Bruno Posted May 20, 2004 Share Posted May 20, 2004 Just posted in the Tips . . . but want to make sure everybody knows the new procedure in cdrecord:In a nutshell:In Mandrake 10, and probably soon in other distro's with the 2.6 kernel, first do # dmesg | grep CD to see what /dev/hd?? your burner is located . . and then: # cdrecord  dev=/dev/hdc  filename.iso That is all . . . . ( So no more "--scanbus" !! )K3b and other GUI burning tools will already be adapted to the new kernel and cdrecord software.The full story: http://forums.scotsnewsletter.com/index.ph...14&t=503&st=255 Bruno Quote Link to comment Share on other sites More sharing options...
teacher Posted May 20, 2004 Share Posted May 20, 2004 BrunoI see you showed that as root (#) but you can do it as normal user ($) !Julia Quote Link to comment Share on other sites More sharing options...
Dard Posted May 21, 2004 Share Posted May 21, 2004 Thanks for the tip Bruno, if I ever want to burn at the command line this will come in handy. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted May 21, 2004 Share Posted May 21, 2004 K3B did a trumpeting when I finished burning a disc in my new wonderful slick SuSE 9.1 Pro. Quote Link to comment Share on other sites More sharing options...
teacher Posted May 21, 2004 Share Posted May 21, 2004 Yes. It sure takes you by surprise the first time, doesn't it? I think I about jumped out of my seat the first time I heard it.Julia Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 21, 2004 Author Share Posted May 21, 2004 K3B did a trumpeting when I finished burning a disc in my new wonderful slick SuSE 9.1 Pro. Hi JasonDon't tell me you are using K3b . . . where cdrecord is so much faster and easier . . . . in the time the k3b GUI needs to load I have my CD already burned with cdrecord :DB) Bruno Quote Link to comment Share on other sites More sharing options...
teacher Posted May 21, 2004 Share Posted May 21, 2004 BrunoYou obviously have not used the new cdrecord. I tested it this morning burning another PCLos6 disk. It opened up K3B! I was surprised to see that!Julia Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 21, 2004 Author Share Posted May 21, 2004 I know . .if you flip in an blanc CD-RW it automatically opens K3B . . . I hate that and disabled it . . darn autorun . . I, me , myself want to be in control and not The Drake :DB) BrunoPS: to disable autorun selectively: Menu --> System --> Configuration --> Hardware --> CD properties Quote Link to comment Share on other sites More sharing options...
kamicota Posted May 21, 2004 Share Posted May 21, 2004 Love the Auto Run in K3b especially when it comes to ISO's as it makes them bootable without me having to grope around corners to see how-toColin Quote Link to comment Share on other sites More sharing options...
teacher Posted May 21, 2004 Share Posted May 21, 2004 I know . .if you flip in an blanc CD-RW it automatically opens K3B . . . I hate that and disabled it . . darn autorun . . I, me , myself want to be in control and not The Drake :DB) BrunoPS: to disable autorun selectively: Menu --> System --> Configuration --> Hardware --> CD properties Funny, if that is what it is, it did the burning I had set in the command line as I did not touch a thing in K3B!Julia Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 21, 2004 Author Share Posted May 21, 2004 What are you folks raving about K3b ?? . . . . cdrecord on the commandline is much much better and faster ! :DB) Bruno Quote Link to comment Share on other sites More sharing options...
kamicota Posted May 21, 2004 Share Posted May 21, 2004 Maybe we have to update PCLos or the konsole with the cdrecord commands HU?And then see what all the fuss is about Colin Quote Link to comment Share on other sites More sharing options...
teacher Posted May 21, 2004 Share Posted May 21, 2004 I know . .if you flip in an blanc CD-RW it automatically opens K3B . . . I hate that and disabled it .You were right. After going in and clearing that then cdrecord works without k3b!Julia Quote Link to comment Share on other sites More sharing options...
Bruno Posted May 21, 2004 Author Share Posted May 21, 2004 We start an action group: "Ban the Autorun !" . . . . :DB) Bruno Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted May 22, 2004 Share Posted May 22, 2004 Don't tell me you are using K3b . . . where cdrecord is so much faster and easier . . . . in the time the k3b GUI needs to load I have my CD already burned with cdrecord On my system (and you know how slow that is, if not, look at my info), k3b takes a whopping 20 seconds to load. You're burning ISOs in 20 seconds, Bruno? Besides, I'm using 12 speed CD-RWs usually (because I love my planet ) so they take a bit longer to burn anyway. I've grown out of the need to use cdrecord at the command-line just as I don't need to download a new distro every day anymore. Quote Link to comment Share on other sites More sharing options...
linuxdude32 Posted May 22, 2004 Share Posted May 22, 2004 Funny about the autorun stuff, though. Those things usually bug me, too. Everytime I insert an audio CD (to rip), kscd is loaded and it starts playing. Thanks for reminding me to go in and turn that off, though. Some people seem to really like those features, though. I know one guy who used to go on and on about how great Mandrake was because it did all those things automatically as compared with SuSE which didn't (at that time). Now SuSE does, and I'm irritated by it. They should have a popup that asks you the very first time it wants to do that kind of thing if you're the type of user who wants it or not (like a 'Go Away!' button). Quote Link to comment Share on other sites More sharing options...
