amenditman Posted May 8, 2011 Share Posted May 8, 2011 When I attempted to system update today I got this error. [amenditman@bobdesk ~]$ yaourt -SyuPassword: :: Synchronizing package databases... core is up to date extra is up to date community is up to date multilib is up to date archlinuxfr is up to dateerror: failed to prepare transaction (could not satisfy dependencies):: Starting full system upgrade...:: package-query: requires yajl>=2.0 When I checked the repos I see yajl is only on version 1.0.11.3I could remove yaourt and try to get around it, but I'd rather wait and see if there is a better fix.Any suggestions. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 8, 2011 Share Posted May 8, 2011 I'm going to double post this here and at Amenditman's thread about this same topic:I just updated Arch. No tribbles at all. Here's where the differences may lie... I'm running a pure 64 bit installation with NO KDE libs. My WM/DE is Xfce 4.8. I do have some Gnome libs, though.What are you guys running on your Arch installations?++++++Also, Bob... why don't you update using Pacman and see what happens... # pacman -Syu If that works then: $ yaourt -Syua Quote Link to comment Share on other sites More sharing options...
amenditman Posted May 9, 2011 Author Share Posted May 9, 2011 Ha, great minds and all that.I tried to update using pacman, it said it couldn't because it couldn't resolve yaourt dependencies.I can either wait and see or uninstall yaourt. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 9, 2011 Share Posted May 9, 2011 My yaourt got corrupted a while back (cause unknown). I had to uninstall/reinstall to fix it. You may as well go ahead and do that. No sense in waiting. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 11, 2011 Share Posted May 11, 2011 I agree with Eric, try to reinstall Yaourt first and post your results. Quote Link to comment Share on other sites More sharing options...
amenditman Posted May 11, 2011 Author Share Posted May 11, 2011 I did pacman -R yaourt all went as expected.I did pacman -Syu I got the same error about package-query and an unresolvable dependency, namely yajl >=2.0It asked if I would like to ignore that package for the transaction, I answered yes.It then said everything is up to date with no other output. I cannot be up to date, I haven't updated in a month.I cleared the cache with pacman -Scc Resynced my repositories with pacman -Syy That seemed to go right. pacman -Syu Still says there is nothing to do.So, I have uninstalled yaourt, package-queryBut the original problem still exists. yajl >=2.0 is needed for yaourt and the repository only has yajl 1.0.11-3 [installed].Cannot reinstall yaourt because I don't have the required dependencies.When I search for the dependency I get [root@bobdesk amenditman]# pacman -Ss yajlcommunity/lua-yajl-git 20101121-1 Lua interface to yajl.community/yajl 1.0.11-3 [installed] Yet Another JSON Library. Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 11, 2011 Share Posted May 11, 2011 I had the exact same issue as you, Bob. Try removing the offending app... yajl --> http://lloyd.github.com/yajl/ Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 12, 2011 Share Posted May 12, 2011 Rebuild package-query and yaourt from AUR and all will be fixed. There is no need to remove yajl:https://bbs.archlinux.org/viewtopic.php?id=117606https://bbs.archlinux.org/viewtopic.php?pid=925260 Quote Link to comment Share on other sites More sharing options...
V.T. Eric Layton Posted May 12, 2011 Share Posted May 12, 2011 There ya' go! Quote Link to comment Share on other sites More sharing options...
abarbarian Posted May 12, 2011 Share Posted May 12, 2011 [root@myhost ~]# pacman -Syu:: Synchronising package databases... core 37.7K 136.7K/s 00:00:00 [######################] 100% extra 474.3K 145.1K/s 00:00:03 [######################] 100% community 434.8K 126.5K/s 00:00:03 [######################] 100% archlinuxfr 24.7K 128.9K/s 00:00:00 [######################] 100%:: Starting full system upgrade...:: Replace heimdal with core/krb5? [Y/n] yresolving dependencies...looking for inter-conflicts...Remove (1): heimdal-1.3.3-4Total Removed Size: 12.15 MBTargets (22): apr-1.4.4-1 apr-util-1.3.11-1 krb5-1.9.1-1 autofs-5.0.5-6 cifs-utils-4.9-3 dbus-core-1.4.8-1 dbus-1.4.8-1 libcups-1.4.6-2 gtk-update-icon-cache-2.24.4-2 gtk2-2.24.4-2 exo-0.6.1-1 ghostscript-9.02-2 smbclient-3.5.8-3 gnome-vfs-2.24.4-3 gtk3-3.0.9-2 kernel26-2.6.38.6-1 libtirpc-0.2.1-3 lm_sensors-3.3.0-3 neon-0.29.3-3 sbcl-1.0.48-1 subversion-1.6.15-2 syslog-ng-3.2.4-1Total Download Size: 82.95 MBTotal Installed Size: 362.80 MB Thats my update from today. [root@myhost ~]# su user[user@myhost root]$ yaourt -SyuaPassword: :: Synchronising package databases... core is up to date extra is up to date community is up to date archlinuxfr is up to date Foreign packages: / 9 / 9 An thats todays yaourt.Looks like evrything is running good here. Don't know if that helps you folks. Quote Link to comment Share on other sites More sharing options...
amenditman Posted May 17, 2011 Author Share Posted May 17, 2011 I finally got around to re-installing package-query and yaourt today.Everything went fine. Ran yaourt -Syyu and had ~1700MB of downloaded updates to the system.I have a new question raised by this experience.Will the new install of yaourt be aware of the AUR packages I have installed and keep them up to date?I'm thinking yes, but not 100% about that. Quote Link to comment Share on other sites More sharing options...
securitybreach Posted May 17, 2011 Share Posted May 17, 2011 I finally got around to re-installing package-query and yaourt today.Everything went fine. Ran yaourt -Syyu and had ~1700MB of downloaded updates to the system.I have a new question raised by this experience.Will the new install of yaourt be aware of the AUR packages I have installed and keep them up to date?I'm thinking yes, but not 100% about that.Yes, yaourt will work as before since it reads the same package list as before. All of your packages will be upgraded as normal. Quote Link to comment Share on other sites More sharing options...
