ReuvenNY Posted October 13, 2006 Share Posted October 13, 2006 I use Lotus Organizer 6 for my calendaring and contact needs. It’s OK, but is outdated and not really supported by IBM. It does serve my needs in those two areas.The Note and Task part of that program is totally unsuitable for my needs. I looked at MS Outlook 2003 (which I own), as well as many other Personal Information Managers, but find that most are cumbersome, too detailed and just visually no appealing.I am looking for a program that is primarily Task Manager,( not a project manager) with a modern look and feel - simple yet powerful.Does anything like that exist? Where should I look for it?Thanks for any help. Quote Link to comment Share on other sites More sharing options...
epp_b Posted October 13, 2006 Share Posted October 13, 2006 (edited) I don't know if there is any specific empasis on these programs, but here are a few I know of... - Chandler - Palm DesktopPalm Desktop is actually a great little piece of software that you needn't even have a Palm device to go with it. It will work perfectly fine as a stand-alone desktop PIM client. Edited October 13, 2006 by epp_b Quote Link to comment Share on other sites More sharing options...
ReuvenNY Posted October 14, 2006 Author Share Posted October 14, 2006 Using some links and help on this and/or other forums, I found a great little program that exactly addresses my needs. It's called ViaList and can be found here: http://www.vialist.com/Check them out if you need a To Do program that can be also synchronized online with their site. Quote Link to comment Share on other sites More sharing options...
b2cm Posted October 17, 2006 Share Posted October 17, 2006 another lurker, i presume? good golly, a join date prior to mine, too boot!perhaps you should be welcoming me! That just says that you've been hanging around the forum for months before deciding to sign up. Quote Link to comment Share on other sites More sharing options...
ross549 Posted October 18, 2006 Share Posted October 18, 2006 True lurkers don't sign up.... :PNow, Git back on topic! :DAdam Quote Link to comment Share on other sites More sharing options...
b2cm Posted October 18, 2006 Share Posted October 18, 2006 likewise, b2cm, our join dates are pretty close too!Like 347 guys in between. True lurkers don't sign upYeah. And it is a miserable existence----always fighting the itch to sign up so you can react to posts you dislike.Back to topic, I recommend NeoMem: http://www.neomem.org/ Quote Link to comment Share on other sites More sharing options...
