX/MX 400] (rev 161). IRQ 11. Master Capable. Latency=248. Min Gnt=5.Max Lat=1. Non-prefetchable 32 bit memory at 0xec000000 [0xecffffff]. Prefetchable 32 bit memory at 0xe0000000 [0xe7ffffff].does the IRQ 9 help any? This is sooooo confusing. Quote Link to comment Share on other sites More sharing options...
